Błąd Protected Multilib Versions: Libffi-3.0.5-3.2.el6.i686 != Libffi-3.0.9-1.el5.rf.x86_64
Robert412
instaluję ponownie virtualbox u siebie poprzednio miałem błąd przy jego działaniu
Kernel driver not installed (rc=-1908)
The VirtualBox Linux kernel driver (vboxdrv) is either not loaded or there is a permission problem with /dev/vboxdrv. Please reinstall the kernel module by executing
'/etc/init.d/vboxdrv setup'
as root. If it is available in your distribution, you should install the DKMS package first. This package keeps track of Linux kernel changes and recompiles the vboxdrv kernel module if necessary.
Failed to open a session for the virtual machine bazaczeresnia.
The virtual machine 'bazaczeresnia' has terminated unexpectedly during startup with exit code 1 (0x1).
niestety polecenie '/etc/init.d/vboxdrv setup'  generowało kolejne błędy
trochę walczyłem z tym w końcu odinstalowałem virtualbox
i podjąłem próbę jego ponownej instalacji   yum install /home/oracle/Downloads/VirtualBox-4.3-4.3.18_96516_el6-1.i686.rpm
 w trakcie wykonania pojawił się błąd
Error:  Multilib version problems found. This often means that the root
       cause is something else and multilib version checking is just
       pointing out that there is a problem. Eg.:
         1. You have an upgrade for libffi which is missing some
            dependency that another package requires. Yum is trying to
            solve this by installing an older version of libffi of the
            different architecture. If you exclude the bad architecture
            yum will tell you what the root cause is (which package
            requires what). You can try redoing the upgrade with
            --exclude libffi.otherarch ... this should give you an error
            message showing the root cause of the problem.
         2. You have multiple architectures of libffi installed, but
            yum can only see an upgrade for one of those arcitectures.
            If you don't want/need both architectures anymore then you
            can remove the one with the missing update and everything
            will work.
         3. You have duplicate versions of libffi installed already.
            You can use "yum check" to get yum show these errors.
       ...you can also use --setopt=protected_multilib=false to remove
       this checking, however this is almost never the correct thing to
       do as something else is very likely to go wrong (often causing
       much more problems).
       Protected multilib versions: libffi-3.0.5-3.2.el6.i686 != libffi-3.0.9-1.el5.rf.x86_64
jak go usunąć jest zapewne wynikiem prób usunięcia poprzedniego błedu poprzez instalacje dodatkowych pakietów
Podstawowe pytanie jaki masz system? Jeśli Fedorę, to dlaczego pakiet dla RHEL? Jeśli RHEL, to nie ten dział.
Paczki dla Fedory najlepiej jest instalować z repozytorium Oracla. Jak zainstalować repo? → https://www.virtualbox.org/wiki/Linux_Downloads w części "RPM-based Linux distributions"
[EDIT]
Jako root:
wget http://download.virtualbox.org/virtualbox/rpm/fedora/virtualbox.repo  -O /etc/yum.repos.d/vbox.repo
[/EDIT]
Polecenie '/etc/init.d/vboxdrv setup' zrzuca log, o którym zapewne jest mowa w komunikacie błędu. Stawiam, że brakuje Ci kernel-devel odpowiedniego dla uruchomionego jądra i/lub gcc.
Poza zainstalowaniem powyższych pakietów warto też zainstalować dkms - przy aktualizacji jądra moduł przebuduje się przy pierwszym uruchomieniu systemu bez konieczności ręcznego uruchamiania polecenia.
[EDIT]
Jako root:
[/EDIT]
system oparty na redhat gdzie pisać ?
Running rpm_check_debug
Running Transaction Test
Transaction Test Succeeded
Running Transaction
Installing : VirtualBox-4.3-4.3.18_96516_el6-1.x86_64 1/1
Creating group 'vboxusers'. VM users must be member of that group!
No precompiled module for this kernel found -- trying to build one. Messages
emitted during module compilation will be logged to /var/log/vbox-install.log.
Stopping VirtualBox kernel modules [ OK ]
Uninstalling old VirtualBox DKMS kernel modules [ OK ]
Trying to register the VirtualBox kernel modules using DKMSError! echo
Your kernel headers for kernel 3.8.13-44.1.4.el6uek.x86_64 cannot be found at
/lib/modules/3.8.13-44.1.4.el6uek.x86_64/build or /lib/modules/3.8.13-44.1.4.el6uek.x86_64/source.
