Lineage Ii - Agp Deactivated, A Jak Aktywować ?
Haspet
Sprawdź najpierw, czy masz zainstalowane sterowniki do karty graficznej i aktywną akcelerację. Jak nie wiesz, użyj komend:
rpm -q kmod-ati kmod-nvidia
glxinfo
Z tej pierwszej wklej pierwsze 3 linijki, a z drugiej całość.
[Haspet@localhost ~]$ rpm -q kmod-ati kmod-nvidia
pakiet kmod-ati nie jest zainstalowany
kmod-nvidia-1.0.8762-2.2.6.17_1.2157_FC5
i
[Haspet@localhost ~]$ glxinfo
name of display: :0.0
display: :0  screen: 0
direct rendering: Yes
server glx vendor string: NVIDIA Corporation
server glx version string: 1.4
server glx extensions:
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_SGIX_fbconfig,
GLX_SGIX_pbuffer, GLX_SGI_video_sync, GLX_SGI_swap_control
client glx vendor string: NVIDIA Corporation
client glx version string: 1.4
client glx extensions:
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_visual_info,
GLX_EXT_visual_rating, GLX_EXT_import_context, GLX_SGI_video_sync,
GLX_NV_swap_group, GLX_NV_video_out, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
GLX_SGI_swap_control, GLX_NV_float_buffer, GLX_ARB_fbconfig_float
GLX version: 1.3
GLX extensions:
GLX_SGIX_pbuffer, GLX_SGI_video_sync, GLX_SGI_swap_control,
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: GeForce2 MX/AGP/SSE/3DNOW!
OpenGL version string: 1.5.6 NVIDIA 87.62
OpenGL extensions:
GL_ARB_imaging, GL_ARB_multitexture, GL_ARB_pixel_buffer_object,
GL_ARB_point_parameters, GL_ARB_point_sprite, GL_ARB_shader_objects,
GL_ARB_shading_language_100, GL_ARB_texture_compression,
GL_ARB_texture_cube_map, GL_ARB_texture_env_add,
GL_ARB_texture_env_combine, GL_ARB_texture_env_dot3,
GL_ARB_texture_mirrored_repeat, GL_ARB_texture_rectangle,
GL_ARB_transpose_matrix, GL_ARB_vertex_buffer_object,
GL_ARB_vertex_program, GL_ARB_vertex_shader, GL_ARB_window_pos,
GL_S3_s3tc, GL_EXT_texture_env_add, GL_EXT_abgr, GL_EXT_bgra,
GL_EXT_blend_color, GL_EXT_blend_minmax, GL_EXT_blend_subtract,
GL_EXT_clip_volume_hint, GL_EXT_compiled_vertex_array, GL_EXT_Cg_shader,
GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_multi_draw_arrays,
GL_EXT_packed_pixels, GL_EXT_paletted_texture, GL_EXT_pixel_buffer_object,
GL_EXT_point_parameters, GL_EXT_rescale_normal, GL_EXT_secondary_color,
GL_EXT_separate_specular_color, GL_EXT_shared_texture_palette,
GL_EXT_stencil_wrap, GL_EXT_texture_compression_s3tc,
GL_EXT_texture_cube_map, GL_EXT_texture_edge_clamp,
GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3,
GL_EXT_texture_filter_anisotropic, GL_EXT_texture_lod,
GL_EXT_texture_lod_bias, GL_EXT_texture_object, GL_EXT_vertex_array,
GL_IBM_rasterpos_clip, GL_IBM_texture_mirrored_repeat,
GL_KTX_buffer_region, GL_NV_blend_square, GL_NV_fence,
GL_NV_fog_distance, GL_NV_light_max_exponent, GL_NV_packed_depth_stencil,
GL_NV_pixel_data_range, GL_NV_point_sprite, GL_NV_register_combiners,
GL_NV_texgen_reflection, GL_NV_texture_env_combine4,
GL_NV_texture_rectangle, GL_NV_vertex_array_range,
GL_NV_vertex_array_range2, GL_NV_vertex_program, GL_NV_vertex_program1_1,
GL_SGIS_generate_mipmap, GL_SGIS_multitexture, GL_SGIS_texture_lod,
GL_SUN_slice_accum
glu version: 1.3
glu extensions:
GLU_EXT_nurbs_tessellator, GLU_EXT_object_space_tess
  visual  x  bf lv rg d st colorbuffer ax dp st accumbuffer  ms  cav
id dep cl sp sz l  ci b ro  r  g  b  a bf th cl  r  g  b  a ns b eat
