Samba I Problem Z Dostepem Do Czegokolwiek
marcini
Witam!
Pomozcie mi prosze w konfiuracji Samby, bo kombinuje i juz nie wiem co z tym zrobic.
Ma byc 2 uzytkownikow Samby: pup i gosc. Zalozylem te konta w systemie (useradd) i ustawilem hasla. Potem dodalem userow do Samby. Probowalem juz korzystac z smbpasswd i tdbsam, ale tak i tak nie dziala.
Jak lacze sie z WinXP z \\samba, to prosi o haslo. Podaje uzytkownika pup, haslo i widze udostepnione katalogi (czyli user w smbpasswd jest ok, bo sie moge zalogowac).
Potem jak probuje wejsc w katalog test, to znowu pyta o haslo, ale juz nie udaje mi sie zalogowac do niego.
Probowalem sie polaczyc z localhosta:
[root@localhost ~]# smbclient //localhost/test -U pup
Password:
Domain=[sAMBA] OS=[unix] Server=[samba 3.0.21b-2]
tree connect failed: NT_STATUS_BAD_NETWORK_NAME
Co oznacza ten blad?
Dodam, ze jak robie smbclient -L samba -U pup, to widze liste udostepnionych udzialow.
Wynik polecenia testparm:
[global]
        workgroup = PUP
        netbios name = SAMBA
        server string = Samba Server
        null passwords = Yes
        passdb backend = smbpasswd, tdbsam
        guest account = gosc
        username map = /etc/samba/smbusers
        log file = /var/log/samba/%m.log
        max log size = 50
        socket options = TCP_NODELAY SO_RCVBUF=8192 SO_SNDBUF=8192
        printcap name = /etc/printcap
        preferred master = Yes
        dns proxy = No
        guest ok = Yes
        hosts allow = 192.168.0., 127.
        cups options = raw
[homes]
        comment = Home Directories
        read only = No
        browseable = No
[printers]
        comment = All Printers
        path = /var/spool/samba
        printable = Yes
        browseable = No
[public]
        path = /dane/samba/public
        read only = No
        guest only = Yes
[test]
        path = /dane/samba/test
Zamieszczam tez wynik tail -f /var/log/messages, w czasie gdy probuje sie zalogowac z Windowsa do \\samba\test:
May 15 10:14:09 localhost nmbd[26877]:  Samba name server SAMBA is now a local master browser for workgroup PUP on subnet 192.168.0.201
May 15 10:14:09 localhost nmbd[26877]:  *****
May 15 10:15:35 localhost smbd[26890]: [2006/05/15 10:15:35, 0] smbd/service.c:make_connection_snum(663)
May 15 10:15:35 localhost smbd[26890]:  '/dane/samba/test' does not exist or permission denied when connecting to [test] Error was Permission denied
May 15 10:15:35 localhost kernel: audit(1147680935.115:60): avc:  denied  { search } for  pid=26890 comm="smbd" name="/" dev=sdb1 ino=2 scontext=root:system_r:smbd_t:s0 tcontext=system_u:object_r:file_t:s0 tclass=dir
May 15 10:15:35 localhost kernel: audit(1147680935.207:61): avc:  denied  { search } for  pid=26890 comm="smbd" name="/" dev=sdb1 ino=2 scontext=root:system_r:smbd_t:s0 tcontext=system_u:object_r:file_t:s0 tclass=dir
May 15 10:15:35 localhost kernel: audit(1147680935.875:62): avc:  denied  { search } for  pid=26890 comm="smbd" name="/" dev=sdb1 ino=2 scontext=root:system_r:smbd_t:s0 tcontext=system_u:object_r:file_t:s0 tclass=dir
May 15 10:15:35 localhost kernel: audit(1147680935.899:63): avc:  denied  { search } for  pid=26890 comm="smbd" name="/" dev=sdb1 ino=2 scontext=root:system_r:smbd_t:s0 tcontext=system_u:object_r:file_t:s0 tclass=dir
May 15 10:15:35 localhost kernel: audit(1147680935.903:64): avc:  denied  { search } for  pid=26890 comm="smbd" name="/" dev=sdb1 ino=2 scontext=root:system_r:smbd_t:s0 tcontext=system_u:object_r:file_t:s0 tclass=dir
May 15 10:15:36 localhost smbd[26890]: [2006/05/15 10:15:36, 0] smbd/service.c:make_connection_snum(663)
May 15 10:15:36 localhost smbd[26890]:  '/dane/samba/test' does not exist or permission denied when connecting to [test] Error was Permission denied
May 15 10:15:36 localhost kernel: audit(1147680936.224:65): avc:  denied  { search } for  pid=26890 comm="smbd" name="/" dev=sdb1 ino=2 scontext=root:system_r:smbd_t:s0 tcontext=system_u:object_r:file_t:s0 tclass=dir
May 15 10:15:36 localhost kernel: audit(1147680936.232:66): avc:  denied  { search } for  pid=26890 comm="smbd" name="/" dev=sdb1 ino=2 scontext=root:system_r:smbd_t:s0 tcontext=system_u:object_r:file_t:s0 tclass=dir
May 15 10:15:45 localhost smbd[26890]: [2006/05/15 10:15:45, 0] smbd/service.c:make_connection_snum(663)
May 15 10:15:45 localhost smbd[26890]:  '/dane/samba/test' does not exist or permission denied when connecting to [test] Error was Permission denied
May 15 10:15:45 localhost kernel: audit(1147680945.740:67): avc:  denied  { search } for  pid=26890 comm="smbd" name="/" dev=sdb1 ino=2 scontext=root:system_r:smbd_t:s0 tcontext=system_u:object_r:file_t:s0 tclass=dir
May 15 10:14:09 localhost nmbd[26877]: [2006/05/15 10:14:09, 0] nmbd/nmbd_become_lmb.c:become_local_master_stage2(396)
Przepraszam, jesli post jest za dlugi, ale staralem sie podac jak najwiecej informacji.
Aha, prawa do katalou /dane/samba i podkatalogow mam na 777, wlasciciel pup:users.
Niestety nie pomoglo:
[root@localhost ~]# smbclient //samba/test -U pup
Password:
Prosze o dalsze wskazowki...
EDIT:
Znalazlem przyczyne wszystkich klopotow: SELinux.
Nie wiem jeszcze jak zmodyfikowac jego polityke, tak zeby wszystko dzialalo, a jednoczesnie zeby nie wylaczac ochrony dla calej Samby.
Na razie przelaczylem na Permissive i bede sie staral do tego dojsc. Swoja droga, czy to nie przesada z tym poziomem ochrony, jesli w domyslnej konfiuracji blokuje on mozliwosc udostepnienia czegokolwiek?
