F11 Dovecot
AdamS-75
Stopping Dovecot Imap: [FAILED]
Starting Dovecot Imap: Warning: Last died with error (see error log for more information): Auth process died too early - shutting down
[ OK ]
gdzie szukac blędu ?
bo logi mi nic nie mowia :(
Aug 31 16:07:26 ff dovecot: Dovecot v1.2.3 starting up (core dumps disabled)
Aug 31 16:07:26 ff dovecot: auth(default): Fatal: No passdbs specified in confi$
Aug 31 16:07:26 ff dovecot: dovecot: Fatal: Auth process died too early - shutt$
offtopic : jak w vi wyciac linie z # na poczatku ?
## Dovecot configuration file
# If you're in a hurry, see http://wiki.dovecot.org/QuickConfiguration
# "dovecot -n" command gives a clean output of the changed settings. Use it
# instead of copy&pasting this file when posting to the Dovecot mailing list.
# '#' character and everything after it is treated as comments. Extra spaces
# and tabs are ignored. If you want to use either of these explicitly, put the
# value inside quotes, eg.: key = "# char and trailing whitespace  "
# Default values are shown for each setting, it's not required to uncomment
# any of the lines.
# Base directory where to store runtime data.
#base_dir = /var/run/dovecot/
# Protocols we want to be serving: imap imaps pop3 pop3s managesieve
# If you only want to use dovecot-auth, you can set this to "none".
protocols = imap imaps pop3 pop3s
# A space separated list of IP or host addresses where to listen in for
# connections. "*" listens in all IPv4 interfaces. "[::]" listens in all IPv6
# interfaces. Use "*, [::]" for listening both IPv4 and IPv6.
# If you want to specify ports for each service, you will need to configure
# these settings inside the protocol imap/pop3/managesieve { ... } section,
# so you can specify different ports for IMAP/POP3/MANAGESIEVE. For example:
#   protocol imap {
#     listen = *:10143
#     ssl_listen = *:10943
#   protocol pop3 {
#     listen = *:10100
#   protocol managesieve {
#     listen = *:12000
#listen = *, [::]
# Disable LOGIN command and all other plaintext authentications unless
# SSL/TLS is used (LOGINDISABLED capability). Note that if the remote IP
# matches the local IP (ie. you're connecting from the same computer), the
# connection is considered secure and plaintext authentication is allowed.
#disable_plaintext_auth = no
# Should all IMAP and POP3 processes be killed when Dovecot master process
# shuts down. Setting this to "no" means that Dovecot can be upgraded without
# forcing existing client connections to close (although that could also be
# a problem if the upgrade is eg. because of a security fix). This however
# means that after master process has died, the client processes can't write
# to log files anymore.
#shutdown_clients = yes
## Logging
# Log file to use for error messages, instead of sending them to syslog.
# /dev/stderr can be used to log into stderr.
#log_path =
# Log file to use for informational and debug messages.
# Default is the same as log_path.
#info_log_path =
# Prefix for each line written to log file. % codes are in strftime(3)
# format.
#log_timestamp = "%b %d %H:%M:%S "
