mysio Napisano Kwiecień 11, 2008 Zgłoszenie Share Napisano Kwiecień 11, 2008 Witam mam problem staram się zrobić paczkę rtorrenta która by zaczęła obsługiwać xmlrpc-c ale jest problem: Wykonywanie(%prep): /bin/sh -e /var/tmp/rpm-tmp.68774 + umask 022 + cd /pliki-alpha/rpmbuild/BUILD + LANG=C + export LANG + unset DISPLAY + cd /pliki-alpha/rpmbuild/BUILD + rm -rf rtorrent-0.7.8 + /bin/gzip -dc /pliki-alpha/rpmbuild/SOURCES/rtorrent-0.7.8.tar.gz + tar -xf - + STATUS=0 + '[' 0 -ne 0 ']' + cd rtorrent-0.7.8 ++ /usr/bin/id -u + '[' 500 = 0 ']' ++ /usr/bin/id -u + '[' 500 = 0 ']' + /bin/chmod -Rf a+rX,u+w,g-w,o-w . + exit 0 Wykonywanie(%build): /bin/sh -e /var/tmp/rpm-tmp.68774 + umask 022 + cd /pliki-alpha/rpmbuild/BUILD + cd rtorrent-0.7.8 + LANG=C + export LANG + unset DISPLAY ++ echo -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic ++ /bin/sed s/-O2/-Os/ + export 'RPM_OPT_FLAGS=-Os -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic' + RPM_OPT_FLAGS='-Os -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic' + export 'CFLAGS=-Os -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic' + CFLAGS='-Os -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic' + export 'CXXFLAGS=-Os -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic' + CXXFLAGS='-Os -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic' + install -m 644 /pliki-alpha/rpmbuild/SOURCES/rtorrent.rc.example . + CFLAGS='-Os -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic' + export CFLAGS + CXXFLAGS='-Os -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic' + export CXXFLAGS + FFLAGS='-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic' + export FFLAGS ++ find . -name config.guess -o -name config.sub + for i in '$(find . -name config.guess -o -name config.sub)' ++ basename ./config.sub + '[' -f /usr/lib/rpm/redhat/config.sub ']' + /bin/rm -f ./config.sub ++ basename ./config.sub + /bin/cp -fv /usr/lib/rpm/redhat/config.sub ./config.sub `/usr/lib/rpm/redhat/config.sub' -> `./config.sub' + for i in '$(find . -name config.guess -o -name config.sub)' ++ basename ./config.guess + '[' -f /usr/lib/rpm/redhat/config.guess ']' + /bin/rm -f ./config.guess ++ basename ./config.guess + /bin/cp -fv /usr/lib/rpm/redhat/config.guess ./config.guess `/usr/lib/rpm/redhat/config.guess' -> `./config.guess' + ./configure --build=x86_64-redhat-linux-gnu --host=x86_64-redhat-linux-gnu --target=x86_64-redhat-linux-gnu --program-prefix= --prefix=/usr --exec-prefix=/usr --bindir=/usr/bin --sbindir=/usr/sbin --sysconfdir=/etc --datadir=/usr/share --includedir=/usr/include --libdir=/usr/lib64 --libexecdir=/usr/libexec --localstatedir=/var --sharedstatedir=/usr/com --mandir=/usr/share/man --infodir=/usr/share/info --with-xmlrpc-c checking for a BSD-compatible install... /usr/bin/install -c checking whether build environment is sane... yes checking for gawk... gawk checking whether make sets $(MAKE)... yes checking for user-defined CXXFLAGS... user-defined "-Os -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic" checking for x86_64-redhat-linux-gnu-g++... no checking for x86_64-redhat-linux-gnu-c++... no checking for x86_64-redhat-linux-gnu-gpp... no checking for x86_64-redhat-linux-gnu-aCC... no checking for x86_64-redhat-linux-gnu-CC... no checking for x86_64-redhat-linux-gnu-cxx... no checking for x86_64-redhat-linux-gnu-cc++... no checking for x86_64-redhat-linux-gnu-cl.exe... no checking for x86_64-redhat-linux-gnu-FCC... no checking for x86_64-redhat-linux-gnu-KCC... no checking for x86_64-redhat-linux-gnu-RCC... no checking for x86_64-redhat-linux-gnu-xlC_r... no checking for x86_64-redhat-linux-gnu-xlC... no checking for g++... g++ checking for C++ compiler default output file name... a.out checking whether the C++ compiler works... yes checking whether we are cross compiling... no checking for suffix of executables... checking for suffix of object files... o checking whether we are using the GNU C++ compiler... yes checking whether g++ accepts -g... yes checking for style of include used by make... GNU checking dependency style of g++... gcc3 checking build system type... x86_64-redhat-linux-gnu checking host system type... x86_64-redhat-linux-gnu checking for x86_64-redhat-linux-gnu-gcc... no checking for gcc... gcc checking whether we are using the GNU C compiler... yes checking whether gcc accepts -g... yes checking for gcc option to accept ISO C89... none needed checking dependency style of gcc... gcc3 checking for a sed that does not truncate output... /bin/sed