koralm Napisano Wrzesień 24, 2006 Zgłoszenie Share Napisano Wrzesień 24, 2006 tworze sobie klucze ssh-keygen -t dsa -N "" - b 1024 i mam np. pliki dsa i dsa.pub tworze w katalogu uzytkownika /home/user/.ssh/authorized.keys wrzucam tam plik dsa.pub plik dsa uzywam ja do polaczenia. ssh -l user host -i dsa no i teraz pytanko, gdzie i jak dodac command="polecenie" zeby mi to zadzialalo?? wiem ze sie da to zrobic ale nie wiem jak, a nie moge nigdzie znalesc. znalazlem jeden mikroskopijny opis po ktory i tak mi to nie dziala. moze cos robie zle? moze gdzies w configu sshd_config mam nie odpalone? --edit-- sshd_config Port 22 Protocol 2,1 ListenAddress 0.0.0.0 # HostKey for protocol version 1 #HostKey /etc/ssh/ssh_host_key # HostKeys for protocol version 2 #HostKey /etc/ssh/ssh_host_rsa_key #HostKey /etc/ssh/ssh_host_dsa_key #HostKey /root/test_dsa SyslogFacility AUTHPRIV # Authentication: #LoginGraceTime 2m PermitRootLogin yes #StrictModes yes #MaxAuthTries 6 #RSAAuthentication yes #PubkeyAuthentication yes AuthorizedKeysFile .ssh/authorized_keys # For this to work you will also need host keys in /etc/ssh/ssh_known_hosts RhostsRSAAuthentication no # similar for protocol version 2 HostbasedAuthentication no # Change to yes if you don't trust ~/.ssh/known_hosts for # RhostsRSAAuthentication and HostbasedAuthentication #IgnoreUserKnownHosts no # Don't read the user's ~/.rhosts and ~/.shosts files #IgnoreRhosts yes # To disable tunneled clear text passwords, change to no here! #PasswordAuthentication yes PermitEmptyPasswords yes PasswordAuthentication yes # Change to no to disable s/key passwords #ChallengeResponseAuthentication yes ChallengeResponseAuthentication no # Kerberos options #KerberosAuthentication no #KerberosOrLocalPasswd yes #KerberosTicketCleanup yes #KerberosGetAFSToken no # GSSAPI options #GSSAPIAuthentication no GSSAPIAuthentication yes #GSSAPICleanupCredentials yes GSSAPICleanupCredentials yes #UsePAM no #UsePAM yes # Accept locale-related environment variables AcceptEnv LANG LC_CTYPE LC_NUMERIC LC_TIME LC_COLLATE LC_MONETARY LC_MESSAGES AcceptEnv LC_PAPER LC_NAME LC_ADDRESS LC_TELEPHONE LC_MEASUREMENT AcceptEnv LC_IDENTIFICATION LC_ALL generuje klucze, wrzucam klucz.pub do ~user/.ssh/autorized_keys edytuje autorized_keys dodajac na samym poczatku klucza command="who" i testuje logujac sie i nic. dalej pyta o haslo a polecenia nie wykonuje. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
gajownik Napisano Wrzesień 24, 2006 Zgłoszenie Share Napisano Wrzesień 24, 2006 tworze w katalogu uzytkownika /home/user/.ssh/authorized.keys Tam jest myślnik, a nie kropka. Poza tym nadałeś poprawne uprawnienia (700) do katalogu .ssh? edytuje autorized_keys dodajac na samym poczatku klucza command="who" authorized_keys! Jak tak dalej będziesz robił literówki, to kiedyś system obrócisz w drobny mak... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
koralm Napisano Wrzesień 24, 2006 Autor Zgłoszenie Share Napisano Wrzesień 24, 2006 ups... gdzies mi sie literowka zrobila juz poprawilem co i tak nie zmienia faktu ze nie dziala. .ssh ma prawa 700, natomiast plik authorized_keys 600. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
gajownik Napisano Wrzesień 24, 2006 Zgłoszenie Share Napisano Wrzesień 24, 2006 Samo logowanie za pomocą klucza działa (bez wykonywania polecenia)? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
