Problem Przy Instalacji Ndiswrapper-1.24rc4 - Fc5
darek015
Jestem poczatkujacym urzytkownikiem (_linuxa_ → Linuksa) ORT i mam problem z zainstalowaniem ndiswrapper-1.24rc4.
kernel ver: 2.6.15-1.2054_FC5
Czynnosci ktore wykonalem:
[root@localhost ~]# ln -s /usr/src/2.6.15-1.2054_FC5 /lib/modules/2.6.15-1.2054_FC5/build
ln: tworzenie dowiązania symbolicznego `/lib/modules/2.6.15-1.2054_FC5/build' do `/usr/src/2.6.15-1.2054_FC5': Plik istnieje
[root@localhost ~]# /root/Desktop
-bash: /root/Desktop: is a directory
[root@localhost ~]# cd /root/Desktop
[root@localhost Desktop]# tar zxvf ndiswrapper-1.24rc4.tar.gz
ndiswrapper-1.24rc4/
ndiswrapper-1.24rc4/AUTHORS
ndiswrapper-1.24rc4/ChangeLog
ndiswrapper-1.24rc4/INSTALL
ndiswrapper-1.24rc4/Makefile
ndiswrapper-1.24rc4/README
ndiswrapper-1.24rc4/ndiswrapper.spec
ndiswrapper-1.24rc4/ndiswrapper.8
ndiswrapper-1.24rc4/utils/
ndiswrapper-1.24rc4/utils/Makefile
ndiswrapper-1.24rc4/utils/ndiswrapper
ndiswrapper-1.24rc4/utils/loadndisdriver.c
ndiswrapper-1.24rc4/utils/ndiswrapper-buginfo
ndiswrapper-1.24rc4/driver/
ndiswrapper-1.24rc4/driver/divdi3.c
ndiswrapper-1.24rc4/driver/hal.c
ndiswrapper-1.24rc4/driver/iw_ndis.c
ndiswrapper-1.24rc4/driver/iw_ndis.h
ndiswrapper-1.24rc4/driver/loader.c
ndiswrapper-1.24rc4/driver/loader.h
ndiswrapper-1.24rc4/driver/longlong.h
ndiswrapper-1.24rc4/driver/Makefile
ndiswrapper-1.24rc4/driver/crt.c
ndiswrapper-1.24rc4/driver/ndis.c
ndiswrapper-1.24rc4/driver/ndis.h
ndiswrapper-1.24rc4/driver/ndiswrapper.h
ndiswrapper-1.24rc4/driver/ntoskernel.c
ndiswrapper-1.24rc4/driver/ntoskernel.h
ndiswrapper-1.24rc4/driver/ntoskernel_io.c
ndiswrapper-1.24rc4/driver/pe_linker.c
ndiswrapper-1.24rc4/driver/pe_linker.h
ndiswrapper-1.24rc4/driver/pnp.c
ndiswrapper-1.24rc4/driver/pnp.h
ndiswrapper-1.24rc4/driver/proc.c
ndiswrapper-1.24rc4/driver/rtl.c
ndiswrapper-1.24rc4/driver/usb.c
ndiswrapper-1.24rc4/driver/usb.h
ndiswrapper-1.24rc4/driver/winnt_types.h
ndiswrapper-1.24rc4/driver/workqueue.c
ndiswrapper-1.24rc4/driver/wrapmem.h
ndiswrapper-1.24rc4/driver/wrapmem.c
ndiswrapper-1.24rc4/driver/wrapper.c
ndiswrapper-1.24rc4/driver/wrapndis.h
ndiswrapper-1.24rc4/driver/wrapndis.c
ndiswrapper-1.24rc4/driver/lin2win.h
ndiswrapper-1.24rc4/driver/win2lin_stubs.S
[root@localhost Desktop]# cd /usr/src
[root@localhost src]# cd /usr/src/ndiswrapper-1.24rc4
[root@localhost ndiswrapper-1.24rc4]# make distclean
make -C driver clean
make[1]: Entering directory `/usr/src/ndiswrapper-1.24rc4/driver'
rm -rf ndiswrapper.ko ndiswrapper.o hal.o iw_ndis.o loader.o crt.o ndis.o ntoskernel.o ntoskernel_io.
