Dziwne Zachowanie F11, Brak Przejsc Miedzy Tty, Brak Trybu Tekstowego Init 3, Brak Opcji Norhgb
benji
Ok wiec oto wyniki walki z tym problemem:
lspci																																													 16:49
|00:00.0 Host bridge: Intel Corporation Mobile 945GM/PM/GMS, 943/940GML and 945GT Express Memory Controller Hub (rev 03)
00:02.0 VGA compatible controller: Intel Corporation Mobile 945GM/GMS, 943/940GML Express Integrated Graphics Controller (rev 03)
00:02.1 Display controller: Intel Corporation Mobile 945GM/GMS/GME, 943/940GML Express Integrated Graphics Controller (rev 03)
00:1b.0 Audio device: Intel Corporation 82801G (ICH7 Family) High Definition Audio Controller (rev 02)
00:1c.0 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 1 (rev 02)
00:1c.1 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 2 (rev 02)
00:1d.0 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #1 (rev 02)
00:1d.1 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #2 (rev 02)
00:1d.2 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #3 (rev 02)
00:1d.3 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #4 (rev 02)
00:1d.7 USB Controller: Intel Corporation 82801G (ICH7 Family) USB2 EHCI Controller (rev 02)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev e2)
00:1f.0 ISA bridge: Intel Corporation 82801GBM (ICH7-M) LPC Interface Bridge (rev 02)
00:1f.2 IDE interface: Intel Corporation 82801GBM/GHM (ICH7 Family) SATA IDE Controller (rev 02)
00:1f.3 SMBus: Intel Corporation 82801G (ICH7 Family) SMBus Controller (rev 02)
03:00.0 Network controller: Intel Corporation PRO/Wireless 3945ABG [Golan] Network Connection (rev 02)
05:06.0 CardBus bridge: Texas Instruments PCIxx12 Cardbus Controller
05:06.1 FireWire (IEEE 1394): Texas Instruments PCIxx12 OHCI Compliant IEEE 1394 Host Controller
05:06.2 Mass storage controller: Texas Instruments 5-in-1 Multimedia Card Reader (SD/MMC/MS/MS PRO/xD)
05:06.3 SD Host controller: Texas Instruments PCIxx12 SDA Standard Compliant SD Host Controller
05:08.0 Ethernet controller: Intel Corporation PRO/100 VM Network Connection (rev 02)
Karta jak widac intelowska, wczesniej na tym laptopie mialem ubunciaka i w sumie jedyna rzecza ktora mnie od niego odsunela to zle napisane nowe stery do kart video intela, ale jak widze na F11 tez jest ten sam problem.
W /etc/sysconfig/init ustawilem z powrotem BOOTUP na color.
Bez opcji VGA odpala sie ale nie ma framebuffera i jest bardzo duza czcionka co jest niezadowalajace jak dla mnie.
Oto obecny konfig gruba:
cat /boot/grub/menu.lst																																								   16:55
# grub.conf generated by anaconda
# Note that you do not have to rerun grub after making changes to this file
# NOTICE:  You have a /boot partition.  This means that
#		  all kernel and initrd paths are relative to /boot/, eg.
#		  root (hd0,0)
#		  kernel /vmlinuz-version ro root=/dev/sda2
#		  initrd /initrd-version.img
#boot=/dev/sda
default=0
timeout=15
#splashimage=(hd0,0)/grub/splash.xpm.gz
#hiddenmenu
title Fedora (2.6.29.5-191.fc11.i686.PAE)
root (hd0,0)
kernel /vmlinuz-2.6.29.5-191.fc11.i686.PAE ro root=UUID=c725d723-8ce7-4b8e-bbf4-226118bb1d0b nomodeset vga=0x317
initrd /initrd-2.6.29.5-191.fc11.i686.PAE.img
title Fedora (2.6.29.4-167.fc11.i686.PAE)
root (hd0,0)
kernel /vmlinuz-2.6.29.4-167.fc11.i686.PAE ro root=UUID=c725d723-8ce7-4b8e-bbf4-226118bb1d0b nomodeset vga=0x317
initrd /initrd-2.6.29.4-167.fc11.i686.PAE.img
Po ustawieniu opcji "nomodeset" moge uzywac terminali za posrednictwem ctrl+alt+Fx oraz nie laduje mi sie ten dedykowany FB ktory blankowal ekran. W dodatku opcje 'nomodeset' mozna laczyc z opcja 'vga' i wtedy mam ladna czcionke i to wszystko jakos wygada.
