Problem Ze Startem Fedory 9 64 Bit Na 8 Gb Ram
danziger
Witam,
temat był w sekcji "sprzęt" ale teraz to chyba już problem z uruchomianiem systemu więc go będę dalej ciagnął tutaj.
ma jednej kości ram 2GB system ładnie się instaluje, jakieś tam błędy wysupuje ale uruchamia się i to jest ok.
Jul 27 23:46:57 localhost kernel: imklog 3.16.1, log source = /proc/kmsg started.
Jul 27 23:46:57 localhost kernel: Initializing cgroup subsys cpuset
Jul 27 23:46:57 localhost kernel: Linux version 2.6.25-14.fc9.x86_64 (mockbuild@) (gcc version 4.3.0 20080428 (Red Hat 4.3.0-8) (GCC) ) #1 SMP Thu May 1 06:06:21 EDT 2008
Jul 27 23:46:57 localhost kernel: Command line: ro root=UUID=84dbcdfe-1da7-4bab-aeb1-fde0a9afc017 rhgb quiet
Jul 27 23:46:57 localhost kernel: BIOS-provided physical RAM map:
Jul 27 23:46:57 localhost kernel:  BIOS-e820: 0000000000000000 - 0000000000096000 (usable)
Jul 27 23:46:57 localhost kernel:  BIOS-e820: 0000000000096000 - 00000000000a0000 (reserved)
Jul 27 23:46:57 localhost kernel:  BIOS-e820: 00000000000e4000 - 0000000000100000 (reserved)
Jul 27 23:46:57 localhost kernel:  BIOS-e820: 0000000000100000 - 000000007ff80000 (usable)
Jul 27 23:46:57 localhost kernel:  BIOS-e820: 000000007ff80000 - 000000007ff8e000 (ACPI data)
Jul 27 23:46:57 localhost kernel:  BIOS-e820: 000000007ff8e000 - 000000007ffe0000 (ACPI NVS)
Jul 27 23:46:57 localhost kernel:  BIOS-e820: 000000007ffe0000 - 0000000080000000 (reserved)
Jul 27 23:46:57 localhost kernel:  BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
Jul 27 23:46:57 localhost kernel:  BIOS-e820: 00000000fff00000 - 0000000100000000 (reserved)
Jul 27 23:46:57 localhost kernel: end_pfn_map = 1048576
Jul 27 23:46:57 localhost kernel: DMI 2.4 present.
Jul 27 23:46:57 localhost kernel: ACPI: RSDP 000FBC10, 0014 (r0 ACPIAM)
Jul 27 23:46:57 localhost kernel: ACPI: RSDT 7FF80000, 003C (r1 A_M_I_ OEMRSDT   4000818 MSFT       97)
Jul 27 23:46:57 localhost kernel: ACPI: FACP 7FF80200, 0084 (r2 A_M_I_ OEMFACP   4000818 MSFT       97)
Jul 27 23:46:57 localhost kernel: ACPI: DSDT 7FF80440, 8B31 (r1  A0916 A0916032       32 INTL 20060113)
Jul 27 23:46:57 localhost kernel: ACPI: FACS 7FF8E000, 0040
Jul 27 23:46:57 localhost kernel: ACPI: APIC 7FF80390, 006C (r1 A_M_I_ OEMAPIC   4000818 MSFT       97)
Jul 27 23:46:57 localhost kernel: ACPI: MCFG 7FF80400, 003C (r1 A_M_I_ OEMMCFG   4000818 MSFT       97)
Jul 27 23:46:57 localhost kernel: ACPI: OEMB 7FF8E040, 0081 (r1 A_M_I_ AMI_OEM   4000818 MSFT       97)
Jul 27 23:46:57 localhost kernel: ACPI: HPET 7FF88F80, 0038 (r1 A_M_I_ OEMHPET   4000818 MSFT       97)
Jul 27 23:46:57 localhost kernel: ACPI: OSFR 7FF88FC0, 00B0 (r1 A_M_I_ OEMOSFR   4000818 MSFT       97)
Jul 27 23:46:57 localhost kernel: No NUMA configuration found
Jul 27 23:46:57 localhost kernel: Faking a node at 0000000000000000-000000007ff80000
Jul 27 23:46:57 localhost kernel: Bootmem setup node 0 0000000000000000-000000007ff80000
Jul 27 23:46:57 localhost kernel:   NODE_DATA [000000000000c000 - 0000000000013fff]
Jul 27 23:46:57 localhost kernel:   bootmap [0000000000014000 -  0000000000023fef] pages 10
Jul 27 23:46:57 localhost kernel: early res: 0 [0-fff] BIOS data page
Jul 27 23:46:57 localhost kernel: early res: 1 [6000-7fff] SMP_TRAMPOLINE
Jul 27 23:46:57 localhost kernel: early res: 2 [200000-75db3b] TEXT DATA BSS
Jul 27 23:46:57 localhost kernel: early res: 3 [37c89000-37fef477] RAMDISK
Jul 27 23:46:57 localhost kernel: early res: 4 [96000-9ffff] EBDA
Jul 27 23:46:57 localhost kernel: early res: 5 [8000-bfff] PGTABLE
Jul 27 23:46:57 localhost kernel: Zone PFN ranges:
Jul 27 23:46:57 localhost kernel:   DMA             0 ->     4096
Jul 27 23:46:57 localhost kernel:   DMA32        4096 ->  1048576
Jul 27 23:46:57 localhost kernel:   Normal    1048576 ->  1048576
Jul 27 23:46:57 localhost kernel: Movable zone start PFN for each node
Jul 27 23:46:57 localhost kernel: early_node_map[2] active PFN ranges
Jul 27 23:46:57 localhost kernel:     0:        0 ->      150
Jul 27 23:46:57 localhost kernel:     0:      256 ->   524160
Jul 27 23:46:57 localhost kernel: ACPI: PM-Timer IO Port: 0x808
Jul 27 23:46:57 localhost kernel: ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
Jul 27 23:46:57 localhost kernel: Processor #0 (Bootup-CPU)
Jul 27 23:46:57 localhost kernel: ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
Jul 27 23:46:57 localhost kernel: Processor #1
Jul 27 23:46:57 localhost kernel: ACPI: LAPIC (acpi_id[0x03] lapic_id[0x82] disabled)
Jul 27 23:46:57 localhost kernel: ACPI: LAPIC (acpi_id[0x04] lapic_id[0x83] disabled)
Jul 27 23:46:57 localhost kernel: ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
Jul 27 23:46:57 localhost kernel: IOAPIC[0]: apic_id 2, address 0xfec00000, GSI 0-23
Jul 27 23:46:57 localhost kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
Jul 27 23:46:57 localhost kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
Jul 27 23:46:57 localhost kernel: Setting APIC routing to flat
Jul 27 23:46:57 localhost kernel: ACPI: HPET id: 0xffffffff base: 0xfed00000
Jul 27 23:46:57 localhost kernel: Using ACPI (MADT) for SMP configuration information
Jul 27 23:46:57 localhost kernel: PM: Registered nosave memory: 0000000000096000 - 00000000000a0000
Jul 27 23:46:57 localhost kernel: PM: Registered nosave memory: 00000000000a0000 - 00000000000e4000
Jul 27 23:46:57 localhost kernel: PM: Registered nosave memory: 00000000000e4000 - 0000000000100000
Jul 27 23:46:57 localhost kernel: Allocating PCI resources starting at 88000000 (gap: 80000000:7ee00000)
Jul 27 23:46:57 localhost kernel: SMP: Allowing 4 CPUs, 2 hotplug CPUs
Jul 27 23:46:57 localhost kernel: PERCPU: Allocating 45232 bytes of per cpu data
Jul 27 23:46:57 localhost kernel: Built 1 zonelists in Node order, mobility grouping on.  Total pages: 515496
Jul 27 23:46:57 localhost kernel: Policy zone: DMA32
Jul 27 23:46:57 localhost kernel: Kernel command line: ro root=UUID=84dbcdfe-1da7-4bab-aeb1-fde0a9afc017 rhgb quiet
Jul 27 23:46:57 localhost kernel: Initializing CPU#0
Jul 27 23:46:57 localhost kernel: PID hash table entries: 4096 (order: 12, 32768 bytes)
Jul 27 23:46:57 localhost kernel: TSC calibrated against PM_TIMER
Jul 27 23:46:57 localhost kernel: time.c: Detected 3005.557 MHz processor.
Jul 27 23:46:57 localhost kernel: Console: colour VGA+ 80x25
Jul 27 23:46:57 localhost kernel: console [tty0] enabled
Jul 27 23:46:57 localhost kernel: Checking aperture...
Jul 27 23:46:57 localhost kernel: Memory: 2058068k/2096640k available (2656k kernel code, 38148k reserved, 1396k data, 356k init)
Jul 27 23:46:57 localhost kernel: SLUB: Genslabs=13, HWalign=64, Order=0-1, MinObjects=4, CPUs=4, Nodes=1
Jul 27 23:46:57 localhost kernel: Calibrating delay using timer specific routine.. 6014.24 BogoMIPS (lpj=3007121)
Jul 27 23:46:57 localhost kernel: Security Framework initialized
Jul 27 23:46:57 localhost kernel: SELinux:  Initializing.
Jul 27 23:46:57 localhost kernel: selinux_register_security:  Registering secondary module capability
Jul 27 23:46:57 localhost kernel: Capability LSM initialized as secondary
Jul 27 23:46:57 localhost kernel: Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
Jul 27 23:46:57 localhost kernel: Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
Jul 27 23:46:57 localhost kernel: Mount-cache hash table entries: 256
Jul 27 23:46:57 localhost kernel: Initializing cgroup subsys ns
Jul 27 23:46:57 localhost kernel: Initializing cgroup subsys cpuacct
Jul 27 23:46:57 localhost kernel: CPU: L1 I cache: 32K, L1 D cache: 32K
Jul 27 23:46:57 localhost kernel: CPU: L2 cache: 6144K
Jul 27 23:46:57 localhost kernel: CPU 0/0 -> Node 0
Jul 27 23:46:57 localhost kernel: CPU: Physical Processor ID: 0
Jul 27 23:46:57 localhost kernel: CPU: Processor Core ID: 0
Jul 27 23:46:57 localhost kernel: CPU0: Thermal monitoring enabled (TM2)
Jul 27 23:46:57 localhost kernel: using mwait in idle threads.
Jul 27 23:46:57 localhost kernel: ACPI: Core revision 20070126
Jul 27 23:46:57 localhost kernel: Using local APIC timer interrupts.
Jul 27 23:46:57 localhost kernel: Detected 20.871 MHz APIC timer.
Jul 27 23:46:57 localhost kernel: Booting processor 1/2 APIC 0x1
Jul 27 23:46:57 localhost kernel: Initializing CPU#1
Jul 27 23:46:57 localhost kernel: Calibrating delay using timer specific routine.. 6010.89 BogoMIPS (lpj=3005445)
Jul 27 23:46:57 localhost kernel: CPU 1/1 -> Node 0
Jul 27 23:46:57 localhost kernel: CPU: Processor Core ID: 1
Jul 27 23:46:57 localhost kernel: CPU1: Thermal monitoring enabled (TM2)
Jul 27 23:46:57 localhost rsyslogd: [origin software="rsyslogd" swVersion="3.16.1" x-pid="1798" x-info="http://www.rsyslog.com"] restart
Jul 27 23:46:57 localhost kernel: Intel® Core2 Duo CPU     E8400  @ 3.00GHz stepping 06
Jul 27 23:46:57 localhost kernel: checking TSC synchronization [CPU#0 -> CPU#1]: passed.
Jul 27 23:46:57 localhost kernel: Brought up 2 CPUs
Jul 27 23:46:57 localhost kernel: net_namespace: 1016 bytes
Jul 27 23:46:57 localhost kernel: Time: 21:46:38  Date: 07/27/08
Jul 27 23:46:57 localhost kernel: NET: Registered protocol family 16
Jul 27 23:46:57 localhost kernel: No dock devices found.
Jul 27 23:46:57 localhost kernel: ACPI: bus type pci registered
Jul 27 23:46:57 localhost kernel: PCI: Using configuration type 1
Jul 27 23:46:57 localhost kernel: ACPI: Interpreter enabled
Jul 27 23:46:57 localhost kernel: ACPI: (supports S0 S1 S3 S4 S5)
Jul 27 23:46:57 localhost kernel: ACPI: Using IOAPIC for interrupt routing
Jul 27 23:46:57 localhost kernel: ACPI: PCI Root Bridge [PCI0] (0000:00)
Jul 27 23:46:57 localhost kernel: pci 0000:00:1f.0: quirk: region 0800-087f claimed by ICH6 ACPI/GPIO/TCO
Jul 27 23:46:57 localhost kernel: pci 0000:00:1f.0: quirk: region 0480-04bf claimed by ICH6 GPIO
Jul 27 23:46:57 localhost kernel: PCI: Transparent bridge - 0000:00:1e.0
Jul 27 23:46:57 localhost kernel: ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 10 *11 12 14 15)
Jul 27 23:46:57 localhost kernel: ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 *10 11 12 14 15)
Jul 27 23:46:57 localhost kernel: ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 *5 6 7 10 11 12 14 15)
Jul 27 23:46:57 localhost kernel: ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 10 11 12 *14 15)
Jul 27 23:46:57 localhost kernel: ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
Jul 27 23:46:57 localhost kernel: ACPI: PCI Interrupt Link [LNKF] (IRQs *3 4 5 6 7 10 11 12 14 15)
Jul 27 23:46:57 localhost kernel: ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 10 11 12 14 *15)
Jul 27 23:46:57 localhost kernel: ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 *7 10 11 12 14 15)
Jul 27 23:46:57 localhost kernel: ACPI Warning (tbutils-0217): Incorrect checksum in table [OEMB] -  CA, should be C1 [20070126]
Jul 27 23:46:57 localhost kernel: Linux Plug and Play Support v0.97 © Adam Belay
Jul 27 23:46:57 localhost kernel: pnp: PnP ACPI init
Jul 27 23:46:57 localhost kernel: ACPI: bus type pnp registered
Jul 27 23:46:57 localhost kernel: pnp: PnP ACPI: found 16 devices
Jul 27 23:46:57 localhost kernel: ACPI: ACPI bus type pnp unregistered
Jul 27 23:46:57 localhost kernel: usbcore: registered new interface driver usbfs
Jul 27 23:46:57 localhost kernel: usbcore: registered new interface driver hub
Jul 27 23:46:57 localhost kernel: usbcore: registered new device driver usb
Jul 27 23:46:57 localhost kernel: PCI: Using ACPI for IRQ routing
Jul 27 23:46:57 localhost kernel: PCI: If a device doesn't work, try "pci=routeirq".  If it helps, post a report
Jul 27 23:46:57 localhost kernel: NetLabel: Initializing
Jul 27 23:46:57 localhost kernel: NetLabel:  domain hash size = 128
Jul 27 23:46:57 localhost kernel: NetLabel:  protocols = UNLABELED CIPSOv4
Jul 27 23:46:57 localhost kernel: NetLabel:  unlabeled traffic allowed by default
Jul 27 23:46:57 localhost kernel: DMAR:parse DMAR table failure.
