Renegade Napisano Czerwiec 23, 2007 Zgłoszenie Share Napisano Czerwiec 23, 2007 Na FC7 zainstalowałem binda, próbowałem odpalić named i wywala mi: # /etc/init.d/named start Uruchamianie named: Błąd w konfiguracji named: zone localdomain/IN: loading from master file localdomain.zone failed: file not found _default/localdomain/IN: file not found zone localhost/IN: loading from master file localhost.zone failed: file not foun d _default/localhost/IN: file not found zone 0.0.127.in-addr.arpa/IN: loading from master file named.local failed: file not found _default/0.0.127.in-addr.arpa/IN: file not found zone 0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.ip6.arpa/IN: loading from master file named.ip6.local failed: file not found _default/0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.ip6.arpa/ IN: file not found zone 255.in-addr.arpa/IN: loading from master file named.broadcast failed: file not found _default/255.in-addr.arpa/IN: file not found zone 0.in-addr.arpa/IN: loading from master file named.zero failed: file not fou nd _default/0.in-addr.arpa/IN: file not found [ZAWIÓDŁ] co jest nie tak, te pliki są w katalogu zdefiniowanym w pliku named.conf ??? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
