martinrudowicz Napisano Styczeń 19, 2007 Zgłoszenie Share Napisano Styczeń 19, 2007 Witam ma Fedore 6 + ISPConfig wszystko ladnie smiga jednak mam problem z wysylaniem poczty Tak wyglada moj konfig queue_directory = /var/spool/postfix command_directory = /usr/sbin daemon_directory = /usr/libexec/postfix mail_owner = postfix inet_interfaces = all mydestination = $myhostname, localhost.$mydomain, localhost, 127.0.0.1 myorigin = $mydomain unknown_local_recipient_reject_code = 550 alias_maps = hash:/etc/aliases alias_database = hash:/etc/aliases debug_peer_level = 2 debugger_command = PATH=/bin:/usr/bin:/usr/local/bin:/usr/X11R6/bin xxgdb $daemon_directory/$process_name $process_id & sleep 5 sendmail_path = /usr/sbin/sendmail.postfix newaliases_path = /usr/bin/newaliases.postfix mailq_path = /usr/bin/mailq.postfix setgid_group = postdrop html_directory = no manpage_directory = /usr/share/man sample_directory = /usr/share/doc/postfix-2.2.8/samples readme_directory = /usr/share/doc/postfix-2.2.8/README_FILES smtpd_sasl_local_domain = smtpd_sasl_auth_enable = yes smtpd_sasl_security_options = noanonymous broken_sasl_auth_clients = yes smtpd_recipient_restrictions = permit_sasl_authenticated, permit_mynetworks, reject_unauth_destination smtpd_tls_auth_only = yes smtp_use_tls = yes smtpd_use_tls = yes smtp_tls_note_starttls_offer = yes smtpd_tls_key_file = /etc/postfix/ssl/smtpd.key smtpd_tls_cert_file = /etc/postfix/ssl/smtpd.crt smtpd_tls_CAfile = /etc/postfix/ssl/cacert.pem smtpd_tls_loglevel = 2 smtpd_tls_received_header = yes smtpd_tls_session_cache_timeout = 3600s tls_random_source = dev:/dev/urandom Podczas proby wyslanai poczty wyskakuje mi blad Warning: fsockopen() [function.fsockopen]: unable to connect to localhost:25 (Connection refused) in /home/admispconfig/ispconfig/web/webmail/inc/class.smtp.php on line 534 SMTP Error: could not connect to SMTP host server(s) Kto moze pomoc ??? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
exbros Napisano Styczeń 19, 2007 Zgłoszenie Share Napisano Styczeń 19, 2007 A firewall Ci przypadkiem portu 25 nie blokuje? Pozdro Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
martinrudowicz Napisano Styczeń 19, 2007 Autor Zgłoszenie Share Napisano Styczeń 19, 2007 A firewall Ci przypadkiem portu 25 nie blokuje? Pozdro Firewall jest wylaczony (wlacze go i posutawiam jak sie uporam z podstawowymi problemami) Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