Jul 27 23:46:57 localhost kernel: PCI-GART: No AMD northbridge found.
Jul 27 23:46:57 localhost kernel: hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0
Jul 27 23:46:57 localhost kernel: hpet0: 4 64-bit timers, 14318180 Hz
Jul 27 23:46:57 localhost kernel: ACPI: RTC can wake from S4
Jul 27 23:46:57 localhost kernel: system 00:01: iomem range 0xfed14000-0xfed19fff has been reserved
Jul 27 23:46:57 localhost kernel: system 00:07: ioport range 0x290-0x297 has been reserved
Jul 27 23:46:57 localhost kernel: system 00:08: ioport range 0x4d0-0x4d1 has been reserved
Jul 27 23:46:57 localhost kernel: system 00:08: ioport range 0x800-0x87f has been reserved
Jul 27 23:46:57 localhost kernel: system 00:08: ioport range 0x480-0x4bf has been reserved
Jul 27 23:46:57 localhost kernel: system 00:08: iomem range 0xfed1c000-0xfed1ffff has been reserved
Jul 27 23:46:57 localhost kernel: system 00:08: iomem range 0xfed20000-0xfed3ffff has been reserved
Jul 27 23:46:57 localhost kernel: system 00:08: iomem range 0xfed50000-0xfed8ffff has been reserved
Jul 27 23:46:57 localhost kernel: system 00:08: iomem range 0xffa00000-0xffafffff has been reserved
Jul 27 23:46:57 localhost kernel: system 00:08: iomem range 0xffb00000-0xffbfffff has been reserved
Jul 27 23:46:57 localhost kernel: system 00:08: iomem range 0xffe00000-0xffefffff has been reserved
Jul 27 23:46:57 localhost kernel: system 00:08: iomem range 0xfff00000-0xfffffffe could not be reserved
Jul 27 23:46:57 localhost kernel: system 00:0b: iomem range 0xfec00000-0xfec00fff has been reserved
Jul 27 23:46:57 localhost kernel: system 00:0b: iomem range 0xfee00000-0xfee00fff could not be reserved
Jul 27 23:46:57 localhost kernel: system 00:0e: iomem range 0xe0000000-0xefffffff has been reserved
Jul 27 23:46:57 localhost kernel: system 00:0f: iomem range 0x0-0x9ffff could not be reserved
Jul 27 23:46:57 localhost kernel: system 00:0f: iomem range 0xc0000-0xcffff has been reserved
Jul 27 23:46:57 localhost kernel: system 00:0f: iomem range 0xe0000-0xfffff could not be reserved
Jul 27 23:46:57 localhost kernel: system 00:0f: iomem range 0x100000-0x7fffffff could not be reserved
Jul 27 23:46:57 localhost kernel: system 00:0f: iomem range 0x0-0x0 could not be reserved
Jul 27 23:46:57 localhost kernel: PCI: Bridge: 0000:00:01.0
Jul 27 23:46:57 localhost kernel:   IO window: b000-bfff
Jul 27 23:46:57 localhost kernel:   MEM window: 0xfa000000-0xfe8fffff
Jul 27 23:46:57 localhost kernel:   PREFETCH window: 0x00000000d0000000-0x00000000dfffffff
Jul 27 23:46:57 localhost kernel: PCI: Bridge: 0000:00:1c.0
Jul 27 23:46:57 localhost kernel:   IO window: disabled.
Jul 27 23:46:57 localhost kernel:   MEM window: disabled.
Jul 27 23:46:57 localhost kernel:   PREFETCH window: 0x00000000f8f00000-0x00000000f8ffffff
Jul 27 23:46:57 localhost kernel: PCI: Bridge: 0000:00:1c.4
Jul 27 23:46:57 localhost kernel:   IO window: d000-dfff
Jul 27 23:46:57 localhost kernel:   MEM window: 0xfea00000-0xfeafffff
Jul 27 23:46:57 localhost kernel:   PREFETCH window: disabled.
Jul 27 23:46:57 localhost kernel: PCI: Bridge: 0000:00:1c.5
Jul 27 23:46:57 localhost kernel:   IO window: c000-cfff
Jul 27 23:46:57 localhost kernel:   MEM window: 0xfe900000-0xfe9fffff
Jul 27 23:46:57 localhost kernel: PCI: Bridge: 0000:00:1e.0
Jul 27 23:46:57 localhost kernel:   IO window: e000-efff
Jul 27 23:46:57 localhost kernel:   MEM window: 0xfeb00000-0xfebfffff
Jul 27 23:46:57 localhost kernel: ACPI: PCI Interrupt 0000:00:01.0[A] -> GSI 16 (level, low) -> IRQ 16
Jul 27 23:46:57 localhost kernel: ACPI: PCI Interrupt 0000:00:1c.0[A] -> GSI 17 (level, low) -> IRQ 17
Jul 27 23:46:57 localhost kernel: ACPI: PCI Interrupt 0000:00:1c.4[A] -> GSI 17 (level, low) -> IRQ 17
Jul 27 23:46:57 localhost kernel: ACPI: PCI Interrupt 0000:00:1c.5[A] -> GSI 16 (level, low) -> IRQ 16
Jul 27 23:46:57 localhost kernel: NET: Registered protocol family 2
Jul 27 23:46:57 localhost kernel: IP route cache hash table entries: 65536 (order: 7, 524288 bytes)
Jul 27 23:46:57 localhost kernel: TCP established hash table entries: 262144 (order: 10, 4194304 bytes)
Jul 27 23:46:57 localhost kernel: TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
Jul 27 23:46:57 localhost kernel: TCP: Hash tables configured (established 262144 bind 65536)
Jul 27 23:46:57 localhost kernel: TCP reno registered
Jul 27 23:46:57 localhost kernel: checking if image is initramfs... it is
Jul 27 23:46:57 localhost kernel: Freeing initrd memory: 3481k freed
Jul 27 23:46:57 localhost kernel: audit: initializing netlink socket (disabled)
Jul 27 23:46:57 localhost kernel: type=2000 audit(1217195198.395:1): initialized
Jul 27 23:46:57 localhost kernel: Total HugeTLB memory allocated, 0
Jul 27 23:46:57 localhost kernel: VFS: Disk quotas dquot_6.5.1
Jul 27 23:46:57 localhost kernel: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Jul 27 23:46:57 localhost kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
Jul 27 23:46:57 localhost kernel: io scheduler noop registered
Jul 27 23:46:57 localhost kernel: io scheduler anticipatory registered
Jul 27 23:46:57 localhost kernel: io scheduler deadline registered
Jul 27 23:46:57 localhost kernel: io scheduler cfq registered (default)
Jul 27 23:46:57 localhost kernel: assign_interrupt_mode Found MSI capability
Jul 27 23:46:57 localhost kernel: pci_hotplug: PCI Hot Plug PCI Core version: 0.5
Jul 27 23:46:57 localhost kernel: ACPI: SSDT 7FF8E0D0, 01D2 (r1    AMI   CPU1PM        1 INTL 20060113)
Jul 27 23:46:57 localhost kernel: ACPI: ACPI0007:00 is registered as cooling_device0
Jul 27 23:46:57 localhost kernel: ACPI: SSDT 7FF8E2B0, 0143 (r1    AMI   CPU2PM        1 INTL 20060113)
Jul 27 23:46:57 localhost kernel: ACPI: ACPI0007:01 is registered as cooling_device1
Jul 27 23:46:57 localhost kernel: Non-volatile memory driver v1.2
Jul 27 23:46:57 localhost kernel: Linux agpgart interface v0.103
Jul 27 23:46:57 localhost kernel: Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
Jul 27 23:46:57 localhost kernel: serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
Jul 27 23:46:57 localhost kernel: 00:0a: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
Jul 27 23:46:57 localhost kernel: brd: module loaded
Jul 27 23:46:57 localhost kernel: input: Macintosh mouse button emulation as /devices/virtual/input/input0
Jul 27 23:46:57 localhost kernel: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f03:PS2M] at 0x60,0x64 irq 1,12
Jul 27 23:46:57 localhost kernel: serio: i8042 KBD port at 0x60,0x64 irq 1
Jul 27 23:46:57 localhost kernel: serio: i8042 AUX port at 0x60,0x64 irq 12
Jul 27 23:46:57 localhost kernel: mice: PS/2 mouse device common for all mice
Jul 27 23:46:57 localhost kernel: input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input1
Jul 27 23:46:57 localhost kernel: rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
Jul 27 23:46:57 localhost kernel: rtc0: alarms up to one month, y3k
Jul 27 23:46:57 localhost kernel: cpuidle: using governor ladder
Jul 27 23:46:57 localhost kernel: cpuidle: using governor menu
Jul 27 23:46:57 localhost kernel: usbcore: registered new interface driver hiddev
Jul 27 23:46:57 localhost kernel: usbcore: registered new interface driver usbhid
Jul 27 23:46:57 localhost kernel: drivers/hid/usbhid/hid-core.c: v2.6:USB HID core driver
Jul 27 23:46:57 localhost kernel: TCP cubic registered
Jul 27 23:46:57 localhost kernel: Initializing XFRM netlink socket
Jul 27 23:46:57 localhost kernel: NET: Registered protocol family 17
Jul 27 23:46:57 localhost kernel: registered taskstats version 1
Jul 27 23:46:57 localhost kernel:   Magic number: 0:500:804
Jul 27 23:46:57 localhost kernel: Freeing unused kernel memory: 356k freed
Jul 27 23:46:57 localhost kernel: Write protecting the kernel read-only data: 1120k
Jul 27 23:46:57 localhost kernel: ACPI: PCI Interrupt 0000:00:1a.7[C] -> GSI 18 (level, low) -> IRQ 18
Jul 27 23:46:57 localhost kernel: ehci_hcd 0000:00:1a.7: EHCI Host Controller
Jul 27 23:46:57 localhost kernel: ehci_hcd 0000:00:1a.7: new USB bus registered, assigned bus number 1
Jul 27 23:46:57 localhost kernel: ehci_hcd 0000:00:1a.7: debug port 1
Jul 27 23:46:57 localhost kernel: ehci_hcd 0000:00:1a.7: irq 18, io mem 0xf9fffc00
Jul 27 23:46:57 localhost kernel: ehci_hcd 0000:00:1a.7: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
Jul 27 23:46:57 localhost kernel: usb usb1: configuration #1 chosen from 1 choice
Jul 27 23:46:57 localhost kernel: hub 1-0:1.0: USB hub found
Jul 27 23:46:57 localhost kernel: hub 1-0:1.0: 6 ports detected
Jul 27 23:46:57 localhost kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Jul 27 23:46:57 localhost kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jul 27 23:46:57 localhost kernel: usb usb1: Product: EHCI Host Controller
Jul 27 23:46:57 localhost kernel: usb usb1: Manufacturer: Linux 2.6.25-14.fc9.x86_64 ehci_hcd
Jul 27 23:46:57 localhost kernel: usb usb1: SerialNumber: 0000:00:1a.7
Jul 27 23:46:57 localhost kernel: ACPI: PCI Interrupt 0000:00:1d.7[A] -> GSI 23 (level, low) -> IRQ 23
Jul 27 23:46:57 localhost kernel: ehci_hcd 0000:00:1d.7: EHCI Host Controller
Jul 27 23:46:57 localhost kernel: ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 2
Jul 27 23:46:57 localhost kernel: ehci_hcd 0000:00:1d.7: debug port 1
Jul 27 23:46:57 localhost kernel: ehci_hcd 0000:00:1d.7: irq 23, io mem 0xf9fff800
Jul 27 23:46:57 localhost kernel: ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
Jul 27 23:46:57 localhost kernel: usb usb2: configuration #1 chosen from 1 choice
Jul 27 23:46:57 localhost kernel: hub 2-0:1.0: USB hub found
Jul 27 23:46:57 localhost kernel: hub 2-0:1.0: 6 ports detected
Jul 27 23:46:57 localhost kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
Jul 27 23:46:57 localhost kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jul 27 23:46:57 localhost kernel: usb usb2: Product: EHCI Host Controller
Jul 27 23:46:57 localhost kernel: usb usb2: Manufacturer: Linux 2.6.25-14.fc9.x86_64 ehci_hcd
Jul 27 23:46:57 localhost kernel: usb usb2: SerialNumber: 0000:00:1d.7
Jul 27 23:46:57 localhost kernel: USB Universal Host Controller Interface driver v3.0
Jul 27 23:46:57 localhost kernel: ACPI: PCI Interrupt 0000:00:1a.0[A] -> GSI 16 (level, low) -> IRQ 16
Jul 27 23:46:57 localhost kernel: uhci_hcd 0000:00:1a.0: UHCI Host Controller
Jul 27 23:46:57 localhost kernel: uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 3
Jul 27 23:46:57 localhost kernel: uhci_hcd 0000:00:1a.0: irq 16, io base 0x0000a800
Jul 27 23:46:57 localhost kernel: usb usb3: configuration #1 chosen from 1 choice
Jul 27 23:46:57 localhost kernel: hub 3-0:1.0: USB hub found
Jul 27 23:46:57 localhost kernel: hub 3-0:1.0: 2 ports detected
Jul 27 23:46:57 localhost kernel: usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
Jul 27 23:46:57 localhost kernel: usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jul 27 23:46:57 localhost kernel: usb usb3: Product: UHCI Host Controller
Jul 27 23:46:57 localhost kernel: usb usb3: Manufacturer: Linux 2.6.25-14.fc9.x86_64 uhci_hcd
Jul 27 23:46:57 localhost kernel: usb usb3: SerialNumber: 0000:00:1a.0
Jul 27 23:46:57 localhost kernel: ACPI: PCI Interrupt 0000:00:1a.1 -> GSI 21 (level, low) -> IRQ 21
Jul 27 23:46:57 localhost kernel: uhci_hcd 0000:00:1a.1: UHCI Host Controller
Jul 27 23:46:57 localhost kernel: uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 4
Jul 27 23:46:57 localhost kernel: uhci_hcd 0000:00:1a.1: irq 21, io base 0x0000a880
Jul 27 23:46:57 localhost kernel: usb usb4: configuration #1 chosen from 1 choice
Jul 27 23:46:57 localhost kernel: hub 4-0:1.0: USB hub found
Jul 27 23:46:57 localhost kernel: hub 4-0:1.0: 2 ports detected
Jul 27 23:46:57 localhost kernel: usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
Jul 27 23:46:57 localhost kernel: usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jul 27 23:46:57 localhost kernel: usb usb4: Product: UHCI Host Controller
Jul 27 23:46:57 localhost kernel: usb usb4: Manufacturer: Linux 2.6.25-14.fc9.x86_64 uhci_hcd
Jul 27 23:46:57 localhost kernel: usb usb4: SerialNumber: 0000:00:1a.1
