Czy Mam Jutro Iść Do Sklepu Po Nowy Dysk?
milosz_bozenski
dzisiaj zaniepokoiła mnie jedna sytuacja. parę razy dysk mi się wyłączył i od razu włączył. postanowiłem zrobić
smartctl --test=LONG /dev/hda
i baaaaaaardzo zaniepokoiło mnie parę lini potem gdy wywołałem
smartctl -a /dev/hda
. oto one:
Error 46 occurred at disk power-on lifetime: 681 hours (28 days + 9 hours)
  When the command that caused the error occurred, the device was active or idle.
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Extended offline    Completed: read failure       90%       681         417244
# 2  Conveyance offline  Completed without error       00%       321         -
# 3  Conveyance offline  Completed without error       00%       769         -
jak nie mam powodów do niepokoju to powiedźcie - nie będę się martwił bezpodstawnie ...
ps. a tu jeszcze gdyby ktoś chciał zobaczyć całość co wypluł smartctl
=== START OF INFORMATION SECTION ===
Model Family:     Western Digital Caviar family
Device Model:     WDC WD200BB-00CLB0
Serial Number:    WD-WMAAR2611449
Firmware Version: 05.04E05
User Capacity:    20,020,396,032 bytes
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   5
ATA Standard is:  Exact ATA specification draft version not indicated
Local Time is:    Fri Aug 24 19:16:21 2007 CEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                       was completed without error.
                                       Auto Offline Data Collection: Enabled.
Self-test execution status:      ( 121) The previous self-test completed having
                                       the read element of the test failed.
Total time to complete Offline
data collection:                 (1584) seconds.
capabilities:                    (0x3b) SMART execute Offline immediate.
                                       Auto Offline data collection on/off support.
                                       Suspend Offline collection upon new
                                       command.
                                       Offline surface scan supported.
                                       Self-test supported.
                                       Conveyance Self-test supported.
                                       No Selective Self-test supported.
SMART capabilities:            (0x0003) Saves SMART data before entering
                                       power-saving mode.
                                       Supports SMART auto save timer.
Error logging capability:        (0x01) Error logging supported.
                                       No General Purpose Logging support.
Short self-test routine
recommended polling time:        (   2) minutes.
Extended self-test routine
recommended polling time:        (  28) minutes.
Conveyance self-test routine
recommended polling time:        (   5) minutes.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
 1 Raw_Read_Error_Rate     0x000b   195   195   051    Pre-fail  Always       -       52
 3 Spin_Up_Time            0x0007   116   088   021    Pre-fail  Always       -       1550
 4 Start_Stop_Count        0x0032   093   093   040    Old_age   Always       -       7062
 5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
 7 Seek_Error_Rate         0x000b   200   200   051    Pre-fail  Always       -       0
 9 Power_On_Hours          0x0032   077   077   000    Old_age   Always       -       17066
10 Spin_Retry_Count        0x0013   100   100   051    Pre-fail  Always       -       0
11 Calibration_Retry_Count 0x0013   100   100   051    Pre-fail  Always       -       0
12 Power_Cycle_Count       0x0032   094   094   000    Old_age   Always       -       6615
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0012   200   200   000    Old_age   Always       -       1
198 Offline_Uncorrectable   0x0012   200   200   000    Old_age   Always       -       1
199 UDMA_CRC_Error_Count    0x000a   200   200   000    Old_age   Always       -       796
200 Multi_Zone_Error_Rate   0x0009   200   200   051    Pre-fail  Offline      -       0
SMART Error Log Version: 1
ATA Error Count: 50 (device log contains only the most recent five errors)
       CR = Command Register [HEX]
       FR = Features Register [HEX]
       SC = Sector Count Register [HEX]
       SN = Sector Number Register [HEX]
       CL = Cylinder Low Register [HEX]
       CH = Cylinder High Register [HEX]
       DH = Device/Head Register [HEX]
       DC = Device Command Register [HEX]
       ER = Error register [HEX]
       ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 50 occurred at disk power-on lifetime: 681 hours (28 days + 9 hours)
 After command completion occurred, registers were:
 ER ST SC SN CL CH DH
 40 51 30 dc 5d 06 e0  Error: UNC 48 sectors at LBA = 0x00065ddc = 417244
 Commands leading to the command that caused the error were:
 CR FR SC SN CL CH DH DC   Powered_Up_Time  Command/Feature_Name
 c8 00 30 d5 5d 06 e0 00      00:22:57.750  READ DMA
 c8 00 38 cd 5d 06 e0 00      00:22:55.150  READ DMA
 c8 00 40 c5 5d 06 e0 00      00:22:52.500  READ DMA
 c8 00 48 bd 5d 06 e0 00      00:22:49.900  READ DMA
 c8 00 50 b5 5d 06 e0 00      00:22:47.400  READ DMA
Error 49 occurred at disk power-on lifetime: 681 hours (28 days + 9 hours)
 40 51 38 dc 5d 06 e0  Error: UNC 56 sectors at LBA = 0x00065ddc = 417244
 c8 00 58 ad 5d 06 e0 00      00:22:44.850  READ DMA
Error 48 occurred at disk power-on lifetime: 681 hours (28 days + 9 hours)
 40 51 40 dc 5d 06 e0  Error: UNC 64 sectors at LBA = 0x00065ddc = 417244
 c8 00 60 a5 5d 06 e0 00      00:22:42.250  READ DMA
Error 47 occurred at disk power-on lifetime: 681 hours (28 days + 9 hours)
 40 51 48 dc 5d 06 e0  Error: UNC 72 sectors at LBA = 0x00065ddc = 417244
 c8 00 68 9d 5d 06 e0 00      00:22:39.400  READ DMA
 40 51 50 dc 5d 06 e0  Error: UNC 80 sectors at LBA = 0x00065ddc = 417244
 c8 00 70 95 5d 06 e0 00      00:22:36.900  READ DMA
  • 2 weeks later...
Co prawda pytanie stare jak swiat, ale ze nie doczekalo sie odpowiedzi...
Tak - to co widzisz w logach to w 100% padaczka. Taki stan moze potrwac kilka dni/tygodni/miesiecy zanim dysk sie kompletnie wysypie (lub zacznie tracic kolejne sektory z czestotliwoscia uniemozliwiajaca normalna prace), w kazdym badz razie ja jak najszybciej przeniosl bym system i dane na nowy (a przynajmniej w 100% sprawny) dysk, a tego uzywal jako skladowiska niewaznych smieci ;)
Pozdro