checking for grep that handles long lines and -e... /bin/grep checking for egrep... /bin/grep -E checking for ld used by gcc... /usr/bin/ld checking if the linker (/usr/bin/ld) is GNU ld... yes checking for /usr/bin/ld option to reload object files... -r checking for BSD-compatible nm... /usr/bin/nm -B checking whether ln -s works... yes checking how to recognise dependent libraries... pass_all checking how to run the C preprocessor... gcc -E checking for ANSI C header files... yes checking for sys/types.h... yes checking for sys/stat.h... yes checking for stdlib.h... yes checking for string.h... yes checking for memory.h... yes checking for strings.h... yes checking for inttypes.h... yes checking for stdint.h... yes checking for unistd.h... yes checking dlfcn.h usability... yes checking dlfcn.h presence... yes checking for dlfcn.h... yes checking how to run the C++ preprocessor... g++ -E checking for x86_64-redhat-linux-gnu-g77... no checking for x86_64-redhat-linux-gnu-f77... no checking for x86_64-redhat-linux-gnu-xlf... no checking for x86_64-redhat-linux-gnu-frt... no checking for x86_64-redhat-linux-gnu-pgf77... no checking for x86_64-redhat-linux-gnu-cf77... no checking for x86_64-redhat-linux-gnu-fort77... no checking for x86_64-redhat-linux-gnu-fl32... no checking for x86_64-redhat-linux-gnu-af77... no checking for x86_64-redhat-linux-gnu-f90... no checking for x86_64-redhat-linux-gnu-xlf90... no checking for x86_64-redhat-linux-gnu-pgf90... no checking for x86_64-redhat-linux-gnu-pghpf... no checking for x86_64-redhat-linux-gnu-epcf90... no checking for x86_64-redhat-linux-gnu-gfortran... no checking for x86_64-redhat-linux-gnu-g95... no checking for x86_64-redhat-linux-gnu-f95... no checking for x86_64-redhat-linux-gnu-fort... no checking for x86_64-redhat-linux-gnu-xlf95... no checking for x86_64-redhat-linux-gnu-ifort... no checking for x86_64-redhat-linux-gnu-ifc... no checking for x86_64-redhat-linux-gnu-efc... no checking for x86_64-redhat-linux-gnu-pgf95... no checking for x86_64-redhat-linux-gnu-lf95... no checking for x86_64-redhat-linux-gnu-ftn... no checking for g77... no checking for f77... no checking for xlf... no checking for frt... no checking for pgf77... no checking for cf77... no checking for fort77... no checking for fl32... no checking for af77... no checking for f90... no checking for xlf90... no checking for pgf90... no checking for pghpf... no checking for epcf90... no checking for gfortran... no checking for g95... no checking for f95... no checking for fort... no checking for xlf95... no checking for ifort... no checking for ifc... no checking for efc... no checking for pgf95... no checking for lf95... no checking for ftn... no checking whether we are using the GNU Fortran 77 compiler... no checking whether accepts -g... no checking the maximum length of command line arguments... 32768 checking command to parse /usr/bin/nm -B output from gcc object... ok checking for objdir... .libs checking for x86_64-redhat-linux-gnu-ar... no checking for ar... ar checking for x86_64-redhat-linux-gnu-ranlib... no checking for ranlib... ranlib checking for x86_64-redhat-linux-gnu-strip... no checking for strip... strip checking if gcc supports -fno-rtti -fno-exceptions... no checking for gcc option to produce PIC... -fPIC checking if gcc PIC flag -fPIC works... yes checking if gcc static flag -static works... yes checking if gcc supports -c -o file.o... yes checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes checking whether -lc should be explicitly linked in... no checking dynamic linker characteristics... GNU/Linux ld.so checking how to hardcode library paths into programs... immediate checking whether stripping libraries is possible... yes checking if libtool supports shared libraries... yes checking whether to build shared libraries... yes checking whether to build static libraries... yes configure: creating libtool appending configuration tag "CXX" to libtool checking for ld used by g++... /usr/bin/ld -m elf_x86_64 checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld... yes checking whether the g++ linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes checking for g++ option to produce PIC... -fPIC checking if g++ PIC flag -fPIC works... yes checking if g++ static flag -static works... yes checking if g++ supports -c -o file.o... yes checking whether the g++ linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes checking dynamic linker characteristics... GNU/Linux ld.so checking how to hardcode library