Konfiguracja Proftpd
freecast
Witam
mam taki problem mianowicie chce aby proftpd laczylo sie z Baza mysql i pobierało dane dokladnie login i haslo i tworzylo ftp usera moja konfiguracja pliku proftpd wyglada tak
# /etc/proftpd/proftpd.conf -- This is a basic ProFTPD configuration file.
# To really apply changes reload proftpd after modifications.
# Includes DSO modules
Include /etc/proftpd/modules.conf
# Set off to disable IPv6 support which is annoying on IPv4 only boxes.
UseIPv6				off
ServerName			"Debian"
ServerType			standalone
DeferWelcome			off
DefaultRoot			~
MultilineRFC2228		on
DefaultServer			on
ShowSymlinks			on
TimeoutNoTransfer		600
TimeoutStalled			600
TimeoutIdle			1200
DisplayLogin					welcome.msg
DisplayFirstChdir			   .message
ListOptions					"-l"
DenyFilter			\*.*/
# Port 21 is the standard FTP port.
Port				21
# In some cases you have to specify passive ports range to by-pass
# firewall limitations. Ephemeral ports can be used for that, but
# feel free to use a more narrow range.
# PassivePorts					49152 65534
# To prevent DoS attacks, set the maximum number of child processes
# to 30.  If you need to allow more than 30 concurrent connections
# at once, simply increase this value.  Note that this ONLY works
# in standalone mode, in inetd mode you should use an inetd server
# that allows you to limit maximum number of processes per service
# (such as xinetd)
MaxInstances			30
# Set the user and group that the server normally runs at.
User				proftpd
Group				nogroup
# Umask 022 is a good standard umask to prevent new files and dirs
# (second parm) from being group and world writable.
Umask				022  022
# Normally, we want files to be overwriteable.
AllowOverwrite			on
# Uncomment this if you are using NIS or LDAP to retrieve passwords:
# PersistentPasswd		off
# Be warned: use of this directive impacts CPU average load!
# Uncomment this if you like to see progress and transfer rate with ftpwho
# in downloads. That is not needed for uploads rates.
# UseSendFile			off
TransferLog /var/log/proftpd/xferlog
SystemLog   /var/log/proftpd/proftpd.log
<IfModule mod_tls.c>
TLSEngine off
</IfModule>
<IfModule mod_quota.c>
QuotaEngine on
</IfModule>
<IfModule mod_ratio.c>
Ratios on
</IfModule>
# Delay engine reduces impact of the so-called Timing Attack described in
# http://security.lss.hr/index.php?page=deta...=LSS-2004-10-02
# It is on by default.
<IfModule mod_delay.c>
DelayEngine on
</IfModule>
<IfModule mod_ctrls.c>
ControlsEngine		on
ControlsMaxClients	2
ControlsLog		   /var/log/proftpd/controls.log
ControlsInterval	  5
ControlsSocket		/var/run/proftpd/proftpd.sock
</IfModule>
<IfModule mod_ctrls_admin.c>
AdminControlsEngine on
</IfModule>
# A basic anonymous configuration, no upload directories.
# <Anonymous ~ftp>
#   User				ftp
#   Group				nogroup
#   # We want clients to be able to login with "anonymous" as well as "ftp"
#   UserAlias			anonymous ftp
#   # Cosmetic changes, all files belongs to ftp user
#   DirFakeUser	on ftp
#   DirFakeGroup on ftp
#   RequireValidShell		off
#   # Limit the maximum number of anonymous logins
#   MaxClients			10
#   # We want 'welcome.msg' displayed at login, and '.message' displayed
#   # in each newly chdired directory.
#   DisplayLogin			welcome.msg
#   DisplayFirstChdir		.message
#   # Limit WRITE everywhere in the anonymous chroot
#   <Directory *>
#	 <Limit WRITE>
#	   DenyAll
#	 </Limit>
#   </Directory>
#   # Uncomment this if you're brave.
#   # <Directory incoming>
#   #   # Umask 022 is a good standard umask to prevent new files and dirs
#   #   # (second parm) from being group and world writable.
#   #   Umask				022  022
#   #			<Limit READ WRITE>
#   #			DenyAll
#   #			</Limit>
#   #			<Limit STOR>
#   #			AllowAll
#   #			</Limit>
#   # </Directory>
# </Anonymous>
SQLAuthTypes	Plaintext Crypt
SQLAuthenticate	users* groups*
LoadModule		mod_sql_mysql.c
SQLConnectInfo	xxx@localhost ccccc ddddd
SQLUserInfo	ftpuser userid passwd uid gid homedir shell
SQLGroupInfo	ftpgroup groupname gid members
SQLMinID	500
SQLHomedirOnDemand on
SQLLog PASS updatecount
SQLNamedQuery updatecount UPDATE "count=count+1, accessed=now() WHERE userid='%u'" ftpuser
SQLLog  STOR,DELE modified
SQLNamedQuery modified UPDATE "modified=now() WHERE userid='%u'" ftpuser
QuotaEngine on
QuotaDirectoryTally on
QuotaDisplayUnits Mb
QuotaShowQuotas on
SQLNamedQuery get-quota-limit SELECT "name, quota_type, per_session, limit_type, bytes_in_avail, bytes_out_avail, bytes_xfer_avail, files_in_avail, files_out_avail, files_xfer_avail FROM ftpquotalimits WHERE name = '%{0}' AND quota_type = '%{1}'"
SQLNamedQuery get-quota-tally SELECT "name, quota_type, bytes_in_used, bytes_out_used, bytes_xfer_used, files_in_used, files_out_used, files_xfer_used FROM ftpquotatallies WHERE name = '%{0}' AND quota_type = '%{1}'"
SQLNamedQuery update-quota-tally UPDATE "bytes_in_used = bytes_in_used + %{0}, bytes_out_used = bytes_out_used + %{1}, bytes_xfer_used = bytes_xfer_used + %{2}, files_in_used = files_in_used + %{3}, files_out_used = files_out_used + %{4}, files_xfer_used = files_xfer_used + %{5} WHERE name = '%{6}' AND quota_type = '%{7}'" ftpquotatallies
SQLNamedQuery insert-quota-tally INSERT "%{0}, %{1}, %{2}, %{3}, %{4}, %{5}, %{6}, %{7}" ftpquotatallies
QuotaLimitTable sql:/get-quota-limit
QuotaTallyTable sql:/get-quota-tally/update-quota-tally/insert-quota-tally
RootLogin off
przy tej konfiguracji podczas startu proftpd pokazuje mi sie blad :
Fatal: unknown configuration directive 'SQLAuthTypes' on line 81 of '/etc/proftpd.conf'
chxialbym zaznaczyc iz na serwerze zainstalowany jest Direct admin czy moze ktos zna odpowiedz jak skonfigurowac aby wszystko poprawnie dzialalo i twozyly sie vhostyprosił bym o jakąś odpowiedz pozdrawiam :)
Edytowane przez WalDo
zmiana znaczików na właściwe
