Jump to content
MGo
[solved] Irda I Toshiba Satellite Pro 4600 - Jak Uruchomić?
Nie potrafię uruchomić irdy na laptopie. :( W biosie nie ma opcji aktywowania irdy.
[root@k4 etc]# modprobe smsc-ircc2
FATAL: Error inserting smsc_ircc2 (/lib/modules/2.6.25.10-86.fc9.i686/kernel/drivers/net/irda/smsc-ircc2.ko): No such device
[root@k4 etc]# dmesg | tail
found SMC SuperIO Chip (devid=0x5a rev=00 base=0x002e): LPC47N227
smsc_superio_flat(): IrDA not enabled
smsc_superio_flat(): fir: 0x00, sir: 0x00, dma: 15, irq: 0, mode: 0x02
[root@k4 etc]# uname -r
[root@k4 etc]# lspci
00:00.0 Host bridge: Intel Corporation 82815 815 Chipset Host Bridge and Memory Controller Hub (rev 11)
00:01.0 PCI bridge: Intel Corporation 82815 815 Chipset AGP Bridge (rev 11)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev 03)
00:1f.0 ISA bridge: Intel Corporation 82801BAM ISA Bridge (LPC) (rev 03)
00:1f.1 IDE interface: Intel Corporation 82801BAM IDE U100 Controller (rev 03)
00:1f.2 USB Controller: Intel Corporation 82801BA/BAM USB Controller #1 (rev 03)
00:1f.4 USB Controller: Intel Corporation 82801BA/BAM USB Controller #1 (rev 03)
00:1f.5 Multimedia audio controller: Intel Corporation 82801BA/BAM AC'97 Audio Controller (rev 03)
01:00.0 VGA compatible controller: Trident Microsystems CyberBlade/XP (rev 63)
02:08.0 Ethernet controller: Intel Corporation 82801BA/BAM/CA/CAM Ethernet Controller (rev 03)
02:0c.0 CardBus bridge: Texas Instruments PCI1410 PC card Cardbus Controller (rev 01)
[topic="s"]s[/topic][topic="s"]s[/topic]
[root@k4 etc]# lspci -vv
    Control: I/O+ Mem+ BusMaster+ SpecCycle+ MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
    Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
    Latency: 0
    Kernel modules: iTCO_wdt, intel-rng
Znalazłem link http://tuxmobil.org/ir_misc.html, gdzie pisze, że irda w tym modelu działa po aktywowaniu w biosie.
Laptop ma symbol PS460E-02HYX-EN. Nie wiem, czy aktualizacja biosu dodaje opcję aktywacji irdy. A może jest inny sposób?
Share this post
Link to post
Share on other sites
A takie głupie pytanie może... Service "irda" jest uruchomiony?
To robiłem i oczywiście nic to nie daje, bo nie ładuje się moduł obsługujący sprzęt.
Share this post
Link to post
Wracam do starego tematu, bo problem rozwiązałem sam.
Skorzystałem ze strony [Linux-IrDA]Toshiba Satellite Pro 4600 (SMSC LPC47n227), ale musiałem trochę zmienić: IRQ 10 było zajęte - zmieniłem na 5. Poprawiłem #include.
plik setsmc.c po zmianach:
#include <stdio.h>
#include <sys/io.h>
#define BASE 0x2e
int main()
    int i;
ioperm(BASE, 2, 1);
    outb(0x55, BASE);
outb(0x0d, BASE);
    if (inb(BASE+1) == 0x5a)
outb(0x25, BASE);
outb(0xBE, BASE+1);
outb(0x28, BASE);
i = inb(BASE+1);
outb((i & 0xf0) | 0x05, BASE+1);
outb(0x2B, BASE);
outb(0x26, BASE+1);
outb(0x2C, BASE);
outb(0x01, BASE+1);
outb(0x0C, BASE);
i = inb(BASE+1);
outb((i & 0xC7) | 0x08, BASE+1);
outb(0x07, BASE);
i = inb(BASE+1);
outb(i | 0x20, BASE+1);
outb(0x02, BASE);
i = inb(BASE+1);
outb(i | 0x80, BASE+1);
outb(0x00, BASE);
i = inb(BASE + 1);
outb(i | 0x80, BASE + 1);
outb(0xaa, BASE);
plik skompilowałem poleceniem:
gcc -g -O2 -o setsmc setsmc.c
Następnie zmieniłem uprawnienia pliku setsmc, aby był wykonywalny, użytkownik root, grupa root, uprawnienia rwxr-xr-x i skopiowałem plik do katalogu /sbin
w katalogu /sbin stworzyłem plik setirda o uprawnieniach jak wyżej i zawartości:
#!/bin/sh
/sbin/setsmc
/sbin/setpci -s 00:1f.0 e0.b=10:70
/sbin/setpci -s 00:1f.0 e6.w=2:2
/sbin/setpci -s 00:1f.0 90.w=c:c
/sbin/setpci -s 00:1f.0 ec.w=131
W /etc/modprobe.conf dopisałem linię:
install smsc-ircc2 /sbin/setirda; /sbin/modprobe --ignore-install smsc-ircc2
i moduł załadował się (modprobe smsc-ircc2). :)
Polecenie dmesg:
smsc_superio_flat(): fir: 0x130, sir: 0x2f8, dma: 01, irq: 5, mode: 0x0a
SMsC IrDA Controller found
IrCC version 2.0, firport 0x130, sirport 0x2f8 dma=1, irq=5
No transceiver found. Defaulting to Fast pin select
IrDA: Registered device irda0
Plik /etc/sysconfig/irda:
IRDA=yes
DEVICE=/dev/ttyS1
#DONGLE=actisys+
DISCOVERY=yes
i ostatnie polecenie:
chkconfig irda on
potem restart komputera... i wszystko załadowane.
P.S. Gratulacje dla WalDo
Share this post
Link to post
Register a new account
Sign in
