drawdew Napisano Marzec 28, 2005 Zgłoszenie Share Napisano Marzec 28, 2005 Witam Mam problem z konfiguracją Gruba, mam dwa dyski: # fdisk -l Disk /dev/sda: 120.0 GB, 120034123776 bytes 255 heads, 63 sectors/track, 14593 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Device Boot Start End Blocks Id System /dev/sda1 1318 5838 36314901 7 HPFS/NTFS /dev/sda2 5839 14593 70324537+ f W95 Ext'd (LBA) /dev/sda3 * 1 1228 9863878+ 83 Linux /dev/sda4 1229 1317 714892+ 82 Linux swap /dev/sda5 5839 12642 54653098+ 7 HPFS/NTFS /dev/sda6 12643 14593 15671376 b W95 FAT32 Partition table entries are not in disk order Disk /dev/sdb: 120.0 GB, 120034123776 bytes 255 heads, 63 sectors/track, 14593 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Device Boot Start End Blocks Id System /dev/sdb1 * 1 6374 51199123+ 7 HPFS/NTFS /dev/sdb2 6375 14593 66019117+ f W95 Ext'd (LBA) /dev/sdb5 6375 14593 66019086 7 HPFS/NTFS sda1- WindowsXP sda3- Linux sdb1- WindowsXP (drugi) Problem jest taki że spoko mi działa uruchamianie windowsXP i linux a windowsxp(drugi) nie chce się uruchomić. Wyświetla komunikat z dwoma linijkami kodu i nic sie nie dzieje. Może ktoś ma jakiś pomysł? boot/grub.conf # grub.conf generated by anaconda # # Note that you do not have to rerun grub after making changes to this file # NOTICE: You do not have a /boot partition. This means that # all kernel and initrd paths are relative to /, eg. # root (hd0,2) # kernel /boot/vmlinuz-version ro root=/dev/sda3 # initrd /boot/initrd-version.img #boot=/dev/sda default=3 timeout=9 splashimage=(hd0,2)/boot/grub/splash.xpm.gz hiddenmenu title Fedora Core (2.6.10-1.770_FC3smp) root (hd0,2) kernel /boot/vmlinuz-2.6.10-1.770_FC3smp ro root=LABEL=/ rhgb quiet initrd /boot/initrd-2.6.10-1.770_FC3smp.img title Fedora Core (2.6.9-1.667smp) root (hd0,2) kernel /boot/vmlinuz-2.6.9-1.667smp ro root=LABEL=/ rhgb quiet initrd /boot/initrd-2.6.9-1.667smp.img title WindowsXP rootnoverify (hd0,0) chainloader +1 title WindowsXP (drugi) rootnoverify (hd1,0) chainloader +1 Dzięki za info Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
lszk Napisano Marzec 28, 2005 Zgłoszenie Share Napisano Marzec 28, 2005 Nie wiem, czy się nie myle, ale winda musi chyba być podpięta jako master. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Gość _PaT Napisano Marzec 28, 2005 Zgłoszenie Share Napisano Marzec 28, 2005 Piszesz w konsoli info grub, wchodzisz w rozdział 4.2.6 i znajdujesz informację, że jak Windows nie jest na pierwszym to przed bootowaniem pisze się map (hd1) (hd0) albo odwrotnie. Dzięki temu grub emuluje zmianę kolejności dysków i oszukuje Windows. Reasumując: title WindowsXP (drugi) map (hd1) (hd0) rootnoverify (hd1,0) chainloader +1 Oczywiście sprawdź jeszcze odwrotną kolejność w tym mapowaniu gdyby nie działało. Heh, jak możesz to pożycz dysk bo gniotę się na 30GB Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
lszk Napisano Marzec 28, 2005 Zgłoszenie Share Napisano Marzec 28, 2005 Piszesz w konsoli info grub, wchodzisz w rozdział 4.2.6 i znajdujesz informację, że jak Windows nie jest na pierwszym to przed bootowaniem pisze się map (hd1) (hd0) albo odwrotnie. Dzięki temu grub emuluje zmianę kolejności dysków i oszukuje Windows. Oooo dobrze wiedzieć Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
drawdew Napisano Marzec 28, 2005 Autor Zgłoszenie Share Napisano Marzec 28, 2005 Tnx, tego mi było trzeba Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Gość ciupu Napisano Maj 6, 2005 Zgłoszenie Share Napisano Maj 6, 2005 Może mi to ktoś rozjaśnić ?? nic z tego nie kumam . krok po kroku bym prosił : ) pozdrawiam Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Gość _PaT Napisano Maj 6, 2005 Zgłoszenie Share Napisano Maj 6, 2005 Może mi to ktoś rozjaśnić ?? nic z tego nie kumam . krok po kroku bym prosił : ) Ja kumam niewiele więcej.RTFM Zaloguj się jako root i wklej tu swój plik /etc/fstab Wklej to co wyświetli Ci polecenie: sfdisk -l Postaraj się sam rozwiązać problem mając te dane Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