Pracuje na standardowym driverze intela i narazie nie bede zmienial na VESE bo wszystko wrocilo do normy.
Dziekuje wszystkim za pomoc i wyjasnienie co sie dzialo.
nie powinno byc blacklist radeonfb ?? jak wylaczyles selinuxa? samo setenforce wylacza dla biezacej sesji. zrobisz reset i dalej selinux jest wlaczony. wylaczasz go permamentnie w /etc/sysconfig/selinux albo dopisujesz do gruba selinux=0 w linii kernela. wystarczy ze zmodyfikowales jakies pliki systemowe (przez np update), i juz ci nie przydzieli kontekstow - w rezultacie nie odpalisz systemu. dlaczego co wersje to gorzej? w windowsie ile jest dziur i jest ok, a ile niezalatamych? w linuksie masz laty codziennie, bo tutaj ludzie ciezko pracuja i traktuja sprawe powaznie, a nie dlatego zeby zbic kase...
Więc co do blacklist to tam już jest radeonfb, a startuje mi radeondrmfb, BTW jak wpiszę oba do blacklist to i tak startuje.
Selinuxa wyłączałem na oba sposoby, czy zadziałało nie wiem bo mi zwisał po tym przy starcie zaraz po zamontowaniu dysków
po pierwszym komunikacie audit.... Problem rozwiązałem przez reinstall.
A tak ogólnie OT: Fedory znam wszystkie od 1 fo 11, używam w firmie od zawsze i twierdzę że ostatnia coby po wypuszczeniu działała bez niespodzianek to chyba 7 czy 8
potem zawsze od razu po relasie pojawiało się milion poprawek bugów.
Przykładowo: w 9 chodziło mi X na driverze Intel spoko, w 10 driver został "poprawiony" i przestał działać in chipsecie ICH5 musiałem przejść na Vesa, do dzisiaj bug wisi nie załatany w Bugzilli. Pierwszy kernel działał, następne z updatów robiły kernel panic.... chodzi o takie coś właśnie i nie ma to żadnego związku z Windowsem, już się lata temu wyleczyłem z takiego podejścia.
No ale to nie w tym miejscu taka dyskusja
Edit: Jeszcze coś zauważyłem, mc się nie uruchamia przy podniesionym eth0, jak eth0 zdownuję to mc działa. W logach śladu nie ma....
hm a sprawdzales ten parametr nomodeset ktory koledzy wczesniej sugerowali?
Sprawdzę to na pewno, na razie wywalczyłem problem z mc, dla potomności i googla:
Problem: midnight commander doesn't start / hangs when network interface is up. [mc nie startuje przy włączonej sieci]
Solution: Add PC-Box and Gateway name to /etc/hosts [dodać nazwy kompa i bramy do hosts]
Why: As shown is strace output, mc looks for it from dns. [pyta dnsa, cholera wie po co o te ip , a jak masz lokalna bramę bez dns'a to wisi]
wlasnie a dodales nazwe komputera do /etc/hosts ?
[maciek @ amd64 os_iso] $ more /etc/hosts
127.0.0.1               localhost.localdomain localhost amd64 amd64.home.local
::1             localhost6.localdomain6 localhost6
u mnie jak podam mu lokalna brame to po restarcie sieci i tak pobiera mi dnsy z routera, i je wstawia do resolv.conf mimo ze mam dhcp wylaczone :) dziwne
Właśnie teraz dodałem ale wpis dla bramy dopiero pomógł, wpis localhost jest domyślny.
Z tego co pamiętam - ale nie na pewno - to networkmanager tak robi, ja go wyłączyłem i odpala się sieć po dawnemu z /etc/init.d/network przez
wpisy statyczne z /etc/sysconfig/network-scripts/ifcfg-ethx.
A co do framebuffera to rzeczywiście:
nomodeset wyłącza wybór przez jądro
vga= włącza VESA VGA
zapomnialem dodac ze odinstalowalem NetworkManagera. co ciekawe przy probier restartu serwisu network wywala mi blad selinuxa :)
edit:
ok zapomnialem ze w ifcfg-eth0 sa wpisane na sztywno adresy DNS :)
Edytowane przez fafig