Jul 27 23:46:57 localhost kernel: ACPI: PCI Interrupt 0000:00:1a.2[C] -> GSI 18 (level, low) -> IRQ 18
Jul 27 23:46:57 localhost kernel: uhci_hcd 0000:00:1a.2: UHCI Host Controller
Jul 27 23:46:57 localhost kernel: uhci_hcd 0000:00:1a.2: new USB bus registered, assigned bus number 5
Jul 27 23:46:57 localhost kernel: uhci_hcd 0000:00:1a.2: irq 18, io base 0x0000ac00
Jul 27 23:46:57 localhost kernel: usb usb5: configuration #1 chosen from 1 choice
Jul 27 23:46:57 localhost kernel: hub 5-0:1.0: USB hub found
Jul 27 23:46:57 localhost kernel: hub 5-0:1.0: 2 ports detected
Jul 27 23:46:57 localhost kernel: usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
Jul 27 23:46:57 localhost kernel: usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jul 27 23:46:57 localhost kernel: usb usb5: Product: UHCI Host Controller
Jul 27 23:46:57 localhost kernel: usb usb5: Manufacturer: Linux 2.6.25-14.fc9.x86_64 uhci_hcd
Jul 27 23:46:57 localhost kernel: usb usb5: SerialNumber: 0000:00:1a.2
Jul 27 23:46:57 localhost kernel: ACPI: PCI Interrupt 0000:00:1d.0[A] -> GSI 23 (level, low) -> IRQ 23
Jul 27 23:46:57 localhost kernel: uhci_hcd 0000:00:1d.0: UHCI Host Controller
Jul 27 23:46:57 localhost kernel: uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 6
Jul 27 23:46:57 localhost kernel: uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000a080
Jul 27 23:46:57 localhost kernel: usb usb6: configuration #1 chosen from 1 choice
Jul 27 23:46:57 localhost kernel: hub 6-0:1.0: USB hub found
Jul 27 23:46:57 localhost kernel: hub 6-0:1.0: 2 ports detected
Jul 27 23:46:57 localhost kernel: usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
Jul 27 23:46:57 localhost kernel: usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jul 27 23:46:57 localhost kernel: usb usb6: Product: UHCI Host Controller
Jul 27 23:46:57 localhost kernel: usb usb6: Manufacturer: Linux 2.6.25-14.fc9.x86_64 uhci_hcd
Jul 27 23:46:57 localhost kernel: usb usb6: SerialNumber: 0000:00:1d.0
Jul 27 23:46:57 localhost kernel: ACPI: PCI Interrupt 0000:00:1d.1[b] -> GSI 19 (level, low) -> IRQ 19
Jul 27 23:46:57 localhost kernel: uhci_hcd 0000:00:1d.1: UHCI Host Controller
Jul 27 23:46:57 localhost kernel: uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 7
Jul 27 23:46:57 localhost kernel: uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000a400
Jul 27 23:46:57 localhost kernel: usb usb7: configuration #1 chosen from 1 choice
Jul 27 23:46:57 localhost kernel: hub 7-0:1.0: USB hub found
Jul 27 23:46:57 localhost kernel: hub 7-0:1.0: 2 ports detected
Jul 27 23:46:57 localhost kernel: usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
Jul 27 23:46:57 localhost kernel: usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jul 27 23:46:57 localhost kernel: usb usb7: Product: UHCI Host Controller
Jul 27 23:46:57 localhost kernel: usb usb7: Manufacturer: Linux 2.6.25-14.fc9.x86_64 uhci_hcd
Jul 27 23:46:57 localhost kernel: usb usb7: SerialNumber: 0000:00:1d.1
Jul 27 23:46:57 localhost kernel: ACPI: PCI Interrupt 0000:00:1d.2[C] -> GSI 18 (level, low) -> IRQ 18
Jul 27 23:46:57 localhost kernel: uhci_hcd 0000:00:1d.2: UHCI Host Controller
Jul 27 23:46:57 localhost kernel: uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 8
Jul 27 23:46:57 localhost kernel: uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000a480
Jul 27 23:46:57 localhost kernel: usb usb8: configuration #1 chosen from 1 choice
Jul 27 23:46:57 localhost kernel: hub 8-0:1.0: USB hub found
Jul 27 23:46:57 localhost kernel: hub 8-0:1.0: 2 ports detected
Jul 27 23:46:57 localhost kernel: usb 5-2: new low speed USB device using uhci_hcd and address 2
Jul 27 23:46:57 localhost kernel: usb usb8: New USB device found, idVendor=1d6b, idProduct=0001
Jul 27 23:46:57 localhost kernel: usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jul 27 23:46:57 localhost kernel: usb usb8: Product: UHCI Host Controller
Jul 27 23:46:57 localhost kernel: usb usb8: Manufacturer: Linux 2.6.25-14.fc9.x86_64 uhci_hcd
Jul 27 23:46:57 localhost kernel: usb usb8: SerialNumber: 0000:00:1d.2
Jul 27 23:46:57 localhost kernel: SCSI subsystem initialized
Jul 27 23:46:57 localhost kernel: Driver 'sd' needs updating - please use bus_type methods
Jul 27 23:46:57 localhost kernel: ACPI: PCI Interrupt 0000:00:1f.2[b] -> GSI 22 (level, low) -> IRQ 22
Jul 27 23:46:57 localhost kernel: usb 5-2: configuration #1 chosen from 1 choice
Jul 27 23:46:57 localhost kernel: input: Logitech USB-PS/2 Optical Mouse as /devices/pci0000:00/0000:00:1a.2/usb5/5-2/5-2:1.0/input/input2
Jul 27 23:46:57 localhost kernel: input,hidraw0: USB HID v1.10 Mouse [Logitech USB-PS/2 Optical Mouse] on usb-0000:00:1a.2-2
Jul 27 23:46:57 localhost kernel: usb 5-2: New USB device found, idVendor=046d, idProduct=c00e
Jul 27 23:46:57 localhost kernel: usb 5-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Jul 27 23:46:57 localhost kernel: usb 5-2: Product: USB-PS/2 Optical Mouse
Jul 27 23:46:57 localhost kernel: usb 5-2: Manufacturer: Logitech
Jul 27 23:46:57 localhost kernel: ahci 0000:00:1f.2: AHCI 0001.0200 32 slots 6 ports 3 Gbps 0x3f impl RAID mode
Jul 27 23:46:57 localhost kernel: ahci 0000:00:1f.2: flags: 64bit ncq sntf stag pm led clo pmp pio slum part
Jul 27 23:46:57 localhost kernel: scsi0 : ahci
Jul 27 23:46:57 localhost kernel: scsi1 : ahci
Jul 27 23:46:57 localhost kernel: scsi2 : ahci
Jul 27 23:46:57 localhost kernel: scsi3 : ahci
Jul 27 23:46:57 localhost kernel: scsi4 : ahci
Jul 27 23:46:57 localhost kernel: scsi5 : ahci
Jul 27 23:46:57 localhost kernel: ata1: SATA max UDMA/133 abar m2048@0xf9ffe800 port 0xf9ffe900 irq 22
Jul 27 23:46:57 localhost kernel: ata2: SATA max UDMA/133 abar m2048@0xf9ffe800 port 0xf9ffe980 irq 22
Jul 27 23:46:57 localhost kernel: ata3: SATA max UDMA/133 abar m2048@0xf9ffe800 port 0xf9ffea00 irq 22
Jul 27 23:46:57 localhost kernel: ata4: SATA max UDMA/133 abar m2048@0xf9ffe800 port 0xf9ffea80 irq 22
Jul 27 23:46:57 localhost kernel: ata5: SATA max UDMA/133 abar m2048@0xf9ffe800 port 0xf9ffeb00 irq 22
Jul 27 23:46:57 localhost kernel: ata6: SATA max UDMA/133 abar m2048@0xf9ffe800 port 0xf9ffeb80 irq 22
Jul 27 23:46:57 localhost kernel: ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Jul 27 23:46:57 localhost kernel: ata1.00: ATA-6: ST3500320NS, SN04, max UDMA/133
Jul 27 23:46:57 localhost kernel: ata1.00: 976773168 sectors, multi 0: LBA48 NCQ (depth 31/32)
Jul 27 23:46:57 localhost kernel: ata1.00: configured for UDMA/133
Jul 27 23:46:57 localhost kernel: ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Jul 27 23:46:57 localhost kernel: ata2.00: ATA-6: ST3500320NS, SN04, max UDMA/133
Jul 27 23:46:57 localhost kernel: ata2.00: 976773168 sectors, multi 0: LBA48 NCQ (depth 31/32)
Jul 27 23:46:57 localhost kernel: ata2.00: configured for UDMA/133
Jul 27 23:46:57 localhost kernel: ata3: SATA link down (SStatus 0 SControl 300)
Jul 27 23:46:57 localhost kernel: ata4: SATA link down (SStatus 0 SControl 300)
Jul 27 23:46:57 localhost kernel: ata5: SATA link down (SStatus 0 SControl 300)
Jul 27 23:46:57 localhost kernel: ata6: SATA link down (SStatus 0 SControl 300)
Jul 27 23:46:57 localhost kernel: scsi 0:0:0:0: Direct-Access     ATA      ST3500320NS      SN04 PQ: 0 ANSI: 5
Jul 27 23:46:57 localhost kernel: sd 0:0:0:0: [sda] 976773168 512-byte hardware sectors (500108 MB)
Jul 27 23:46:57 localhost kernel: sd 0:0:0:0: [sda] Write Protect is off
Jul 27 23:46:57 localhost kernel: sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jul 27 23:46:57 localhost kernel:  sda: sda1 sda2
Jul 27 23:46:57 localhost kernel:  sda: p2 exceeds device capacity
Jul 27 23:46:57 localhost kernel: sd 0:0:0:0: [sda] Attached SCSI disk
Jul 27 23:46:57 localhost kernel: scsi 1:0:0:0: Direct-Access     ATA      ST3500320NS      SN04 PQ: 0 ANSI: 5
Jul 27 23:46:57 localhost kernel: sd 1:0:0:0: [sdb] 976773168 512-byte hardware sectors (500108 MB)
Jul 27 23:46:57 localhost kernel: sd 1:0:0:0: [sdb] Write Protect is off
Jul 27 23:46:57 localhost kernel: sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jul 27 23:46:57 localhost kernel:  sdb: unknown partition table
Jul 27 23:46:57 localhost kernel: sd 1:0:0:0: [sdb] Attached SCSI disk
Jul 27 23:46:57 localhost kernel: device-mapper: uevent: version 1.0.3
Jul 27 23:46:57 localhost kernel: device-mapper: ioctl: 4.13.0-ioctl (2007-10-18) initialised: [email protected]
Jul 27 23:46:57 localhost kernel: kjournald starting.  Commit interval 5 seconds
Jul 27 23:46:57 localhost kernel: EXT3-fs: mounted filesystem with ordered data mode.
Jul 27 23:46:57 localhost kernel: type=1404 audit(1217195206.497:2): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
Jul 27 23:46:57 localhost kernel: SELinux: policy loaded with handle_unknown=allow
Jul 27 23:46:57 localhost kernel: type=1403 audit(1217195206.851:3): policy loaded auid=4294967295 ses=4294967295
Jul 27 23:46:57 localhost kernel: Floppy drive(s): fd0 is 1.44M
Jul 27 23:46:57 localhost kernel: FDC 0 is a post-1991 82077
Jul 27 23:46:57 localhost kernel: input: PC Speaker as /devices/platform/pcspkr/input/input3
Jul 27 23:46:57 localhost kernel: ACPI: PCI Interrupt 0000:03:00.0[A] -> GSI 16 (level, low) -> IRQ 16
Jul 27 23:46:57 localhost kernel: scsi6 : pata_marvell
Jul 27 23:46:57 localhost kernel: scsi7 : pata_marvell
Jul 27 23:46:57 localhost kernel: ata7: PATA max UDMA/100 cmd 0xdc00 ctl 0xd880 bmdma 0xd400 irq 16
Jul 27 23:46:57 localhost kernel: ata8: DUMMY
Jul 27 23:46:57 localhost kernel: BAR5:00:00 01:7F 02:22 03:CA 04:00 05:00 06:00 07:00 08:00 09:00 0A:00 0B:00 0C:01 0D:00 0E:00 0F:00
Jul 27 23:46:57 localhost kernel: iTCO_vendor_support: vendor-support=0
Jul 27 23:46:57 localhost kernel: iTCO_wdt: Intel TCO WatchDog Timer Driver v1.02 (26-Jul-2007)
Jul 27 23:46:57 localhost kernel: iTCO_wdt: Found a ICH9R TCO device (Version=2, TCOBASE=0x0860)
Jul 27 23:46:57 localhost kernel: iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
Jul 27 23:46:57 localhost kernel: input: Power Button (FF) as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input4
Jul 27 23:46:57 localhost kernel: ACPI: Power Button (FF) [PWRF]
Jul 27 23:46:57 localhost kernel: input: Power Button (CM) as /devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input5
Jul 27 23:46:57 localhost kernel: ACPI: Power Button (CM) [PWRB]
Jul 27 23:46:57 localhost kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
Jul 27 23:46:57 localhost kernel: sd 1:0:0:0: Attached scsi generic sg1 type 0
Jul 27 23:46:57 localhost kernel: ata7.01: ATAPI: TSSTcorpCD/DVDW SH-S182D, SB02, max UDMA/33
Jul 27 23:46:57 localhost kernel: ata7.01: configured for UDMA/33
Jul 27 23:46:57 localhost kernel: scsi 6:0:1:0: CD-ROM            TSSTcorp CD/DVDW SH-S182D SB02 PQ: 0 ANSI: 5
Jul 27 23:46:57 localhost kernel: scsi 6:0:1:0: Attached scsi generic sg2 type 5
Jul 27 23:46:57 localhost kernel: ACPI: PCI Interrupt 0000:02:00.0[A] -> GSI 17 (level, low) -> IRQ 17
Jul 27 23:46:57 localhost kernel: sky2 0000:02:00.0: v1.21 addr 0xfe9fc000 irq 17 Yukon-EC Ultra (0xb4) rev 3
Jul 27 23:46:57 localhost kernel: sky2 eth0: addr 00:1f:c6:85:41:69
Jul 27 23:46:57 localhost kernel: ACPI: PCI Interrupt 0000:00:1f.3[C] -> GSI 18 (level, low) -> IRQ 18
Jul 27 23:46:57 localhost kernel: ACPI: PCI Interrupt 0000:05:03.0[A] -> GSI 16 (level, low) -> IRQ 16
Jul 27 23:46:57 localhost kernel: firewire_ohci: Added fw-ohci device 0000:05:03.0, OHCI version 1.10
Jul 27 23:46:57 localhost kernel: Driver 'sr' needs updating - please use bus_type methods
Jul 27 23:46:57 localhost kernel: sr0: scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
Jul 27 23:46:57 localhost kernel: Uniform CD-ROM driver Revision: 3.20
Jul 27 23:46:57 localhost kernel: ACPI: PCI Interrupt 0000:00:1b.0[A] -> GSI 22 (level, low) -> IRQ 22
Jul 27 23:46:57 localhost kernel: ALSA sound/pci/hda/hda_intel.c:1810: chipset global capabilities = 0x4401
Jul 27 23:46:57 localhost kernel: ALSA sound/pci/hda/hda_intel.c:749: codec_mask = 0x1
Jul 27 23:46:57 localhost kernel: hda_codec: Unknown model for ALC883, trying auto-probe from BIOS...
