Podsluchiwanie,wirusy Itp...
Jasiek_M
Witam!
Na IRC`u mi poradzono by sprawdzić czy nie jestem podsłuchiwany , nie mam koni trojańskich, itp. wpisać
netstat -ln
Wynik tego to:
# [Jasiek@localhost ~]$ netstat -ln
# Active Internet connections (only servers)
# Proto Recv-Q Send-Q Local Address              Foreign Address            State
# tcp        0      0 127.0.0.1:2208              0.0.0.0:*                  LISTEN
# tcp        0      0 0.0.0.0:1550                0.0.0.0:*                  LISTEN
# tcp        0      0 0.0.0.0:111                0.0.0.0:*                  LISTEN
# tcp        0      0 127.0.0.1:631              0.0.0.0:*                  LISTEN
# tcp        0      0 127.0.0.1:25                0.0.0.0:*                  LISTEN
# tcp        0      0 0.0.0.0:893                0.0.0.0:*                  LISTEN
# tcp        0      0 127.0.0.1:2207              0.0.0.0:*                  LISTEN
# tcp        0      0 :::22                      :::*                        LISTEN
# tcp        0      0 ::1:631                    :::*                        LISTEN
# udp        0      0 0.0.0.0:32768              0.0.0.0:*
# udp        0      0 0.0.0.0:32771              0.0.0.0:*
# udp        0      0 0.0.0.0:5353                0.0.0.0:*
# udp        0      0 0.0.0.0:111                0.0.0.0:*
# udp        0      0 0.0.0.0:631                0.0.0.0:*
# udp        0      0 0.0.0.0:887                0.0.0.0:*
# udp        0      0 0.0.0.0:890                0.0.0.0:*
# udp        0      0 :::32769                    :::*
# udp        0      0 :::5353                    :::*
# Active UNIX domain sockets (only servers)
# Proto RefCnt Flags      Type      State        I-Node Path
# unix  2      [ ACC ]    STREAM    LISTENING    13191  /tmp/orbit-Jasiek/linc-cbd-0-267bd767d95b
# unix  2      [ ACC ]    STREAM    LISTENING    13713  /tmp/mapping-Jasiek
# unix  2      [ ACC ]    STREAM    LISTENING    13226  /tmp/orbit-Jasiek/linc-cc8-0-57a2321e22215
# unix  2      [ ACC ]    STREAM    LISTENING    36990  /tmp/orbit-Jasiek/linc-13ba-0-707e04cce071
# unix  2      [ ACC ]    STREAM    LISTENING    8829  /var/run/dbus/system_bus_socket
# unix  2      [ ACC ]    STREAM    LISTENING    8923  /var/run/sdp
# unix  2      [ ACC ]    STREAM    LISTENING    9018  /var/run/pcscd.comm
# unix  2      [ ACC ]    STREAM    LISTENING    12222  /tmp/.gdm_socket
# unix  2      [ ACC ]    STREAM    LISTENING    13257  /tmp/orbit-Jasiek/linc-cc6-0-aed77537399e
# unix  2      [ ACC ]    STREAM    LISTENING    14034  /tmp/orbit-Jasiek/linc-d31-0-2795938a29c05
# unix  2      [ ACC ]    STREAM    LISTENING    8591  /var/run/setrans/.setrans-unix
# unix  2      [ ACC ]    STREAM    LISTENING    13569  /tmp/orbit-Jasiek/linc-cc1-0-27aa52938a9d
# unix  2      [ ACC ]    STREAM    LISTENING    9154  /var/run/acpid.socket
# unix  2      [ ACC ]    STREAM    LISTENING    14126  /tmp/orbit-Jasiek/linc-d2f-0-9aed6bc75239
# unix  2      [ ACC ]    STREAM    LISTENING    12669  @/tmp/dbus-TpvLEJwU3H
# unix  2      [ ACC ]    STREAM    LISTENING    9248  /var/run/cups/cups.sock
# unix  2      [ ACC ]    STREAM    LISTENING    13144  /tmp/orbit-Jasiek/linc-cbb-0-34a9834ad2af7
# unix  2      [ ACC ]    STREAM    LISTENING    14212  /tmp/orbit-Jasiek/linc-d48-0-57f7c1a8142ed
# unix  2      [ ACC ]    STREAM    LISTENING    13906  /tmp/orbit-Jasiek/linc-ce4-0-a74560da17c1
# unix  2      [ ACC ]    STREAM    LISTENING    