Hadron Napisano Sierpień 11, 2006 Zgłoszenie Share Napisano Sierpień 11, 2006 Nie stety nie moge skompilowac tego programu juz od kilku wersji jego badz fedory zawsze jest problem, tym razem po ./configure dostalem to : Using config source xml:merged:/etc/gconf/gconf.xml.defaults for schema installation Using $(sysconfdir)/gconf/schemas as install directory for schema files checking for update-desktop-database... yes checking for GCP... configure: error: Package requirements (gtk+-2.0 >= 2.8.0 libglade-2.0 >= 2.4.0 libgnomeprintui-2.2 >= 2.6.0 libbonoboui-2.0 >= 2.6.0 libgnomeui-2.0 >= 2.6.0 gnome-vfs-module-2.0 >= 2.6.0 gcu-unstable >= 0.7.1 shared-mime-info >= 0.12 ) were not met: No package 'gcu-unstable' found Consider adjusting the PKG_CONFIG_PATH environment variable if you installed software in a non-standard prefix. Alternatively, you may set the environment variables GCP_CFLAGS and GCP_LIBS to avoid the need to call pkg-config. See the pkg-config man page for more details. ... prosze o wskazowki http://www.nongnu.org/gchempaint/ http://download.savannah.nongnu.org/releases/gchempaint/ gchempaint-0.7.2.tar.gz Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