Jul 27 23:46:57 localhost kernel: ALSA sound/pci/hda/hda_codec.c:1073: Cannot find slave Headphone Playback Volume, skipped
Jul 27 23:46:57 localhost kernel: ALSA sound/pci/hda/hda_codec.c:1073: Cannot find slave Speaker Playback Volume, skipped
Jul 27 23:46:57 localhost kernel: ALSA sound/pci/hda/hda_codec.c:1073: Cannot find slave Mono Playback Volume, skipped
Jul 27 23:46:57 localhost kernel: ALSA sound/pci/hda/hda_codec.c:1073: Cannot find slave Line-Out Playback Volume, skipped
Jul 27 23:46:57 localhost kernel: ALSA sound/pci/hda/hda_codec.c:1073: Cannot find slave Speaker Playback Switch, skipped
Jul 27 23:46:57 localhost kernel: ALSA sound/pci/hda/hda_codec.c:1073: Cannot find slave Mono Playback Switch, skipped
Jul 27 23:46:57 localhost kernel: firewire_core: created device fw0: GUID 001e8c00013936a8, S400
Jul 27 23:46:57 localhost kernel: NET: Registered protocol family 10
Jul 27 23:46:57 localhost kernel: lo: Disabled Privacy Extensions
Jul 27 23:46:57 localhost kernel: device-mapper: multipath: version 1.0.5 loaded
Jul 27 23:46:57 localhost kernel: loop: module loaded
Jul 27 23:46:57 localhost kernel: EXT3 FS on dm-3, internal journal
Jul 27 23:46:57 localhost kernel: EXT3 FS on dm-1, internal journal
Jul 27 23:46:57 localhost kernel: Adding 2031608k swap on /dev/mapper/VolGroup00-LogVol01.  Priority:-1 extents:1 across:2031608k
Jul 27 23:46:57 localhost kernel: IA-32 Microcode Update Driver: v1.14a <[email protected]>
Jul 27 23:46:57 localhost kernel: ip6_tables: © 2000-2006 Netfilter Core Team
Jul 27 23:46:57 localhost kernel: nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
Jul 27 23:46:57 localhost kernel: ip_tables: © 2000-2006 Netfilter Core Team
Jul 27 23:46:57 localhost rpc.statd[1836]: Version 1.1.2 Starting
Jul 27 23:46:58 localhost sm-notify[1838]: sm-notify running as root. chown /var/lib/nfs/sm to choose different user
Jul 27 23:46:58 localhost Backgrounding to notify hosts...
Jul 27 23:46:58 localhost kernel: RPC: Registered udp transport module.
Jul 27 23:46:58 localhost kernel: RPC: Registered tcp transport module.
Jul 27 23:46:59 localhost kernel: fuse init (API version 7.9)
Jul 27 23:46:59 localhost pcscd: pcscdaemon.c:507:main() pcsc-lite 1.4.4 daemon ready.
Jul 27 23:46:59 localhost acpid: starting up
Jul 27 23:47:00 localhost acpid: client connected from 2051[68:68]
Jul 27 23:47:01 localhost NetworkManager: <info>  starting...
Jul 27 23:47:01 localhost NetworkManager: <info>  eth0: Device is fully-supported using driver 'sky2'.
Jul 27 23:47:01 localhost NetworkManager: <info>  Found new Ethernet device 'eth0'.
Jul 27 23:47:01 localhost NetworkManager: <info>  (eth0): exported as /org/freedesktop/Hal/devices/net_00_1f_c6_85_41_69
Jul 27 23:47:01 localhost NetworkManager: <info>  Trying to start the supplicant...
Jul 27 23:47:01 localhost NetworkManager: <info>  Trying to start the system settings daemon...
Jul 27 23:47:01 localhost nm-system-settings: Loaded plugin ifcfg-fedora: © 2007 - 2008 Red Hat, Inc.  To report bugs please use the NetworkManager mailing list.
Jul 27 23:47:02 localhost nm-system-settings:    ifcfg-fedora: parsing /etc/sysconfig/network-scripts/ifcfg-lo ...
Jul 27 23:47:02 localhost nm-system-settings:    ifcfg-fedora:     error: Ignoring loopback device config.
Jul 27 23:47:02 localhost nm-system-settings:    ifcfg-fedora: parsing /etc/sysconfig/network-scripts/ifcfg-eth0 ...
Jul 27 23:47:02 localhost nm-system-settings:    ifcfg-fedora:     error: File '/etc/sysconfig/network-scripts/ifcfg-eth0' specified device 'eth0', but the device's type could not be determined.
Jul 27 23:47:02 localhost hcid[2103]: Bluetooth HCI daemon
Jul 27 23:47:02 localhost kernel: Bluetooth: Core ver 2.11
Jul 27 23:47:02 localhost kernel: NET: Registered protocol family 31
Jul 27 23:47:02 localhost kernel: Bluetooth: HCI device and connection manager initialized
Jul 27 23:47:02 localhost kernel: Bluetooth: HCI socket layer initialized
Jul 27 23:47:02 localhost hcid[2103]: Parsing /etc/bluetooth/main.conf failed: No such file or directory
Jul 27 23:47:02 localhost hcid[2103]: Starting SDP server
Jul 27 23:47:02 localhost kernel: Bluetooth: L2CAP ver 2.9
Jul 27 23:47:02 localhost kernel: Bluetooth: L2CAP socket layer initialized
Jul 27 23:47:02 localhost kernel: Bluetooth: RFCOMM socket layer initialized
Jul 27 23:47:02 localhost kernel: Bluetooth: RFCOMM TTY layer initialized
Jul 27 23:47:02 localhost kernel: Bluetooth: RFCOMM ver 1.8
Jul 27 23:47:02 localhost hcid[2103]: Registered manager path:/org/bluez/serial
Jul 27 23:47:02 localhost kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.2
Jul 27 23:47:02 localhost kernel: Bluetooth: BNEP filters: protocol multicast
Jul 27 23:47:02 localhost kernel: Bridge firewalling registered
Jul 27 23:47:02 localhost kernel: pan0: Dropping NETIF_F_UFO since no NETIF_F_HW_CSUM feature.
Jul 27 23:47:02 localhost hcid[2103]: bridge pan0 created
Jul 27 23:47:02 localhost hcid[2103]: Registered manager path:/org/bluez/network
Jul 27 23:47:02 localhost hcid[2103]: Parsing /etc/bluetooth/input.conf failed: No such file or directory
Jul 27 23:47:02 localhost hcid[2103]: Registered input manager path:/org/bluez/input
Jul 27 23:47:02 localhost hcid[2103]: Unix socket created: 17
Jul 27 23:47:02 localhost hcid[2103]: Registered manager path:/org/bluez/audio
Jul 27 23:47:04 localhost avahi-daemon[2217]: Found user 'avahi' (UID 498) and group 'avahi' (GID 495).
Jul 27 23:47:04 localhost avahi-daemon[2217]: Successfully dropped root privileges.
Jul 27 23:47:04 localhost avahi-daemon[2217]: avahi-daemon 0.6.22 starting up.
Jul 27 23:47:04 localhost avahi-daemon[2217]: WARNING: No NSS support for mDNS detected, consider installing nss-mdns!
Jul 27 23:47:04 localhost avahi-daemon[2217]: Successfully called chroot().
Jul 27 23:47:04 localhost avahi-daemon[2217]: Successfully dropped remaining capabilities.
Jul 27 23:47:04 localhost avahi-daemon[2217]: Loading service file /services/ssh.service.
Jul 27 23:47:04 localhost avahi-daemon[2217]: System host name is set to 'localhost'. This is not a suitable mDNS host name, looking for alternatives.
Jul 27 23:47:04 localhost avahi-daemon[2217]: Network interface enumeration completed.
Jul 27 23:47:04 localhost avahi-daemon[2217]: Registering HINFO record with values 'X86_64'/'LINUX'.
Jul 27 23:47:04 localhost avahi-daemon[2217]: Server startup complete. Host name is linux.local. Local service cookie is 1761406.
Jul 27 23:47:04 localhost avahi-daemon[2217]: Service "linux" (/services/ssh.service) successfully established.
Jul 27 23:47:05 localhost NetworkManager: <info>  (eth0): device state change: 1 -> 2
Jul 27 23:47:05 localhost kernel: sky2 eth0: enabling interface
Jul 27 23:47:05 localhost NetworkManager: <info>  (eth0): bringing up device.
Jul 27 23:47:05 localhost kernel: ADDRCONF(NETDEV_UP): eth0: link is not ready
Jul 27 23:47:05 localhost NetworkManager: <info>  (eth0): preparing device.
Jul 27 23:47:05 localhost NetworkManager: <info>  (eth0): deactivating device.
Jul 27 23:47:05 localhost NetworkManager: <info>  (eth0): carrier now ON (device state 2)
Jul 27 23:47:05 localhost NetworkManager: <info>  (eth0): device state change: 2 -> 3
Jul 27 23:47:05 localhost NetworkManager: <info>  (eth0): carrier now OFF (device state 3)
Jul 27 23:47:05 localhost NetworkManager: <info>  (eth0): device state change: 3 -> 2
Jul 27 23:47:05 localhost acpid: client connected from 2316[0:0]
Jul 27 23:47:05 localhost nm-system-settings: Adding default connection 'Auto eth0' for /org/freedesktop/Hal/devices/net_00_1f_c6_85_41_69
Jul 27 23:47:07 localhost kernel: sky2 eth0: Link is up at 100 Mbps, full duplex, flow control both
Jul 27 23:47:07 localhost NetworkManager: <info>  (eth0): carrier now ON (device state 2)
Jul 27 23:47:07 localhost NetworkManager: <info>  (eth0): device state change: 2 -> 3
Jul 27 23:47:07 localhost NetworkManager: <info>  Activation (eth0) starting connection 'Auto eth0'
Jul 27 23:47:07 localhost NetworkManager: <info>  (eth0): device state change: 3 -> 4
Jul 27 23:47:07 localhost NetworkManager: <info>  Activation (eth0) Stage 1 of 5 (Device Prepare) scheduled...
Jul 27 23:47:07 localhost NetworkManager: <info>  Activation (eth0) Stage 1 of 5 (Device Prepare) started...
Jul 27 23:47:07 localhost NetworkManager: <info>  Activation (eth0) Stage 2 of 5 (Device Configure) scheduled...
Jul 27 23:47:07 localhost NetworkManager: <info>  Activation (eth0) Stage 1 of 5 (Device Prepare) complete.
Jul 27 23:47:07 localhost NetworkManager: <info>  Activation (eth0) Stage 2 of 5 (Device Configure) starting...
Jul 27 23:47:07 localhost NetworkManager: <info>  (eth0): device state change: 4 -> 5
Jul 27 23:47:07 localhost NetworkManager: <info>  Activation (eth0) Stage 2 of 5 (Device Configure) successful.
Jul 27 23:47:07 localhost NetworkManager: <info>  Activation (eth0) Stage 3 of 5 (IP Configure Start) scheduled.
Jul 27 23:47:07 localhost NetworkManager: <info>  Activation (eth0) Stage 2 of 5 (Device Configure) complete.
Jul 27 23:47:07 localhost NetworkManager: <info>  Activation (eth0) Stage 3 of 5 (IP Configure Start) started...
Jul 27 23:47:07 localhost NetworkManager: <info>  (eth0): device state change: 5 -> 7
Jul 27 23:47:07 localhost NetworkManager: <info>  Activation (eth0) Beginning DHCP transaction.
Jul 27 23:47:07 localhost kernel: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Jul 27 23:47:07 localhost NetworkManager: <info>  dhclient started with pid 2361
Jul 27 23:47:07 localhost NetworkManager: <info>  Activation (eth0) Stage 3 of 5 (IP Configure Start) complete.
Jul 27 23:47:07 localhost gconfd (gdm-2360): uruchamianie (wersja 2.22.0), pid 2360, użytkownik "gdm"
Jul 27 23:47:07 localhost dhclient: Internet Systems Consortium DHCP Client 4.0.0
Jul 27 23:47:07 localhost dhclient: Copyright 2004-2007 Internet Systems Consortium.
Jul 27 23:47:07 localhost dhclient: All rights reserved.
Jul 27 23:47:07 localhost dhclient: For info, please visit http://www.isc.org/sw/dhcp/
Jul 27 23:47:07 localhost NetworkManager: <info>  DHCP: device eth0 state changed (null) -> preinit
Jul 27 23:47:07 localhost dhclient: Listening on LPF/eth0/00:1f:c6:85:41:69
Jul 27 23:47:07 localhost dhclient: Sending on   LPF/eth0/00:1f:c6:85:41:69
Jul 27 23:47:07 localhost dhclient: Sending on   Socket/fallback
Jul 27 23:47:07 localhost gconfd (gdm-2360): Uzyskano adres "xml:readonly:/etc/gconf/gconf.xml.mandatory" do źródła konfiguracji tylko do odczytu na pozycji 0
Jul 27 23:47:07 localhost gconfd (gdm-2360): Uzyskano adres "xml:readonly:/etc/gconf/gconf.xml.system" do źródła konfiguracji tylko do odczytu na pozycji 1
Jul 27 23:47:07 localhost gconfd (gdm-2360): Uzyskano adres "xml:readonly:/var/lib/gdm/.gconf.mandatory" do źródła konfiguracji tylko do odczytu na pozycji 2
Jul 27 23:47:07 localhost gconfd (gdm-2360): Uzyskano adres "xml:readwrite:/var/lib/gdm/.gconf" do zapisywalnego źródła konfiguracji na pozycji 3
Jul 27 23:47:07 localhost gconfd (gdm-2360): Uzyskano adres "xml:readonly:/etc/gconf/gconf.xml.defaults" do źródła konfiguracji tylko do odczytu na pozycji 4
Jul 27 23:47:08 localhost avahi-daemon[2217]: Registering new address record for fe80::21f:c6ff:fe85:4169 on eth0.*.
Jul 27 23:47:09 localhost dhclient: DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 7
Jul 27 23:47:09 localhost dhclient: DHCPOFFER from 10.162.0.1
Jul 27 23:47:09 localhost dhclient: DHCPREQUEST on eth0 to 255.255.255.255 port 67
Jul 27 23:47:09 localhost dhclient: DHCPACK from 10.162.0.1
Jul 27 23:47:09 localhost NetworkManager: <info>  DHCP: device eth0 state changed preinit -> bound
Jul 27 23:47:09 localhost NetworkManager: <info>  Activation (eth0) Stage 4 of 5 (IP Configure Get) scheduled...
Jul 27 23:47:09 localhost NetworkManager: <info>  Activation (eth0) Stage 4 of 5 (IP Configure Get) started...