koralm Napisano Wrzesień 24, 2006 Autor Zgłoszenie Share Napisano Wrzesień 24, 2006 czy mozna to nazwac dzialaniem to nie wiem. w zaleznowsci czy dam: "ssh -l user localhost" czy tez: "ssh -l user localhost -i klucz" to i tak jest to samo. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
gajownik Napisano Wrzesień 24, 2006 Zgłoszenie Share Napisano Wrzesień 24, 2006 w zaleznowsci czy dam: "ssh -l user localhost" czy tez: "ssh -l user localhost -i klucz" to i tak jest to samo. To nie ma żadnego znaczenia jeśli klucz został zapisany w odpowiednim pliku (man ssh opcja -i). ssh pluje się o hasło do klucza czy hasło do konta? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
koralm Napisano Wrzesień 24, 2006 Autor Zgłoszenie Share Napisano Wrzesień 24, 2006 tak samo pyta o haslo do konta Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
koralm Napisano Wrzesień 25, 2006 Autor Zgłoszenie Share Napisano Wrzesień 25, 2006 i problem rozwiazany. wlasciciel pliku byl zly:P zmienilem na usera i dziala, calkiem przyjemnie a moze ktos wie jak teraz to samo uruchomic uzywajac putty? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
smopi Napisano Wrzesień 26, 2006 Zgłoszenie Share Napisano Wrzesień 26, 2006 a moze ktos wie jak teraz to samo uruchomic uzywajac putty? Czytaj tu: LINK W skrócie: jeśli używasz SSH1 to możesz zamiennie używać klucza wygenerowanego przez OpenPGP i Putty. Jeśli jednak preferujesz SSH2, to klucz prywatny najpierw musisz zaimportować do PuTTy'ego i pozniej zapisać w jego formacie. Pozniej mozesz go uzywac w PuTTy'ym do autoryzacji na serwerze. Pozdrawiam, Piotr Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
koralm Napisano Wrzesień 26, 2006 Autor Zgłoszenie Share Napisano Wrzesień 26, 2006 wszystko milo i ladnie, tyle ze: generuje sobie klucze ssh-2 puttygen. tworze na koncie usera ~user/.ssh/authorized_keys i ~user/.ssh/authorized_keys2 dostep do pliku 600 i wlasciciel "user" wrzucam klucz publiczny do obu, i uzywajac putty i klucza prywatnego wlaczam logowanie. Sent username "koralm" Trying public key authentication. Key is of wrong type (PuTTY SSH-2 private key) [email protected]'s password: i nic. jesli zrobie klucz ssh-1 (rsa) to bryka jak szalone, nawet wykonuje zdalnie polecenia. a ssh-2 nijak nie moge zrobic. moze mam cos zle w configu sshd_config? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
smopi Napisano Wrzesień 27, 2006 Zgłoszenie Share Napisano Wrzesień 27, 2006 U mnie zarówno klucz publiczny SSH-1 jak i SSH-2 jest wrzucony do ~/.ssh/authorized_keys i dziala. Authorized_keys2 bylo w starszych wersjach OpenSSH i raczej nie musisz tworzyc tego pliku (tak jest napisane w dokumentacji do której linka Ci dalem a moje doswiadczenia to potwierdzaja, tzn brak pliku authorized_keys2 i obsluga SSH-2 i autoryzacja kluczami) . W PuTTym zainteresuj sie jeszcze czy masz wlaczona obsluge protokolu SSH-1 i 2. To samo w pliku sshd_config (chociaz z listingu który zamiesciles wynika, ze tak). Ja dodatkowo zablokowalem zupelnie autoryzacje haslem a sshd dziala na niestandardowym porcie (tzn. roznym od 22). Pozdrawiam, Piotr //EDIT Jeszcze szybki cytacik: "If your server is OpenSSH and is using the SSH-2 protocol, you should follow the same instructions, except that in earlier versions of OpenSSH 2 the file might be called authorized_keys2. (In modern versions the same authorized_keys file is used for both SSH-1 and SSH-2 keys.)" Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
