adrub Napisano Styczeń 22, 2007 Zgłoszenie Share Napisano Styczeń 22, 2007 Witam Próbowałem zainstalować xawtv. Yum nie znalazł odpowiednich pakietów, więc ściągnąłem źródło z oficjalnej strony xawtv. I mam problem przy poleceniu make. [root@localhost xawtv-3.95]# /.configure -bash: /.configure: Nie ma takiego pliku ani katalogu [root@localhost xawtv-3.95]# ./configure checking for gcc... gcc checking for C compiler default output file name... a.out checking whether the C compiler works... yes checking whether we are cross compiling... no checking for suffix of executables... checking for suffix of object files... o checking whether we are using the GNU C compiler... yes checking whether gcc accepts -g... yes checking for gcc option to accept ANSI C... none needed checking for g++... g++ checking whether we are using the GNU C++ compiler... yes checking whether g++ accepts -g... yes checking how to run the C preprocessor... gcc -E checking for a BSD-compatible install... /usr/bin/install -c checking for gccmakedep... gccmakedep checking for egrep... grep -E checking for ANSI C header files... yes checking for sys/types.h... yes checking for sys/stat.h... yes checking for stdlib.h... yes checking for string.h... yes checking for memory.h... yes checking for strings.h... yes checking for inttypes.h... yes checking for stdint.h... yes checking for unistd.h... yes checking getopt.h usability... yes checking getopt.h presence... yes checking for getopt.h... yes checking soundcard.h usability... no checking soundcard.h presence... no checking for soundcard.h... no checking for unistd.h... (cached) yes checking sys/select.h usability... yes checking sys/select.h presence... yes checking for sys/select.h... yes checking sys/soundcard.h usability... yes checking sys/soundcard.h presence... yes checking for sys/soundcard.h... yes checking alsa/asoundlib.h usability... yes checking alsa/asoundlib.h presence... yes checking for alsa/asoundlib.h... yes checking linux/joystick.h usability... yes checking linux/joystick.h presence... yes checking for linux/joystick.h... yes checking dev/ic/bt8xx.h usability... no checking dev/ic/bt8xx.h presence... no checking for dev/ic/bt8xx.h... no checking machine/ioctl_bt848.h usability... no checking machine/ioctl_bt848.h presence... no checking for machine/ioctl_bt848.h... no checking for ftello... yes checking for fseeko... yes checking for getpt... yes checking for getnameinfo... yes checking for getopt_long... yes checking for strcasestr... yes checking for dlopen... no checking for dlopen in -ldl... yes checking for ELF... yes checking for pthread_create in -lpthread... yes checking for main in -lossaudio... no checking for initscr in -lncurses... yes checking for X... libraries , headers checking for gethostbyname... yes checking for connect... yes checking for remove... yes checking for shmat... yes checking for IceConnectionNumber in -lICE... yes checking for Xft... yes checking for jpeg_start_compress in -ljpeg... yes checking for snd_seq_open in -lasound... yes checking for lirc_init in -llirc_client... no checking for vbi_capture_fd in -lzvbi... no checking for aa_autoinit in -laa... no checking for dv_decoder_new in -ldv... no checking for lqt_query_registry in -lquicktime... no checking for XF86DGAQueryExtension in -lXxf86dga... no checking for XF86VidModeQueryExtension in -lXxf86vm... no checking for DPMSQueryExtension in -lXdpms... no checking for DPMSQueryExtension in -lXext... yes checking for XineramaQueryExtension in -lXinerama... yes checking for XRenderQueryExtension in -lXrender... yes checking for XRRConfigCurrentConfiguration in -lXrandr... yes checking for XvQueryExtension in -lXv... no checking for XmStringGenerate in -lXm... no checking for glXChooseVisual in -lGL... yes checking for X11 config directory... /etc/X11 checking for X11 app-defaults directory... /usr/X11R6/lib/X11/app-defaults checking if mmx should be used... yes configure: creating ./config.status config.status: creating Makefile config.status: creating xawtv.spec config.status: creating config.h config.status: config.h is unchanged [root@localhost xawtv-3.95]# make CC console/fbtv.o In file included from console/fbtv.c:31: ./libng/grab-ng.h:28:1: warning: "bool" redefined In file included from /usr/include/curses.h:161, from console/fbtv.c:24: /usr/lib/gcc/i386-redhat-linux/4.1.1/include/stdbool.h:36:1: warning: this is the location of the previous definition In file included from console/fbtv.c:44: console/fs.h:2:20: error: FSlib.h: Nie ma takiego pliku ani katalogu In file included from console/fbtv.c:44: console/fs.h:6: error: expected specifier-qualifier-list before ‘FSXFontInfoHeader’ console/fs.h:58: error: expected declaration specifiers or ‘...’ before ‘FSXCharInfo’ console/fs.h:62: error: expected ‘)’ before ‘*’ token console/fbtv.c: In function ‘text_out’: console/fbtv.c:339: error: ‘struct fs_font’ has no member named ‘height’ console/fbtv.c:340: error: ‘struct fs_font’ has no member named ‘fontHeader’ console/fbtv.c:341: warning: pointer targets in passing argument 4 of ‘fs_puts’ differ in signedness console/fbtv.c: In function ‘text_width’: console/fbtv.c:347: warning: pointer targets in passing argument 2 of ‘fs_textwidth’ differ in signedness console/fbtv.c: In function ‘do_capture’: console/fbtv.c:405: error: ‘struct fs_font’ has no member named ‘height’ console/fbtv.c:406: error: ‘struct fs_font’ has no member named ‘height’ console/fbtv.c:443: error: ‘struct fs_font’ has no member named ‘height’ console/fbtv.c:444: error: ‘struct fs_font’ has no member named ‘height’ console/fbtv.c: In function ‘main’: console/fbtv.c:755: error: ‘struct fs_font’ has no member named ‘height’ console/fbtv.c:773: error: ‘struct fs_font’ has no member named ‘width’ console/fbtv.c:813: warning: pointer targets in assignment differ in signedness make: *** [console/fbtv.o] Błąd 1 czym to jest spowodowane? jak to naprawić? Proszę o pomoc adrub Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