Jul 27 23:47:09 localhost NetworkManager: <info>    address 87.207.27.172
Jul 27 23:47:09 localhost NetworkManager: <info>    netmask 255.255.255.0
Jul 27 23:47:09 localhost NetworkManager: <info>    gateway 87.207.27.1
Jul 27 23:47:09 localhost NetworkManager: <info>    nameserver '62.179.1.62'
Jul 27 23:47:09 localhost NetworkManager: <info>    nameserver '62.179.1.63'
Jul 27 23:47:09 localhost NetworkManager: <info>    domain name 'chello.pl'
Jul 27 23:47:09 localhost NetworkManager: <info>  Activation (eth0) Stage 5 of 5 (IP Configure Commit) scheduled...
Jul 27 23:47:09 localhost NetworkManager: <info>  Activation (eth0) Stage 4 of 5 (IP Configure Get) complete.
Jul 27 23:47:09 localhost NetworkManager: <info>  Activation (eth0) Stage 5 of 5 (IP Configure Commit) started...
Jul 27 23:47:09 localhost avahi-daemon[2217]: Joining mDNS multicast group on interface eth0.IPv4 with address 87.207.27.172.
Jul 27 23:47:09 localhost avahi-daemon[2217]: New relevant interface eth0.IPv4 for mDNS.
Jul 27 23:47:09 localhost avahi-daemon[2217]: Registering new address record for 87.207.27.172 on eth0.IPv4.
Jul 27 23:47:09 localhost dhclient: bound to 87.207.27.172 -- renewal in 55194 seconds.
Jul 27 23:47:09 localhost pulseaudio[2394]: polkit.c: Cannot set UID on session object.
Jul 27 23:47:09 localhost pulseaudio[2394]: main.c: Called SUID root and real-time/high-priority scheduling was requested in the configuration. However, we lack the necessary priviliges:
Jul 27 23:47:09 localhost pulseaudio[2394]: main.c: We are not in group 'pulse-rt' and PolicyKit refuse to grant us priviliges. Dropping SUID again.
Jul 27 23:47:09 localhost pulseaudio[2394]: main.c: For enabling real-time scheduling please acquire the appropriate PolicyKit priviliges, or become a member of 'pulse-rt', or increase the RLIMIT_NICE/RLIMIT_RTPRIO resource limits for this user.
Jul 27 23:47:09 localhost pulseaudio[2394]: main.c: setrlimit(RLIMIT_NICE, (31, 31)) failed: Operacja niedozwolona
Jul 27 23:47:09 localhost pulseaudio[2394]: main.c: setrlimit(RLIMIT_RTPRIO, (9, 9)) failed: Operacja niedozwolona
Jul 27 23:47:09 localhost gconfd (gdm-2360): Błąd przy ustawianiu wartości dla "/apps/gnome-screensaver/power_management_delay": Nie można nadpisać istniejącej wartości przeznaczonej tylko do odczytu: Wartość "/apps/gnome-screensaver/power_management_delay" jest ustawiona w źródle tylko od odczytu na początku ścieżki konfiguracji.
Jul 27 23:47:10 localhost NetworkManager: <info>  (eth0): device state change: 7 -> 8
Jul 27 23:47:10 localhost NetworkManager: <info>  Policy set (eth0) as default device for routing and DNS.
Jul 27 23:47:10 localhost NetworkManager: <info>  Activation (eth0) successful, device activated.
Jul 27 23:47:10 localhost NetworkManager: <info>  Activation (eth0) Stage 5 of 5 (IP Configure Commit) complete.
Jul 27 23:47:17 localhost gconfd (gdm-2360): Zakończenie
Jul 27 23:47:18 localhost gconfd (danz-2467): starting (version 2.22.0), pid 2467 user 'danz'
Jul 27 23:47:18 localhost gconfd (danz-2467): Resolved address "xml:readonly:/etc/gconf/gconf.xml.mandatory" to a read-only configuration source at position 0
Jul 27 23:47:18 localhost gconfd (danz-2467): Resolved address "xml:readwrite:/home/danz/.gconf" to a writable configuration source at position 1
Jul 27 23:47:18 localhost gconfd (danz-2467): Resolved address "xml:readonly:/etc/gconf/gconf.xml.defaults" to a read-only configuration source at position 2
Jul 27 23:47:18 localhost pulseaudio[2515]: main.c: Called SUID root and real-time/high-priority scheduling was requested in the configuration. However, we lack the necessary priviliges:
Jul 27 23:47:18 localhost pulseaudio[2515]: main.c: We are not in group 'pulse-rt' and PolicyKit refuse to grant us priviliges. Dropping SUID again.
Jul 27 23:47:18 localhost pulseaudio[2515]: main.c: For enabling real-time scheduling please acquire the appropriate PolicyKit priviliges, or become a member of 'pulse-rt', or increase the RLIMIT_NICE/RLIMIT_RTPRIO resource limits for this user.
Jul 27 23:47:19 localhost pulseaudio[2515]: pid.c: Stale PID file, overwriting.
Jul 27 23:47:19 localhost pulseaudio[2515]: main.c: setrlimit(RLIMIT_NICE, (31, 31)) failed: Operacja niedozwolona
Jul 27 23:47:19 localhost pulseaudio[2515]: main.c: setrlimit(RLIMIT_RTPRIO, (9, 9)) failed: Operacja niedozwolona
Jul 27 23:47:19 localhost gconfd (danz-2467): Resolved address "xml:readwrite:/home/danz/.gconf" to a writable configuration source at position 0
Jul 27 23:47:20 localhost hcid[2103]: Default passkey agent (:1.31, /org/bluez/passkey) registered
Jul 27 23:47:20 localhost hcid[2103]: Default authorization agent (:1.31, /org/bluez/auth) registered
Jul 27 23:47:20 localhost pulseaudio[2515]: module-x11-xsmp.c: X11 session manager not running.
Jul 27 23:47:20 localhost pulseaudio[2515]: module.c: Failed to load  module "module-x11-xsmp" (argument: ""): initialization failed.
Jul 27 23:47:34 localhost gconfd (root-2707): uruchamianie (wersja 2.22.0), pid 2707, użytkownik "root"
Jul 27 23:47:34 localhost gconfd (root-2707): Uzyskano adres "xml:readonly:/etc/gconf/gconf.xml.mandatory" do źródła konfiguracji tylko do odczytu na pozycji 0
Jul 27 23:47:34 localhost gconfd (root-2707): Uzyskano adres "xml:readwrite:/root/.gconf" do zapisywalnego źródła konfiguracji na pozycji 1
Jul 27 23:47:34 localhost gconfd (root-2707): Uzyskano adres "xml:readonly:/etc/gconf/gconf.xml.defaults" do źródła konfiguracji tylko do odczytu na pozycji 2
jak jest z kolei więcej pamięci 4GB to niestety zawiesza sie i ostatni zapis jaki jest to Registered manager path:/org/bluez/audio, dalej już tylko czarny ekran i koniec intalacji.
Jul 27 23:54:14 localhost kernel: imklog 3.16.1, log source = /proc/kmsg started.
Jul 27 23:54:14 localhost kernel: Initializing cgroup subsys cpuset
Jul 27 23:54:14 localhost kernel: Linux version 2.6.25-14.fc9.x86_64 (mockbuild@) (gcc version 4.3.0 20080428 (Red Hat 4.3.0-8) (GCC) ) #1 SMP Thu May 1 06:06:21 EDT 2008
Jul 27 23:54:14 localhost kernel: Command line: ro root=UUID=84dbcdfe-1da7-4bab-aeb1-fde0a9afc017 rhgb quiet
Jul 27 23:54:14 localhost kernel: BIOS-provided physical RAM map:
Jul 27 23:54:14 localhost kernel:  BIOS-e820: 0000000000000000 - 0000000000096000 (usable)
Jul 27 23:54:14 localhost kernel:  BIOS-e820: 0000000000096000 - 00000000000a0000 (reserved)
Jul 27 23:54:14 localhost kernel:  BIOS-e820: 00000000000e4000 - 0000000000100000 (reserved)
Jul 27 23:54:14 localhost kernel:  BIOS-e820: 0000000000100000 - 00000000cff80000 (usable)
Jul 27 23:54:14 localhost kernel:  BIOS-e820: 00000000cff80000 - 00000000cff8e000 (ACPI data)
Jul 27 23:54:14 localhost kernel:  BIOS-e820: 00000000cff8e000 - 00000000cffe0000 (ACPI NVS)
Jul 27 23:54:14 localhost kernel:  BIOS-e820: 00000000cffe0000 - 00000000d0000000 (reserved)
Jul 27 23:54:14 localhost kernel:  BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
Jul 27 23:54:14 localhost kernel:  BIOS-e820: 00000000fff00000 - 0000000100000000 (reserved)
Jul 27 23:54:14 localhost kernel:  BIOS-e820: 0000000100000000 - 0000000130000000 (usable)
Jul 27 23:54:14 localhost kernel: end_pfn_map = 1245184
Jul 27 23:54:14 localhost kernel: DMI 2.4 present.
Jul 27 23:54:14 localhost kernel: ACPI: RSDP 000FBC10, 0014 (r0 ACPIAM)
Jul 27 23:54:14 localhost kernel: ACPI: RSDT CFF80000, 003C (r1 A_M_I_ OEMRSDT   4000818 MSFT       97)
Jul 27 23:54:14 localhost kernel: ACPI: FACP CFF80200, 0084 (r2 A_M_I_ OEMFACP   4000818 MSFT       97)
Jul 27 23:54:14 localhost kernel: ACPI: DSDT CFF80440, 8B31 (r1  A0916 A0916032       32 INTL 20060113)
Jul 27 23:54:14 localhost kernel: ACPI: FACS CFF8E000, 0040
Jul 27 23:54:14 localhost kernel: ACPI: APIC CFF80390, 006C (r1 A_M_I_ OEMAPIC   4000818 MSFT       97)
Jul 27 23:54:14 localhost kernel: ACPI: MCFG CFF80400, 003C (r1 A_M_I_ OEMMCFG   4000818 MSFT       97)
Jul 27 23:54:14 localhost kernel: ACPI: OEMB CFF8E040, 0081 (r1 A_M_I_ AMI_OEM   4000818 MSFT       97)
Jul 27 23:54:14 localhost kernel: ACPI: HPET CFF88F80, 0038 (r1 A_M_I_ OEMHPET   4000818 MSFT       97)
Jul 27 23:54:14 localhost kernel: ACPI: OSFR CFF88FC0, 00B0 (r1 A_M_I_ OEMOSFR   4000818 MSFT       97)
Jul 27 23:54:14 localhost kernel: No NUMA configuration found
Jul 27 23:54:14 localhost kernel: Faking a node at 0000000000000000-0000000130000000
Jul 27 23:54:14 localhost kernel: Bootmem setup node 0 0000000000000000-0000000130000000
Jul 27 23:54:14 localhost kernel:   NODE_DATA [000000000000e000 - 0000000000015fff]
Jul 27 23:54:14 localhost kernel:   bootmap [0000000000016000 -  000000000003bfff] pages 26
Jul 27 23:54:14 localhost kernel: early res: 0 [0-fff] BIOS data page
Jul 27 23:54:14 localhost kernel: early res: 1 [6000-7fff] SMP_TRAMPOLINE
Jul 27 23:54:14 localhost kernel: early res: 2 [200000-75db3b] TEXT DATA BSS
Jul 27 23:54:14 localhost kernel: early res: 3 [37c89000-37fef477] RAMDISK
Jul 27 23:54:14 localhost kernel: early res: 4 [96000-9ffff] EBDA
Jul 27 23:54:14 localhost kernel: early res: 5 [8000-dfff] PGTABLE
Jul 27 23:54:14 localhost kernel: Zone PFN ranges:
Jul 27 23:54:14 localhost kernel:   DMA             0 ->     4096
Jul 27 23:54:14 localhost kernel:   DMA32        4096 ->  1048576
Jul 27 23:54:14 localhost kernel:   Normal    1048576 ->  1245184
Jul 27 23:54:14 localhost kernel: Movable zone start PFN for each node
Jul 27 23:54:14 localhost kernel: early_node_map[3] active PFN ranges
Jul 27 23:54:14 localhost kernel:     0:        0 ->      150
Jul 27 23:54:14 localhost kernel:     0:      256 ->   851840
Jul 27 23:54:14 localhost kernel:     0:  1048576 ->  1245184
Jul 27 23:54:14 localhost kernel: ACPI: PM-Timer IO Port: 0x808
Jul 27 23:54:14 localhost kernel: ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
Jul 27 23:54:14 localhost kernel: Processor #0 (Bootup-CPU)
Jul 27 23:54:14 localhost kernel: ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
Jul 27 23:54:14 localhost kernel: Processor #1
Jul 27 23:54:14 localhost kernel: ACPI: LAPIC (acpi_id[0x03] lapic_id[0x82] disabled)
Jul 27 23:54:14 localhost kernel: ACPI: LAPIC (acpi_id[0x04] lapic_id[0x83] disabled)
Jul 27 23:54:14 localhost kernel: ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
Jul 27 23:54:14 localhost kernel: IOAPIC[0]: apic_id 2, address 0xfec00000, GSI 0-23
Jul 27 23:54:14 localhost kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
Jul 27 23:54:14 localhost kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
Jul 27 23:54:14 localhost kernel: Setting APIC routing to flat
Jul 27 23:54:14 localhost kernel: ACPI: HPET id: 0xffffffff base: 0xfed00000
Jul 27 23:54:14 localhost kernel: Using ACPI (MADT) for SMP configuration information
Jul 27 23:54:14 localhost kernel: PM: Registered nosave memory: 0000000000096000 - 00000000000a0000
Jul 27 23:54:14 localhost kernel: PM: Registered nosave memory: 00000000000a0000 - 00000000000e4000
Jul 27 23:54:14 localhost kernel: PM: Registered nosave memory: 00000000000e4000 - 0000000000100000
Jul 27 23:54:14 localhost kernel: PM: Registered nosave memory: 00000000cff80000 - 00000000cff8e000
Jul 27 23:54:14 localhost kernel: PM: Registered nosave memory: 00000000cff8e000 - 00000000cffe0000
Jul 27 23:54:14 localhost kernel: PM: Registered nosave memory: 00000000cffe0000 - 00000000d0000000
Jul 27 23:54:14 localhost kernel: PM: Registered nosave memory: 00000000d0000000 - 00000000fee00000
Jul 27 23:54:14 localhost kernel: PM: Registered nosave memory: 00000000fee00000 - 00000000fee01000
Jul 27 23:54:14 localhost kernel: PM: Registered nosave memory: 00000000fee01000 - 00000000fff00000
Jul 27 23:54:14 localhost kernel: PM: Registered nosave memory: 00000000fff00000 - 0000000100000000
Jul 27 23:54:14 localhost kernel: Allocating PCI resources starting at d4000000 (gap: d0000000:2ee00000)
Jul 27 23:54:14 localhost kernel: SMP: Allowing 4 CPUs, 2 hotplug CPUs
Jul 27 23:54:14 localhost kernel: PERCPU: Allocating 45232 bytes of per cpu data
Jul 27 23:54:14 localhost kernel: Built 1 zonelists in Node order, mobility grouping on.  Total pages: 1029924
Jul 27 23:54:14 localhost kernel: Policy zone: Normal
Jul 27 23:54:14 localhost kernel: Kernel command line: ro root=UUID=84dbcdfe-1da7-4bab-aeb1-fde0a9afc017 rhgb quiet
Jul 27 23:54:14 localhost kernel: Initializing CPU#0
Jul 27 23:54:14 localhost kernel: PID hash table entries: 4096 (order: 12, 32768 bytes)
Jul 27 23:54:14 localhost kernel: TSC calibrated against PM_TIMER
Jul 27 23:54:14 localhost kernel: time.c: Detected 3005.554 MHz processor.
