seawolf Napisano Styczeń 22, 2007 Zgłoszenie Share Napisano Styczeń 22, 2007 Witam! Chciałbym aby moduł aic7xxx_old był ładowany podczas startu systemu zamiast modułu aic7xxx, ponieważ jest w nim jakiś bug podczas startu systemu otrzymuje komunikat "Wide transfers fail": Komenda dmesg: scsi0 : Adaptec AIC7XXX EISA/VLB/PCI SCSI HBA DRIVER, Rev 7.0 <Adaptec aic7899 Ultra160 SCSI adapter> aic7899: Ultra160 Wide Channel A, SCSI Id=7, 32/253 SCBs Vendor: MAXTOR Model: ATLAS10K4_36WLS Rev: DFL0 Type: Direct-Access ANSI SCSI revision: 03 scsi0:A:1:0: Tagged Queuing enabled. Depth 4 target0:0:1: Beginning Domain Validation target0:0:1: wide asynchronous (scsi0:A:1:0): parity error detected in Data-in phase. SEQADDR(0x1a7) SCSIRATE(0x80) target0:0:1: Wide Transfers Fail target0:0:1: FAST-40 SCSI 40.0 MB/s ST (25 ns, offset 127) target0:0:1: Domain Validation skipping write tests target0:0:1: Ending Domain Validation SCSI device sda: 71833096 512-byte hdwr sectors (36779 MB) sda: Write Protect is off sda: Mode Sense: fd 00 10 08 SCSI device sda: drive cache: write back w/ FUA SCSI device sda: 71833096 512-byte hdwr sectors (36779 MB) sda: Write Protect is off sda: Mode Sense: fd 00 10 08 SCSI device sda: drive cache: write back w/ FUA sda: sda1 sd 0:0:1:0: Attached scsi disk sda ACPI: PCI Interrupt 0000:00:09.1 -> GSI 27 (level, low) -> IRQ 17 scsi1 : Adaptec AIC7XXX EISA/VLB/PCI SCSI HBA DRIVER, Rev 7.0 <Adaptec aic7899 Ultra160 SCSI adapter> aic7899: Ultra160 Wide Channel B, SCSI Id=7, 32/253 SCBs Vendor: MAXTOR Model: ATLAS10K4_36WLS Rev: DFL0 Type: Direct-Access ANSI SCSI revision: 03 scsi1:A:0:0: Tagged Queuing enabled. Depth 4 [b] target1:0:0: Beginning Domain Validation target1:0:0: wide asynchronous target1:0:0: FAST-80 WIDE SCSI 160.0 MB/s DT (12.5 ns, offset 127) target1:0:0: Ending Domain Validation SCSI device sdb: 71833096 512-byte hdwr sectors (36779 MB) sdb: Write Protect is off sdb: Mode Sense: fd 00 10 08 SCSI device sdb: drive cache: write back w/ FUA SCSI device sdb: 71833096 512-byte hdwr sectors (36779 MB) sdb: Write Protect is off sdb: Mode Sense: fd 00 10 08 SCSI device sdb: drive cache: write back w/ FUA sdb: sdb1 sdb2 Korzystając z modułu aic7xxx_old znika ten problem. Skompilowałem jądro samodzielnie bez modułu aic7xxx dlatego łądowany jest aic7xxx_old. Chciałbym tak zrobić aby ładowany był moduł aic7xxx_old nawet jeżeli aic7xxx został skompilowany. Zmieniłem wpis w /etc/modprobe.conf z modprobe scsi_hostadapter aic7xxx na modprobe scsi_hostadapter aic7xxx_old ale nie pomogło. Dalej ładowany jest moduł ktorego nie chce. Czy zna może ktoś rozwiązanie mojego problemu? Chciałbym uniknąć kompilowania co jakiś czas nowego jądra i zmieniania parametrów w plikach konfiguracyjnych po każdym instalowaniu. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
