Gnome-commander-1.1.6-problem Z Instalacja
rycerz_83
witam,
od pewnego czasu chce zainstalowac gnome-commandera no i nie moge.
w jego pliku install instrukcja jest jasna:
The simplest way to compile this package is:
1. `cd' to the directory containing the package's source code and type
`./configure' to configure the package for your system. If you're
using `csh' on an old version of System V, you might need to type
`sh ./configure' instead to prevent `csh' from trying to execute
`configure' itself.
Running `configure' takes awhile. While running, it prints some
messages telling which features it is checking for.
2. Type `make' to compile the package.
3. Optionally, type `make check' to run any self-tests that come with
the package.
4. Type `make install' to install the programs and any data files and
documentation.
5. You can remove the program binaries and object files from the
source code director
o, przycielo moj post pierwszy, czy to kwestia ustawien przegladania?
ale wracajac do problemu, yum rowniez nie zadzial:
primary.xml.gz            100% |=========================| 889 kB    02:28
extras    : ################################################## 2871/2871
Added 298 new packages, deleted 1400 old in 21.74 seconds
No Match for argument: gnome-commander
Nothing to do
ale jak by to rozwiazac normalnie bez yum-a? gdy nie bede mial dostepu do neta albo na innej dystrybucji?
