marcinps Napisano Kwiecień 17, 2008 Zgłoszenie Share Napisano Kwiecień 17, 2008 Otóż tak mamy na wirtualnych maszynach 3 fedory 8 z adresami: host1 fe80::20c:29ff:fe34:14f3/64 (na ktorym jest serwer DNS) host2 fe80::20c:29ff:fe76:b0fc/64 host3 fe80::20c:29ff:fe92:7d93/64 Zaktualizowalem binda oczywiscie. Oto moja konfiguracja DNS na hoscie1: 1)resolv.conf ; generated by /sbin/dhclient-script search moja nameserver 212.182.56.184 nameserver 192.168.1.1 nameserver fe80::20c:29ff:fe34:14f3 //dodalem recznie ten wpis 2)named.conf options { directory "/var/named"; listen-on-v6 { any; }; listen-on-v6 port 53 { ::1; }; }; zone "." IN { type hint; file "named.ca"; }; // IPv6 zone files zone "dnstest.com" IN { type master; file "ipv6rules.com"; allow-update { none; }; }; zone "0.0.0.0.0.0.0.0.0.0.0.0.0.8.e.f.ip6.int" IN { //wydaje mi sie ze odwrocony adres IPv6 powinien wygladac tak (chodzi tu chyba o prefiks sieci //fe80::/64) type master; file "revipv6rules.com.arpa"; allow-update { none; }; }; 3)/var/named/ipv6rules.com $ttl 38400 dnstest.com. IN SOA jedy.dnstest.com. root.dnstest.com. ( 1114694017 10800 3600 604800 38400 ) dnstest.com. IN NS jedy.dnstest.com. jedy.dnstest.com. IN AAAA fe80::20c:29ff:fe34:14f3 hostServer1 IN AAAA fe80::20c:29ff:fe76:b0fc hostClient2 IN AAAA fe80::20c:29ff:fe92:7d93 4)/var/named/revipv6rules.com.arpa $ttl 38400 0.0.0.0.0.0.0.0.0.0.0.0.0.8.e.f.ip6.int. IN SOA jedy.dnstest.com . root.dnstest.com. ( 1114694101 10800 3600 604800 38400 ) 0.0.0.0.0.0.0.0.0.0.0.0.0.8.e.f.ip6.int. IN NS jedy.dnstest.com. 3.f.4.1.4.3.e.f.f.f.9.2.c.0.2.0.0.0.0.0.0.0.0.0.0.0.0.0.0.8.e.f.ip6.int. IN PTR jedy.dnstest.com. c.f.0.b.6.7.e.f.f.f.9.2.c.0.2.0.0.0.0.0.0.0.0.0.0.0.0.0.0.8.e.f.ip6.int. IN PTR hostServer1. 3.9.d.7.2.9.e.f.f.f.9.2.c.0.2.0.0.0.0.0.0.0.0.0.0.0.0.0.0.8.e.f.ip6.int. IN PTR hostClient2. 5) [root@localhost ~]# /etc/init.d/named start Uruchamianie named: Error in named configuration: zone dnstest.com/IN: loading from master file ipv6rules.com failed: file not found _default/dnstest.com/IN: file not found zone 0.0.0.0.0.0.0.0.0.0.0.0.0.8.e.f.ip6.int/IN: loading from master file revipv6rules.com.arpa failed: file not found _default/0.0.0.0.0.0.0.0.0.0.0.0.0.8.e.f.ip6.int/IN: file not found //pokazuje ze plikow nie ma a sa w tym takalagu /var/named [ZAWIÓDŁ] 6)[root@localhost ~]# netstat -an | grep ':53' udp 0 0 0.0.0.0:5353 0.0.0.0:* [root@localhost ~]# 7)[root@localhost ~]# named -u named -g 17-Apr-2008 21:02:45.893 starting BIND 9.5.0b1 -u named -g 17-Apr-2008 21:02:45.893 found 1 CPU, using 1 worker thread 17-Apr-2008 21:02:45.898 loading configuration from '/etc/named.conf' 17-Apr-2008 21:02:45.899 listening on IPv6 interfaces, port 53 17-Apr-2008 21:02:45.902 listening on IPv6 interface lo, ::1#53 17-Apr-2008 21:02:45.902 binding TCP socket: address in use 17-Apr-2008 21:02:45.903 listening on IPv4 interface lo, 127.0.0.1#53 17-Apr-2008 21:02:45.904 listening on IPv4 interface eth2, 192.168.1.113#53 17-Apr-2008 21:02:45.911 automatic empty zone: 127.IN-ADDR.ARPA 17-Apr-2008 21:02:45.915 automatic empty zone: 254.169.IN-ADDR.ARPA 17-Apr-2008 21:02:45.915 automatic empty zone: 2.0.192.IN-ADDR.ARPA 17-Apr-2008 21:02:45.915 automatic empty zone: 255.255.255.255.IN-ADDR.ARPA 17-Apr-2008 21:02:45.915 automatic empty zone: 0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.IP6.ARPA 17-Apr-2008 21:02:45.915 automatic empty zone: 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.IP6.ARPA 17-Apr-2008 21:02:45.915 automatic empty zone: D.F.IP6.ARPA 17-Apr-2008 21:02:45.916 automatic empty zone: 8.E.F.IP6.ARPA 17-Apr-2008 21:02:45.916 automatic empty zone: 9.E.F.IP6.ARPA 17-Apr-2008 21:02:45.916 automatic empty zone: A.E.F.IP6.ARPA 17-Apr-2008 21:02:45.916 automatic empty zone: B.E.F.IP6.ARPA 17-Apr-2008 21:02:45.920 command channel listening on 127.0.0.1#953 17-Apr-2008 21:02:45.921 command channel listening on ::1#953 17-Apr-2008 21:02:45.921 ignoring config file logging statement due to -g option 17-Apr-2008 21:02:45.924 zone dnstest.com/IN: loaded serial 1114694017 17-Apr-2008 21:02:45.924 dns_rdata_fromtext: revipv6rules.com.arpa:2: near eol: unexpected end of input 17-Apr-2008 21:02:45.924 zone 0.0.0.0.0.0.0.0.0.0.0.0.0.8.e.f.ip6.int/IN: loading from master file revipv6rules.com.arpa failed: unexpected end of input 17-Apr-2008 21:02:45.927 running 8)[root@localhost ~]# nslookup > jedy.dnstest.com Server: 212.182.56.184 Address: 212.182.56.184#53 ** server can't find jedy.dnstest.com: NXDOMAIN Co jest nie tak z tym moim DNS???nie znam sie na (_linuxa_ → Linuksa) ORT wiec moglem zrobic cos nie tak Bardzo prosze o pomoc, bo chce stworzyc DNS oparty o IPv6 w celach testowych. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
