Dhcpv6 Problem
marcinps
Witam otóż mam taki problem Zainstalowalem na wirtualnych maszynach 2 systemy fedora 8(HostA i HostB). Pociagalem yum-em dhcpv6 na obu systemach, gdyz chce uzyskac na systemie klienckim Host B adres z servera DHCPv6 (Host A).
Ponizej przedstawiam konfiguracje servera DHCPv6 (Hosta A):
Plik: /etc/sysconfig/network-scripts/ifcfg-eth0
# Advanced Micro Devices [AMD] 79c970 [PCnet32 LANCE]
DEVICE=eth0
BOOTPROTO=dhcp
HWADDR=00:0C:29:11:F0:A1
IPV6INIT=yes
IPV6_AUTOCONF=no
ONBOOT=yes
TYPE=Ethernet
IPV6ADDR="2002:1851:c622:1::1/64"
IPV6_ROUTER=yes
Plik: /etc/sysconfig/dhcp6s
# specify the interface for dhcp6s
DHCP6SIF=eth0
# Command line options here
DHCP6SARGS=
Plik: /etc/dhcp6s.conf
interface eth0 {
server-preference 255;
renew-time 60;
rebind-time 90;
prefer-life-time 130;
valid-life-time 200;
allow rapid-commit;
option dns_servers 2002:1851:c622:1::1 example.com;
link AAA {
pool{
range 2002:1851:c622:1::2 to 2002:1851:c622:1::9/64;
prefix 2002:1851:c622:1::/64;
NETWORKING=yes
IPV6FORWARDING=yes
NETWORKING_IPV6=yes
IPV6INIT=yes
HOSTNAME=localhost.localdomain
#service dhcp6s start
#ifconfig -a
[root@localhost ~]# ifconfig -a
eth0 Link encap:Ethernet HWaddr 00:0C:29:11:F0:A1
inet addr:192.168.1.101 Bcast:255.255.255.255 Mask:255.255.255.0
inet6 addr: fe80::20c:29ff:fe11:f0a1/64 Scope:Link
inet6 addr: 2002:1851:c622:1::1/64 Scope:Global //adres przypisany
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:21887 errors:0 dropped:0 overruns:0 frame:0
TX packets:14295 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:30491986 (29.0 MiB) TX bytes:1131377 (1.0 MiB)
Interrupt:18 Base address:0x1080
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:2135 errors:0 dropped:0 overruns:0 frame:0
TX packets:2135 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:2867841 (2.7 MiB) TX bytes:2867841 (2.7 MiB)
sit0 Link encap:IPv6-in-IPv4
Konfiguracja klienta Host B
Plik: /etc/sysconfig/network-scripts/ifcfg-eth1
DEVICE=eth1
ONBOOT=yes
BOOTPROTO=dhcp
HWADDR=00:0c:29:9a:ba:3d
TYPE=Ethernet
USERCTL=no
IPV6INIT=yes
PEERDNS=yes
DHCP6C=yes
Plik: /etc/dhcp6c.conf
interface eth1 {
send rapid-commit;
request domain-name-servers;
# service network restart
# ifconfig -a
eth1 Link encap:Ethernet HWaddr 00:0C:29:9A:BA:3D
inet addr:192.168.1.106 Bcast:255.255.255.255 Mask:255.255.255.0
inet6 addr: fe80::20c:29ff:fe9a:ba3d/64 Scope:Link
RX packets:1197 errors:0 dropped:0 overruns:0 frame:0
TX packets:1095 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:903897 (882.7 KiB) TX bytes:167939 (164.0 KiB)
RX packets:2811 errors:0 dropped:0 overruns:0 frame:0
TX packets:2811 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:3105088 (2.9 MiB) TX bytes:3105088 (2.9 MiB)
Nie dostaje adresu z servera DHCPv6 na kliencie.
Oba systemy sie widza Dochodzi ping6 z obus sytemow.
Co mam zrobic aby to zadziałało???Bardzo prosze o pomoc.
Udało sie :) U mnie problem byl akurat z identyfikatorem DUID, ktory jest w katalogu /etc/var/lib/dhcpv6/ serwera i klienta.
Poprostu wywalilem go w serwerze i kliencie i uruchomilem ponownie serwer DHCPv6.Identyfiaktor wygenerowal sie na nowo i bylo oki. Przy tworzeniu DHCPv6 korzystalem z nast polecen (moze kiedy sie komus to przyda):
yum install dhcpv6
Server:
1)
File : /etc/sysconfig/dhcp6s
DHCP6SIF=eth0
2)
File : /etc/dhcp6s.conf
interface eth0 {
renew-time 60;
rebind-time 90;
allow rapid-commit;
link BBB {
pool{
range 2001:0E30:1402:2::4 to 2001:0E30:1402:2::ffff/64;
prefix 2001:0E30:1402::/48;
3) #service dhcp6s start
Client:
1)
File : /etc/sysconfig/network-scripts/ifcfg-eth0
IPV6INIT=yes
DHCP6C=yes
2)
File : /etc/dhcp6c.conf
interface eth0 {
#information-only;
send rapid-commit;
#request prefix-delegation;
#request temp-address;
address {
2001:0E30:1402:1:9656:3:4:56/64;
3)
Start the server daemon in debug mode in foreground
#dhcp6s –dDf eth0
4)
Restart the network service of client
#service network restart
5)
#ifconfig
Tylko zawsze jak uruchomie wirtualne maszyny to musze te DUID-y kasowac :( No ale jakos zadzialalo.
