Rpm I Duplikat
skywalker
Mam dwie wersje gcc bo chcialem zainstalowac oracla. w ktorym miejscu mam porobic ponizsze wpisy:
This package won't be cleanly updated, unless you leave
only one version. To leave multiple versions installed,
you may remove that warning by setting the following
option in your configuration file:
RPM::Allow-Duplicated { "^msttcorefonts$"; };
To disable these warnings completely set:
RPM::Allow-Duplicated-Warning "false";
pozdrawiam
Skywalker