[FAILED]
(Failed, trying without DKMS)
Recompiling VirtualBox kernel modules [FAILED]
(Look at /var/log/vbox-install.log to find out what went wrong)
Verifying : VirtualBox-4.3-4.3.18_96516_el6-1.x86_64 1/1
Installed:
VirtualBox-4.3.x86_64 0:4.3.18_96516_el6-1
Complete!
przy ponownej instalacji uzyskałem błąd potwierdza to potrzebę wymienionych poprzednio zmian ?
w pliku /var/log/vbox-install.log
Uninstalling modules from DKMS
Attempting to install using DKMS
Creating symlink /var/lib/dkms/vboxhost/4.3.18/source ->
/usr/src/vboxhost-4.3.18
DKMS: add completed.
Failed to install using DKMS, attempting to install without
Makefile:183: *** Error: unable to find the sources of your current Linux kernel. Specify KERN_DIR=<directory> and run Make again. Stop.
Nie pisz postów pod własnymi.
Nie cytuj własnych postów - przecież to bez sensu
Jeśli system RHEL, to przenoszę do działu RHEL :)
P.S. tak jak pisałem wcześniej brakuje ci kernel-devel, przeciez widzisz:
Zresztą jak widzę sokar620 udzielił już wsparcia.
ponownie pojawia się błąd w wirtualnej maszynie
Result Code: NS_ERROR_FAILURE (0x80004005)
Component: Machine
Interface: IMachine {..............}
po komendzie
wynik
Uninstalling old VirtualBox DKMS kernel modulesError! There are no instances of module: vboxhost
4.3.18 located in the DKMS tree.
                                                           [  OK  ]
                                                           [FAILED]
zawartość pliku /var/log/vbox-install.log
  removing old DKMS module vboxhost version  4.3.18
-------- Uninstall Beginning --------
Module:  vboxhost
Version: 4.3.18
Kernel:  2.6.32-504.1.3.el6.x86_64 (x86_64)
Status: Before uninstall, this module version was ACTIVE on this kernel.
Removing any linked weak-modules
vboxdrv.ko:
 - Uninstallation
   - Deleting from: /lib/modules/2.6.32-504.1.3.el6.x86_64/extra/
 - Original module
   - No original module was found for this module on this kernel.
   - Use the dkms install command to reinstall any previous module version.
vboxnetflt.ko:
 - Uninstallation
 - Original module
vboxnetadp.ko:
 - Uninstallation
 - Original module
vboxpci.ko:
 - Uninstallation
 - Original module
depmod......
DKMS: uninstall completed.
Deleting module version: 4.3.18
completely from the DKMS tree.
Done.
Edytowane przez WalDo
Dodanie znaczników
Pokaż wyniki poleceń.
Najlepiej jakbyś wcześniej ponownie spróbował uruchomić setup i w razie niepowodzenia wykonał poniższe w tej samej sesji:
uname -r
rpm -qa  kernel kernel-devel hernel-headers
P.S. Korzystaj ze znaczników [ code ] [/ code ] (wytnij spacje!) do umieszczania wyników wyjścia z konsoli - czytelniejsze.
[EDIT]
Prawie na pewno masz zainstalowane niepasujące do kernela paczki *-devel i *headers
No to jak widzisz: kernel 3.8.13-44.14, brak kernel-headers a kernel-devel oba od jądra 2.6.32. Nie ma prawy działać.
Proponuję najpierw aktualizację jądra, żeby upewnić się, że nie ma nic nowszego niż 3.8.13-44.1.4.
Potem restart na najnowszym jądrze.
Potem instalacja kernel-devel i kernel-headers.
Czyli po kolei:
yum update kernel
restart (tylko o ile coś nowego się zainstaluje) a potem
yum install kernel-devel kernel-headers
Jak coś pójdzie nie tak, to wklej wynik polecenia
yum repolist
Może nie masz zainstalowanych właściwych repozytoriów? Jak instalowałeś kernel-3.8.13-44.1.4.el6uek.x86_64?
