Kylix Problem
mac1us
Próbuję zainstalowac kylixa 3. Po ściągnięciu i rozpakowaniu postępuję tak jak opisano w pliku readme ale niestety wygląda to tak :
[/code]
[root@localhost kylix3_open]# sh setup.sh
BORLAND KYLIX 3
Checking dependencies...
Kernel version >= 2.2.0....OK
Glibc version >= 2.1.2....OK
X11 Server....OK
Libjpeg version >= 6.2.0....OK
Libgtk version >= 1.2.0....OK
----====== Borland Kylix 3 installation program ======----
You are running a x86 machine with glibc-2.1 or later.
Hit Control-C anytime to cancel this installation program.
BORLAND SOFTWARE CORPORATION
LICENSE TERMS
KYLIX 3 OPEN
NOTICE: THIS BORLAND SOFTWARE PRODUCT (TOGETHER WITH ITS
ACCOMPANYING DOCUMENTATION, THE "PRODUCT") IS THE PROPERTY
OF BORLAND SOFTWARE CORPORATION ("BORLAND"). THE PRODUCT
IS MADE AVAILABLE TO YOU, THE ORIGINAL PURCHASER, SUBJECT
TO THE FOLLOWING LICENSE AGREEMENT ("LICENSE"). PLEASE
READ THIS LICENSE CAREFULLY BEFORE INSTALLING OR USING THE
PRODUCT. A COPY OF THIS LICENSE IS AVAILABLE FOR YOUR
FUTURE REFERENCE IN THE "LICENSE.TXT" FILE PROVIDED WITH
THE PRODUCT.
YOU MAY ACCEPT THIS LICENSE BY CLICKING ON THE "I AGREE"
BUTTON BELOW. YOU MAY REJECT THIS LICENSE, AND TERMINATE
THIS INSTALLATION PROCESS, BY CLICKING THE "CANCEL" BUTTON
BELOW. IF YOU DO NOT ACCEPT THIS LICENSE, THEN YOU MAY NOT
INSTALL OR USE THE PRODUCT. IN THAT CASE, YOU MAY, WITHIN
TEN (10) DAYS AFTER YOU FIRST RECEIVED THE PRODUCT, RETURN
IT TO BORLAND OR YOUR BORLAND AUTHORIZED RESELLER, ALONG
WITH ITS ORIGINAL PACKAGING AND PROOF-OF-PURCHASE, FOR A
Do you agree with the license? [Y/n] y
Would you like to read the README file ? [Y/n] n
Please enter the installation path [/usr/local/kylix3]
Please enter the path in which to create the symbolic links [/usr/local/bin]
Install Main Program Files? [Y/n/?] y
Install Help Files? [Y/n/?] y
Do you want to install GNOME/KDE menu items? [Y/n] y
Installing to /usr/local/kylix3
8358 MB available, 171 MB will be installed.
Continue install? [Y/n] y
Installing Main Program Files ...
100% - setup.data/packages/kylix3_main_program_files-1.0-1.i386.rpm
100% - setup.data/packages/kylix3_ide-1.0-1.i386.rpm
100% - /usr/local/kylix3/DEPLOY
100% - /usr/local/kylix3/INSTALL
100% - /usr/local/kylix3/PREINSTALL
100% - /usr/local/kylix3/privacy.txt
100% - /usr/local/kylix3/oe.slip
0% - Running script
Na tym wszystko się kończy - "Running script" wciąż ma 0 %
Ma ktoś jakieś pomysły?