13887  /tmp/orbit-Jasiek/linc-cf1-0-2c5d68ec35044
# unix  2      [ ACC ]    STREAM    LISTENING    13722  /tmp/orbit-Jasiek/linc-cc4-0-267bd7622e3ce
# unix  2      [ ACC ]    STREAM    LISTENING    13949  /tmp/orbit-Jasiek/linc-d1d-0-40def22a751a3
# unix  2      [ ACC ]    STREAM    LISTENING    14187  /home/Jasiek/.beagle/socket
# unix  2      [ ACC ]    STREAM    LISTENING    14065  /tmp/orbit-Jasiek/linc-d2d-0-2795938a5d043
# unix  2      [ ACC ]    STREAM    LISTENING    14418  /tmp/orbit-Jasiek/linc-d4b-0-6cb1a5a170306
# unix  2      [ ACC ]    STREAM    LISTENING    36209  /tmp/orbit-Jasiek/linc-12d7-0-68b56ded5169c
# unix  2      [ ACC ]    STREAM    LISTENING    9973  @/var/run/hald/dbus-TUzA2IzuXi
# unix  2      [ ACC ]    STREAM    LISTENING    14584  /tmp/orbit-Jasiek/linc-cef-0-71cd26e68578f
# unix  2      [ ACC ]    STREAM    LISTENING    14621  /tmp/orbit-Jasiek/linc-d84-0-30acb2eee96a2
# unix  2      [ ACC ]    STREAM    LISTENING    14916  /home/Jasiek/.beagle/socket-helper
# unix  2      [ ACC ]    STREAM    LISTENING    13898  @/tmp/fam-Jasiek-
# unix  2      [ ACC ]    STREAM    LISTENING    9879  /var/run/avahi-daemon/socket
# unix  2      [ ACC ]    STREAM    LISTENING    13165  /tmp/orbit-Jasiek/linc-cbf-0-34a9834ae7e69
# unix  2      [ ACC ]    STREAM    LISTENING    12652  /tmp/ssh-UAbAEs3160/agent.3160
# unix  2      [ ACC ]    STREAM    LISTENING    12301  /tmp/.X11-unix/X0
# unix  2      [ ACC ]    STREAM    LISTENING    12706  /tmp/orbit-Jasiek/linc-c9f-0-5653f44d4b6bd
# unix  2      [ ACC ]    STREAM    LISTENING    9723  /tmp/.font-unix/fs7100
# unix  2      [ ACC ]    STREAM    LISTENING    9974  @/var/run/hald/dbus-4oxsj3ChR9
# unix  2      [ ACC ]    STREAM    LISTENING    12715  /tmp/orbit-Jasiek/linc-c58-0-424658f952b48
# unix  2      [ ACC ]    STREAM    LISTENING    12945  /tmp/.ICE-unix/3160
# unix  2      [ ACC ]    STREAM    LISTENING    12954  /tmp/keyring-8eljmw/socket
# unix  2      [ ACC ]    STREAM    LISTENING    12975  /tmp/orbit-Jasiek/linc-ca4-0-42223a6a6719e
# unix  2      [ ACC ]    STREAM    LISTENING    13059  /tmp/orbit-Jasiek/linc-cab-0-34a9834a4c489
# unix  2      [ ACC ]    STREAM    LISTENING    13092  /tmp/orbit-Jasiek/linc-cb5-0-6a490e166aa1a
Potem mi poradzili bym sprawdził wszystkie porty przy których jest "Foreign Adress 0.0.0.0 poleceniami
fuser -n tcp nr_portu
i
fuser -n udp nr_portu
Oto wynik:
# [root@localhost ~]# fuser -n tcp 2208
# 2208/tcp:            2613
# [root@localhost ~]# fuser -n udp 2208
# 2208/udp:            2613
# [root@localhost ~]# fuser -n tcp 1550
# 1550/tcp:            3422
# [root@localhost ~]# fuser -n udp 1550
# 1550/udp:            3422
# [root@localhost ~]# fuser -n tcp 111
# 111/tcp:              2386
# [root@localhost ~]# fuser -n udp 111
# 111/udp:              2386
# [root@localhost ~]# fuser -n tcp 631
# 631/tcp:              2630
# [root@localhost ~]# fuser -n udp 631
# 631/udp:              2630
# [root@localhost ~]# fuser -n tcp 25
# 25/tcp:              2664
# [root@localhost ~]# fuser -n udp 25
# 25/udp:              2664
# [root@localhost ~]# fuser -n tcp 893
# 893/tcp:              2407
# [root@localhost ~]# fuser -n udp 893
# 893/udp:              2407
# [root@localhost ~]# fuser -n tcp 2207
# 2207/tcp:            2618
# [root@localhost ~]# fuser -n udp 2207
# 2207/udp:            2618
Niestety użytkownik który mi pomagał musiał iść do domu, może może ktoś zinterpretować te wyniki?