o pe_linker.o pnp.o proc.o rtl.o wrapmem.o wrapndis.o wrapper.o divdi3.o usb.o win2lin_stubs.o \
  divdi3.o workqueue.o .*.ko.cmd .*.o.cmd \
  ndiswrapper.mod.[oc] *~ .tmp_versions Modules.symvers Module.symvers
make[1]: Leaving directory `/usr/src/ndiswrapper-1.24rc4/driver'
make -C utils clean
make[1]: Entering directory `/usr/src/ndiswrapper-1.24rc4/utils'
rm -f *~ *.o loadndisdriver
make[1]: Leaving directory `/usr/src/ndiswrapper-1.24rc4/utils'
rm -f *~
rm -fr ndiswrapper-1.24rc4 ndiswrapper-1.24rc4.tar.gz patch-stamp
make -C driver distclean
rm -f *_exports.h .\#* win2lin_stubs.h
make -C utils distclean
rm -f .\#*
rm -f .\#*
make -C driver
Can't find kernel build files in /lib/modules/2.6.15-1.2054_FC5/build;
 give the path to kernel build directory with
 KBUILD=<path> argument to make
make[1]: *** [prereq_check] Błąd 1
make: *** [all] Błąd 2
make -C driver
[root@localhost ndiswrapper-1.24rc4]# make install
make -C driver install
make: *** [install] Błąd 2
  • Odpowiedzi 30
  • Created
  • Ostatniej odpowiedzi
Top Posters In This Topic
Upewnij się że posiadasz repozytoria z FAQ
I najpierw zaktualizuj kernel:
yum update kernel
A ndiswrapper i inne rzeczy instaluj lepiej z repo:
yum install kmod-ndiswrapper
jeśli chcesz moduły do kernela kompilować ręcznie, zainstaluj devele :
yum install kernel-devel
yum update kernel
Po wpisaniu komend wyskoczylo...
root@localhost ~]# yum update kernel
Loading "installonlyn" plugin
Setting up Update Process
Setting up repositories
core [1/3]
Cannot find a valid baseurl for repo: core
Error: Cannot find a valid baseurl for repo: core
[root@localhost ~]# yum install kernel-devel
Setting up Install Process
core [1/3]
Przeczytaj jescze raz mojego posta dokładnie ze wskazaniem na linijke:
Pozdr.
###EDIT###
McMonster: Amen B)
###EDIT###
FAQ---> TUTAJ
Niestety nie mam neta pod linuxem i wszystkie czynnosci z FAQ---> TUTAJ musialem robic recznie...
udalo mi sie tylko:
podmienic plik yum.conf --- na sciagniety wczesniej z linka umieszczonego w FAQ`u
sciagnolem takze pliki yum.rmp i livna-release-5.rpm --- po wpisaniu [root@localhost ~]# rpm Uvh yum.rpm
pojawilo sie cos takiego:
RPM wersja 4.4.2
Copyright © 1998-2002 - Red Hat, Inc.
Ten program może być swobodnie rozpowszechniany na warunkach licencji GNU GPL
Składnia: rpm [-aKfgpWHqV] [-aKfgpWHqVcdils] [-aKfgpWHqVcdilsaKfgpWHqV] [-aKfgpWHqVcdilsaKfgpWHqV] [-aKfgpWHqVcdilsaKfgpWHqV] [-aKfgpWHqVcdilsaKfgpWHqVK] [-aKfgpWHqVcdilsaKfgpWHqVK] [-aKfgpWHqVcdilsaKfgpWHqVKi] [-aKfgpWHqVcdilsaKfgpWHqVKiv] [-aKfgpWHqVcdilsaKfgpWHqVKiv] [-aKfgpWHqVcdilsaKfgpWHqVKiv?] [-a|--all] [-f|--file] [-g|--group]
       [-p|--package] [-W|--ftswalk] [--pkgid] [--hdrid] [--fileid]
       [--specfile] [--triggeredby] [--whatrequires] [--whatprovides]
       [--nomanifest] [-c|--configfiles] [-d|--docfiles] [--dump] [-l|--list]
       [--queryformat=QUERYFORMAT] [-s|--state] [--nomd5] [--nofiles]
       [--nodeps] [--noscript] [--comfollow] [--logical] [--nochdir]
       [--nostat] [--physical] [--seedot] [--xdev] [--whiteout]
       [--addsign] [-K|--checksig] [--delsign] [--import] [--resign]
       [--nodigest] [--nosignature] [--initdb] [--rebuilddb] [--aid]
