KoN Napisano Czerwiec 11, 2008 Zgłoszenie Share Napisano Czerwiec 11, 2008 Witam Mam pytanko odnosnie spamu. Chodzi o to jak sprawic zeby przy zakwalifikowaniu wiadomosci jako "spam" spamassassin umieszczal jakis wpis w logach. Potrzebne mi to do dalszej analizy ile spamu doszlo. na serwerze : sendmail, dovecot, spamassassin na ta chwile jak puszczam wiadomosc testowa z tematem "spam" system zachowuje sie nastepująco: log z maillog: Jun 11 10:10:17 delta dovecot: imap-login: Login: user=<konrad>, method=PLAIN, rip=::ffff:127.0.0.1, lip=::ffff:127.0.0.1, secured Jun 11 10:10:17 delta dovecot: IMAP(konrad): Disconnected: Logged out Jun 11 10:10:22 delta dovecot: imap-login: Login: user=<konrad>, method=PLAIN, rip=::ffff:127.0.0.1, lip=::ffff:127.0.0.1, secured Jun 11 10:10:22 delta dovecot: IMAP(konrad): Disconnected: Logged out Jun 11 10:10:23 delta dovecot: imap-login: Login: user=<konrad>, method=PLAIN, rip=::ffff:127.0.0.1, lip=::ffff:127.0.0.1, secured Jun 11 10:10:23 delta sendmail[16301]: m5B8AN7O016301: Authentication-Warning: delta.domenka: apache set sender to [email protected] using -f Jun 11 10:10:23 delta sendmail[16301]: m5B8AN7O016301: [email protected], size=3003, class=0, nrcpts=1, msgid=<[email protected]>, relay=apache@localhost Jun 11 10:10:23 delta sendmail[16302]: m5B8ANnd016302: from=<[email protected]>, size=3295, class=0, nrcpts=1, msgid=<[email protected]>, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1] Jun 11 10:10:23 delta sendmail[16301]: m5B8AN7O016301: [email protected], [email protected] (501/501), delay=00:00:00, xdelay=00:00:00, mailer=relay, pri=33003, relay=[127.0.0.1] [127.0.0.1], dsn=2.0.0, stat=Sent (m5B8ANnd016302 Message accepted for delivery) Jun 11 10:10:24 delta dovecot: IMAP(konrad): Disconnected: Logged out Jun 11 10:10:49 delta sendmail[16303]: m5B8ANnd016302: to=<[email protected]>, ctladdr=<[email protected]> (501/501), delay=00:00:26, xdelay=00:00:25, mailer=local, pri=63524, dsn=2.0.0, stat=Sent zrodlo wiadomosci oznaczonej jako spam: Return-Path: <[email protected]> X-Spam-Flag: YES X-Spam-Checker-Version: SpamAssassin 3.2.4 (2008-01-01) on delta.domenka X-Spam-Level: ***** X-Spam-Status: Yes, score=5.7 required=5.0 tests=ALL_TRUSTED,NO_DNS_FOR_FROM, PYZOR_CHECK,TVD_SPACE_RATIO autolearn=no version=3.2.4 X-Spam-Pyzor: Reported 10 times. X-Spam-Report: * 1.4 NO_DNS_FOR_FROM DNS: Envelope sender has no MX or A DNS records * -1.4 ALL_TRUSTED Passed through trusted hosts only via SMTP * 2.9 TVD_SPACE_RATIO BODY: TVD_SPACE_RATIO * 2.8 PYZOR_CHECK Listed in Pyzor (http://pyzor.sf.net/) Received: from delta.domenka (localhost.localdomain [127.0.0.1]) by delta.domenka (8.14.1/8.14.1) with ESMTP id m5B7kn2H015987 for <[email protected]>; Wed, 11 Jun 2008 09:46:49 +0200 Received: (from apache@localhost) by delta.domenka (8.14.1/8.14.1/Submit) id m5B7knFa015986 for [email protected]; Wed, 11 Jun 2008 09:46:49 +0200 X-Authentication-Warning: delta.domenka: apache set sender to [email protected] using -f Received: from admin1.domenka (admin1.domenka [192.168.2.20]) by poczta2.delta.domenka (Horde Framework) with HTTP; Wed, 11 Jun 2008 09:46:49 +0200 Message-ID: <[email protected]> Date: Wed, 11 Jun 2008 09:46:49 +0200 From: konrad <[email protected]> To: [email protected] Subject: **SPAM** spam MIME-Version: 1.0 Content-Type: text/plain; charset=ISO-8859-2; DelSp="Yes"; format="flowed" Content-Disposition: inline Content-Transfer-Encoding: 7bit User-Agent: Dynamic Internet Messaging Program (DIMP) H3 (1.0) X-Spam-Prev-Subject: spam spam ---------------------------------------------------------------- This message was sent using IMP, the Internet Messaging Program. jedyna informacja od spamassasina w logach to: log messages Jun 11 10:09:05 delta spamd[16264]: spamd: server started on port 783/tcp (running version 3.2.4) Jun 11 10:09:05 delta spamd[16264]: spamd: server pid: 16264 Jun 11 10:09:05 delta spamd[16264]: spamd: server successfully spawned child process, pid 16272 Jun 11 10:09:05 delta spamd[16264]: spamd: server successfully spawned child process, pid 16273 Jun 11 10:09:05 delta spamd[16264]: prefork: child states: IS Jun 11 10:09:05 delta spamd[16264]: prefork: child states: II czyli info tylko o starcie spamassasina. Gdzies na necie znalazlem gotowe skrypty do analizy logow wzgledem spamu, ale skrypty te u mnie nie dzialaja bo nie ma zadnej informacji ktora wiadomosc przeszla jako dobra a ktora przeszla jako spam. Pozdrawiam Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