Jul 27 23:54:14 localhost kernel: Console: colour VGA+ 80x25
Jul 27 23:54:14 localhost kernel: console [tty0] enabled
Jul 27 23:54:14 localhost kernel: Checking aperture...
Jul 27 23:54:14 localhost kernel: PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
Jul 27 23:54:14 localhost kernel: Placing software IO TLB between 0x8421000 - 0xc421000
Jul 27 23:54:14 localhost kernel: Memory: 4058408k/4980736k available (2656k kernel code, 134960k reserved, 1396k data, 356k init)
Jul 27 23:54:14 localhost kernel: SLUB: Genslabs=13, HWalign=64, Order=0-1, MinObjects=4, CPUs=4, Nodes=1
Jul 27 23:54:14 localhost kernel: Calibrating delay using timer specific routine.. 6014.21 BogoMIPS (lpj=3007108)
Jul 27 23:54:14 localhost kernel: Security Framework initialized
Jul 27 23:54:14 localhost kernel: SELinux:  Initializing.
Jul 27 23:54:14 localhost kernel: selinux_register_security:  Registering secondary module capability
Jul 27 23:54:14 localhost kernel: Capability LSM initialized as secondary
Jul 27 23:54:14 localhost kernel: Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
Jul 27 23:54:14 localhost kernel: Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
Jul 27 23:54:14 localhost kernel: Mount-cache hash table entries: 256
Jul 27 23:54:14 localhost kernel: Initializing cgroup subsys ns
Jul 27 23:54:14 localhost kernel: Initializing cgroup subsys cpuacct
Jul 27 23:54:14 localhost kernel: CPU: L1 I cache: 32K, L1 D cache: 32K
Jul 27 23:54:14 localhost kernel: CPU: L2 cache: 6144K
Jul 27 23:54:14 localhost kernel: CPU 0/0 -> Node 0
Jul 27 23:54:14 localhost kernel: CPU: Physical Processor ID: 0
Jul 27 23:54:14 localhost kernel: CPU: Processor Core ID: 0
Jul 27 23:54:14 localhost kernel: CPU0: Thermal monitoring enabled (TM2)
Jul 27 23:54:14 localhost kernel: using mwait in idle threads.
Jul 27 23:54:14 localhost kernel: ACPI: Core revision 20070126
Jul 27 23:54:14 localhost kernel: Using local APIC timer interrupts.
Jul 27 23:54:14 localhost kernel: Detected 20.871 MHz APIC timer.
Jul 27 23:54:14 localhost kernel: Booting processor 1/2 APIC 0x1
Jul 27 23:54:14 localhost kernel: Initializing CPU#1
Jul 27 23:54:14 localhost kernel: Calibrating delay using timer specific routine.. 6010.88 BogoMIPS (lpj=3005443)
Jul 27 23:54:14 localhost kernel: CPU 1/1 -> Node 0
Jul 27 23:54:14 localhost kernel: CPU: Processor Core ID: 1
Jul 27 23:54:14 localhost kernel: CPU1: Thermal monitoring enabled (TM2)
Jul 27 23:54:14 localhost kernel: Intel® Core2 Duo CPU     E8400  @ 3.00GHz stepping 06
Jul 27 23:54:14 localhost kernel: checking TSC synchronization [CPU#0 -> CPU#1]: passed.
Jul 27 23:54:14 localhost kernel: Brought up 2 CPUs
Jul 27 23:54:14 localhost kernel: net_namespace: 1016 bytes
Jul 27 23:54:14 localhost kernel: Time: 21:53:55  Date: 07/27/08
Jul 27 23:54:14 localhost kernel: NET: Registered protocol family 16
Jul 27 23:54:14 localhost kernel: No dock devices found.
Jul 27 23:54:14 localhost kernel: ACPI: bus type pci registered
Jul 27 23:54:14 localhost kernel: PCI: Using configuration type 1
Jul 27 23:54:14 localhost kernel: ACPI: Interpreter enabled
Jul 27 23:54:14 localhost kernel: ACPI: (supports S0 S1 S3 S4 S5)
Jul 27 23:54:14 localhost kernel: ACPI: Using IOAPIC for interrupt routing
Jul 27 23:54:14 localhost kernel: ACPI: PCI Root Bridge [PCI0] (0000:00)
Jul 27 23:54:14 localhost kernel: pci 0000:00:1f.0: quirk: region 0800-087f claimed by ICH6 ACPI/GPIO/TCO
Jul 27 23:54:14 localhost kernel: pci 0000:00:1f.0: quirk: region 0480-04bf claimed by ICH6 GPIO
Jul 27 23:54:14 localhost kernel: PCI: Transparent bridge - 0000:00:1e.0
Jul 27 23:54:14 localhost kernel: ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 10 *11 12 14 15)
Jul 27 23:54:14 localhost kernel: ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 *10 11 12 14 15)
Jul 27 23:54:14 localhost kernel: ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 *5 6 7 10 11 12 14 15)
Jul 27 23:54:14 localhost kernel: ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 10 11 12 *14 15)
Jul 27 23:54:14 localhost kernel: ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
Jul 27 23:54:14 localhost kernel: ACPI: PCI Interrupt Link [LNKF] (IRQs *3 4 5 6 7 10 11 12 14 15)
Jul 27 23:54:14 localhost kernel: ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 10 11 12 14 *15)
Jul 27 23:54:14 localhost kernel: ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 *7 10 11 12 14 15)
Jul 27 23:54:14 localhost kernel: ACPI Warning (tbutils-0217): Incorrect checksum in table [OEMB] -  7A, should be 71 [20070126]
Jul 27 23:54:14 localhost kernel: Linux Plug and Play Support v0.97 © Adam Belay
Jul 27 23:54:14 localhost kernel: pnp: PnP ACPI init
Jul 27 23:54:14 localhost kernel: ACPI: bus type pnp registered
Jul 27 23:54:14 localhost kernel: pnp: PnP ACPI: found 16 devices
Jul 27 23:54:14 localhost kernel: ACPI: ACPI bus type pnp unregistered
Jul 27 23:54:14 localhost kernel: usbcore: registered new interface driver usbfs
Jul 27 23:54:14 localhost kernel: usbcore: registered new interface driver hub
Jul 27 23:54:14 localhost kernel: usbcore: registered new device driver usb
Jul 27 23:54:14 localhost kernel: PCI: Using ACPI for IRQ routing
Jul 27 23:54:14 localhost kernel: PCI: If a device doesn't work, try "pci=routeirq".  If it helps, post a report
Jul 27 23:54:14 localhost kernel: NetLabel: Initializing
Jul 27 23:54:14 localhost kernel: NetLabel:  domain hash size = 128
Jul 27 23:54:14 localhost kernel: NetLabel:  protocols = UNLABELED CIPSOv4
Jul 27 23:54:14 localhost kernel: NetLabel:  unlabeled traffic allowed by default
Jul 27 23:54:14 localhost kernel: PCI-GART: No AMD northbridge found.
Jul 27 23:54:14 localhost kernel: hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0
Jul 27 23:54:14 localhost kernel: hpet0: 4 64-bit timers, 14318180 Hz
Jul 27 23:54:14 localhost kernel: ACPI: RTC can wake from S4
Jul 27 23:54:14 localhost kernel: system 00:01: iomem range 0xfed14000-0xfed19fff has been reserved
Jul 27 23:54:14 localhost kernel: system 00:07: ioport range 0x290-0x297 has been reserved
Jul 27 23:54:14 localhost kernel: system 00:08: ioport range 0x4d0-0x4d1 has been reserved
Jul 27 23:54:14 localhost kernel: system 00:08: ioport range 0x800-0x87f has been reserved
Jul 27 23:54:14 localhost kernel: system 00:08: ioport range 0x480-0x4bf has been reserved
Jul 27 23:54:14 localhost kernel: system 00:08: iomem range 0xfed1c000-0xfed1ffff has been reserved
Jul 27 23:54:14 localhost kernel: system 00:08: iomem range 0xfed20000-0xfed3ffff has been reserved
Jul 27 23:54:14 localhost kernel: system 00:08: iomem range 0xfed50000-0xfed8ffff has been reserved
Jul 27 23:54:14 localhost kernel: system 00:08: iomem range 0xffa00000-0xffafffff has been reserved
Jul 27 23:54:14 localhost kernel: system 00:08: iomem range 0xffb00000-0xffbfffff has been reserved
Jul 27 23:54:14 localhost kernel: system 00:08: iomem range 0xffe00000-0xffefffff has been reserved
Jul 27 23:54:14 localhost kernel: system 00:08: iomem range 0xfff00000-0xfffffffe could not be reserved
Jul 27 23:54:14 localhost kernel: system 00:0b: iomem range 0xfec00000-0xfec00fff has been reserved
Jul 27 23:54:14 localhost kernel: system 00:0b: iomem range 0xfee00000-0xfee00fff could not be reserved
Jul 27 23:54:14 localhost kernel: system 00:0e: iomem range 0xe0000000-0xefffffff has been reserved
Jul 27 23:54:14 localhost kernel: system 00:0f: iomem range 0x0-0x9ffff could not be reserved
Jul 27 23:54:14 localhost kernel: system 00:0f: iomem range 0xc0000-0xcffff has been reserved
Jul 27 23:54:14 localhost kernel: system 00:0f: iomem range 0xe0000-0xfffff could not be reserved
Jul 27 23:54:14 localhost kernel: system 00:0f: iomem range 0x100000-0xcfffffff could not be reserved
Jul 27 23:54:14 localhost kernel: system 00:0f: iomem range 0x0-0x0 could not be reserved
Jul 27 23:54:14 localhost kernel: PCI: Bridge: 0000:00:01.0
Jul 27 23:54:14 localhost kernel:   IO window: b000-bfff
Jul 27 23:54:14 localhost kernel:   MEM window: 0xfa000000-0xfe8fffff
Jul 27 23:54:14 localhost kernel:   PREFETCH window: 0x00000000d0000000-0x00000000dfffffff
Jul 27 23:54:14 localhost kernel: PCI: Bridge: 0000:00:1c.0
Jul 27 23:54:14 localhost kernel:   IO window: disabled.
Jul 27 23:54:14 localhost kernel:   MEM window: disabled.
Jul 27 23:54:14 localhost kernel:   PREFETCH window: 0x00000000f8f00000-0x00000000f8ffffff
Jul 27 23:54:14 localhost kernel: PCI: Bridge: 0000:00:1c.4
Jul 27 23:54:14 localhost kernel:   IO window: d000-dfff
Jul 27 23:54:14 localhost kernel:   MEM window: 0xfea00000-0xfeafffff
Jul 27 23:54:14 localhost kernel:   PREFETCH window: disabled.
