Samba Prawa Uzytkowników
strongman25
no i znów problem
samba sama zmienia mi atrybut do pliku na tylko do odczytu nieważne ze go poprawie na archiwalny i tak zrobi go na tylko do odczytu
smb.conf wygląda tak co tu jest żle?? :?: :?: :?: :?:
[global]
workgroup = centrum
server string = fedora
printcap name = cups
log file = /var/log/samba/%m.log
max log size = 50
local master = no
os level = 99
socket options = TCP_NODELAY IPTOS_LOWDELAY SO_SNDBUF=16384 SO_RCVBUF=16384
max xmit = 65535
log level = 3
#restric anonymous = no
domain master = no
preferred master = no
netbios name = ferrodo
read raw = yes
write raw = yes
##############################3
#restrict anonymous = no
max protocol = NT
read only = no
#map to guest = Bad User
guest ok = yes
security = share
[printers]
path = /var/spool/samba
browseable = no
printable = yes
create mask = 0700
[ferrodo]
path = /home/ferrodo/
directory mask = 0777
create mask = 0777
guest ok = yes
guest only = yes