# Syslog facility to use if you're logging to syslog. Usually if you don't
# want to use "mail", you'll use local0..local7. Also other standard
# facilities are supported.
#syslog_facility = mail
## SSL settings
# IP or host address where to listen in for SSL connections. Remember to also
# add imaps and/or pop3s to protocols setting. Defaults to same as "listen"
# setting if not specified.
#ssl_listen =
# SSL/TLS support: yes, no, required. <doc/wiki/SSL.txt>
#ssl = yes
# PEM encoded X.509 SSL/TLS certificate and private key. They're opened before
# dropping root privileges, so keep the key file unreadable by anyone but
# root. Included doc/mkcert.sh can be used to easily generate self-signed
# certificate, just make sure to update the domains in dovecot-openssl.cnf
#ssl_cert_file = /etc/pki/dovecot/certs/dovecot.pem
#ssl_key_file = /etc/pki/dovecot/private/dovecot.pem
# If key file is password protected, give the password here. Alternatively
# give it when starting dovecot with -p parameter. Since this file is often
# world-readable, you may want to place this setting instead to a different
# root owned 0600 file by using !include_try <path>.
#ssl_key_password =
# File containing trusted SSL certificate authorities. Set this only if you
# intend to use ssl_verify_client_cert=yes. The CAfile should contain the
# CA-certificate(s) followed by the matching CRL(s).
#ssl_ca_file =
# Request client to send a certificate. If you also want to require it, set
# ssl_require_client_cert=yes in auth section.
#ssl_verify_client_cert = no
# Which field from certificate to use for username. commonName and
# x500UniqueIdentifier are the usual choices. You'll also need to set
# ssl_username_from_cert=yes.
#ssl_cert_username_field = commonName
# How often to regenerate the SSL parameters file. Generation is quite CPU
# intensive operation. The value is in hours, 0 disables regeneration
# entirely.
#ssl_parameters_regenerate = 168
# SSL ciphers to use
#ssl_cipher_list = ALL:!LOW:!SSLv2
# Show protocol level SSL errors.
#verbose_ssl = no
## Login processes
# <doc/wiki/LoginProcess.txt>
# Directory where authentication process places authentication UNIX sockets
# which login needs to be able to connect to. The sockets are created when
# running as root, so you don't have to worry about permissions. Note that
# everything in this directory is deleted when Dovecot is started.
#login_dir = /var/run/dovecot/login
# chroot login process to the login_dir. Only reason not to do this is if you
# wish to run the whole Dovecot without roots. <doc/wiki/Rootless.txt>
#login_chroot = yes
# User to use for the login process. Create a completely new user for this,
# and don't use it anywhere else. The user must also belong to a group where
# only it has access, it's used to control access for authentication process.
# Note that this user is NOT used to access mails. <doc/wiki/UserIds.txt>
#login_user = dovecot
# Set max. process size in megabytes. If you don't use
# login_process_per_connection you might need to grow this.
#login_process_size = 64
# Should each login be processed in it's own process (yes), or should one
# login process be allowed to process multiple connections (no)? Yes is more
# secure, espcially with SSL/TLS enabled. No is faster since there's no need
# to create processes all the time.
#login_process_per_connection = yes
# Number of login processes to keep for listening new connections.
#login_processes_count = 3
# Maximum number of login processes to create. The listening process count
# usually stays at login_processes_count, but when multiple users start logging
# in at the same time more extra processes are created. To prevent fork-bombing
# we check only once in a second if new processes should be created - if all
# of them are used at the time, we double their amount until the limit set by
# this setting is reached.
#login_max_processes_count = 128
# Maximum number of connections allowed per each login process. This setting
# is used only if login_process_per_connection=no. Once the limit is reached,
# the process notifies master so that it can create a new login process.
#login_max_connections = 256
# Greeting message for clients.
#login_greeting = Dovecot ready.