Z góry dziękuje i pozdrawiam
Jasiek Matacz
Zacznij nie od sprawdzenia słuchających portów, ale od uruchomionych usług. Użyj do tego programu system-config-services.
Widzę, ze masz odpalonych wiele usług. Wyłącz najpierw niepotrzebne i ponów test. To rozjasni obraz sytuacji. Możesz też spróbowac nmap -O 127.0.0.1
ok, dzięki, wyłączyłem kilka nie używanych rzeczy. Mam drugie pytanie czy nie dało by się wyłączyć tych procesów które podczas uruchamiania zawodzą? Bo po co w ogóle próbować po raz tysięczny je włączać jak zawodzą?
Jasne, ze się da, ale zauważ, że nie podałeś nam absolutnie żadnych szczegółów dotyczących tego, o co ci chodzi.
Hmm, zawodzą mi 2 procesy jeden eth0i prosi o sprawdzenie kabla a drugi to "Mount special device", ale zaraz jeszcze sprawdzę i powiem:P
a Co do tego polecenia:
[root@localhost ~]# nmap -O 127.0.0.1
Starting Nmap 4.11 ( http://www.insecure.org/nmap/ ) at 2007-05-20 20:17 CEST
Interesting ports on localhost.localdomain (127.0.0.1):
Not shown: 1675 closed ports
PORT     STATE SERVICE
22/tcp   open  ssh
111/tcp  open  rpcbind
631/tcp  open  ipp
857/tcp  open  unknown
1550/tcp open  3m-image-lm
No exact OS matches for host (If you know what OS is running on it, see http://www.insecure.org/cgi-bin/nmap-submit.cgi).
TCP/IP fingerprint:
SInfo(V=4.11%P=i686-redhat-linux-gnu%D=5/20%Tm=465090C2%O=22%C=1)
TSeq(Class=RI%gcd=1%SI=348EDE%IPID=Z%TS=1000HZ)
TSeq(Class=RI%gcd=1%SI=3490F8%IPID=Z%TS=1000HZ)
TSeq(Class=RI%gcd=1%SI=348F6A%IPID=Z%TS=1000HZ)
T1(Resp=Y%DF=Y%W=8000%ACK=S++%Flags=AS%Ops=MNNTNW)
T2(Resp=N)
T3(Resp=Y%DF=Y%W=8000%ACK=S++%Flags=AS%Ops=MNNTNW)
T4(Resp=Y%DF=Y%W=0%ACK=O%Flags=R%Ops=)
T5(Resp=Y%DF=Y%W=0%ACK=S++%Flags=AR%Ops=)
T6(Resp=Y%DF=Y%W=0%ACK=O%Flags=R%Ops=)
T7(Resp=Y%DF=Y%W=0%ACK=S++%Flags=AR%Ops=)
PU(Resp=Y%DF=N%TOS=C0%IPLEN=164%RIPTL=148%RID=E%RIPCK=E%UCK=E%ULEN=134%DAT=E)
Uptime 0.012 days (since Sun May 20 19:59:52 2007)
Nmap finished: 1 IP address (1 host up) scanned in 10.340 seconds
[root@localhost ~]#
Edit: Jeszcze zdjęcia procesów które zawodzą(zdjęcia bo boję się że zrobię literówkę i coś źle wyłączę potem i zepsuje nieodwracalnie system:P)
Pierwsze to usluga network która znalazla aktywny, lecz uszkodzony interfejs. Jesli chodzi o rezultaty dzialania programu netstat, to widac, ze masz uruchomiona usluge logowania zdalnego, wywalanie RPC(na pewno potrzebne? ;)) drukowanie przez CUPS i.... cos dziwnego - przyjrzyj sie tym dwóm portom. Jezeli juz zabierasz sie powazniej za bezpieczenstwo, to sprawdz swoje reguly zapory sieciowej.
