guciol Napisano Sierpień 24, 2004 Zgłoszenie Share Napisano Sierpień 24, 2004 Mam probllemik z tym calyp Captive 1. robie ./install -wszystko jest oki 2. potem captive-install-acquire -i zaczyna sie jazda pokazuje mi ze " still needed essential module: ntfs.sys" "still needed essential module: ntoskrnl.exe " Czy ktos wie o co tu chodzi. W opisie instalaci znalazlem ze powinno mi zwrocic cos takiego "Found although not best "fastfat.sys" (pri=510110690; best=515110690): MS-Windows XP Service Pack 1/1a Free Build 5.1.2600.1106 FastFAT/vfat at URI: file:///var/lib/captive/fastfat.sys Found best available "ext2fsd.sys": ext2 Filesystem v0.10a by http://sys.xiloo.com Checked Build English at URI: file:///var/lib/captive/ext2fsd.sys Found although not best "ntoskrnl.exe" (pri=510115180; best=515110690): MS-Windows XP Q811493_WXP_SP2 Free Build Polish 5.1.2600.1151 Kernel at URI: file:///var/lib/captive/ntoskrnl.exe Found although not best "ntfs.sys" (pri=510110690; best=515110690): MS-Windows XP Service Pack 1/1a Free Build 5.1.2600.1106 NTFS at URI: file:///var/lib/captive/ntfs.sys Found although not best "cdfs.sys" (pri=510110690; best=515110690): MS-Windows XP Service Pack 1/1a Free Build 5.1.2600.1106 CD-ROM/iso-9660 at URI: file:///var/lib/captive/cdfs.sys Essential modules ("ntoskrnl.exe" and "ntfs.sys") are available. You may still want to get their better version and/or more modules." a zwraca mi tylko cos takiego "Found best available "ext2fsd.sys": ext2 Filesystem v0.10 by http://sys.xiloo.com Checked Build English at URI: file:///var/lib/captive/ext2fsd.sys Still needed essential module: ntfs.sys Still needed essential module: ntoskrnl.exe Quickly scan your local disks to find needed drivers? Enter 'y' for YES, 'n' to NO, 'd' if DONE [hit ENTER for YES]:" Probowalem jak mialem zamontowana partycje ntfs i jak mialem odmontowana - zawsze to samo zwraca(to co wyzej) Dzieki za jakakolwiek pomoc Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
