Serwer Dns, Startuje Ale Nie Dziala
Yaro
Na jutro musze umiec stawiac dnsa, mam zaliczenie kombinuje w domu z notatkami z zajec ale cos nie chce dzialac:
moje pliki:
resolv.conf
nameserver 192.168.1.1
search localdomain
nameserver 192.168.1.4
named.conf
options {
     directory "/var/named";
     dump-file "/var/named/data/cache_dump.db";
     statistics-file "/var/named/data/named_stats.txt";
                                           // query-source address * port 53;
// a caching only nameserver config
controls {
      inet 127.0.0.1 allow { localhost; } keys { rndckey; };
zone "." IN {
             type hint;
	 file "named.ca";
zone "localdomain" IN {
           type master;
          file "localdomain.zone";
                 allow-update { none; };
zone "localhost" IN {
        type master;
           file "localhost.zone";
zone "0.0.127.in-addr.arpa" IN {
                 type master;
            file "named.local";
zone "0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.ip6.arpa" IN {
           type master;
                  file "named.ip6.local";
zone "wshe-linux.com"    IN {
                type master;
               file "wshe-linux.zone";
zone "255.in-addr.arpa" IN {
          type master;
         file "named.broadcast";
zone "0.in-addr.arpa" IN {
       type master;
          file "named.zero";
zone "192.168.1.in-addr.arpa" IN {
       type master;
          file "192.168.1.in-addr.arpa.zone";
include "/etc/rndc.key";
$TTL 1W
@    IN SOA myhost.wshe-linux.com. root.wshe-linux.com. (
                    2007010301
                    12H
                    1H
                    4D
                    6H)
    IN NS    dns1.wshe-linux.com.
    IN PTR    mychost.wshe-linux.com.
    IN PTR     komp1.wshe-linux.com.
    IN PTR     komp2.wshe-linux.com.
wshe-linux.zone
$TTL 1W
wshe-linux.com. IN SOA myhost.wshe-linux.com.    root.wshe-linux.com. (
            2007010301
            12H
            1H
            4D
            6H)
wshe-linux.com.  IN MX 5 mail.wshe-linux.com.
myhost         IN A    192.168.1.4
dns1        IN A    192.168.1.4
komp1        IN A    192.168.1.4
komp2        IN A    192.168.1.3
mail         IN A    192.168.1.4
www        IN CNAME myhost
ftp        IN CNAME myhost
192.168.1.4 adres mojedo kompa z serverm
192.168.1.3 adres drugiego kompa w sieci
serwer startuje ale nie dziala
