marcini Napisano Sierpień 30, 2006 Zgłoszenie Share Napisano Sierpień 30, 2006 Witam! Zaktualizowalem system za pomoca yum update, m.in. Sambe: [root@localhost log]# cat yum.log | grep samba Aug 29 10:15:53 Updated: samba-common.i386 3.0.23a-1.fc5.1 Aug 29 10:18:17 Updated: samba-client.i386 3.0.23a-1.fc5.1 Aug 29 10:21:24 Updated: samba.i386 3.0.23a-1.fc5.1 Po aktualizacji smbd przestal sie uruchamiac. Jak startuje to niby wszystko jest ok: [root@localhost log]# /etc/init.d/smb start Uruchamianie usług SMB: [ OK ] Uruchamianie usług NMB: [ OK ] Ale w /var/log/messages mam to: Aug 30 09:27:45 localhost smbd[2611]: [2006/08/30 09:27:45, 0] passdb/pdb_interface.c:make_pdb_method_name(174) Aug 30 09:27:45 localhost smbd[2611]: No builtin nor plugin backend for smbpasswd, tdbsam found Aug 30 09:27:45 localhost smbd[2611]: [2006/08/30 09:27:45, 0] lib/util.c:smb_panic(1614) Aug 30 09:27:45 localhost smbd[2611]: PANIC (pid 2611): pdb_get_methods_reload: failed to get pdb methods for backend smbpasswd, tdbsam Aug 30 09:27:45 localhost smbd[2611]: Aug 30 09:27:45 localhost smbd[2611]: [2006/08/30 09:27:45, 0] lib/util.c:log_stack_trace(1721) Aug 30 09:27:45 localhost smbd[2611]: BACKTRACE: 7 stack frames: Aug 30 09:27:45 localhost smbd[2611]: #0 smbd(log_stack_trace+0x2d) [0xcbb39d] Aug 30 09:27:45 localhost smbd[2611]: #1 smbd(smb_panic+0x5d) [0xcbb4cd] Aug 30 09:27:45 localhost smbd[2611]: #2 smbd [0xc719e0] Aug 30 09:27:45 localhost smbd[2611]: #3 smbd(initialize_password_db+0xe) [0xc71a2e] Aug 30 09:27:45 localhost smbd[2611]: #4 smbd(main+0x615) [0xd69045] Aug 30 09:27:45 localhost smbd[2611]: #5 /lib/libc.so.6(__libc_start_main+0xdc) [0x295724] Aug 30 09:27:45 localhost smbd[2611]: #6 smbd [0xada651] Aug 30 09:27:45 localhost smbd[2611]: [2006/08/30 09:27:45, 0] lib/fault.c:dump_core(173) Aug 30 09:27:45 localhost smbd[2611]: dumping core in /var/log/samba/cores/smbd Efekt jest taki, ze smbd nie jest uruchomiony: [root@localhost log]# /etc/init.d/smb status smbd jest martwy, ale plik PID istnieje nmbd (pid 2614) jest uruchomiony... Czy to jakis bug? Co moge z tym zrobic? Pomozcie mi to jakos uruchomic. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
marcini Napisano Sierpień 30, 2006 Autor Zgłoszenie Share Napisano Sierpień 30, 2006 Rozwiazalem problem poprzez usuniecie wpisu passdb backend = smbpasswd, tdbsam z smb.conf (i tak uzywam tylko domyslnego smbpasswd). Okazuje sie, ze podawanie kilku baz danych hasel na raz nie jest juz wspierane w tej wersji Samby. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