[EDIT]
RHEL 6 ma w repozytoriach najwyższe jadro kernel-2.6.32-504.1.3.el6.x86_64.rpm
Czyli kernel-devel są OK. Brakuje kernel-headers i musisz uruchamiać (wcześniej być moze zainstalować?) właściwy kernel-2.6.32-504.1.3.el6.x86_64.rpm
to co tu widać to zapewne efekt dość przypadkowego wpisywania poleceń z różnych forów korzystam z oracle linux 6.5 bo uczę się oracle a na windows mam za wolny komputer
yum repolist
Loaded plugins: protectbase, refresh-packagekit, security
0 packages excluded due to repository protections
repo id repo name status
chromium-el6 CentOS-6Server - Chromium EL6 7
epel Extra Packages for Enterprise Linux 6 - x86_64 11,191
google-chrome google-chrome – 64-bit 3
public_ol6_UEKR3_latest Unbreakable Enterprise Kernel Release 3 for Oracl 252
public_ol6_UEK_latest Latest Unbreakable Enterprise Kernel for Oracle L 365
public_ol6_latest Oracle Linux 6Server Latest (x86_64) 28,743
rpmforge RHEL 6Server - RPMforge.net - dag 11,403
virtualbox Oracle Linux / RHEL / CentOS-6Server / x86_64 - V 19
repolist: 51,983
polecenia wcześniejsze
yum update kernel
Setting up Update Process
No Packages marked for Update
yum install kernel-devel kernel-headersyum install kernel-devel kernel-headers
Setting up Install Process
Package kernel-devel-2.6.32-504.1.3.el6.x86_64 already installed and latest version
No package kernel-headersyum available.
No package install available.
Package kernel-headers-2.6.32-504.1.3.el6.x86_64 is obsoleted by kernel-uek-headers-3.8.13-26.2.4.el6uek.x86_64 which is already installed
Nothing to do
/etc/init.d/vboxdrv setup to polecenie daje błąd identyczny co poprzednio
[EDIT]
Your kernel headers for kernel 3.8.13-44.1.4.el6uek.x86_64 cannot be found at/lib/modules/3.8.13-44.1.4.el6uek.x86_64/build or /lib/modules/3.8.13-44.1.4.el6uek.x86_64/source.
jak te paczki usunąć *-devel i *headers
Prosiłem o dwie rzeczy:
1. nie pisz postów pod własnymi - to jakis problem korzystać z "Edytuj" pod postem?
2. korzystaj ze znaczników "code" - daj znać jeśli masz z tym jakiś problem.
Nie usuwaj paczek devel i headers tylko uruchom system na jądrze kernel-2.6.32-504.1.3.el6.x86_64 albo kernel-2.6.32-504.el6.x86_64 (to pierwsze pewnie aktualne). Po uruchomieniu usuń kernel-3.8.13-44.1.4.el6uek.x86_64, bo to jest źródło wszystkich problemów.
Jeszcze raz pytanie skąd wziąłeś kernel 3.8.13-44.1.4.el6uek.x86_64?
http://www.oracle.com/us/technologies/linux/product/specifications/index.html
oracle linux 6.5 posiada takie kernele
  • 3.8.13 Unbreakable Enterprise Kernel Release 3 (x86_64 only)
  • 2.6.39 Unbreakable Enterprise Kernel Release 2**
  • 2.6.32 (Red Hat compatible kernel)
co się stanie z systemem jak go usunę i z innymi programami z których obecnie korzystam ?
jak to bezpiecznie zrobić ?
aktuanie system startuje bez możliwości wyboru kernela wcześniej było inaczej
co znaczników [ code ] [/ code ] mam obejmować nimi instrukcje linuxa i wyniki poleceń ?
Jeśli Oracle posiada takie jajka na składzie, to powinien również udostępniać repo z paczkami umożliwiającymi kompilację VirtualBox - w końcu to teraz ich produkt ;) Ale informacji na ten temat musisz szukać raczej na ich forum.
Jadra 3.18.13 nie musisz nawet odinstalowywać. Wystarczy, że uruchomisz system na jądrze 2.6.32, do którego devel już masz i brakuje Ci tylko headers.
Co do "code", to dokladnie o to mi chodziło. Oczywiście po usunięci zbędnych spacji z okolic nawiasów kwadratowych ;)
kernel-devel-2.6.32-504.el6.x86_64
 udało się ruszyć na tym kernelu
przy uruchamianiu już konkretnej maszyny pojawił się błąd
This kernel requires the following features not present on the CPU:
Unable to boot - please use kernel appropriate for your CPU
posiadam Intel Core2 Duo E6300 @ 1.86GHz
na studiach otrzymałem dysk vdi z środowiskiem oracle database  11g 64 bit do wykonania zadania
na stronie oracla też są 64 bitowe tylko
pod moim linuxem mam problemy z połączeniem java oracle database  którego nie udało się usunąć pomimo pomocy na forum baz danych
pozostaje mi tylko virtualna maszyna z gotowym środowiskiem bazy bo w tym środowisku ma być wykonane zadanie (linux)
czy trzeba wymieniać komputer czy da się to obejść ?
