Yum Się Wykłada
MC'
Witam,
Przy kolejnych komendach yum wydaje coś podaobnego
# yum cleanall
Loading "changelog" plugin
Loading "installonlyn" plugin
Loading "fastestmirror" plugin
Loading "fedorakmod" plugin
rpmdb: PANIC: fatal region error detected; run recovery
error: db4 error(-30977) from dbenv->open: DB_RUNRECOVERY: Fatal error, run database recovery
error: cannot open Packages index using db3 -  (-30977)
error: cannot open Packages database in /var/lib/rpm
  File "/usr/bin/yum", line 29, in ?
    yummain.main(sys.argv[1:])
  File "/usr/share/yum-cli/yummain.py", line 82, in main
    base.getOptionsConfig(args)
  File "/usr/share/yum-cli/cli.py", line 205, in getOptionsConfig
    errorlevel=opts.errorlevel)
  File "/usr/lib/python2.4/site-packages/yum/__init__.py", line 125, in doConfigSetup
    self.conf = config.readMainConfig(startupconf)
  File "/usr/lib/python2.4/site-packages/yum/config.py", line 598, in readMainConfig
    yumvars['releasever'] = _getsysver(startupconf.installroot, startupconf.distroverpkg)
  File "/usr/lib/python2.4/site-packages/yum/config.py", line 661, in _getsysver
    idx = ts.dbMatch('provides', distroverpkg)
TypeError: rpmdb open failed
Jak można tego budga rozwiązać?
Pozdr
[EDIT] Ok przepraszam... rozwiązanie: http://forum.fedora.pl/index.php?showtopic=13446
