vlogic Napisano Maj 9, 2008 Zgłoszenie Share Napisano Maj 9, 2008 Mam problem z haldaemon'em. Przy starcie systemu nie uruchamia się (bez komunikatu błędu). Z resztą z konsoli też nie mogę go uruchomić. Mam laptopa DELL Latitude D600 i wersję hal-0.5.10-1.fc8.2 Jestem niebardzo doświadczony nie wiem gdzie szukać logów hala? Podejrzewam że może to być powiązane z innym moim problemem - z dbus komenda sytem-config-network daje Component: system-config-network Version: 1.5.5 Summary: TB90e244fb bus.py:121:__new__:DBusException: org.freedesktop.DBus.Error.FileNotFound: Failed to connect to socket /var/run/dbus/system_bus_socket: Nie ma takiego pliku ani katalogu Traceback (most recent call last): File "/usr/sbin/system-config-network-gui", line 166, in runit window = mainDialog() File "/usr/share/system-config-network/netconfpkg/gui/maindialog.py", line 275, in __init__ self.load() File "/usr/share/system-config-network/netconfpkg/gui/maindialog.py", line 299, in load self.loadDevices() File "/usr/share/system-config-network/netconfpkg/gui/maindialog.py", line 307, in loadDevices devicelist = getDeviceList() File "/usr/share/system-config-network/netconfpkg/NCDeviceList.py", line 318, in getDeviceList __DVList.load() File "/usr/share/system-config-network/netconfpkg/NCDeviceList.py", line 78, in load hwlist = NCHardwareList.getHardwareList() File "/usr/share/system-config-network/netconfpkg/NCHardwareList.py", line 759, in getHardwareList __HWList.load() File "/usr/share/system-config-network/netconfpkg/NCHardwareList.py", line 603, in load self.updateFromSystem() File "/usr/share/system-config-network/netconfpkg/NCHardwareList.py", line 483, in updateFromSystem self.updateFromHal(hdellist) File "/usr/share/system-config-network/netconfpkg/NCHardwareList.py", line 447, in updateFromHal hal = NCBackendHal.NCBackendHal() File "/usr/share/system-config-network/netconfpkg/NCBackendHal.py", line 30, in __init__ self._dbusBus = dbus.SystemBus() File "/usr/lib/python2.5/site-packages/dbus/_dbus.py", line 201, in __new__ private=private) File "/usr/lib/python2.5/site-packages/dbus/_dbus.py", line 107, in __new__ bus = BusConnection.__new__(subclass, bus_type, mainloop=mainloop) File "/usr/lib/python2.5/site-packages/dbus/bus.py", line 121, in __new__ bus = cls._new_for_bus(address_or_type, mainloop=mainloop) DBusException: org.freedesktop.DBus.Error.FileNotFound: Failed to connect to socket /var/run/dbus/system_bus_socket: Nie ma takiego pliku ani katalogu Local variables in innermost frame: mainloop: None address_or_type: 1 cls: <class 'dbus._dbus.SystemBus'> Podejrzewam że dlatego hal nie wstaje. Na potwierdzenie hald --daemon=no --verbose=yes 20:42:48.237 [I] hald.c:634: hal 0.5.10 20:42:48.237 [I] hald.c:699: Will not daemonize 20:42:48.238 [I] hald_dbus.c:5284: local server is listening at unix:abstract=/var/run/hald/dbus-PM1swejDeb,guid=98195fb54b3523453704320048249b28 20:42:48.238 [E] hald_dbus.c:5650: dbus_bus_get(): Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory Co mam zrobić ?? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
arni Napisano Maj 10, 2008 Zgłoszenie Share Napisano Maj 10, 2008 Wpisz w terminalu: su - ps ax |grep -i dbus Jak dbus nie będzie uruchomiony to wpisz: dbus-daemon --system Opis dbus uzyskasz jak wpiszesz: man dbus-daemon Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
vlogic Napisano Maj 11, 2008 Autor Zgłoszenie Share Napisano Maj 11, 2008 Wpisz w terminalu: su - ps ax |grep -i dbus Jak dbus nie będzie uruchomiony to wpisz: dbus-daemon --system Opis dbus uzyskasz jak wpiszesz: man dbus-daemon Dbus mi zupełnie zdechł przewertowałem kilkanaście forów i nie znalazlem solucji. Mialem świeży system więc przeinstalowałem i wszystko jest już w porządku. Dzięki za pomoc. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
