Postfix + Saslauth Nie Dzila.
greyat
Witam
Jako nowy pragne sie przywitac. Mam problem z postfixem, ktorego probuje zmusic do dzialania z sasl.Jest to moj pierwszy serwer pocztowy.
Dla wlasnych potrzeb.
a wiec:
[root@linux sasl2]# ps aux | grep -i sasl
root 20455 0.0 0.1 5312 644 ? Ss 08:48 0:00 /usr/sbin/saslauthd -m /var/run/saslauthd -a pam
root 20456 0.0 0.0 5312 356 ? S 08:48 0:00 /usr/sbin/saslauthd -m /var/run/saslauthd -a pam
root 20457 0.0 0.0 5312 376 ? S 08:48 0:00 /usr/sbin/saslauthd -m /var/run/saslauthd -a pam
root 20458 0.0 0.0 5312 356 ? S 08:48 0:00 /usr/sbin/saslauthd -m /var/run/saslauthd -a pam
root 20459 0.0 0.0 5312 356 ? S 08:48 0:00 /usr/sbin/saslauthd -m /var/run/saslauthd -a pam
root 20673 0.0 0.1 4048 728 pts/0 S+ 10:08 0:00 grep -i sasl
[root@linux sasl2]#
[root@linux sasl2]# { echo "ehlo test"; echo "AUTH PLAIN bmFkYXdjYQBuYWRhd2NhAGRlZg=="; echo "quit"; } | nc localhost 25
220 domenamoja.pl ESMTP Postfix (FC8/GNU)
250-domenamoja.pl
250-PIPELINING
250-SIZE 10240000
250-VRFY
250-ETRN
250-ENHANCEDSTATUSCODES
250-8BITMIME
250 DSN
503 5.5.1 Error: authentication not enabled
221 2.0.0 Bye
dodalem to z lapy, ale chyba nie potrzebnie!
[root@linux sasl2]# cat /etc/postfix/sasl/smtpd.conf
pwcheck_method: saslauthd
bo mam w
[root@linux sasl2]# cat /usr/lib/sasl2/smtpd.conf
#pwcheck_method: auxprop
niby wszystko mam :) ale knie dizla :(
main.cf:
command_directory = /usr/sbin
mail_owner = postfix
mydomain = domenamoja.pl
myhostname = domenamoja.pl
myorigin = /etc/mailname
alias_maps = hash:/etc/aliases
alias_database = hash:/etc/aliases
mydestination = $mydomain,$myhostname, localhost, localhost.localdomain
mynetworks = 127.0.0.0/8 #[10.0.0.0/24] - Twoja siec
inet_interfaces = all
inet_protocols = ipv4
home_mailbox = Maildir/
mail_spool_directory = /home/
smtpd_banner = $myhostname ESMTP $mail_name (FC8/GNU)
mailbox_size_limit = 0
recipient_delimiter = +
relayhost =
#SASL smtpd_sasl_auth_enable = yes
smtpd_sasl2_auth_enable = yes
smtpd_sasl_security_options = noanonymous
broken_sasl_auth_clients = yes
smtpd_sasl_local_domain = $myhostname
smtpd_recipient_restrictions = permit_sasl_authenticated,permit_mynetworks,reject_unauth_destination
jak widac powinno to dzialac a nie dziala :( Macie moze jakies pomysly ?bo moje sie juz wyczerpaly.
Wszystkie pakiety instalowane podczas instalacji systemu. (i wybrane do Postfx + sasl+tls+www).
Niby wszystko powinno dzialac ale nie dziala :(
Jakby sasl dzialal to przeszedlbym do TLS-a a tak to kicha
  • 2 weeks later...
  • 3 weeks later...
a ja mialbym male pytanie. jak moge ustawic dovecota zeby dzialal mi tez pop3 ? bo dovecot otwiera mi tylko port pod imapa
powinno wystarczyć żeby było w configu (najprawdopodobniej /etc/dovecot.conf)
protocols = imap pop3
imap_listen = [::]
pop3_listen = [::]
login = imap
login = pop3
ale z tego co wiem takie linijki są tam domyślnie...