# Space separated list of trusted network ranges. Connections from these
# IPs are allowed to override their IP addresses and ports (for logging and
# for authentication checks). disable_plaintext_auth is also ignored for
# these networks. Typically you'd specify your IMAP proxy servers here.
#login_trusted_networks =
# Space-separated list of elements we want to log. The elements which have
# a non-empty variable value are joined together to form a comma-separated
# string.
#login_log_format_elements = user=<%u> method=%m rip=%r lip=%l %c
# Login log format. %$ contains login_log_format_elements string, %s contains
# the data we want to log.
#login_log_format = %$: %s
## Mailbox locations and namespaces
# Location for users' mailboxes. This is the same as the old default_mail_env
# setting. The default is empty, which means that Dovecot tries to find the
# mailboxes automatically. This won't work if the user doesn't have any mail
# yet, so you should explicitly tell Dovecot the full location.
# If you're using mbox, giving a path to the INBOX file (eg. /var/mail/%u)
# isn't enough. You'll also need to tell Dovecot where the other mailboxes are
# kept. This is called the "root mail directory", and it must be the first
# path given in the mail_location setting.
# There are a few special variables you can use, eg.:
#   %u - username
#   %n - user part in user@domain, same as %u if there's no domain
#   %d - domain part in user@domain, empty if there's no domain
#   %h - home directory
# See <doc/wiki/Variables.txt> for full list. Some examples:
  mail_location = maildir:~/Maildir/
#   mail_location = mbox:~/mail:INBOX=/var/mail/%u
#   mail_location = mbox:/var/mail/%d/%1n/%n:INDEX=/var/indexes/%d/%1n/%n
# <doc/wiki/MailLocation.txt>
#mail_location =
# If you need to set multiple mailbox locations or want to change default
# namespace settings, you can do it by defining namespace sections.
# You can have private, shared and public namespaces. Private namespaces
# are for user's personal mails. Shared namespaces are for accessing other
# users' mailboxes that have been shared. Public namespaces are for shared
# mailboxes that are managed by sysadmin. If you create any shared or public
# namespaces you'll typically want to enable ACL plugin also, otherwise all
# users can access all the shared mailboxes, assuming they have permissions
# on filesystem level to do so.
# REMEMBER: If you add any namespaces, the default namespace must be added
# explicitly, ie. mail_location does nothing unless you have a namespace
# without a location setting. Default namespace is simply done by having a
# namespace with empty prefix.
#namespace private {
  # Hierarchy separator to use. You should use the same separator for all
  # namespaces or some clients get confused. '/' is usually a good one.
  # The default however depends on the underlying mail storage format.
  #separator =
  # Prefix required to access this namespace. This needs to be different for
  # all namespaces. For example "Public/".
  #prefix =
  # Physical location of the mailbox. This is in same format as
  # mail_location, which is also the default for it.
  #location =
  # There can be only one INBOX, and this setting defines which namespace
  # has it.
  #inbox = no
  # If namespace is hidden, it's not advertised to clients via NAMESPACE
  # extension. You'll most likely also want to set list=no. This is mostly
  # useful when converting from another server with different namespaces which
  # you want to deprecate but still keep working. For example you can create
  # hidden namespaces with prefixes "~/mail/", "~%u/mail/" and "mail/".
  #hidden = yes
  # Show the mailboxes under this namespace with LIST command. This makes the
  # namespace visible for clients that don't support NAMESPACE extension.
  # "children" value lists child mailboxes, but hides the namespace prefix.
  #list = yes
  # Namespace handles its own subscriptions. If set to "no", the parent
  # namespace handles them (empty prefix should always have this as "yes")
  #subscriptions = yes
# Example shared namespace configuration
#namespace shared {
  #separator = /
  # Mailboxes are visible under "shared/user@domain/"
  # %%n, %%d and %%u are expanded to the destination user.
  #prefix = shared/%%u/
  # Mail location for other users' mailboxes. Note that %variables and ~/
  # expands to the logged in user's data. %%n, %%d, %%u and %%h expand to the
  # destination user's data.
  #location = maildir:%%h/Maildir:INDEX=~/Maildir/shared/%%u
  # Use the default namespace for saving subscriptions.
  #subscriptions = no
  # List the shared/ namespace only if there are visible shared mailboxes.
  #list = children
# System user and group used to access mails. If you use multiple, userdb
# can override these by returning uid or gid fields. You can use either numbers
# or names. <doc/wiki/UserIds.txt>
#mail_uid =
#mail_gid =
# Group to enable temporarily for privileged operations. Currently this is
# used only with INBOX when either its initial creation or dotlocking fails.
# Typically this is set to "mail" to give access to /var/mail.
#mail_privileged_group =
# Grant access to these supplementary groups for mail processes. Typically
# these are used to set up access to shared mailboxes. Note that it may be
# dangerous to set these if users can create symlinks (e.g. if "mail" group is
# set here, ln -s /var/mail ~/mail/var could allow a user to delete others'
# mailboxes, or ln -s /secret/shared/box ~/mail/mybox would allow reading it).
#mail_access_groups =
# Allow full filesystem access to clients. There's no access checks other than
# what the operating system does for the active UID/GID. It works with both
# maildir and mboxes, allowing you to prefix mailboxes names with eg. /path/
# or ~user/.
#mail_full_filesystem_access = no
## Mail processes
# Enable mail process debugging. This can help you figure out why Dovecot
# isn't finding your mails.
#mail_debug = no
# Log prefix for mail processes. See <doc/wiki/Variables.txt> for list of
# possible variables you can use.
#mail_log_prefix = "%Us(%u): "