paths into programs... immediate appending configuration tag "F77" to libtool checking for special C compiler options needed for large files... no checking for _FILE_OFFSET_BITS value needed for large files... no checking for _LARGE_FILES value needed for large files... no checking for execinfo.h... yes checking for proper overloaded template function disambiguation... yes checking for library containing add_wch... -lncursesw checking sys/vfs.h usability... yes checking sys/vfs.h presence... yes checking for sys/vfs.h... yes checking sys/statvfs.h usability... yes checking sys/statvfs.h presence... yes checking for sys/statvfs.h... yes checking sys/statfs.h usability... yes checking sys/statfs.h presence... yes checking for sys/statfs.h... yes checking for statvfs... ok checking for x86_64-redhat-linux-gnu-pkg-config... no checking for pkg-config... /usr/bin/pkg-config checking pkg-config is at least version 0.9.0... yes checking for STUFF... yes checking for XMLRPC-C... Package server-util was not found in the pkg-config search path. Perhaps you should add the directory containing `server-util.pc' to the PKG_CONFIG_PATH environment variable No package 'server-util' found Package xmlrpc_server_util was not found in the pkg-config search path. Perhaps you should add the directory containing `xmlrpc_server_util.pc' to the PKG_CONFIG_PATH environment variable No package 'xmlrpc_server_util' found failed configure: error: Could not compile XMLRPC-C test. błąd: Błędny stan wyjścia z /var/tmp/rpm-tmp.68774 (%build) Błędy budowania RPM-a: Błędny stan wyjścia z /var/tmp/rpm-tmp.68774 (%build) /var/tmp/rpm-tmp.68774 #!/bin/sh RPM_SOURCE_DIR="/pliki-alpha/rpmbuild/SOURCES" RPM_BUILD_DIR="/pliki-alpha/rpmbuild/BUILD" RPM_OPT_FLAGS="-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic" RPM_ARCH="x86_64" RPM_OS="linux" export RPM_SOURCE_DIR RPM_BUILD_DIR RPM_OPT_FLAGS RPM_ARCH RPM_OS RPM_DOC_DIR="/usr/share/doc" export RPM_DOC_DIR RPM_PACKAGE_NAME="rtorrent" RPM_PACKAGE_VERSION="0.7.8" RPM_PACKAGE_RELEASE="1.fc8" export RPM_PACKAGE_NAME RPM_PACKAGE_VERSION RPM_PACKAGE_RELEASE RPM_BUILD_ROOT="/var/tmp/rtorrent-0.7.8-1.fc8-root-mysio" export RPM_BUILD_ROOT set -x umask 022 cd /pliki-alpha/rpmbuild/BUILD cd rtorrent-0.7.8 LANG=C export LANG unset DISPLAY # work around a bug thats triggered by gcc 4.1 export RPM_OPT_FLAGS=`echo $RPM_OPT_FLAGS | /bin/sed s/-O2/-Os/` export CFLAGS=$RPM_OPT_FLAGS export CXXFLAGS=$RPM_OPT_FLAGS install -m 644 /pliki-alpha/rpmbuild/SOURCES/rtorrent.rc.example . CFLAGS="${CFLAGS:--O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic}" ; export CFLAGS ; CXXFLAGS="${CXXFLAGS:--O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic}" ; export CXXFLAGS ; FFLAGS="${FFLAGS:--O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic}" ; export FFLAGS ; for i in $(find . -name config.guess -o -name config.sub) ; do [ -f /usr/lib/rpm/redhat/$(basename $i) ] && /bin/rm -f $i && /bin/cp -fv /usr/lib/rpm/redhat/$(basename $i) $i ; done ; ./configure --build=x86_64-redhat-linux-gnu --host=x86_64-redhat-linux-gnu \ --target=x86_64-redhat-linux-gnu \ --program-prefix= \ --prefix=/usr \ --exec-prefix=/usr \ --bindir=/usr/bin \ --sbindir=/usr/sbin \ --sysconfdir=/etc \ --datadir=/usr/share \ --includedir=/usr/include \ --libdir=/usr/lib64 \ --libexecdir=/usr/libexec \ --localstatedir=/var \ --sharedstatedir=/usr/com \ --mandir=/usr/share/man \ --infodir=/usr/share/info \ --with-xmlrpc-c make -j3 [mysio@fedora-home SPECS]$ pkg-config --list-all |grep xmlrpc xmlrpc_client xmlrpc_client - XMLRPC client library xmlrpc++ xmlrpc++ - XMLRPC C++ Base library xmlrpc_util xmlrpc_util - XMLRPC utility library xmlrpc_server_cgi xmlrpc_server_cgi - XMLRPC CGI-Server library xmlrpc_server_abyss++ xmlrpc_server_abyss++ - XMLRPC C++ Abyss-Server library xmlrpc xmlrpc - XMLRPC base library xmlrpc_server xmlrpc_server - XMLRPC Server library xmlrpc_client++ xmlrpc_client++ - XMLRPC C++ Client library xmlrpc_server_abyss xmlrpc_server_abyss - XMLRPC Server Abyss library xmlrpc_abyss xmlrpc_abyss - XMLRPC Abyss base library xmlrpc_cpp xmlrpc_cpp - XMLRPC CPP library xmlrpc_server++ xmlrpc_server++ - XMLRPC C++ Server library [mysio@fedora-home SPECS]$ rpm -qa xmlrpc* xmlrpc-2.0.1-3jpp.2 xmlrpc3-server-devel-3.0-1jpp.4.fc8 xmlrpc-c-devel-1.06.18-1.fc8 xmlrpc3-server-3.0-1jpp.4.fc8 xmlrpc-c-apps-1.06.18-1.fc8 xmlrpc-c-1.06.18-1.fc8 xmlrpc3-common-3.0-1jpp.4.fc8 xmlrpc3-client-3.0-1jpp.4.fc8 Ma ktoś jakiś pomysł :?: Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
