Ati X600
maskaz
Pytanie: Wie moze ktos jak odpalic S-video na sterownikach opensource?
xrandr --output TV --mode 800x600 --set TV_FORMAT PALX Error of failed request:  169
  Major opcode of failed request:  150 (RANDR)
  Minor opcode of failed request:  15 ()
  Serial number of failed request:  16
  Current serial number in output stream:  16
xrandr --addmode S-video 800x600
xrandr: cannot find output "S-video"
Poradzilem sobie z tv-out'em przy pomocy tego tutoriala:
http://wiki.cchtml.com/index.php/Fedora_10...tallation_Guide
One more way for i386
Download and install libdrm package from Fedora 9, as described above. You have to prevent yum from updating these packages:
1. perl -i -pe "s/(\[.*\])/\1\nexclude=libdrm/" /etc/yum.repos.d/fedora.repo
2. perl -i -pe "s/(\[.*\])/\1\nexclude=libdrm/" /etc/yum.repos.d/fedora-updates.repo
Install ati driver from amd's binary package.
Install system-config-display package:
1. yum install system-config-display
After the successful install start system-config-display to create an xorg.conf template in /etc/X11. Install ati driver from downloaded binary, edit /etc/X11/xorg.conf. Add these lines:
Section "Extensions" Option "Composite" "Enable" EndSection
Section "ServerFlags" Option "AIGLX" "on" EndSection
Section "DRI" Mode 0666 EndSection
and add to 'Device section':
Option "OpenGLOverlay" "off" Option "VideoOverlay" "on"
Przez przypadek (niefortunny reboot) pominalem dalsza czesc, ku mojemu zdumieniu tv-out ozyl od razu po restarcie :D
Minus - Compiz nie dziala, ale akurat nie jest potrzebny
Cheers