# Max. number of lines a mail process is allowed to log per second before it's
# throttled. 0 means unlimited. Typically there's no need to change this
# unless you're using mail_log plugin, which may log a lot. This setting is
# ignored while mail_debug=yes to avoid pointless throttling.
#mail_log_max_lines_per_sec = 10
# Don't use mmap() at all. This is required if you store indexes to shared
# filesystems (NFS or clustered filesystem).
#mmap_disable = no
# Rely on O_EXCL to work when creating dotlock files. NFS supports O_EXCL
# since version 3, so this should be safe to use nowadays by default.
#dotlock_use_excl = yes
# Don't use fsync() or fdatasync() calls. This makes the performance better
# at the cost of potential data loss if the server (or the file server)
# goes down.
#fsync_disable = no
# Mail storage exists in NFS. Set this to yes to make Dovecot flush NFS caches
# whenever needed. If you're using only a single mail server this isn't needed.
#mail_nfs_storage = no
# Mail index files also exist in NFS. Setting this to yes requires
# mmap_disable=yes and fsync_disable=no.
#mail_nfs_index = no
# Locking method for index files. Alternatives are fcntl, flock and dotlock.
# Dotlocking uses some tricks which may create more disk I/O than other locking
# methods. NFS users: flock doesn't work, remember to change mmap_disable.
#lock_method = fcntl
# Drop all privileges before exec()ing the mail process. This is mostly
# meant for debugging, otherwise you don't get core dumps. It could be a small
# security risk if you use single UID for multiple users, as the users could
# ptrace() each others processes then.
#mail_drop_priv_before_exec = no
# Show more verbose process titles (in ps). Currently shows user name and
# IP address. Useful for seeing who are actually using the IMAP processes
# (eg. shared mailboxes or if same uid is used for multiple accounts).
#verbose_proctitle = no
# Valid UID range for users, defaults to 500 and above. This is mostly
# to make sure that users can't log in as daemons or other system users.
# Note that denying root logins is hardcoded to dovecot binary and can't
# be done even if first_valid_uid is set to 0.
#first_valid_uid = 500
#last_valid_uid = 0
# Valid GID range for users, defaults to non-root/wheel. Users having
# non-valid GID as primary group ID aren't allowed to log in. If user
# belongs to supplementary groups with non-valid GIDs, those groups are
# not set.
#first_valid_gid = 1
#last_valid_gid = 0
# Maximum number of running mail processes. When this limit is reached,
# new users aren't allowed to log in.
#max_mail_processes = 512
# Set max. process size in megabytes. Most of the memory goes to mmap()ing
# files, so it shouldn't harm much even if this limit is set pretty high.
#mail_process_size = 256
# Maximum allowed length for mail keyword name. It's only forced when trying
# to create new keywords.
#mail_max_keyword_length = 50
# ':' separated list of directories under which chrooting is allowed for mail
# processes (ie. /var/mail will allow chrooting to /var/mail/foo/bar too).
# This setting doesn't affect login_chroot, mail_chroot or auth chroot
# settings. If this setting is empty, "/./" in home dirs are ignored.
# WARNING: Never add directories here which local users can modify, that
# may lead to root exploit. Usually this should be done only if you don't
# allow shell access for users. <doc/wiki/Chrooting.txt>
#valid_chroot_dirs =
# Default chroot directory for mail processes. This can be overridden for
# specific users in user database by giving /./ in user's home directory
# (eg. /home/./user chroots into /home). Note that usually there is no real
# need to do chrooting, Dovecot doesn't allow users to access files outside
# their mail directory anyway. If your home directories are prefixed with
# the chroot directory, append "/." to mail_chroot. <doc/wiki/Chrooting.txt>
#mail_chroot =
## Mailbox handling optimizations
# The minimum number of mails in a mailbox before updates are done to cache
# file. This allows optimizing Dovecot's behavior to do less disk writes at
# the cost of more disk reads.
#mail_cache_min_mail_count = 0
# When IDLE command is running, mailbox is checked once in a while to see if
# there are any new mails or other changes. This setting defines the minimum
# time in seconds to wait between those checks. Dovecot can also use dnotify,
# inotify and kqueue to find out immediately when changes occur.
#mailbox_idle_check_interval = 30
# Save mails with CR+LF instead of plain LF. This makes sending those mails
# take less CPU, especially with sendfile() syscall with Linux and FreeBSD.
# But it also creates a bit more disk I/O which may just make it slower.
# Also note that if other software reads the mboxes/maildirs, they may handle
# the extra CRs wrong and cause problems.
#mail_save_crlf = no
## Maildir-specific settings
# By default LIST command returns all entries in maildir beginning with a dot.
# Enabling this option makes Dovecot return only entries which are directories.
# This is done by stat()ing each entry, so it causes more disk I/O.
# (For systems setting struct dirent->d_type, this check is free and it's
# done always regardless of this setting)
#maildir_stat_dirs = no
# When copying a message, do it with hard links whenever possible. This makes
# the performance much better, and it's unlikely to have any side effects.
#maildir_copy_with_hardlinks = yes
# When copying a message, try to preserve the base filename. Only if the
# destination mailbox already contains the same name (ie. the mail is being
# copied there twice), a new name is given. The destination filename check is
# done only by looking at dovecot-uidlist file, so if something outside
# Dovecot does similar filename preserving copies, you may run into problems.
# NOTE: This setting requires maildir_copy_with_hardlinks = yes to work.
#maildir_copy_preserve_filename = no
# Assume Dovecot is the only MUA accessing Maildir: Scan cur/ directory only
# when its mtime changes unexpectedly or when we can't find the mail otherwise.
#maildir_very_dirty_syncs = no
## mbox-specific settings
# Which locking methods to use for locking mbox. There are four available:
#  dotlock: Create <mailbox>.lock file. This is the oldest and most NFS-safe
#           solution. If you want to use /var/mail/ like directory, the users
#           will need write access to that directory.
#  dotlock_try: Same as dotlock, but if it fails because of permissions or
#               because there isn't enough disk space, just skip it.
#  fcntl  : Use this if possible. Works with NFS too if lockd is used.
#  flock  : May not exist in all systems. Doesn't work with NFS.
#  lockf  : May not exist in all systems. Doesn't work with NFS.
# You can use multiple locking methods; if you do the order they're declared
# in is important to avoid deadlocks if other MTAs/MUAs are using multiple
# locking methods as well. Some operating systems don't allow using some of
# them simultaneously.
#mbox_read_locks = fcntl
#mbox_write_locks = fcntl
# Maximum time in seconds to wait for lock (all of them) before aborting.
#mbox_lock_timeout = 300
# If dotlock exists but the mailbox isn't modified in any way, override the
# lock file after this many seconds.
#mbox_dotlock_change_timeout = 120
# When mbox changes unexpectedly we have to fully read it to find out what
# changed. If the mbox is large this can take a long time. Since the change
# is usually just a newly appended mail, it'd be faster to simply read the
# new mails. If this setting is enabled, Dovecot does this but still safely
# fallbacks to re-reading the whole mbox file whenever something in mbox isn't
# how it's expected to be. The only real downside to this setting is that if
# some other MUA changes message flags, Dovecot doesn't notice it immediately.
# Note that a full sync is done with SELECT, EXAMINE, EXPUNGE and CHECK
# commands.
#mbox_dirty_syncs = yes
# Like mbox_dirty_syncs, but don't do full syncs even with SELECT, EXAMINE,
# EXPUNGE or CHECK commands. If this is set, mbox_dirty_syncs is ignored.
#mbox_very_dirty_syncs = no
