Tomcat
matlas
Mam problem z skonfigurowaniem serwera Tomcat.
Na poczatku zainstalowalem:
Installed Packages
tomcat5.i386                             5.5.25-1jpp.1.fc8      installed
tomcat5-common-lib.i386                  5.5.25-1jpp.1.fc8      installed
tomcat5-jasper.i386                      5.5.25-1jpp.1.fc8      installed
tomcat5-jsp-2.0-api.i386                 5.5.25-1jpp.1.fc8      installed
tomcat5-server-lib.i386                  5.5.25-1jpp.1.fc8      installed
tomcat5-servlet-2.4-api.i386             5.5.25-1jpp.1.fc8      installed
tomcat5-webapps.i386
Dodalem tez nastepujace zmienne:
export JAVA_HOME=/opt/jre1.6/bin
export CATALINA_HOME=/usr/share/tomcat5
export ANT_HOME=/usr/share/ant
export PATH=${PATH}:${JAVA_HOME}/bin:${ANT_HOME}/bin:${CATALINA_HOME}/bin
Odpalam przyklad:
http://localhost:8080/jsp-examples/jsp2/el...-arithmetic.jsp
Dotej pory wszystko niby wyglada oki .... ale nie dzialaja zadne przyklady stworozne przezemnie lub nawet jesli zmienie nazwe pliku poprzedniego na:
To strona JSP sie nie uruchamia i wywala nastepujacy blad:
type Exception report
message
description The server encountered an internal error () that prevented it from fulfilling this request.
exception
org.apache.jasper.JasperException: Unable to compile class for JSP:
JSP FileName:null
Java FileName:/usr/share/tomcat5/work/Catalina/localhost/jsp-examples//org/apache/jsp/jsp2/el/basic2_002darithmetic_jsp.java
An error occurred at line: 1 in the generated java file
The type java.lang.Object cannot be resolved. It is indirectly referenced from required .class files
JSP FileName:null
The type java.lang.Throwable cannot be resolved. It is indirectly referenced from required .class files
JSP FileName:null
The type java.lang.Exception cannot be resolved. It is indirectly referenced from required .class files
JSP FileName:null
The type java.lang.String cannot be resolved. It is indirectly referenced from required .class files
JSP FileName:null
The type java.lang.Class cannot be resolved. It is indirectly referenced from required .class files
JSP FileName:null
The type java.io.Serializable cannot be resolved. It is indirectly referenced from required .class files
JSP FileName:null
The type java.io.IOException cannot be resolved. It is indirectly referenced from required .class files
JSP FileName:null
The type java.util.Enumeration cannot be resolved. It is indirectly referenced from required .class files
JSP FileName:null
An error occurred at line: 7 in the generated java file
The hierarchy of the type basic2_002darithmetic_jsp is inconsistent
JSP FileName:null
The type basic2_002darithmetic_jsp must implement the inherited abstract method JspSourceDependent.getDependants()
JSP FileName:null
An error occurred at line: 10 in the generated java file
java.util.List cannot be resolved to a type
JSP FileName:null
