Dmesg | Grep Avc
jaro33
Mam takie komunikaty od SELinux , nie wiem czy to OK , i czy można coś z tym zrobić
 dmesg | grep avc
audit(1145632138.050:2): avc:  denied  { getattr } for  pid=1961 comm="hald" name="/" dev=hda4 ino=2 scontext=system_u:system_r:hald_t:s0 tcontext=system_u:object_r:file_t:s0 tclass=dir
audit(1145632138.326:3): avc:  denied  { getattr } for  pid=1961 comm="hald" name="/" dev=hda4 ino=2 scontext=system_u:system_r:hald_t:s0 tcontext=system_u:object_r:file_t:s0 tclass=dir
audit(1145632138.410:4): avc:  denied  { getattr } for  pid=1961 comm="hald" name="/" dev=hda4 ino=2 scontext=system_u:system_r:hald_t:s0 tcontext=system_u:object_r:file_t:s0 tclass=dir
audit(1145632138.502:5): avc:  denied  { getattr } for  pid=1961 comm="hald" name="/" dev=hda4 ino=2 scontext=system_u:system_r:hald_t:s0 tcontext=system_u:object_r:file_t:s0 tclass=dir
audit(1145632138.578:6): avc:  denied  { getattr } for  pid=1961 comm="hald" name="/" dev=hda4 ino=2 scontext=system_u:system_r:hald_t:s0 tcontext=system_u:object_r:file_t:s0 tclass=dir
audit(1145632138.634:7): avc:  denied  { getattr } for  pid=1961 comm="hald" name="/" dev=hda4 ino=2 scontext=system_u:system_r:hald_t:s0 tcontext=system_u:object_r:file_t:s0 tclass=dir
audit(1145632138.678:8): avc:  denied  { getattr } for  pid=1961 comm="hald" name="/" dev=hda4 ino=2 scontext=system_u:system_r:hald_t:s0 tcontext=system_u:object_r:file_t:s0 tclass=dir
audit(1145632138.746:9): avc:  denied  { getattr } for  pid=1961 comm="hald" name="/" dev=hda4 ino=2 scontext=system_u:system_r:hald_t:s0 tcontext=system_u:object_r:file_t:s0 tclass=dir
audit(1145632138.870:10): avc:  denied  { mounton } for  pid=2001 comm="mount" name="/" dev=hda6 ino=5 scontext=system_u:system_r:mount_t:s0 tcontext=system_u:object_r:dosfs_t:s0 tclass=dir
audit(1145632144.379:11): avc:  denied  { getattr } for  pid=1961 comm="hald" name="/" dev=hda4 ino=2 scontext=system_u:system_r:hald_t:s0 tcontext=system_u:object_r:file_t:s0 tclass=dir
audit(1145632161.112:12): avc:  denied  { use } for  pid=2225 comm="bluez-pin" name="[7564]" dev=pipefs ino=7564 scontext=user_u:system_r:bluetooth_helper_t:s0 tcontext=system_u:system_r:xdm_t:s0-s0:c0.c255 tclass=fd
audit(1145632161.112:13): avc:  denied  { use } for  pid=2225 comm="bluez-pin" name="[7564]" dev=pipefs ino=7564 scontext=user_u:system_r:bluetooth_helper_t:s0 tcontext=system_u:system_r:xdm_t:s0-s0:c0.c255 tclass=fd
Narka
Ale warto zainteresować się tym HALem. Wywala coś nie tak z hda4. Możesz podać konkretnie co to za partycja(dane z fstab raczej się nie przydadzą, HAL z nich nie kożysta)
fdisk -l
  Device Boot      Start         End      Blocks   Id  System
/dev/hda1   *           1         130     1044193+   b  W95 FAT32
/dev/hda2             131        7702    60822090    f  W95 Ext'd (LBA)
/dev/hda3            7703        7824      979965   82  Linux swap / Solaris
/dev/hda4            7825        9729    15301912+  83  Linux
/dev/hda5             131        2040    15342043+   7  HPFS/NTFS
/dev/hda6            2041        4794    22121473+   7  HPFS/NTFS
/dev/hda7            4795        6707    15366141    b  W95 FAT32
/dev/hda8            6708        7702     7992306   83  Linux
hda4 - uBuntu - buło pierwsze (jako główna partycja za rozszerzoną )
hda8 FC5 później pakowana ( jako logiczna)
/dev/hda3 7703 7824 979965 82 Linux swap / Solaris ( główna)
może za dużo usług wyłączyłem
---- jest tak nieraz że jak odpalam ubuntu , to w pewnym momencie coś długo sprawdza i pod montowuje system plików (czasami może dlatego że RESET twardy był , albo ale myślałem że fat32 czasami wypada) , partycja jest zamontowana pod Fedorą dla przepływu danych
Narka
a ten dysk to IDE czy SATA?
IDE zresztą widać bo z niego pisze
 cat /etc/fstab
LABEL=/1                /                       ext3    defaults        1 1
devpts                  /dev/pts                devpts  gid=5,mode=620  0 0
tmpfs                   /dev/shm                tmpfs   defaults        0 0
proc                    /proc                   proc    defaults        0 0
sysfs                   /sys                    sysfs   defaults        0 0
/dev/hda3               swap                    swap    defaults        0 0
/dev/hda7               /mnt/hda7               vfat    auto,users,umask=0,rw,utf8,quiet        0       0
/dev/hda4               /mnt/ubuntu             ext3    defaults        0       0
/dev/hda6               /mnt/hda6               ntfs    ro,auto,users,umask=000      0 0