# Delay writing mbox headers until doing a full write sync (EXPUNGE and CHECK
# commands and when closing the mailbox). This is especially useful for POP3
# where clients often delete all mails. The downside is that our changes
# aren't immediately visible to other MUAs.
#mbox_lazy_writes = yes
# If mbox size is smaller than this (in kilobytes), don't write index files.
# If an index file already exists it's still read, just not updated.
#mbox_min_index_size = 0
## dbox-specific settings
# Maximum dbox file size in kilobytes until it's rotated.
#dbox_rotate_size = 2048
# Minimum dbox file size in kilobytes before it's rotated
# (overrides dbox_rotate_days)
#dbox_rotate_min_size = 16
# Maximum dbox file age in days until it's rotated. Day always begins from
# midnight, so 1 = today, 2 = yesterday, etc. 0 = check disabled.
#dbox_rotate_days = 0
## IMAP specific settings
protocol imap {
 # Login executable location.
 #login_executable = /usr/libexec/dovecot/imap-login
 # IMAP executable location. Changing this allows you to execute other
 # binaries before the imap process is executed.
 # This would write rawlogs into user's ~/dovecot.rawlog/, if it exists:
 #   mail_executable = /usr/libexec/dovecot/rawlog /usr/libexec/dovecot/imap
 # <doc/wiki/Debugging/Rawlog.txt>
 # This would attach gdb into the imap process and write backtraces into
 # /tmp/gdbhelper.* files:
 #   mail_executable = /usr/libexec/dovecot/gdbhelper /usr/libexec/dovecot/imap
 #mail_executable = /usr/libexec/dovecot/imap
 # Maximum IMAP command line length in bytes. Some clients generate very long
 # command lines with huge mailboxes, so you may need to raise this if you get
 # "Too long argument" or "IMAP command line too large" errors often.
 #imap_max_line_length = 65536
 # Maximum number of IMAP connections allowed for a user from each IP address.
 # NOTE: The username is compared case-sensitively.
 #mail_max_userip_connections = 10
 # Support for dynamically loadable plugins. mail_plugins is a space separated
 # list of plugins to load.
 #mail_plugins =
 #mail_plugin_dir = /usr/lib/dovecot/imap
 # IMAP logout format string:
 #  %i - total number of bytes read from client
 #  %o - total number of bytes sent to client
 #imap_logout_format = bytes=%i/%o
 # Override the IMAP CAPABILITY response.
 #imap_capability =
 # How many seconds to wait between "OK Still here" notifications when
 # client is IDLEing.
 #imap_idle_notify_interval = 120
 # ID field names and values to send to clients. Using * as the value makes
 # Dovecot use the default value. The following fields have default values
 # currently: name, version, os, os-version, support-url, support-email.
 #imap_id_send =
 # ID fields sent by client to log. * means everything.
 #imap_id_log =
 # Workarounds for various client bugs:
 #   delay-newmail:
 #     Send EXISTS/RECENT new mail notifications only when replying to NOOP
 #     and CHECK commands. Some clients ignore them otherwise, for example OSX
 #     Mail (<v2.1). Outlook Express breaks more badly though, without this it
 #     may show user "Message no longer in server" errors. Note that OE6 still
 #     breaks even with this workaround if synchronization is set to
 #     "Headers Only".
 #   netscape-eoh:
 #     Netscape 4.x breaks if message headers don't end with the empty "end of
 #     headers" line. Normally all messages have this, but setting this
 #     workaround makes sure that Netscape never breaks by adding the line if
 #     it doesn't exist. This is done only for FETCH BODY[HEADER.FIELDS..]
 #     commands. Note that RFC says this shouldn't be done.
 #   tb-extra-mailbox-sep:
 #     With mbox storage a mailbox can contain either mails or submailboxes,
 #     but not both. Thunderbird separates these two by forcing server to
 #     accept '/' suffix in mailbox names in subscriptions list.
 # The list is space-separated.
 imap_client_workarounds = delay-newmail outlook-idle netscape-eoh
## POP3 specific settings
protocol pop3 {
 #login_executable = /usr/libexec/dovecot/pop3-login
 # POP3 executable location. See IMAP's mail_executable above for examples
 # how this could be changed.
 #mail_executable = /usr/libexec/dovecot/pop3
 # Don't try to set mails non-recent or seen with POP3 sessions. This is
 # mostly intended to reduce disk I/O. With maildir it doesn't move files
 # from new/ to cur/, with mbox it doesn't write Status-header.
 #pop3_no_flag_updates = no
 # Support LAST command which exists in old POP3 specs, but has been removed
 # from new ones. Some clients still wish to use this though. Enabling this
 # makes RSET command clear all \Seen flags from messages.
 #pop3_enable_last = no
 # If mail has X-UIDL header, use it as the mail's UIDL.
 #pop3_reuse_xuidl = no
 # Keep the mailbox locked for the entire POP3 session.
 #pop3_lock_session = no
 # POP3 UIDL (unique mail identifier) format to use. You can use following
 # variables, along with the variable modifiers described in
 # <doc/wiki/Variables.txt> (e.g.  for the filename in uppercase)
 #  %v - Mailbox's IMAP UIDVALIDITY
 #  %u - Mail's IMAP UID
 #  %m - MD5 sum of the mailbox headers in hex (mbox only)
 #  %f - filename (maildir only)
 # If you want UIDL compatibility with other POP3 servers, use:
 #  UW's ipop3d         : %08Xv%08Xu
 #  Courier             : %f or %v-%u (both might be used simultaneosly)
 #  Cyrus (<= 2.1.3)    : %u
 #  Cyrus (>= 2.1.4)    : %v.%u
 #  Dovecot v0.99.x     : %v.%u
 #  tpop3d              : %Mf
 # Note that Outlook 2003 seems to have problems with %v.%u format which was
 # Dovecot's default, so if you're building a new server it would be a good
 # idea to change this. %08Xu%08Xv should be pretty fail-safe.
pop3_uidl_format = %08Xu%08Xv
 # POP3 logout format string:
 #  %t - number of TOP commands
 #  %p - number of bytes sent to client as a result of TOP command
 #  %r - number of RETR commands
 #  %b - number of bytes sent to client as a result of RETR command
 #  %d - number of deleted messages
 #  %m - number of messages (before deletion)
 #  %s - mailbox size in bytes (before deletion)
 #pop3_logout_format = top=%t/%p, retr=%r/%b, del=%d/%m, size=%s
 # Maximum number of POP3 connections allowed for a user from each IP address.
 #mail_max_userip_connections = 3
 #mail_plugins =
 #mail_plugin_dir = /usr/lib/dovecot/pop3
 #   outlook-no-nuls:
 #     Outlook and Outlook Express hang if mails contain NUL characters.
 #     This setting replaces them with 0x80 character.
 #   oe-ns-eoh:
 #     Outlook Express and Netscape Mail breaks if end of headers-line is
 #     missing. This option simply sends it if it's missing.
pop3_client_workarounds = outlook-no-nuls oe-ns-eoh
## ManageSieve specific settings
 #login_executable = /usr/libexec/dovecot/managesieve-login
 # ManageSieve executable location. See IMAP's mail_executable above for
 # examples how this could be changed.
 #mail_executable = /usr/libexec/dovecot/managesieve
 # Maximum ManageSieve command line length in bytes. This setting is
 # directly borrowed from IMAP. But, since long command lines are very
 # unlikely with ManageSieve, changing this will not be very useful.
 #managesieve_max_line_length = 65536
 # ManageSieve logout format string:
 #managesieve_logout_format = bytes=%i/%o
 # If, for some inobvious reason, the sieve_storage remains unset, the
 # ManageSieve daemon uses the specification of the mail_location to find out
 # where to store the sieve files (see explaination in README.managesieve).
 # The example below, when uncommented, overrides any global mail_location
 # specification and stores all the scripts in '~/mail/sieve' if sieve_storage
 # is unset. However, you should always use the sieve_storage setting.
 # To fool ManageSieve clients that are focused on timesieved you can
 # specify the IMPLEMENTATION capability that the dovecot reports to clients
 # (default: "dovecot").
 #managesieve_implementation_string = Cyrus timsieved v2.2.13
## LDA specific settings
protocol lda {
 # Address to use when sending rejection mails.
 postmaster_address = [email protected]