An error occurred at line: 12 in the generated java file
Object cannot be resolved to a type
JSP FileName:null
An error occurred at line: 13 in the generated java file
_jspx_dependants cannot be resolved
JSP FileName:null
An error occurred at line: 17 in the generated java file
java.io.IOException cannot be resolved to a type
JSP FileName:null
No exception of type ServletException can be thrown; an exception type must be a subclass of Throwable
JSP FileName:null
An error occurred at line: 25 in the generated java file
JSP FileName:/jsp2/el/basic2-arithmetic.jsp
An error occurred at line: 1 in the jsp file: /jsp2/el/basic2-arithmetic.jsp
The type java.io.Writer cannot be resolved. It is indirectly referenced from required .class files
1: <html><body><pre>
2: <!--
3:  Licensed to the Apache Software Foundation (ASF) under one or more
4:   contributor license agreements.  See the NOTICE file distributed with
The method write(String) is undefined for the type JspWriter
2: <!--
2: <!--
2: <!--
2: <!--
2: <!--
2: <!--
2: <!--
2: <!--
2: <!--
2: <!--
2: <!--
2: <!--
2: <!--
2: <!--
2: <!--
2: <!--
2: <!--
2: <!--
2: <!--
2: <!--
2: <!--
2: <!--
2: <!--
2: <!--
2: <!--
2: <!--
2: <!--
2: <!--
2: <!--
2: <!--
2: <!--
2: <!--
2: <!--
2: <!--
2: <!--
2: <!--
2: <!--
2: <!--
2: <!--
An error occurred at line: 39 in the jsp file: /jsp2/el/basic2-arithmetic.jsp
java.lang.String cannot be resolved to a type
36: 	  </thead>
37: 	  <tr>
38: 	    <td>\${1}</td>
39: 	    <td>${1}</td>
40: 	  </tr>
41: 	  <tr>
42: 	    <td>\${1 + 2}</td>
36: 	  </thead>
37: 	  <tr>
38: 	    <td>\${1}</td>
39: 	    <td>${1}</td>
40: 	  </tr>
41: 	  <tr>
36: 	  </thead>
37: 	  <tr>
38: 	    <td>\${1}</td>
39: 	    <td>${1}</td>
40: 	  </tr>
41: 	  <tr>
36: 	  </thead>
37: 	  <tr>
38: 	    <td>\${1}</td>
39: 	    <td>${1}</td>
40: 	  </tr>
41: 	  <tr>
36: 	  </thead>
37: 	  <tr>
38: 	    <td>\${1}</td>
39: 	    <td>${1}</td>
40: 	  </tr>
41: 	  <tr>
36: 	  </thead>
37: 	  <tr>
38: 	    <td>\${1}</td>
39: 	    <td>${1}</td>
40: 	  </tr>
41: 	  <tr>
36: 	  </thead>
37: 	  <tr>
38: 	    <td>\${1}</td>
39: 	    <td>${1}</td>
40: 	  </tr>
41: 	  <tr>
An error occurred at line: 43 in the jsp file: /jsp2/el/basic2-arithmetic.jsp
40: 	  </tr>
41: 	  <tr>
43: 	    <td>${1 + 2}</td>
44: 	  </tr>
45: 	  <tr>
46: 	    <td>\${1.2 + 2.3}</td>
40: 	  </tr>
41: 	  <tr>
44: 	  </tr>
45: 	  <tr>
40: 	  </tr>
41: 	  <tr>
44: 	  </tr>
45: 	  <tr>
40: 	  </tr>
41: 	  <tr>
44: 	  </tr>
45: 	  <tr>
40: 	  </tr>
41: 	  <tr>
44: 	  </tr>
45: 	  <tr>
40: 	  </tr>
41: 	  <tr>
44: 	  </tr>
45: 	  <tr>
40: 	  </tr>
41: 	  <tr>
44: 	  </tr>
45: 	  <tr>
An error occurred at line: 47 in the jsp file: /jsp2/el/basic2-arithmetic.jsp
44: 	  </tr>
45: 	  <tr>
47: 	    <td>${1.2 + 2.3}</td>
48: 	  </tr>
49: 	  <tr>
50: 	    <td>\${1.2E4 + 1.4}</td>
44: 	  </tr>
45: 	  <tr>
48: 	  </tr>
49: 	  <tr>