Blad w /dev/hdaX oznacza prawdopodobnie, ze jakies bzdury masz wypisane w /etc/fstab :>
To znaczy ze nie jest potrzebny, a jesli tak to mozna to wylaczyc a jesli tak to jak?
Zdalne logowanie to znaczy z innego komputera(jesli tak to nie uzywalem i nie bede tego)? Mozna to wylaczyc, czy potrzebne?jesli tak to jak? A co oznaczaja te 2 pozostale rzeczy(wywalanie RPC, drukowanie przez CUPS), i jakim 2 portom i jak to zrobic?
Jak? Bo ja lamer linuxowy:P Jedyne co mam to nawyki z Windowsa ze wszystko co w standardzie to nie dziala, i wlamac sie do mojego kompa to nie problem.
LABEL=/1                /                       ext3    defaults        1 1
devpts                  /dev/pts                devpts  gid=5,mode=620  0 0
tmpfs                   /dev/shm                tmpfs   defaults        0 0
proc                    /proc                   proc    defaults        0 0
sysfs                   /sys                    sysfs   defaults        0 0
LABEL=SWAP-hda4         swap                    swap    defaults        0 0
/dev/hdaX /mnt/hda1  auto ro,umask=0222 0 0
/dev/hdaX /mnt/hda2  auto ro,umask=0222 0 0
/dev/hdaX /mnt/hda5  auto ro,umask=0222 0 0
Ale jakos mam dostep do dysków windwsowych, tylko musialem zainstalowac specjalny program do otwierania dysków NFTS, ale bez mozliwosci zapisu na nich...
To jakaś bzdura jest przeklepałeś to pewnie z jakiegoś przykładu. Za X powinieneś podstawić realne wartości czyli np hda1,hda2... itd. Wiesz jakie to są wartości u ciebie? Spróbuj komendą "fdisk -l" się dowiedzieć.
System ---> Administracja ---> Siec
Urzadzenie eth0 ---> Edytuj ---> Aktywuj....
Ok, dzieki:)
a teraz mam pytanie, jakie procesy móglbym wylaczyc, a które sa nie potrzebne a wrecz nieodpowiedzialne(np. zdalne logowanie). Bo sam sie nie znam...
Prosze o to zdjecia procesów, z góry dziekuje za pomoc, chodzi mi by oczyscic komputer zbednych rzeczy i tych ryzykownych których nie uzywam:
Z góry dziekuje:)
Jasiek
Człowieku...
Każda z tych usług ma opis. Jak nie ma jakims cudem, albo nie rozumiesz, to wrzuć do google'a.
Zasada jest prosta:
nie używasz Bluetooth - wyłącz usługe o tajemniczej nazwie Bluetooth
nie logujesz się zdalnie przez ssh - wyłącz ssh
Zostaw:
oszczędzanie energii, zapora sieciowa, dzienniki systemowe itp.
Litości nie dość ,że temat był poruszany to jeszcze dajesz zrzuty tak nędznej jakości mogłeś to choć połączyć w jeden. Mam jednak dziś dobry dzień więc przeskanowałem ci opis poszczególnych usług i sam zdecydujesz co jest ci potrzebne. Na adnotacje nie zwracaj uwagi bo to ja pisałem ,żeby się nie pomylić jeżeli coś skopie.
http://download.yousendit.com/ADA99B1C34836318
Ale przynajmniej działało, a teraz już nie chce a błąd dalej się wyświetla tylko inny:(