 # Hostname to use in various parts of sent mails, eg. in Message-Id.
 # Default is the system's real hostname.
 #hostname =
 #mail_plugins =
 #mail_plugin_dir = /usr/lib/dovecot/lda
 # If user is over quota, return with temporary failure instead of
 # bouncing the mail.
 #quota_full_tempfail = no
 # Format to use for logging mail deliveries. You can use variables:
 #  %$ - Delivery status message (e.g. "saved to INBOX")
 #  %m - Message-ID
 #  %s - Subject
 #  %f - From address
 #deliver_log_format = msgid=%m: %$
 # Binary to use for sending mails.
 #sendmail_path = /usr/lib/sendmail
 # Subject: header to use for rejection mails. You can use the same variables
 # as for rejection_reason below.
 #rejection_subject = Rejected: %s
 # Human readable error message for rejection mails. You can use variables:
 #  %n = CRLF, %r = reason, %s = original subject, %t = recipient
 #rejection_reason = Your message to <%t> was automatically rejected:%n%r
 # UNIX socket path to master authentication server to find users.
 #auth_socket_path = /var/run/dovecot/auth-master
## Authentication processes
# Executable location
#auth_executable = /usr/libexec/dovecot/dovecot-auth
#auth_process_size = 256
# Authentication cache size in kilobytes. 0 means it's disabled.
# Note that bsdauth, PAM and vpopmail require cache_key to be set for caching
# to be used.
#auth_cache_size = 0
# Time to live in seconds for cached data. After this many seconds the cached
# record is no longer used, *except* if the main database lookup returns
# internal failure. We also try to handle password changes automatically: If
# user's previous authentication was successful, but this one wasn't, the
# cache isn't used. For now this works only with plaintext authentication.
#auth_cache_ttl = 3600
# TTL for negative hits (user not found, password mismatch).
# 0 disables caching them completely.
#auth_cache_negative_ttl = 3600
# Space separated list of realms for SASL authentication mechanisms that need
# them. You can leave it empty if you don't want to support multiple realms.
# Many clients simply use the first one listed here, so keep the default realm
# first.
#auth_realms =
# Default realm/domain to use if none was specified. This is used for both
# SASL realms and appending @domain to username in plaintext logins.
#auth_default_realm =
# List of allowed characters in username. If the user-given username contains
# a character not listed in here, the login automatically fails. This is just
# an extra check to make sure user can't exploit any potential quote escaping
# vulnerabilities with SQL/LDAP databases. If you want to allow all characters,
# set this value to empty.
#auth_username_chars = abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ01234567890.-_@
