boreck Napisano Maj 9, 2007 Zgłoszenie Share Napisano Maj 9, 2007 Witam, fedora 6, samba. Userzy zaczeli plakac ze zawiesza sie word. Obserwacja: po uruchomieniu plikow z udzialow sieciowych nastepuje bardzo dlugi czas oczekiwania na otwarcie dokumentu sprawiajacy wrazenie ze word sie zawiesza. Jednak mysle ze powoduje to "zawieszanie" protokolu sieciowego lub karty sieciowej, poniewaz zaobserwowalem tez opoznienia w czasie polaczenie z serwrem przez ssh. oto wynik pingowania serwera z koncowki sieciowej: Reply from 192.168.40.10: bytes=32 time<1ms TTL=64 Reply from 192.168.40.10: bytes=32 time<1ms TTL=64 Request timed out. Request timed out. Reply from 192.168.40.10: bytes=32 time=1ms TTL=64 Reply from 192.168.40.10: bytes=32 time<1ms TTL=64 Request timed out. Request timed out. Request timed out. Request timed out. Request timed out. Reply from 192.168.40.10: bytes=32 time=1ms TTL=64 Reply from 192.168.40.10: bytes=32 time=1ms TTL=64 Reply from 192.168.40.10: bytes=32 time<1ms TTL=64 Reply from 192.168.40.10: bytes=32 time<1ms TTL=64 Reply from 192.168.40.10: bytes=32 time<1ms TTL=64 Reply from 192.168.40.10: bytes=32 time<1ms TTL=64 Reply from 192.168.40.10: bytes=32 time=1ms TTL=64 Reply from 192.168.40.10: bytes=32 time=1ms TTL=64 Reply from 192.168.40.10: bytes=32 time<1ms TTL=64 Reply from 192.168.40.10: bytes=32 time<1ms TTL=64 Reply from 192.168.40.10: bytes=32 time=1ms TTL=64 Reply from 192.168.40.10: bytes=32 time<1ms TTL=64 Reply from 192.168.40.10: bytes=32 time<1ms TTL=64 Reply from 192.168.40.10: bytes=32 time=1ms TTL=64 Reply from 192.168.40.10: bytes=32 time<1ms TTL=64 Reply from 192.168.40.10: bytes=32 time<1ms TTL=64 Reply from 192.168.40.10: bytes=32 time=27ms TTL=64 Reply from 192.168.40.10: bytes=32 time<1ms TTL=64 Reply from 192.168.40.10: bytes=32 time<1ms TTL=64 Reply from 192.168.40.10: bytes=32 time=1ms TTL=64 Reply from 192.168.40.10: bytes=32 time<1ms TTL=64 Request timed out. Request timed out. Request timed out. Request timed out. Request timed out. Request timed out. Reply from 192.168.40.10: bytes=32 time=1ms TTL=64 Reply from 192.168.40.10: bytes=32 time<1ms TTL=64 oto wynik pingu z serwera: 64 bytes from 192.168.40.10: icmp_seq=706 ttl=64 time=0.023 ms 64 bytes from 192.168.40.10: icmp_seq=707 ttl=64 time=0.023 ms 64 bytes from 192.168.40.10: icmp_seq=708 ttl=64 time=0.023 ms 64 bytes from 192.168.40.10: icmp_seq=709 ttl=64 time=0.023 ms 64 bytes from 192.168.40.10: icmp_seq=710 ttl=64 time=0.027 ms 64 bytes from 192.168.40.10: icmp_seq=711 ttl=64 time=0.023 ms 64 bytes from 192.168.40.10: icmp_seq=712 ttl=64 time=0.024 ms 64 bytes from 192.168.40.10: icmp_seq=713 ttl=64 time=0.023 ms 64 bytes from 192.168.40.10: icmp_seq=714 ttl=64 time=0.023 ms 64 bytes from 192.168.40.10: icmp_seq=715 ttl=64 time=0.022 ms 64 bytes from 192.168.40.10: icmp_seq=716 ttl=64 time=0.023 ms 64 bytes from 192.168.40.10: icmp_seq=717 ttl=64 time=0.022 ms Jak widac w tym przypadku nie wystepuja straty pakietow. Gdzie szukac bledu? Prosze o pomysl lub linka. Siec oczywiscie nie obciazona w momencie testowania. Pozdrawiam Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
twoface Napisano Maj 9, 2007 Zgłoszenie Share Napisano Maj 9, 2007 To raczej nie zwiazane z fedora a z zagadnieniami sieciowymi. Więc trochę niewłaściwe forum. Podejrzenia: - zdublowany adres IP w sieci, powoduje sporo kolizji i blokowanie sieci - zmieszanie sieci o prędkości 10 z siecią o prędkości 100 > to samo konflikty - niesprawne urządzenie sieciowe hub/switch/karta sieciowa w serwerze Sprawdz czy pingi na inne maszyny ida tak samo z problemami. Jeżeli nie to może ktoś wpisał sobie takie samo IP jak masz ip servera, wynik > połowa pakietów nie dochodzi. Sposób na sprawdzenie> wyłącz interfejs sieciowy w serwerze z sambą i zobacz czy możesz pingować to IP (sprawdzeni nie jest 100% bo host może mieć zablokowane odpowiadanie na pingi) Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
