R_Przemek Napisano Maj 3, 2008 Zgłoszenie Share Napisano Maj 3, 2008 Mam problem z instalacją rrdtool dla lstat-a wie ktoś o co może w tym chodzić : tok postępowania jest następujący: wget http://mirrors.evolva.ro/util/rrdtool/rrdtool-1.0.x/rrdtool-1.0.48.tar.gz tar xvzf rrdtool-1.0.48.tar.gz cd rrdtool-1.0.48 ./configure a efektem jest: [root@localhost rrdtool-1.0.48]# ./configure checking build system type... i686-pc-linux-gnu checking host system type... i686-pc-linux-gnu checking target system type... i686-pc-linux-gnu checking for a BSD-compatible install... /usr/bin/install -c checking whether build environment is sane... yes checking for gawk... gawk checking whether make sets $(MAKE)... yes checking for style of include used by make... GNU checking for gcc... no checking for cc... no checking for cc... no checking for cl... no configure: error: no acceptable C compiler found in $PATH See `config.log' for more details. [root@localhost rrdtool-1.0.48]# Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
lszk Napisano Maj 3, 2008 Zgłoszenie Share Napisano Maj 3, 2008 Nie kompiluj czegoś, co masz dostępne w repach. [lszk@fedora ~]$ yum search rrdtool cacti.noarch : An rrd based graphing tool rrdtool-devel.i386 : RRDtool libraries and header files rrdtool-python.i386 : Python RRDtool bindings rrdtool-ruby.i386 : Ruby RRDtool bindings mailgraph.noarch : A RRDtool frontend for Mail statistics rrdtool-python.i386 : Python RRDtool bindings ganglia-gmetad.i386 : Ganglia Metadata collection daemon munin.noarch : Network-wide graphing framework (grapher/gatherer) rrdtool-doc.i386 : RRDtool documentation perl-RRD-Simple.noarch : Simple interface to create and store data in RRD files rrdtool.i386 : Round Robin Database Tool to store and display time-series data munin-node.noarch : Network-wide graphing framework (node) queuegraph.noarch : A RRDtool frontend for Mail statistics rrdtool-php.i386 : PHP RRDtool bindings ganglia-gmetad.i386 : Ganglia Metadata collection daemon cacti.noarch : An rrd based graphing tool queuegraph.noarch : A RRDtool frontend for Mail statistics rrdtool-perl.i386 : Perl RRDtool bindings rrdtool-doc.i386 : RRDtool documentation munin.noarch : Network-wide graphing framework (grapher/gatherer) rrdtool.i386 : Round Robin Database Tool to store and display time-series data rrdtool-devel.i386 : RRDtool libraries and header files rrdtool-perl.i386 : Perl RRDtool bindings mailgraph-selinux.noarch : A RRDtool frontend for Mail statistics rrdtool-php.i386 : PHP RRDtool bindings mailgraph.noarch : A RRDtool frontend for Mail statistics munin-node.noarch : Network-wide graphing framework (node) queuegraph-selinux.noarch : A RRDtool frontend for Mail statistics rrdtool-tcl.i386 : Tcl RRDtool bindings rrdtool-tcl.i386 : Tcl RRDtool bindings Tylko namieszasz, a i tak pewnie będziesz miał problemy, jak będziesz musiał ręcznie ścieżki podawać. ______ Do tego nie kompiluje się softu na roocie. A co do checking for gcc... no checking for cc... no Nie masz poprostu kompilatora gcc. Musisz go doinstalować. Zresztą nawet pisze: no acceptable C compiler found in $PATH Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
