Skrypt Do Wyłuskania Info O Kompie
(BigFan)!
cześć,
napisałem jakiś czas temu skrypcik do wyłuskiwania informacji o komputerze
#!/bin/ksh
Prg=`basename $0`
Usage="Usage: $Prg <hostname>"
DIR=`dirname $0`/..
Host=`hostname`
format4="%-25s %-10s %-20s %-50s\n"
# FUNCTIONS
genconf() {
   mydate=`date +"%d/%m/%y %H:%M"`
   printf "$format4" $Host sys date "$mydate"
   # DNS domain:
   if [ -f "/etc/resolv.conf" ];
   then
       var=`awk '{ var=tolower($1); if ( var == "domain" ) { printf "%s",$2 }}' /etc/resolv.conf`
   else
    var="unknown"
   fi
   printf "$format4" $Host sys dnsdomain "$var"
   # server model:
   # ??? DO zrobienia w C
   # system OS and kernel:
   os=`uname -o`
   kernel=`uname -r`
   kernelarch=`uname -i`
   printf "$format4" $Host sys osver "$os"
   printf "$format4" $Host sys kernel "$kernel"
   printf "$format4" $Host sys kernelarch "$kernelarch"
   # hardware architecture:
   mem=`free | awk '{ if ( $1 == "Mem:" ) { printf "%s %s",$2,kB }}'`
   printf "$format4" $Host sys mem "$mem"
   nbcpu=`cat /proc/cpuinfo | grep processor | wc -l`
   printf "$format4" $Host sys nbcpu "$nbcpu"
   model=`cat /proc/cpuinfo | grep "model name" | uniq | awk '{print $4$5}'`
   printf "$format4" $Host sys cpumodel "$model"
   freq=`cat /proc/cpuinfo | grep "cpu MHz" | uniq | awk '{print $4}' | awk -F"." '{print $1}'`
   printf "$format4" $Host sys cpufreq "$freq MHz"
   cache=`cat /proc/cpuinfo | grep "cache size" | uniq | awk '{print $4$5}'`
   printf "$format4" $Host sys cpucache "$cache"
   # SWAP
   swap=`free | awk '{ if ( $1 == "Swap:" ) { printf "%s",$2 }}'`
   printf "$format4" $Host sys swap "$swap kB"
   # MAC addresse(s):
   typeset -i i=0
   bondcards=""                            # the network cards in bond
   networkcards=`ifconfig -a | grep -i HWaddr | awk '{ printf "%s ",$1 }'`
   for card in $networkcards
   do
    # if bonding card
    exist=`echo $card | grep "^eth"`
    if [ -z "$exist" ];                # bonding card
    then
        cardstmp=`grep eth /proc/net/bonding/$card | awk '{ printf "%s ",$NF }'`
        bondcards="${bondcards} $cardstmp"
    fi
    speed="not configured"
    duplex="not configured"
    MAC=`ifconfig $card | grep -i "HWaddr" | awk '{ printf "%s ",$NF }'`
    IP=""
    IP=`ifconfig $card | awk '{ if ( $1 == "inet" ) { printf "%s %s",$2,$NF }}'`
    if [ -z "$IP" ];        # network card is not configured
    then
         var1="not configured"
        var2=$var1
        exist=`echo $bondcards | grep $card`
        if [ -f "/sbin/ethtool" -a -n "$exist" ];
        then
                speed=`/sbin/ethtool $card | awk '{ if ( $1 == "Speed:" ) { print $NF }}'`
                duplex=`/sbin/ethtool $card | awk '{ if ( $1 == "Duplex:" ) { print $NF }}'`
        fi
    else
        var1=`echo $IP | awk '{ print $1 }' | awk -F":" '{ print $2 }'`
        var2=`echo $IP | awk '{ print $2 }' | awk -F":" '{ print $2 }'`
        if [ -f "/sbin/ethtool" ];
        then
        fi
    fi
       printf "$format4" $Host sys lan$i "$card"
       printf "$format4" $Host sys mac$i "$MAC"
    printf "$format4" $Host sys speed$i "$speed"
    printf "$format4" $Host sys duplex$i "$duplex"
       printf "$format4" $Host sys ip$i "$var1"
       printf "$format4" $Host sys netmask$i "$var2"
    i=i+1
   done
   # Disks list:
   typeset -i i=1
   fdisk -l 2>/dev/null | grep Disk | while read myline
   do
    disk=`echo "$myline" | awk '{ printf "%s",$2 }' | tr -d ":"`
    size=`echo "$myline" | awk '{ printf "%s %s",$3,$4 }' | tr -d ","`
       printf "$format4" $Host sys disk$i "$disk $size"
    i=i+1
   done
   # OS Installation date:
# MAIN
genconf
exit 0
skrypcik działa, ale mam do Was dwa pytania:
1) - jak go mogę jeszcze bardziej rozbudowac? Chce aby skrypcik '#!/bin/ksh' pokazywał mi wszystko co jest tylko możliwe o danym komputerze - np. info o sprzęcie - o karcie sieciowej, o procku, o grafice itp oraz info o wszystkim co przydałoby się administratorowi sieci - podpowiedzcie mi co!! - aby ten administrator mógł stwierdzić z jakim ma kompem styczność i co może by zepsute w tym kompie (w moim skrypcie jest to np. adres MAC karty, czy adres IP hosta). Jak wyłuskac nazwę/identyfikator komputera?
2) - chcę zrobić w PHP skrypcik, ktory bedzie pobierał dane zwrócone przez ten skrypt '#!/bin/ksh' i aby te dane były wyświetlane nie statycznie, tylko w sposób dynamiczny. Mam na myśli takie rozwiązanie, że skrypt '#!/bin/ksh' bedzie pobierał dynamicznie (co jakiś czas, albo przez cały czas) te dane z kompa, a skrypt w PHP bedzie te dane dynamicznie odbierał (co jakiś czas, albo przez cały czas) i aby wszelka zmiana została wyświetlona natchmiastowo przez ten skrypt PHP.