0x21 24 tc  0 32  0 r  y  .  8  8  8  0  4 24  8 16 16 16 16  0 0 None
0x22 24 dc  0 32  0 r  y  .  8  8  8  0  4 24  8 16 16 16 16  0 0 None
0x23 24 tc  0 32  0 r  y  .  8  8  8  8  4 24  8 16 16 16 16  0 0 None
0x24 24 tc  0 32  0 r  .  .  8  8  8  0  4 24  8 16 16 16 16  0 0 None
0x25 24 tc  0 32  0 r  .  .  8  8  8  8  4 24  8 16 16 16 16  0 0 None
0x26 24 tc  0 32  0 r  y  .  8  8  8  0  4 24  0 16 16 16 16  0 0 None
0x27 24 tc  0 32  0 r  y  .  8  8  8  8  4 24  0 16 16 16 16  0 0 None
0x28 24 tc  0 32  0 r  .  .  8  8  8  0  4 24  0 16 16 16 16  0 0 None
0x29 24 tc  0 32  0 r  .  .  8  8  8  8  4 24  0 16 16 16 16  0 0 None
0x2a 24 tc  0 32  0 r  y  .  8  8  8  0  4 16  0 16 16 16 16  0 0 None
0x2b 24 tc  0 32  0 r  y  .  8  8  8  8  4 16  0 16 16 16 16  0 0 None
0x2c 24 tc  0 32  0 r  .  .  8  8  8  0  4 16  0 16 16 16 16  0 0 None
0x2d 24 tc  0 32  0 r  .  .  8  8  8  8  4 16  0 16 16 16 16  0 0 None
0x2e 24 tc  0 32  0 r  y  .  8  8  8  0  4  0  0 16 16 16 16  0 0 None
0x2f 24 tc  0 32  0 r  y  .  8  8  8  8  4  0  0 16 16 16 16  0 0 None
0x30 24 tc  0 32  0 r  .  .  8  8  8  0  4  0  0 16 16 16 16  0 0 None
0x31 24 tc  0 32  0 r  .  .  8  8  8  8  4  0  0 16 16 16 16  0 0 None
0x32 24 dc  0 32  0 r  y  .  8  8  8  8  4 24  8 16 16 16 16  0 0 None
0x33 24 dc  0 32  0 r  .  .  8  8  8  0  4 24  8 16 16 16 16  0 0 None
0x34 24 dc  0 32  0 r  .  .  8  8  8  8  4 24  8 16 16 16 16  0 0 None
0x35 24 dc  0 32  0 r  y  .  8  8  8  0  4 24  0 16 16 16 16  0 0 None
0x36 24 dc  0 32  0 r  y  .  8  8  8  8  4 24  0 16 16 16 16  0 0 None
0x37 24 dc  0 32  0 r  .  .  8  8  8  0  4 24  0 16 16 16 16  0 0 None
0x38 24 dc  0 32  0 r  .  .  8  8  8  8  4 24  0 16 16 16 16  0 0 None
0x39 24 dc  0 32  0 r  y  .  8  8  8  0  4 16  0 16 16 16 16  0 0 None
0x3a 24 dc  0 32  0 r  y  .  8  8  8  8  4 16  0 16 16 16 16  0 0 None
0x3b 24 dc  0 32  0 r  .  .  8  8  8  0  4 16  0 16 16 16 16  0 0 None
0x3c 24 dc  0 32  0 r  .  .  8  8  8  8  4 16  0 16 16 16 16  0 0 None
0x3d 24 dc  0 32  0 r  y  .  8  8  8  0  4  0  0 16 16 16 16  0 0 None
0x3e 24 dc  0 32  0 r  y  .  8  8  8  8  4  0  0 16 16 16 16  0 0 None
0x3f 24 dc  0 32  0 r  .  .  8  8  8  0  4  0  0 16 16 16 16  0 0 None
0x40 24 dc  0 32  0 r  .  .  8  8  8  8  4  0  0 16 16 16 16  0 0 None
P.S Przecież robiłem wszystko wg. tego http://faq.fedora.pl/#nvidia
Edytowane przez lszk
No i w porzadku ;)
Masz dwa kernele i odpowiednie 2 kmody.
Sprawdz jeszcze raz czwarta linijke
glxinfo
czy jest "direct rendering: Yes" na najnowszym kernelu, i ponownie pusc instalacje.
Chociaz cos mi sie widzi ze caly problem jest innego typu - chyba gra probuje uzyskac bezposredni dostep do AGP (co oczywiscie jej sie nie uda) lub odczytuje gdzies info o nim i cos sie jej nie podoba... Ale w tym przypadku pomoc Ci moze tylko ktos komu udalo sie ja uruchomic.
Pozdro
  • 2 weeks later...
Cos mi sie wydaje ze z tą grafiką wcale dobrze nie jest.
W grze racer, czasem samochód zanika, a jedna trasa jest cała czerwona.
W Torcs jak wezme ustawie GL na best a nie compatible, samochody zanikaja.
A z Lineage II jak było tak jest :(
Torcs jest linuksowy czy pod Windows ? Jak widać na tym screenie dużo rzeczy emulujesz :) Nawet ePSXe. Naprawdę nie trzeba, jest linuksowa wersja :)
  • 4 months later...
glxinfo
gdzie mam te code wpisać nie umiem aktywować agp