       [--allfiles] [--allmatches] [--badreloc] [-e|--erase <pakiet>+]
       [--excludedocs] [--excludepath=<ścieżka>] [--fileconflicts]
       [--force] [-F|--freshen <plik pakietu>+] [-h|--hash] [--ignorearch]
       [--ignoreos] [--ignoresize] [-i|--install] [--justdb] [--nodeps]
       [--nomd5] [--nocontexts] [--noorder] [--nosuggest] [--noscripts]
       [--notriggers] [--oldpackage] [--percent] [--prefix=<katalog>]
       [--relocate=<stara-ścieżka>=<nowa-ścieżka>] [--repackage]
       [--replacefiles] [--replacepkgs] [--test]
       [-U|--upgrade <plik pakietu>+] [-D|--define 'MAKRO WYR']
       [-E|--eval 'WYR'] [--macros=<PLIK:...>] [--nodigest] [--nosignature]
       [--rcfile=<PLIK:...>] [-r|--root KATALOG] [--querytags] [--showrc]
       [--quiet] [-v|--verbose] [--version] [-?|--help] [--usage]
       [--scripts] [--setperms] [--setugids] [--conflicts] [--obsoletes]
       [--provides] [--requires] [--info] [--changelog] [--xml]
       [--triggers] [--last] [--filesbypkg] [--fileclass] [--filecolor]
       [--filecontext] [--fscontext] [--recontext] [--fileprovide]
       [--filerequire] [--redhatprovides] [--redhatrequires]
       [--buildpolicy=<polisa>] [--with=<opcja>] [--without=<opcja>]
wystarczy przed Uvh wstawić myślnik, przełączniki podaje się zazwyczaj po myślniku, ;)
czyli
rpm -Uvh yum.rpm(czyli nazwa paczki)
P.S. Jeśli niemasz neta na linuksie to poco te wszystkie zabiegi, skoro ten program (mianowicie "yum") służy do instalacji paczek z internetu z tzw. repozytoriów (czyli serwerów)? A więc? :blink:
czyli
Poniewaz potrzebuje zainstalowan ndiswrappera, ktory jest mi potrzebny do zainstalowania sterownikow do mojej sieciowki (Planet WL-8305)...
Po dodaniu myslnika instalacja yum.rmp i livna-release-5.rpm pzrebiegla pez problemow... ale ndiswrapper dalej nie rysza... te same bledy co na poczatku teatu.
Zdaje sie ze ktos zapomnial o jeszcze jednym pakieciku...
Sciagnij i zainstaluj:
kernel-2.6.17-1.2187_FC5.i686.rpm
kmod-ndiswrapper-1.18-2.2.6.17_1.2187_FC5.i686.rpm
ndiswrapper-1.18-1.lvn5.i386.rpm
To powinno wystarczyc.
Pozdro
//===== edit =====
kernel-devel wywal i zapomnij o kompilacji skoro masz gotowe pakiety ;)
rpm -e kernel-devel
No to teraz ściągnij nowszy KERNEL i zainstaluj poleceniem:
rpm -ivh nazwa pakietu
następnie zrób restart i ściągnij ten MODUŁ i zainstaluj poleceniem tym co kernel.
kernel-2.6.17-1.2187_FC5.i686 zainstalowalem bez problemu... po restarcie wstukuje i wpisaniu komendy: rpm -ivh kmod-ndiswrapper-1.18-2.2.6.17_1.2187_FC5.i686.rpm
wyskakuje mi....
[root@localhost Nowy folder]# rpm -ivh kmod-ndiswrapper-1.18-2.2.6.17_1.2187_FC5.i686.rpm
ostrzeżenie: kmod-ndiswrapper-1.18-2.2.6.17_1.2187_FC5.i686.rpm: Nagłówek V3 DSA signature: NOKEY, key ID a109b1ec
ndiswrapper-kmod-common >= 1.18 jest wymagany przez kmod-ndiswrapper-1.18-2.2.6.17_1.2187_FC5.i686
i to samo przy...
root@localhost Nowy folder]# rpm -ivh ndiswrapper-1.18-1.lvn5.i386.rpm
ostrzeżenie: ndiswrapper-1.18-1.lvn5.i386.rpm: Nagłówek V3 DSA signature: NOKEY, key ID a109b1ec
ndiswrapper-kmod >= 1.18 jest wymagany przez ndiswrapper-1.18-1.lvn5.i386
wyskakuje mi....
i to samo przy...
Musisz dociągnąć ten pakiet