Jul 27 23:54:14 localhost kernel: PCI: Bridge: 0000:00:1c.5
Jul 27 23:54:14 localhost kernel:   IO window: c000-cfff
Jul 27 23:54:14 localhost kernel:   MEM window: 0xfe900000-0xfe9fffff
Jul 27 23:54:14 localhost kernel: PCI: Bridge: 0000:00:1e.0
Jul 27 23:54:14 localhost kernel:   IO window: e000-efff
Jul 27 23:54:14 localhost kernel:   MEM window: 0xfeb00000-0xfebfffff
Jul 27 23:54:14 localhost kernel: ACPI: PCI Interrupt 0000:00:01.0[A] -> GSI 16 (level, low) -> IRQ 16
Jul 27 23:54:14 localhost kernel: ACPI: PCI Interrupt 0000:00:1c.0[A] -> GSI 17 (level, low) -> IRQ 17
Jul 27 23:54:14 localhost kernel: ACPI: PCI Interrupt 0000:00:1c.4[A] -> GSI 17 (level, low) -> IRQ 17
Jul 27 23:54:14 localhost kernel: ACPI: PCI Interrupt 0000:00:1c.5[b] -> GSI 16 (level, low) -> IRQ 16
Jul 27 23:54:14 localhost kernel: NET: Registered protocol family 2
Jul 27 23:54:14 localhost kernel: IP route cache hash table entries: 131072 (order: 8, 1048576 bytes)
Jul 27 23:54:14 localhost kernel: TCP established hash table entries: 524288 (order: 11, 8388608 bytes)
Jul 27 23:54:14 localhost kernel: TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
Jul 27 23:54:14 localhost kernel: TCP: Hash tables configured (established 524288 bind 65536)
Jul 27 23:54:14 localhost kernel: TCP reno registered
Jul 27 23:54:14 localhost kernel: checking if image is initramfs... it is
Jul 27 23:54:14 localhost kernel: Freeing initrd memory: 3481k freed
Jul 27 23:54:14 localhost kernel: audit: initializing netlink socket (disabled)
Jul 27 23:54:14 localhost kernel: type=2000 audit(1217195635.402:1): initialized
Jul 27 23:54:14 localhost kernel: Total HugeTLB memory allocated, 0
Jul 27 23:54:14 localhost kernel: VFS: Disk quotas dquot_6.5.1
Jul 27 23:54:14 localhost kernel: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Jul 27 23:54:14 localhost kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
Jul 27 23:54:14 localhost kernel: io scheduler noop registered
Jul 27 23:54:14 localhost kernel: io scheduler anticipatory registered
Jul 27 23:54:14 localhost kernel: io scheduler deadline registered
Jul 27 23:54:14 localhost kernel: io scheduler cfq registered (default)
Jul 27 23:54:14 localhost kernel: assign_interrupt_mode Found MSI capability
Jul 27 23:54:14 localhost kernel: pci_hotplug: PCI Hot Plug PCI Core version: 0.5
Jul 27 23:54:14 localhost kernel: ACPI: SSDT CFF8E0D0, 01D2 (r1    AMI   CPU1PM        1 INTL 20060113)
Jul 27 23:54:14 localhost kernel: ACPI: ACPI0007:00 is registered as cooling_device0
Jul 27 23:54:14 localhost kernel: ACPI: SSDT CFF8E2B0, 0143 (r1    AMI   CPU2PM        1 INTL 20060113)
Jul 27 23:54:14 localhost kernel: ACPI: ACPI0007:01 is registered as cooling_device1
Jul 27 23:54:14 localhost kernel: Non-volatile memory driver v1.2
Jul 27 23:54:14 localhost kernel: Linux agpgart interface v0.103
Jul 27 23:54:14 localhost kernel: Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
Jul 27 23:54:14 localhost kernel: serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
Jul 27 23:54:14 localhost kernel: 00:0a: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
Jul 27 23:54:14 localhost kernel: brd: module loaded
Jul 27 23:54:14 localhost kernel: input: Macintosh mouse button emulation as /devices/virtual/input/input0
Jul 27 23:54:14 localhost kernel: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f03:PS2M] at 0x60,0x64 irq 1,12
Jul 27 23:54:14 localhost kernel: serio: i8042 KBD port at 0x60,0x64 irq 1
Jul 27 23:54:14 localhost kernel: serio: i8042 AUX port at 0x60,0x64 irq 12
Jul 27 23:54:14 localhost kernel: mice: PS/2 mouse device common for all mice
Jul 27 23:54:14 localhost kernel: input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input1
Jul 27 23:54:14 localhost kernel: rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
Jul 27 23:54:14 localhost kernel: rtc0: alarms up to one month, y3k
Jul 27 23:54:14 localhost kernel: cpuidle: using governor ladder
Jul 27 23:54:14 localhost kernel: cpuidle: using governor menu
Jul 27 23:54:14 localhost kernel: usbcore: registered new interface driver hiddev
Jul 27 23:54:14 localhost kernel: usbcore: registered new interface driver usbhid
Jul 27 23:54:14 localhost kernel: drivers/hid/usbhid/hid-core.c: v2.6:USB HID core driver
Jul 27 23:54:14 localhost kernel: TCP cubic registered
Jul 27 23:54:14 localhost kernel: Initializing XFRM netlink socket
Jul 27 23:54:14 localhost kernel: NET: Registered protocol family 17
Jul 27 23:54:14 localhost kernel: registered taskstats version 1
Jul 27 23:54:14 localhost kernel:   Magic number: 0:603:905
Jul 27 23:54:14 localhost kernel: Freeing unused kernel memory: 356k freed
Jul 27 23:54:14 localhost kernel: Write protecting the kernel read-only data: 1120k
Jul 27 23:54:14 localhost kernel: ACPI: PCI Interrupt 0000:00:1a.7[C] -> GSI 18 (level, low) -> IRQ 18
Jul 27 23:54:14 localhost kernel: ehci_hcd 0000:00:1a.7: EHCI Host Controller
Jul 27 23:54:14 localhost kernel: ehci_hcd 0000:00:1a.7: new USB bus registered, assigned bus number 1
Jul 27 23:54:14 localhost kernel: ehci_hcd 0000:00:1a.7: debug port 1
Jul 27 23:54:14 localhost kernel: ehci_hcd 0000:00:1a.7: irq 18, io mem 0xf9fffc00
Jul 27 23:54:14 localhost kernel: ehci_hcd 0000:00:1a.7: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
Jul 27 23:54:14 localhost kernel: usb usb1: configuration #1 chosen from 1 choice
Jul 27 23:54:14 localhost kernel: hub 1-0:1.0: USB hub found
Jul 27 23:54:14 localhost kernel: hub 1-0:1.0: 6 ports detected
Jul 27 23:54:14 localhost kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Jul 27 23:54:14 localhost kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jul 27 23:54:14 localhost kernel: usb usb1: Product: EHCI Host Controller
Jul 27 23:54:14 localhost kernel: usb usb1: Manufacturer: Linux 2.6.25-14.fc9.x86_64 ehci_hcd
Jul 27 23:54:14 localhost kernel: usb usb1: SerialNumber: 0000:00:1a.7
Jul 27 23:54:14 localhost kernel: ACPI: PCI Interrupt 0000:00:1d.7[A] -> GSI 23 (level, low) -> IRQ 23
Jul 27 23:54:14 localhost kernel: ehci_hcd 0000:00:1d.7: EHCI Host Controller
Jul 27 23:54:14 localhost kernel: ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 2
Jul 27 23:54:14 localhost kernel: ehci_hcd 0000:00:1d.7: debug port 1
Jul 27 23:54:14 localhost kernel: ehci_hcd 0000:00:1d.7: irq 23, io mem 0xf9fff800
Jul 27 23:54:14 localhost kernel: ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
Jul 27 23:54:14 localhost kernel: usb usb2: configuration #1 chosen from 1 choice
Jul 27 23:54:14 localhost kernel: hub 2-0:1.0: USB hub found
Jul 27 23:54:14 localhost kernel: hub 2-0:1.0: 6 ports detected
Jul 27 23:54:14 localhost kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
Jul 27 23:54:14 localhost kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jul 27 23:54:14 localhost kernel: usb usb2: Product: EHCI Host Controller
Jul 27 23:54:14 localhost kernel: usb usb2: Manufacturer: Linux 2.6.25-14.fc9.x86_64 ehci_hcd
Jul 27 23:54:14 localhost kernel: usb usb2: SerialNumber: 0000:00:1d.7
Jul 27 23:54:14 localhost kernel: USB Universal Host Controller Interface driver v3.0
Jul 27 23:54:14 localhost kernel: ACPI: PCI Interrupt 0000:00:1a.0[A] -> GSI 16 (level, low) -> IRQ 16
Jul 27 23:54:14 localhost kernel: uhci_hcd 0000:00:1a.0: UHCI Host Controller
Jul 27 23:54:14 localhost kernel: uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 3
Jul 27 23:54:14 localhost kernel: uhci_hcd 0000:00:1a.0: irq 16, io base 0x0000a800
Jul 27 23:54:14 localhost kernel: usb usb3: configuration #1 chosen from 1 choice
Jul 27 23:54:14 localhost kernel: hub 3-0:1.0: USB hub found
Jul 27 23:54:14 localhost kernel: hub 3-0:1.0: 2 ports detected
Jul 27 23:54:14 localhost kernel: usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
Jul 27 23:54:14 localhost kernel: usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jul 27 23:54:14 localhost kernel: usb usb3: Product: UHCI Host Controller
Jul 27 23:54:14 localhost kernel: usb usb3: Manufacturer: Linux 2.6.25-14.fc9.x86_64 uhci_hcd
Jul 27 23:54:14 localhost kernel: usb usb3: SerialNumber: 0000:00:1a.0
Jul 27 23:54:14 localhost kernel: ACPI: PCI Interrupt 0000:00:1a.1[b] -> GSI 21 (level, low) -> IRQ 21
Jul 27 23:54:14 localhost kernel: uhci_hcd 0000:00:1a.1: UHCI Host Controller
Jul 27 23:54:14 localhost kernel: uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 4
Jul 27 23:54:14 localhost kernel: uhci_hcd 0000:00:1a.1: irq 21, io base 0x0000a880
Jul 27 23:54:14 localhost kernel: usb usb4: configuration #1 chosen from 1 choice
Jul 27 23:54:14 localhost kernel: hub 4-0:1.0: USB hub found
Jul 27 23:54:14 localhost kernel: hub 4-0:1.0: 2 ports detected
Jul 27 23:54:14 localhost kernel: usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
Jul 27 23:54:14 localhost kernel: usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jul 27 23:54:14 localhost kernel: usb usb4: Product: UHCI Host Controller
Jul 27 23:54:14 localhost kernel: usb usb4: Manufacturer: Linux 2.6.25-14.fc9.x86_64 uhci_hcd
Jul 27 23:54:14 localhost kernel: usb usb4: SerialNumber: 0000:00:1a.1
Jul 27 23:54:14 localhost kernel: ACPI: PCI Interrupt 0000:00:1a.2[C] -> GSI 18 (level, low) -> IRQ 18
Jul 27 23:54:14 localhost kernel: uhci_hcd 0000:00:1a.2: UHCI Host Controller
Jul 27 23:54:14 localhost kernel: uhci_hcd 0000:00:1a.2: new USB bus registered, assigned bus number 5
Jul 27 23:54:14 localhost kernel: uhci_hcd 0000:00:1a.2: irq 18, io base 0x0000ac00
Jul 27 23:54:14 localhost kernel: usb usb5: configuration #1 chosen from 1 choice
Jul 27 23:54:14 localhost kernel: hub 5-0:1.0: USB hub found
Jul 27 23:54:14 localhost kernel: hub 5-0:1.0: 2 ports detected
Jul 27 23:54:14 localhost kernel: usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
Jul 27 23:54:14 localhost kernel: usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jul 27 23:54:14 localhost kernel: usb usb5: Product: UHCI Host Controller
Jul 27 23:54:14 localhost kernel: usb usb5: Manufacturer: Linux 2.6.25-14.fc9.x86_64 uhci_hcd
Jul 27 23:54:14 localhost kernel: usb usb5: SerialNumber: 0000:00:1a.2
Jul 27 23:54:14 localhost kernel: ACPI: PCI Interrupt 0000:00:1d.0[A] -> GSI 23 (level, low) -> IRQ 23
Jul 27 23:54:14 localhost kernel: uhci_hcd 0000:00:1d.0: UHCI Host Controller
Jul 27 23:54:14 localhost kernel: uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 6
Jul 27 23:54:14 localhost kernel: uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000a080
Jul 27 23:54:14 localhost kernel: usb usb6: configuration #1 chosen from 1 choice
Jul 27 23:54:14 localhost kernel: hub 6-0:1.0: USB hub found
Jul 27 23:54:14 localhost kernel: hub 6-0:1.0: 2 ports detected
Jul 27 23:54:14 localhost kernel: usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
Jul 27 23:54:14 localhost kernel: usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jul 27 23:54:14 localhost kernel: usb usb6: Product: UHCI Host Controller
Jul 27 23:54:14 localhost kernel: usb usb6: Manufacturer: Linux 2.6.25-14.fc9.x86_64 uhci_hcd
Jul 27 23:54:14 localhost kernel: usb usb6: SerialNumber: 0000:00:1d.0
Jul 27 23:54:14 localhost kernel: ACPI: PCI Interrupt 0000:00:1d.1[b] -> GSI 19 (level, low) -> IRQ 19
Jul 27 23:54:14 localhost kernel: uhci_hcd 0000:00:1d.1: UHCI Host Controller
Jul 27 23:54:14 localhost kernel: uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 7
Jul 27 23:54:14 localhost kernel: uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000a400
Jul 27 23:54:14 localhost kernel: usb usb7: configuration #1 chosen from 1 choice
Jul 27 23:54:14 localhost kernel: hub 7-0:1.0: USB hub found
Jul 27 23:54:14 localhost kernel: hub 7-0:1.0: 2 ports detected
Jul 27 23:54:14 localhost kernel: usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
Jul 27 23:54:14 localhost kernel: usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jul 27 23:54:14 localhost kernel: usb usb7: Product: UHCI Host Controller
Jul 27 23:54:14 localhost kernel: usb usb7: Manufacturer: Linux 2.6.25-14.fc9.x86_64 uhci_hcd
Jul 27 23:54:14 localhost kernel: usb usb7: SerialNumber: 0000:00:1d.1
Jul 27 23:54:14 localhost kernel: ACPI: PCI Interrupt 0000:00:1d.2[C] -> GSI 18 (level, low) -> IRQ 18
Jul 27 23:54:14 localhost kernel: uhci_hcd 0000:00:1d.2: UHCI Host Controller
Jul 27 23:54:14 localhost kernel: uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 8
Jul 27 23:54:14 localhost kernel: uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000a480
Jul 27 23:54:14 localhost kernel: usb usb8: configuration #1 chosen from 1 choice
Jul 27 23:54:14 localhost kernel: hub 8-0:1.0: USB hub found
Jul 27 23:54:14 localhost kernel: hub 8-0:1.0: 2 ports detected
Jul 27 23:54:14 localhost kernel: usb 5-2: new low speed USB device using uhci_hcd and address 2
Jul 27 23:54:14 localhost kernel: usb usb8: New USB device found, idVendor=1d6b, idProduct=0001
Jul 27 23:54:14 localhost kernel: usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jul 27 23:54:14 localhost kernel: usb usb8: Product: UHCI Host Controller
Jul 27 23:54:14 localhost kernel: usb usb8: Manufacturer: Linux 2.6.25-14.fc9.x86_64 uhci_hcd
Jul 27 23:54:14 localhost kernel: usb usb8: SerialNumber: 0000:00:1d.2
Jul 27 23:54:14 localhost kernel: SCSI subsystem initialized
Jul 27 23:54:14 localhost kernel: Driver 'sd' needs updating - please use bus_type methods
Jul 27 23:54:14 localhost kernel: ACPI: PCI Interrupt 0000:00:1f.2[b] -> GSI 22 (level, low) -> IRQ 22
Jul 27 23:54:14 localhost kernel: usb 5-2: configuration #1 chosen from 1 choice
Jul 27 23:54:14 localhost kernel: input: Logitech USB-PS/2 Optical Mouse as /devices/pci0000:00/0000:00:1a.2/usb5/5-2/5-2:1.0/input/input2
Jul 27 23:54:14 localhost kernel: input,hidraw0: USB HID v1.10 Mouse [Logitech USB-PS/2 Optical Mouse] on usb-0000:00:1a.2-2
Jul 27 23:54:14 localhost kernel: usb 5-2: New USB device found, idVendor=046d, idProduct=c00e
Jul 27 23:54:14 localhost kernel: usb 5-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Jul 27 23:54:14 localhost kernel: usb 5-2: Product: USB-PS/2 Optical Mouse
Jul 27 23:54:14 localhost kernel: usb 5-2: Manufacturer: Logitech
Jul 27 23:54:14 localhost kernel: ahci 0000:00:1f.2: AHCI 0001.0200 32 slots 6 ports 3 Gbps 0x3f impl RAID mode
Jul 27 23:54:14 localhost kernel: ahci 0000:00:1f.2: flags: 64bit ncq sntf stag pm led clo pmp pio slum part
Jul 27 23:54:14 localhost kernel: scsi0 : ahci
Jul 27 23:54:14 localhost kernel: scsi1 : ahci
Jul 27 23:54:14 localhost kernel: scsi2 : ahci
Jul 27 23:54:14 localhost kernel: scsi3 : ahci
Jul 27 23:54:14 localhost kernel: scsi4 : ahci
Jul 27 23:54:14 localhost kernel: scsi5 : ahci
Jul 27 23:54:14 localhost kernel: ata1: SATA max UDMA/133 abar m2048@0xf9ffe800 port 0xf9ffe900 irq 22
Jul 27 23:54:14 localhost kernel: ata2: SATA max UDMA/133 abar m2048@0xf9ffe800 port 0xf9ffe980 irq 22
Jul 27 23:54:14 localhost kernel: ata3: SATA max UDMA/133 abar m2048@0xf9ffe800 port 0xf9ffea00 irq 22
Jul 27 23:54:14 localhost kernel: ata4: SATA max UDMA/133 abar m2048@0xf9ffe800 port 0xf9ffea80 irq 22
Jul 27 23:54:14 localhost kernel: ata5: SATA max UDMA/133 abar m2048@0xf9ffe800 port 0xf9ffeb00 irq 22
Jul 27 23:54:14 localhost kernel: ata6: SATA max UDMA/133 abar m2048@0xf9ffe800 port 0xf9ffeb80 irq 22
Jul 27 23:54:14 localhost kernel: ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Jul 27 23:54:14 localhost kernel: ata1.00: ATA-6: ST3500320NS, SN04, max UDMA/133
Jul 27 23:54:14 localhost kernel: ata1.00: 976773168 sectors, multi 0: LBA48 NCQ (depth 31/32)
Jul 27 23:54:14 localhost kernel: ata1.00: configured for UDMA/133
Jul 27 23:54:14 localhost kernel: ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Jul 27 23:54:14 localhost kernel: ata2.00: ATA-6: ST3500320NS, SN04, max UDMA/133
Jul 27 23:54:14 localhost kernel: ata2.00: 976773168 sectors, multi 0: LBA48 NCQ (depth 31/32)
Jul 27 23:54:14 localhost kernel: ata2.00: configured for UDMA/133
Jul 27 23:54:14 localhost kernel: ata3: SATA link down (SStatus 0 SControl 300)
Jul 27 23:54:14 localhost kernel: ata4: SATA link down (SStatus 0 SControl 300)
Jul 27 23:54:14 localhost kernel: ata5: SATA link down (SStatus 0 SControl 300)
Jul 27 23:54:14 localhost kernel: ata6: SATA link down (SStatus 0 SControl 300)
Jul 27 23:54:14 localhost kernel: scsi 0:0:0:0: Direct-Access     ATA      ST3500320NS      SN04 PQ: 0 ANSI: 5
Jul 27 23:54:14 localhost kernel: sd 0:0:0:0: [sda] 976773168 512-byte hardware sectors (500108 MB)
Jul 27 23:54:14 localhost kernel: sd 0:0:0:0: [sda] Write Protect is off
Jul 27 23:54:14 localhost kernel: sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jul 27 23:54:14 localhost kernel:  sda: sda1 sda2
Jul 27 23:54:14 localhost kernel:  sda: p2 exceeds device capacity
Jul 27 23:54:14 localhost kernel: sd 0:0:0:0: [sda] Attached SCSI disk
Jul 27 23:54:14 localhost kernel: scsi 1:0:0:0: Direct-Access     ATA      ST3500320NS      SN04 PQ: 0 ANSI: 5
Jul 27 23:54:14 localhost kernel: sd 1:0:0:0: [sdb] 976773168 512-byte hardware sectors (500108 MB)
Jul 27 23:54:14 localhost kernel: sd 1:0:0:0: [sdb] Write Protect is off
Jul 27 23:54:14 localhost kernel: sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jul 27 23:54:14 localhost kernel:  sdb: unknown partition table
Jul 27 23:54:14 localhost kernel: sd 1:0:0:0: [sdb] Attached SCSI disk
Jul 27 23:54:14 localhost kernel: device-mapper: uevent: version 1.0.3
Jul 27 23:54:14 localhost kernel: device-mapper: ioctl: 4.13.0-ioctl (2007-10-18) initialised: [email protected]
Jul 27 23:54:14 localhost kernel: kjournald starting.  Commit interval 5 seconds
Jul 27 23:54:14 localhost kernel: EXT3-fs: mounted filesystem with ordered data mode.