# Username character translations before it's looked up from databases. The
# value contains series of from -> to characters. For example "#@/@" means
# that '#' and '/' characters are translated to '@'.
#auth_username_translation =
# Username formatting before it's looked up from databases. You can use
# the standard variables here, eg. %Lu would lowercase the username, %n would
# drop away the domain if it was given, or "%n-AT-%d" would change the '@' into
# "-AT-". This translation is done after auth_username_translation changes.
#auth_username_format =
# If you want to allow master users to log in by specifying the master
# username within the normal username string (ie. not using SASL mechanism's
# support for it), you can specify the separator character here. The format
# is then <username><separator><master username>. UW-IMAP uses "*" as the
# separator, so that could be a good choice.
#auth_master_user_separator =
# Username to use for users logging in with ANONYMOUS SASL mechanism
#auth_anonymous_username = anonymous
# Log unsuccessful authentication attempts and the reasons why they failed.
#auth_verbose = no
# Even more verbose logging for debugging purposes. Shows for example SQL
# queries.
#auth_debug = no
# In case of password mismatches, log the passwords and used scheme so the
# problem can be debugged. Enabling this also enables auth_debug.
#auth_debug_passwords = no
# Maximum number of dovecot-auth worker processes. They're used to execute
# blocking passdb and userdb queries (eg. MySQL and PAM). They're
# automatically created and destroyed as needed.
#auth_worker_max_count = 30
# Host name to use in GSSAPI principal names. The default is to use the
# name returned by gethostname(). Use "$ALL" to allow all keytab entries.
#auth_gssapi_hostname =
# Kerberos keytab to use for the GSSAPI mechanism. Will use the system
# default (usually /etc/krb5.keytab) if not specified.
#auth_krb5_keytab =
# Do NTLM and GSS-SPNEGO authentication using Samba's winbind daemon and
# ntlm_auth helper. <doc/wiki/Authentication/Mechanisms/Winbind.txt>
#auth_use_winbind = no
# Path for Samba's ntlm_auth helper binary.
#auth_winbind_helper_path = /usr/bin/ntlm_auth
# Number of seconds to delay before replying to failed authentications.
#auth_failure_delay = 2
auth default {
socket listen {
   client {
  path = /var/spool/postfix/private/auth
  mode = 0660
  user = postfix
  group = postfix
 mechanisms = plain
#  passdb pam {
 # System users (NSS, /etc/passwd, or similiar)
 # In many systems nowadays this uses Name Service Switch, which is
 # configured in /etc/nsswitch.conf. <doc/wiki/AuthDatabase.Passwd.txt>
 #passdb passwd {
   # [blocking=yes] - See userdb passwd for explanation
   #args =
 # Shadow passwords for system users (NSS, /etc/shadow or similiar).
 # Deprecated by PAM nowadays.
 # <doc/wiki/PasswordDatabase.Shadow.txt>
 #passdb shadow {
   #args =
 # PAM-like authentication for OpenBSD.
 # <doc/wiki/PasswordDatabase.BSDAuth.txt>
 #passdb bsdauth {
   # [cache_key=<key>] - See cache_key in PAM for explanation.
   #args =
 # passwd-like file with specified location
 # <doc/wiki/AuthDatabase.PasswdFile.txt>
 #passdb passwd-file {
   # [scheme=<default password scheme>] [username_format=<format>]
   # <Path for passwd-file>
   #args =
 # checkpassword executable authentication
 # NOTE: You will probably want to use "userdb prefetch" with this.
 # <doc/wiki/AuthDatabase.CheckPassword.txt>
 #passdb checkpassword {
   # Path for checkpassword binary
   #args =
 # SQL database <doc/wiki/AuthDatabase.SQL.txt>
 #passdb sql {
   # Path for SQL configuration file, see doc/dovecot-sql-example.conf
   #args =
 # LDAP database <doc/wiki/AuthDatabase.LDAP.txt>
 #passdb ldap {
   # Path for LDAP configuration file, see doc/dovecot-ldap-example.conf
   #args =
 # vpopmail authentication <doc/wiki/AuthDatabase.VPopMail.txt>
 #passdb vpopmail {
   # [quota_template=<template>] - %q expands to Maildir++ quota
   #   (eg. quota_template=quota_rule=*:backend=%q)
   #args =
 # User database specifies where mails are located and what user/group IDs
 # own them. For single-UID configuration use "static".
 # <doc/wiki/UserDatabase.txt>
 # "prefetch" user database means that the passdb already provided the
 # needed information and there's no need to do a separate userdb lookup.
 # This can be made to work with SQL and LDAP databases, see their example
 # configuration files for more information how to do it.
 # <doc/wiki/UserDatabase.Prefetch.txt>
 #userdb prefetch {
 # System users (NSS, /etc/passwd, or similiar). In many systems nowadays this
 # uses Name Service Switch, which is configured in /etc/nsswitch.conf.
 # <doc/wiki/AuthDatabase.Passwd.txt>
 userdb passwd {
   # [blocking=yes] - By default the lookups are done in the main dovecot-auth
   # process. This setting causes the lookups to be done in auth worker
   # proceses. Useful with remote NSS lookups that may block.
   # NOTE: Be sure to use this setting with nss_ldap or users might get
   # logged in as each others!
   #args =
 #userdb passwd-file {
   # [username_format=<format>] <Path for passwd-file>
   #args =
 # checkpassword executable user database lookup
 #userdb checkpassword {
   #args =
 # static settings generated from template <doc/wiki/UserDatabase.Static.txt>
 #userdb static {
   # Template for the fields. Can return anything a userdb could normally
   # return. For example:
   #  args = uid=500 gid=500 home=/var/mail/%u
   # If you use deliver, it needs to look up users only from the userdb. This
   # of course doesn't work with static because there is no list of users.
   # Normally static userdb handles this by doing a passdb lookup. This works
   # with most passdbs, with PAM being the most notable exception. If you do
   # the user verification another way, you can add allow_all_users=yes to
   # the args in which case the passdb lookup is skipped.
   #args =
 #userdb sql {
   #args =
 #userdb ldap {
   #args =
 # vpopmail <doc/wiki/AuthDatabase.VPopMail.txt>
 #userdb vpopmail {
 # User to use for the process. This user needs access to only user and
 # password databases, nothing else. Only shadow and pam authentication
 # requires roots, so use something else if possible. Note that passwd
 # authentication with BSDs internally accesses shadow files, which also
 # requires roots. Note that this user is NOT used to access mails.
 # That user is specified by userdb above.
 user = root
 # Directory where to chroot the process. Most authentication backends don't
 # work if this is set, and there's no point chrooting if auth_user is root.
 # Note that valid_chroot_dirs isn't needed to use this setting.
 #chroot =
 # Number of authentication processes to create
 #count = 1
 # Require a valid SSL client certificate or the authentication fails.
 #ssl_require_client_cert = no
 # Take the username from client's SSL certificate, using
 # X509_NAME_get_text_by_NID() which returns the subject's DN's
 # CommonName.
 #ssl_username_from_cert = no
 # It's possible to export the authentication interface to other programs:
 #socket listen {
   #master {
     # Master socket provides access to userdb information. It's typically
     # used to give Dovecot's local delivery agent access to userdb so it
     # can find mailbox locations.
     #path = /var/run/dovecot/auth-master
     #mode = 0600