vonProteus Napisano Październik 15, 2006 Zgłoszenie Share Napisano Październik 15, 2006 dzieki tego mi bylo potrzeba Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
elf2003 Napisano Listopad 10, 2006 Zgłoszenie Share Napisano Listopad 10, 2006 mam problem z grub'em mianowicie mam 3 systemy : Windows XP Windows VISTA Fedora Core 6 oto wynik sfdisk -l i fdisk -l Disk /dev/sda: 80.0 GB, 80026361856 bytes 255 heads, 63 sectors/track, 9729 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Device Boot Start End Blocks Id System /dev/sda1 * 1 5970 47952896 7 HPFS/NTFS Partition 1 does not end on cylinder boundary. /dev/sda2 8775 9729 7665808+ c W95 FAT32 (LBA) Partition 2 does not end on cylinder boundary. /dev/sda3 5970 7373 11262976 7 HPFS/NTFS Partition 3 does not end on cylinder boundary. /dev/sda4 7374 8774 11253532+ 5 Extended /dev/sda5 7374 8645 10217308+ 83 Linux /dev/sda6 8646 8774 1036161 82 Linux swap / Solaris Partition table entries are not in disk order Disk /dev/sda: 9729 cylinders, 255 heads, 63 sectors/track Units = cylinders of 8225280 bytes, blocks of 1024 bytes, counting from 0 Device Boot Start End #cyls #blocks Id System /dev/sda1 * 0+ 5969- 5970- 47952896 7 HPFS/NTFS /dev/sda2 8774+ 9728- 955- 7665808+ c W95 FAT32 (LBA) /dev/sda3 5969+ 7372- 1403- 11262976 7 HPFS/NTFS /dev/sda4 7373 8773 1401 11253532+ 5 Extended /dev/sda5 7373+ 8644 1272- 10217308+ 83 Linux /dev/sda6 8645+ 8773 129- 1036161 82 Linux swap / Solaris a oto plik fstab : LABEL=/ / ext3 defaults 1 1 devpts /dev/pts devpts gid=5,mode=620 0 0 tmpfs /dev/shm tmpfs defaults 0 0 proc /proc proc defaults 0 0 sysfs /sys sysfs defaults 0 0 LABEL=SWAP-sda6 swap swap defaults 0 0 a oto grub.conf : # grub.conf generated by anaconda # # Note that you do not have to rerun grub after making changes to this file # NOTICE: You do not have a /boot partition. This means that # all kernel and initrd paths are relative to /, eg. # root (hd0,4) # kernel /boot/vmlinuz-version ro root=/dev/sda5 # initrd /boot/initrd-version.img #boot=/dev/sda default=2 timeout=5 splashimage=(hd0,4)/boot/grub/splash.xpm.gz hiddenmenu title Fedora Core (2.6.18-1.2798.fc6xen) root (hd0,4) kernel /boot/xen.gz-2.6.18-1.2798.fc6 module /boot/vmlinuz-2.6.18-1.2798.fc6xen ro root=LABEL=/ rhgb quiet module /boot/initrd-2.6.18-1.2798.fc6xen.img title Fedora Core (2.6.18-1.2798.fc6) root (hd0,4) kernel /boot/vmlinuz-2.6.18-1.2798.fc6 ro root=LABEL=/ rhgb quiet initrd /boot/initrd-2.6.18-1.2798.fc6.img title XP rootnoverify (hd0,0) chainloader +1 title VISTA rootnoverify (hd0,2) chainloader +1 i teraz problem jest taki : po wybraniu XP odpala sie menu windowsowe z wyborem miedzy XP i VISTA po wybraniu VISTA w grubie linuxowym wywala blad !! powiedzcie jak to zrobic co trzeba pozmniac w gubie i w plikach windowsowych ?? ale prosze opiszcie to dokladnie go niedawno zaczolem zabawe z linuxem wiec nie jestem jeszcze dobrze obeznany w tym systemie Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
mrtomfil Napisano Listopad 11, 2006 Zgłoszenie Share Napisano Listopad 11, 2006 Problem nie leży w (_linuxie_ → Linuksie) ORT tylko w .. Windowsie. Jak zapewne zauważyłeś partycję /dev/sda1 masz ustawioną jako aktywną spwodowało to że Vista domyślnie zainstalowała sobie swój program rozruchowy na tej partycji (nie bez przyczyny w grubie pisze się chainloader ) Innymi słowy nie uruchomisz Visty inaczej jak przez uruchomienie pozycji XP w grubie i dalszy wybór systemu w booloaderze Windowsa. Nie pomoże przegranie plików bo bootloader Windowsa sprawdza położenie partycji aktywnej oraz szuka pliku ntdetec.com w konkretnym sektorze .Po prostu zostaw jak jest Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
