Martee Napisano Październik 4, 2006 Zgłoszenie Share Napisano Październik 4, 2006 witam mozecie mnie opieprzyc ze nie umiem googlac itp ale mam maly problem z serwerem ftp pod fedora 5 zainstalowalem vsftpd i gdy probuje sie logowac podaje login i haslo to wyskakuje mi taki blad (login i pass jest na 100% poprawny) ze nie mozna zmienic katalogu domowego uzytkownika [marcin@martee root]$ ftp martee.homelinux.com Connected to martee.homelinux.com. 220 (vsFTPd 2.0.4) 530 Please login with USER and PASS. 530 Please login with USER and PASS. KERBEROS_V4 rejected as an authentication type Name (martee.homelinux.com:marcin): marcin 331 Please specify the password. Password: 500 OOPS: cannot change directory:/home/marcin Login failed. 421 Service not available, remote server has closed connection ftp> quit moj config wyglada tak # Example config file /etc/vsftpd/vsftpd.conf # # The default compiled in settings are fairly paranoid. This sample file # loosens things up a bit, to make the ftp daemon more usable. # Please see vsftpd.conf.5 for all compiled in defaults. # # READ THIS: This example file is NOT an exhaustive list of vsftpd options. # Please read the vsftpd.conf.5 manual page to get a full idea of vsftpd's # capabilities. # # Allow anonymous FTP? (Beware - allowed by default if you comment this out). anonymous_enable=NO # # Uncomment this to allow local users to log in. local_enable=YES # # Uncomment this to enable any form of FTP write command. write_enable=YES # # Default umask for local users is 077. You may wish to change this to 022, # if your users expect that (022 is used by most other ftpd's) local_umask=022 # # Uncomment this to allow the anonymous FTP user to upload files. This only # has an effect if the above global write enable is activated. Also, you will # obviously need to create a directory writable by the FTP user. #anon_upload_enable=YES # # Uncomment this if you want the anonymous FTP user to be able to create # new directories. #anon_mkdir_write_enable=YES # # Activate directory messages - messages given to remote users when they # go into a certain directory. dirmessage_enable=YES # # Activate logging of uploads/downloads. xferlog_enable=YES # # Make sure PORT transfer connections originate from port 20 (ftp-data). connect_from_port_20=YES # # If you want, you can arrange for uploaded anonymous files to be owned by # a different user. Note! Using "root" for uploaded files is not # recommended! #chown_uploads=YES #chown_username=whoever # # You may override where the log file goes if you like. The default is shown # below. #xferlog_file=/var/log/vsftpd.log # # If you want, you can have your log file in standard ftpd xferlog format xferlog_std_format=YES # # You may change the default value for timing out an idle session. idle_session_timeout=600 # # You may change the default value for timing out a data connection. data_connection_timeout=120 # # It is recommended that you define on your system a unique user which the # ftp server can use as a totally isolated and unprivileged user. nopriv_user=ftp # # Enable this and the server will recognise asynchronous ABOR requests. Not # recommended for security (the code is non-trivial). Not enabling it, # however, may confuse older FTP clients. #async_abor_enable=YES # # By default the server will pretend to allow ASCII mode but in fact ignore # the request. Turn on the below options to have the server actually do ASCII # mangling on files when in ASCII mode. # Beware that on some FTP servers, ASCII support allows a denial of service # attack (DoS) via the command "SIZE /big/file" in ASCII mode. vsftpd # predicted this attack and has always been safe, reporting the size of the # raw file. # ASCII mangling is a horrible feature of the protocol. #ascii_upload_enable=YES #ascii_download_enable=YES # # You may fully customise the login banner string: #ftpd_banner=Welcome to martee.homelinux.com FTP Service # # You may specify a file of disallowed anonymous e-mail addresses. Apparently # useful for combatting certain DoS attacks. #deny_email_enable=YES # (default follows) #banned_email_file=/etc/vsftpd/banned_emails # # You may specify an explicit list of local users to chroot() to their home # directory. If chroot_local_user is YES, then this list becomes a list of # users to NOT chroot(). #chroot_list_enable=YES # (default follows) #chroot_list_file=/etc/vsftpd/chroot_list # chroot_local_user=YES # You may activate the "-R" option to the builtin ls. This is disabled by # default to avoid remote users being able to cause excessive I/O on large # sites. However, some broken FTP clients such as "ncftp" and "mirror" assume # the presence of the "-R" option, so there is a strong case for enabling it. #ls_recurse_enable=YES pam_service_name=vsftpd userlist_enable=YES #enable for standalone mode listen=YES tcp_wrappers=YES listen_port=21 ftp_data_port=20 Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
gajownik Napisano Październik 4, 2006 Zgłoszenie Share Napisano Październik 4, 2006 mozecie mnie opieprzyc ze nie umiem googlac itp ale mam maly problem z serwerem ftp pod fedora 5 To, że ktoś nie potrafi znaleźć informacji nie jest powodem, by go zjechać z góry na dół. Tutaj tylko linczuje się za lenistwo i brak chęci do samodzielnego znalezienia rozwiązania ;-) ze nie mozna zmienic katalogu domowego uzytkownika man ftpd_selinux SELinux ftp daemon policy is customizable based on least access required. So by default SElinux does not allow users to login and read their home directories. If you are setting up this machine as a ftpd server and wish to allow users to access their home directorories, you need to set the ftp_home_dir boolean. setsebool -P ftp_home_dir 1 Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Martee Napisano Październik 4, 2006 Autor Zgłoszenie Share Napisano Październik 4, 2006 dzieki wielkie wszystko lata jak sie patrzy Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
