Kompilacja Ekg2
Muniek1
Witam,
Mam problem z kompilacją ekg2. Więc tak ściągnąłem, rozpakowałem, i teraz z roota w konsoli wydaje polecenie ./configure:
[root@Tux ekg2-20070303]# ./configure
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for awk... awk
checking whether make sets $(MAKE)... yes
checking for gcc... gcc
checking for C compiler default output... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking how to run the C preprocessor... gcc -E
checking for an ANSI C-conforming const... yes
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking for a sed that does not truncate output... /bin/sed
checking for egrep... grep -E
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for /usr/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking whether ln -s works... yes
checking how to recognise dependent libraries... pass_all
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking whether we are using the GNU C++ compiler... no
checking whether no accepts -g... no
checking dependency style of no... none
checking how to run the C++ preprocessor... /lib/cpp
configure: error: C++ preprocessor "/lib/cpp" fails sanity check
See `config.log' for more details.
Fragmęt config.log:
configure:2467: checking whether we are using the GNU C compiler
configure:2492: gcc -c   conftest.c >&5
configure:2495: $? = 0
configure:2498: test -s conftest.o
configure:2501: $? = 0
configure:2514: result: yes
configure:2520: checking whether gcc accepts -g
configure:2542: gcc -c -g  conftest.c >&5
configure:2545: $? = 0
configure:2548: test -s conftest.o
configure:2551: $? = 0
configure:2562: result: yes
configure:2579: checking for gcc option to accept ANSI C
configure:2640: gcc  -c -g -O2  conftest.c >&5
configure:2643: $? = 0
configure:2646: test -s conftest.o
configure:2649: $? = 0
configure:2667: result: none needed
configure:2685: gcc -c -g -O2  conftest.c >&5
conftest.c:2: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'me'
configure:2688: $? = 1
configure: failed program was:
| #ifndef __cplusplus
Coś mu nie pasuje z kompilatorem, tylko nie wiem co i jak temu zaradzić. Jakieś pomysły? Za pomoc z góry dziękuje.
Pozdrawiam.
[root@Tux ekg2-20070303]# yum install libgcc\*
Loading "installonlyn" plugin
Repository 'macromedia' is missing name in configuration, using id
Setting up Install Process
Setting up repositories
Nothing to do
Dalej nic nie pomogło, ale zastanawia mnie po co instalowałem qt ekg to przecież aplikacja działająca w konsoli. Proszę o dalszą pomoc, z góry dziekuje.