44: 	  </tr>
45: 	  <tr>
48: 	  </tr>
49: 	  <tr>
44: 	  </tr>
45: 	  <tr>
48: 	  </tr>
49: 	  <tr>
44: 	  </tr>
45: 	  <tr>
48: 	  </tr>
49: 	  <tr>
44: 	  </tr>
45: 	  <tr>
48: 	  </tr>
49: 	  <tr>
44: 	  </tr>
45: 	  <tr>
48: 	  </tr>
49: 	  <tr>
An error occurred at line: 51 in the jsp file: /jsp2/el/basic2-arithmetic.jsp
48: 	  </tr>
49: 	  <tr>
51: 	    <td>${1.2E4 + 1.4}</td>
52: 	  </tr>
53: 	  <tr>
54: 	    <td>\${-4 - 2}</td>
48: 	  </tr>
49: 	  <tr>
52: 	  </tr>
53: 	  <tr>
48: 	  </tr>
49: 	  <tr>
52: 	  </tr>
53: 	  <tr>
48: 	  </tr>
49: 	  <tr>
52: 	  </tr>
53: 	  <tr>
48: 	  </tr>
49: 	  <tr>
52: 	  </tr>
53: 	  <tr>
48: 	  </tr>
49: 	  <tr>
52: 	  </tr>
53: 	  <tr>
48: 	  </tr>
49: 	  <tr>
52: 	  </tr>
53: 	  <tr>
An error occurred at line: 55 in the jsp file: /jsp2/el/basic2-arithmetic.jsp
52: 	  </tr>
53: 	  <tr>
55: 	    <td>${-4 - 2}</td>
56: 	  </tr>
57: 	  <tr>
58: 	    <td>\${21 * 2}</td>
52: 	  </tr>
53: 	  <tr>
56: 	  </tr>
57: 	  <tr>
52: 	  </tr>
53: 	  <tr>
56: 	  </tr>
57: 	  <tr>
52: 	  </tr>
53: 	  <tr>
56: 	  </tr>
57: 	  <tr>
52: 	  </tr>
53: 	  <tr>
56: 	  </tr>
57: 	  <tr>
52: 	  </tr>
53: 	  <tr>
56: 	  </tr>
57: 	  <tr>
52: 	  </tr>
53: 	  <tr>
56: 	  </tr>
57: 	  <tr>
An error occurred at line: 59 in the jsp file: /jsp2/el/basic2-arithmetic.jsp
56: 	  </tr>
57: 	  <tr>
59: 	    <td>${21 * 2}</td>
60: 	  </tr>
61: 	  <tr>
62: 	    <td>\${3/4}</td>
56: 	  </tr>
57: 	  <tr>
60: 	  </tr>
61: 	  <tr>
56: 	  </tr>
57: 	  <tr>
60: 	  </tr>
61: 	  <tr>
56: 	  </tr>
57: 	  <tr>
60: 	  </tr>
61: 	  <tr>
56: 	  </tr>
57: 	  <tr>
60: 	  </tr>
61: 	  <tr>
56: 	  </tr>
57: 	  <tr>
60: 	  </tr>
61: 	  <tr>
56: 	  </tr>
57: 	  <tr>
60: 	  </tr>
61: 	  <tr>
An error occurred at line: 63 in the jsp file: /jsp2/el/basic2-arithmetic.jsp
60: 	  </tr>
61: 	  <tr>
63: 	    <td>${3/4}</td>
64: 	  </tr>
65: 	  <tr>
66: 	    <td>\${3 div 4}</td>
60: 	  </tr>
61: 	  <tr>
63: 	    <td>${3/4}</td>
64: 	  </tr>
65: 	  <tr>
Stacktrace:
org.apache.jasper.compiler.DefaultErrorHandler.javacError(jasper5-compiler-5.5.25.jar.so)
org.apache.jasper.compiler.ErrorDispatcher.javacError(jasper5-compiler-5.5.25.jar.so)
org.apache.jasper.compiler.JDTCompiler.generateClass(jasper5-compiler-5.5.25.jar.so)
org.apache.jasper.compiler.Compiler.compile(jasper5-compiler-5.5.25.jar.so)
org.apache.jasper.JspCompilationContext.compile(jasper5-compiler-5.5.25.jar.so)
org.apache.jasper.servlet.JspServletWrapper.service(jasper5-compiler-5.5.25.jar.so)
org.apache.jasper.servlet.JspServlet.serviceJspFile(jasper5-compiler-5.5.25.jar.so)
org.apache.jasper.servlet.JspServlet.service(jasper5-compiler-5.5.25.jar.so)
javax.servlet.http.HttpServlet.service(tomcat5-servlet-2.4-api-5.5.25.jar.so)
Nie wiem co nie tak (to poprawke do Javy Suna zastosowalem juz). Moze komus na tym forum udalo sie uruchomic tomcata i dziala mu poprawnie???