elf2003 Napisano Listopad 12, 2006 Zgłoszenie Share Napisano Listopad 12, 2006 Problem nie leży w (_linuxie_ → Linuksie) ORT tylko w .. Windowsie. Jak zapewne zauważyłeś partycję /dev/sda1 masz ustawioną jako aktywną spwodowało to że Vista domyślnie zainstalowała sobie swój program rozruchowy na tej partycji (nie bez przyczyny w grubie pisze się chainloader ) Innymi słowy nie uruchomisz Visty inaczej jak przez uruchomienie pozycji XP w grubie i dalszy wybór systemu w booloaderze Windowsa. Nie pomoże przegranie plików bo bootloader Windowsa sprawdza położenie partycji aktywnej oraz szuka pliku ntdetec.com w konkretnym sektorze .Po prostu zostaw jak jest a odinstalowanie VISTY niepomoże ?? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Przemyslaw Zalewski Napisano Listopad 24, 2006 Zgłoszenie Share Napisano Listopad 24, 2006 Witam... nie chce robic bajzeru na forum wiec pisze tutaj poniewaz problem jest troche podobny... jednoczesnie mam nadzieje, ze znajdzie sie osoba, ktora zechce mnie mimo tego wspomoc.... ...do Fedory wrocilem po prawie 2 latach. Wczesniej korzystalem z Fedory 3, pozniej musialem zrezygnowac z (_linuxa_ → Linuksa) ORT by teraz znowu powrocic. Zainstalowalem sobie Fedora Core 6, w komputerze musze miec rowniez Windows XP. Zaintalowalem jako pierwszy w kolejnosci Windows'a, pozniej Fedore... problem polega na tym, ze po zainstalowaniu Fedory BootMenager widzi co prawda windowsa ale po wybraniu go zlisty pokazuje cos w stylu [...] +1 i nic wiecej sie nie dzieje. System nie wstaje.... Instalacja wyglada tak ze na dysku Master na pierwszej partycji jest zainstalowana Fedora, na dugim dysku Windows XP. Chetnie bym pokazal logi ale po wpisaniu w konsoli: fdisk -l jak to wczesniej bylo proponowane w innych przypadkach mi sie pokazuje: [root@localhost przemo]# disk -l bash: disk: command not found ...co robic? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Przemyslaw Zalewski Napisano Listopad 24, 2006 Zgłoszenie Share Napisano Listopad 24, 2006 To znowu ja... juz wiem jak spradzic te logi Disk /dev/hda: 160.0 GB, 160041885696 bytes 255 heads, 63 sectors/track, 19457 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Device Boot Start End Blocks Id System /dev/hda1 * 1 13 104391 83 Linux /dev/hda2 2551 19456 135797445 f W95 Ext'd (LBA) /dev/hda3 14 2550 20378452+ 8e Linux LVM /dev/hda5 2551 3825 10241406 7 HPFS/NTFS /dev/hda6 3826 7649 30716248+ 7 HPFS/NTFS /dev/hda7 7650 8286 5116671 7 HPFS/NTFS /dev/hda8 8287 9433 9213246 7 HPFS/NTFS /dev/hda9 9434 19456 80509716 7 HPFS/NTFS Partition table entries are not in disk order Disk /dev/hdb: 120.0 GB, 120034123776 bytes 255 heads, 63 sectors/track, 14593 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Device Boot Start End Blocks Id System /dev/hdb1 * 1 14592 117210208+ 7 HPFS/NTFS [root@localhost ~]# Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Gość _PaT Napisano Listopad 24, 2006 Zgłoszenie Share Napisano Listopad 24, 2006 ...co robic? Przeczytaj jeszcze raz uważnie temat i spróbuj zmapować dyski. Napisz jakie kroki po koleji wykonałeś i gdzie utknąłeś. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Margolcia Napisano Listopad 24, 2006 Zgłoszenie Share Napisano Listopad 24, 2006 Zaintalowalem jako pierwszy w kolejnosci Windows'a, pozniej Fedore... problem polega na tym, ze po zainstalowaniu Fedory BootMenager widzi co prawda windowsa ale po wybraniu go zlisty pokazuje cos w stylu [...] +1 i nic wiecej sie nie dzieje. System nie wstaje.... z niecały rok temu tez miałam podobną sytuację..nie wiem czy ten sam błąd (też było coś +1 na końcu u mnie wtedy) bo nie podałeś całego komunikatu, ale też mi Windows nie chciał wstać :/ nie pamiętam dokładnie jaki był wtedy komunikat..ale pamiętam, że przyczyn tego błędu było aż 7 :], bo kumpel mi to wtedy na szybko sprawdził na necie:) ja wtedy poszłam na łatwiznę i postawiłam od nowa Windows..bo już byłam w trakcie robienia tego,jak smsa dostałam:]. ale teraz mi się z tego co kojarzy..jednym ze sposobów naprawy tego było pobawieniem bootloaderem windy [jeśli masz ten sam błąd co ja miałam]. [root@localhost przemo]# disk -l bash: disk: command not found hehe nie ma jak literówki na szczęście zawsze warto 2 raz zerknąć Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