Jul 27 23:54:14 localhost kernel: type=1404 audit(1217195643.504:2): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
Jul 27 23:54:14 localhost kernel: SELinux: policy loaded with handle_unknown=allow
Jul 27 23:54:14 localhost kernel: type=1403 audit(1217195643.841:3): policy loaded auid=4294967295 ses=4294967295
Jul 27 23:54:14 localhost kernel: Floppy drive(s): fd0 is 1.44M
Jul 27 23:54:14 localhost kernel: FDC 0 is a post-1991 82077
Jul 27 23:54:14 localhost kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
Jul 27 23:54:14 localhost kernel: sd 1:0:0:0: Attached scsi generic sg1 type 0
Jul 27 23:54:14 localhost kernel: input: Power Button (FF) as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
Jul 27 23:54:14 localhost kernel: ACPI: Power Button (FF) [PWRF]
Jul 27 23:54:14 localhost kernel: input: Power Button (CM) as /devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input4
Jul 27 23:54:14 localhost kernel: ACPI: Power Button (CM) [PWRB]
Jul 27 23:54:14 localhost kernel: iTCO_vendor_support: vendor-support=0
Jul 27 23:54:14 localhost kernel: input: PC Speaker as /devices/platform/pcspkr/input/input5
Jul 27 23:54:14 localhost kernel: ACPI: PCI Interrupt 0000:02:00.0[A] -> GSI 17 (level, low) -> IRQ 17
Jul 27 23:54:14 localhost kernel: sky2 0000:02:00.0: v1.21 addr 0xfe9fc000 irq 17 Yukon-EC Ultra (0xb4) rev 3
Jul 27 23:54:14 localhost kernel: sky2 eth0: addr 00:1f:c6:85:41:69
Jul 27 23:54:14 localhost kernel: ACPI: PCI Interrupt 0000:03:00.0[A] -> GSI 16 (level, low) -> IRQ 16
Jul 27 23:54:14 localhost kernel: scsi6 : pata_marvell
Jul 27 23:54:14 localhost kernel: iTCO_wdt: Intel TCO WatchDog Timer Driver v1.02 (26-Jul-2007)
Jul 27 23:54:14 localhost kernel: iTCO_wdt: Found a ICH9R TCO device (Version=2, TCOBASE=0x0860)
Jul 27 23:54:14 localhost kernel: iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
Jul 27 23:54:14 localhost kernel: scsi7 : pata_marvell
Jul 27 23:54:14 localhost kernel: ata7: PATA max UDMA/100 cmd 0xdc00 ctl 0xd880 bmdma 0xd400 irq 16
Jul 27 23:54:14 localhost kernel: ata8: DUMMY
Jul 27 23:54:14 localhost kernel: BAR5:00:00 01:7F 02:22 03:CA 04:00 05:00 06:00 07:00 08:00 09:00 0A:00 0B:00 0C:01 0D:00 0E:00 0F:00
Jul 27 23:54:14 localhost kernel: ata7.01: ATAPI: TSSTcorpCD/DVDW SH-S182D, SB02, max UDMA/33
Jul 27 23:54:14 localhost kernel: ata7.01: configured for UDMA/33
Jul 27 23:54:14 localhost kernel: scsi 6:0:1:0: CD-ROM            TSSTcorp CD/DVDW SH-S182D SB02 PQ: 0 ANSI: 5
Jul 27 23:54:14 localhost kernel: scsi 6:0:1:0: Attached scsi generic sg2 type 5
Jul 27 23:54:14 localhost kernel: ACPI: PCI Interrupt 0000:00:1b.0[A] -> GSI 22 (level, low) -> IRQ 22
Jul 27 23:54:14 localhost kernel: ALSA sound/pci/hda/hda_intel.c:1810: chipset global capabilities = 0x4401
Jul 27 23:54:14 localhost kernel: ALSA sound/pci/hda/hda_intel.c:749: codec_mask = 0x1
Jul 27 23:54:14 localhost kernel: hda_codec: Unknown model for ALC883, trying auto-probe from BIOS...
Jul 27 23:54:14 localhost kernel: ALSA sound/pci/hda/hda_codec.c:1073: Cannot find slave Headphone Playback Volume, skipped
Jul 27 23:54:14 localhost kernel: ALSA sound/pci/hda/hda_codec.c:1073: Cannot find slave Speaker Playback Volume, skipped
Jul 27 23:54:14 localhost rsyslogd: [origin software="rsyslogd" swVersion="3.16.1" x-pid="1796" x-info="http://www.rsyslog.com"] restart
Jul 27 23:54:14 localhost kernel: ALSA sound/pci/hda/hda_codec.c:1073: Cannot find slave Mono Playback Volume, skipped
Jul 27 23:54:14 localhost kernel: ALSA sound/pci/hda/hda_codec.c:1073: Cannot find slave Line-Out Playback Volume, skipped
Jul 27 23:54:14 localhost kernel: ALSA sound/pci/hda/hda_codec.c:1073: Cannot find slave Speaker Playback Switch, skipped
Jul 27 23:54:14 localhost kernel: ALSA sound/pci/hda/hda_codec.c:1073: Cannot find slave Mono Playback Switch, skipped
Jul 27 23:54:14 localhost kernel: ACPI: PCI Interrupt 0000:00:1f.3[C] -> GSI 18 (level, low) -> IRQ 18
Jul 27 23:54:14 localhost kernel: ACPI: PCI Interrupt 0000:05:03.0[A] -> GSI 16 (level, low) -> IRQ 16
Jul 27 23:54:14 localhost kernel: firewire_ohci: Added fw-ohci device 0000:05:03.0, OHCI version 1.10
Jul 27 23:54:14 localhost kernel: Driver 'sr' needs updating - please use bus_type methods
Jul 27 23:54:14 localhost kernel: sr0: scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
Jul 27 23:54:14 localhost kernel: Uniform CD-ROM driver Revision: 3.20
Jul 27 23:54:14 localhost kernel: firewire_core: created device fw0: GUID 001e8c00013936a8, S400
Jul 27 23:54:14 localhost kernel: NET: Registered protocol family 10
Jul 27 23:54:14 localhost kernel: lo: Disabled Privacy Extensions
Jul 27 23:54:14 localhost kernel: mtrr: type mismatch for d0000000,10000000 old: write-back new: write-combining
Jul 27 23:54:14 localhost kernel: device-mapper: multipath: version 1.0.5 loaded
Jul 27 23:54:14 localhost kernel: loop: module loaded
Jul 27 23:54:14 localhost kernel: EXT3 FS on dm-3, internal journal
Jul 27 23:54:14 localhost kernel: EXT3 FS on dm-1, internal journal
Jul 27 23:54:14 localhost kernel: Adding 2031608k swap on /dev/mapper/VolGroup00-LogVol01.  Priority:-1 extents:1 across:2031608k
Jul 27 23:54:14 localhost kernel: IA-32 Microcode Update Driver: v1.14a <[email protected]>
Jul 27 23:54:14 localhost kernel: ip6_tables: © 2000-2006 Netfilter Core Team
Jul 27 23:54:14 localhost kernel: nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
Jul 27 23:54:14 localhost kernel: ip_tables: © 2000-2006 Netfilter Core Team
Jul 27 23:54:15 localhost rpc.statd[1834]: Version 1.1.2 Starting
Jul 27 23:54:15 localhost sm-notify[1836]: sm-notify running as root. chown /var/lib/nfs/sm to choose different user
Jul 27 23:54:15 localhost Backgrounding to notify hosts...
Jul 27 23:54:15 localhost kernel: RPC: Registered udp transport module.
Jul 27 23:54:15 localhost kernel: RPC: Registered tcp transport module.
Jul 27 23:54:16 localhost kernel: fuse init (API version 7.9)
Jul 27 23:54:16 localhost pcscd: pcscdaemon.c:507:main() pcsc-lite 1.4.4 daemon ready.
Jul 27 23:54:16 localhost acpid: starting up
Jul 27 23:54:17 localhost acpid: client connected from 2048[68:68]
Jul 27 23:54:18 localhost NetworkManager: <info>  starting...
Jul 27 23:54:18 localhost NetworkManager: <info>  eth0: Device is fully-supported using driver 'sky2'.
Jul 27 23:54:18 localhost NetworkManager: <info>  Found new Ethernet device 'eth0'.
Jul 27 23:54:18 localhost NetworkManager: <info>  (eth0): exported as /org/freedesktop/Hal/devices/net_00_1f_c6_85_41_69
Jul 27 23:54:18 localhost NetworkManager: <info>  Trying to start the supplicant...
Jul 27 23:54:18 localhost NetworkManager: <info>  Trying to start the system settings daemon...
Jul 27 23:54:18 localhost nm-system-settings: Loaded plugin ifcfg-fedora: © 2007 - 2008 Red Hat, Inc.  To report bugs please use the NetworkManager mailing list.
Jul 27 23:54:18 localhost nm-system-settings:    ifcfg-fedora: parsing /etc/sysconfig/network-scripts/ifcfg-lo ...
Jul 27 23:54:18 localhost nm-system-settings:    ifcfg-fedora:     error: Ignoring loopback device config.
Jul 27 23:54:18 localhost nm-system-settings:    ifcfg-fedora: parsing /etc/sysconfig/network-scripts/ifcfg-eth0 ...
Jul 27 23:54:18 localhost nm-system-settings:    ifcfg-fedora:     error: File '/etc/sysconfig/network-scripts/ifcfg-eth0' specified device 'eth0', but the device's type could not be determined.
Jul 27 23:54:19 localhost hcid[2100]: Bluetooth HCI daemon
Jul 27 23:54:19 localhost kernel: Bluetooth: Core ver 2.11
Jul 27 23:54:19 localhost kernel: NET: Registered protocol family 31
Jul 27 23:54:19 localhost kernel: Bluetooth: HCI device and connection manager initialized
Jul 27 23:54:19 localhost kernel: Bluetooth: HCI socket layer initialized
Jul 27 23:54:19 localhost hcid[2100]: Parsing /etc/bluetooth/main.conf failed: No such file or directory
Jul 27 23:54:19 localhost kernel: Bluetooth: L2CAP ver 2.9
Jul 27 23:54:19 localhost kernel: Bluetooth: L2CAP socket layer initialized
Jul 27 23:54:19 localhost kernel: Bluetooth: RFCOMM socket layer initialized
Jul 27 23:54:19 localhost hcid[2100]: Starting SDP server
Jul 27 23:54:19 localhost kernel: Bluetooth: RFCOMM TTY layer initialized
Jul 27 23:54:19 localhost kernel: Bluetooth: RFCOMM ver 1.8
Jul 27 23:54:19 localhost hcid[2100]: Registered manager path:/org/bluez/serial
Jul 27 23:54:19 localhost kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.2
Jul 27 23:54:19 localhost kernel: Bluetooth: BNEP filters: protocol multicast
Jul 27 23:54:19 localhost kernel: Bridge firewalling registered
Jul 27 23:54:19 localhost kernel: pan0: Dropping NETIF_F_UFO since no NETIF_F_HW_CSUM feature.
Jul 27 23:54:19 localhost hcid[2100]: bridge pan0 created
Jul 27 23:54:19 localhost hcid[2100]: Registered manager path:/org/bluez/network
Jul 27 23:54:19 localhost hcid[2100]: Parsing /etc/bluetooth/input.conf failed: No such file or directory
Jul 27 23:54:19 localhost hcid[2100]: Registered input manager path:/org/bluez/input
Jul 27 23:54:19 localhost hcid[2100]: Unix socket created: 17
Jul 27 23:54:19 localhost hcid[2100]: Registered manager path:/org/bluez/audio
Mam wiec pytanie, co z tym zrobić? Wyłączyć te audio jakoś czy coś takiego. Problem z pamięciami jest tylko na F9 więc nie chcę omawiać wszystkiego od początku. Uznałem że skoro inne dystybucje sobie radzą to trzaba pokolei wykluczać przyczyny które leża w Fedorze.
Co Wy na to?