     # Default user/group is the one who started dovecot-auth (root)
     #user =
     #group =
   #client {
     # The client socket is generally safe to export to everyone. Typical use
     # is to export it to your SMTP server so it can do SMTP AUTH lookups
     # using it.
     #path = /var/run/dovecot/auth-client
     #mode = 0660
# If you wish to use another authentication server than dovecot-auth, you can
# use connect sockets. They are assumed to be already running, Dovecot's master
# process only tries to connect to them. They don't need any other settings
# than the path for the master socket, as the configuration is done elsewhere.
# Note that the client sockets must exist in the login_dir.
#auth external {
#  socket connect {
#    master {
#      path = /var/run/dovecot/auth-master
## Dictionary server settings
# Dictionary can be used by some plugins to store key=value lists.
# Currently this is only used by dict quota backend. The dictionary can be
# used either directly or though a dictionary server. The following dict block
# maps dictionary names to URIs when the server is used. These can then be
# referenced using URIs in format "proxy::<name>".
dict {
 #quota = mysql:/etc/dovecot-dict-quota.conf
 #expire = db:/var/lib/dovecot/expire.db
# Path to Berkeley DB's configuration file. See doc/dovecot-db-example.conf
#dict_db_config =
## Plugin settings
plugin {
 # Here you can give some extra environment variables to mail processes.
 # This is mostly meant for passing parameters to plugins. %variable
 # expansion is done for all values.
 # Quota plugin. Multiple backends are supported:
 #   dirsize: Find and sum all the files found from mail directory.
 #            Extremely SLOW with Maildir. It'll eat your CPU and disk I/O.
 #   dict: Keep quota stored in dictionary (eg. SQL)
 #   maildir: Maildir++ quota
 #   fs: Read-only support for filesystem quota
 # Quota limits are set using "quota_rule" parameters, either in here or in
 # userdb. It's also possible to give mailbox-specific limits, for example:
 #   quota_rule = *:storage=1048576
 #   quota_rule2 = Trash:storage=102400
 # User has now 1GB quota, but when saving to Trash mailbox the user gets
 # additional 100MB.
 # Multiple quota roots are also possible, for example:
 #   quota = dict:user::proxy::quota
 #   quota2 = dict:domain:%d:proxy::quota_domain
 #   quota_rule = *:storage=102400
 #   quota2_rule = *:storage=1048576
 # Gives each user their own 100MB quota and one shared 1GB quota within
 # the domain.
 # You can execute a given command when user exceeds a specified quota limit.
 # Each quota root has separate limits. Only the command for the first
 # exceeded limit is excecuted, so put the highest limit first.
 # Note that % needs to be escaped as %%, otherwise "% " expands to empty.
 #   quota_warning = storage=95%% /usr/local/bin/quota-warning.sh 95
 #   quota_warning2 = storage=80%% /usr/local/bin/quota-warning.sh 80
 #quota = maildir
 # ACL plugin. vfile backend reads ACLs from "dovecot-acl" file from maildir
 # directory. You can also optionally give a global ACL directory path where
 # ACLs are applied to all users' mailboxes. The global ACL directory contains
 # one file for each mailbox, eg. INBOX or sub.mailbox. cache_secs parameter
 # specifies how many seconds to wait between stat()ing dovecot-acl file
 # to see if it changed.
 #acl = vfile:/etc/dovecot-acls:cache_secs=300
 # To let users LIST mailboxes shared by other users, Dovecot needs a
 # shared mailbox dictionary. For example:
 #acl_shared_dict = file:/var/lib/dovecot/shared-mailboxes
 # Convert plugin. If set, specifies the source storage path which is
 # converted to destination storage (mail_location) when the user logs in.
 # The existing mail directory is renamed to <dir>-converted.
 #convert_mail = mbox:%h/mail
 # Skip mailboxes which we can't open successfully instead of aborting.
 #convert_skip_broken_mailboxes = no
 # Skip directories beginning with '.'
 #convert_skip_dotdirs = no
 # If source storage has mailbox names with destination storage's hierarchy
 # separators, replace them with this character.
 #convert_alt_hierarchy_char = _
 # Trash plugin. When saving a message would make user go over quota, this
 # plugin automatically deletes the oldest mails from configured mailboxes
 # until the message can be saved within quota limits. The configuration file
 # is a text file where each line is in format: <priority> <mailbox name>
 # Mails are first deleted in lowest -> highest priority number order
 #trash = /etc/dovecot-trash.conf
 # Expire plugin. Mails are expunged from mailboxes after being there the
 # configurable time. The first expiration date for each mailbox is stored in
 # a dictionary so it can be quickly determined which mailboxes contain
 # expired mails. The actual expunging is done in a nightly cronjob, which
 # you must set up:
 #   dovecot --exec-mail ext /usr/libexec/dovecot/expire-tool
 #expire = Trash 7 Spam 30
 #expire_dict = proxy::expire
 # Lazy expunge plugin. Currently works only with maildirs. When a user
 # expunges mails, the mails are moved to a mailbox in another namespace
 # (1st). When a mailbox is deleted, the mailbox is moved to another namespace
 # (2nd) as well. Also if the deleted mailbox had any expunged messages,
 # they're moved to a 3rd namespace. The mails won't be counted in quota,
 # and they're not deleted automatically (use a cronjob or something).
 #lazy_expunge = .EXPUNGED/ .DELETED/ .DELETED/.EXPUNGED/
 # Events to log. Also available: flag_change append
 #mail_log_events = delete undelete expunge copy mailbox_delete mailbox_rename
 # Group events within a transaction to one line.
 #mail_log_group_events = no
 # Available fields: uid, box, msgid, from, subject, size, vsize, flags
 # size and vsize are available only for expunge and copy events.
 #mail_log_fields = uid box msgid size
 # Sieve plugin (http://wiki.dovecot.org/LDA/Sieve) and ManageSieve service
 # Location of the active script. When ManageSieve is used this is actually
 # a symlink pointing to the active script in the sieve storage directory.
 #sieve=~/.dovecot.sieve
 # The path to the directory where the personal Sieve scripts are stored. For
 # ManageSieve this is where the uploaded scripts are stored.
 #sieve_dir=~/sieve
# Config files can also be included:
#!include /etc/dovecot/conf.d/*.conf
# Optional configurations, don't give an error if it's not found:
#!include_try /etc/dovecot/extra.conf
znak specjalny czy jakos tak to sie nazywalo i trzeba bylo slasha
dovecot :
protocols = pop3 pop3s imap imaps
auth default {
 socket listen {
   client {
  mode = 0660
  user = postfix
  group = postfix
 mechanisms = plain login
postfix
mynetworks = 127.0.0.0/8
smtpd_sasl_type = dovecot
smtpd_sasl_path = private/auth
smtpd_sasl_auth_enable = yes
smtpd_recipient_restrictions =  permit_mynetworks,
   permit_sasl_authenticated, reject_unauth_destination
broken_sasl_auth_clients = yes
myhostname = bolekililek.com.pl
zadzialalo :D
moze komus sie przyda
pozdrawiam
AdamS
Gratulacje :)
dzieki
to z kolejna sprawa ... czy lepiej jest zrobic tak jak zrobilem i zakladac userow tradycyjnie ... czy lepiej "sprzegnac" poczte z mysqlem ?
i czy w obecnej sytuacji istnieje mozliwosc zmiany hasla przez usera uzywajac squiremaila ? (userzy nie maja dostepu do shella)
pozdro
AdamS
