Błąd Przy Aktualizacji
Morgoth_
Próbowałem aktualizować system parokrotnie, jednakże skutek jest ciągle ten sam:
Błąd podczas sprawdzania transakcji:
 file /usr/lib/compiz/libanimation.so from install of compiz-plugins-main-0.8.3-2.fc11.i586 conflicts with file from package compiz-fusion-0.7.8-8.fc11.i586
 file /usr/lib/compiz/libcolorfilter.so from install of compiz-plugins-main-0.8.3-2.fc11.i586 conflicts with file from package compiz-fusion-0.7.8-8.fc11.i586
 file /usr/lib/compiz/libexpo.so from install of compiz-plugins-main-0.8.3-2.fc11.i586 conflicts with file from package compiz-fusion-0.7.8-8.fc11.i586
 file /usr/lib/compiz/libezoom.so from install of compiz-plugins-main-0.8.3-2.fc11.i586 conflicts with file from package compiz-fusion-0.7.8-8.fc11.i586
 file /usr/lib/compiz/libimgjpeg.so from install of compiz-plugins-main-0.8.3-2.fc11.i586 conflicts with file from package compiz-fusion-0.7.8-8.fc11.i586
 file /usr/lib/compiz/libmag.so from install of compiz-plugins-main-0.8.3-2.fc11.i586 conflicts with file from package compiz-fusion-0.7.8-8.fc11.i586
 file /usr/lib/compiz/libmousepoll.so from install of compiz-plugins-main-0.8.3-2.fc11.i586 conflicts with file from package compiz-fusion-0.7.8-8.fc11.i586
 file /usr/lib/compiz/libneg.so from install of compiz-plugins-main-0.8.3-2.fc11.i586 conflicts with file from package compiz-fusion-0.7.8-8.fc11.i586
 file /usr/lib/compiz/libopacify.so from install of compiz-plugins-main-0.8.3-2.fc11.i586 conflicts with file from package compiz-fusion-0.7.8-8.fc11.i586
 file /usr/lib/compiz/libput.so from install of compiz-plugins-main-0.8.3-2.fc11.i586 conflicts with file from package compiz-fusion-0.7.8-8.fc11.i586
 file /usr/lib/compiz/libresizeinfo.so from install of compiz-plugins-main-0.8.3-2.fc11.i586 conflicts with file from package compiz-fusion-0.7.8-8.fc11.i586
 file /usr/lib/compiz/libring.so from install of compiz-plugins-main-0.8.3-2.fc11.i586 conflicts with file from package compiz-fusion-0.7.8-8.fc11.i586
 file /usr/lib/compiz/libscaleaddon.so from install of compiz-plugins-main-0.8.3-2.fc11.i586 conflicts with file from package compiz-fusion-0.7.8-8.fc11.i586
 file /usr/lib/compiz/libsession.so from install of compiz-plugins-main-0.8.3-2.fc11.i586 conflicts with file from package compiz-fusion-0.7.8-8.fc11.i586
 file /usr/lib/compiz/libshift.so from install of compiz-plugins-main-0.8.3-2.fc11.i586 conflicts with file from package compiz-fusion-0.7.8-8.fc11.i586
 file /usr/lib/compiz/libsnap.so from install of compiz-plugins-main-0.8.3-2.fc11.i586 conflicts with file from package compiz-fusion-0.7.8-8.fc11.i586
 file /usr/lib/compiz/libstaticswitcher.so from install of compiz-plugins-main-0.8.3-2.fc11.i586 conflicts with file from package compiz-fusion-0.7.8-8.fc11.i586
 file /usr/lib/compiz/libtext.so from install of compiz-plugins-main-0.8.3-2.fc11.i586 conflicts with file from package compiz-fusion-0.7.8-8.fc11.i586
 file /usr/lib/compiz/libthumbnail.so from install of compiz-plugins-main-0.8.3-2.fc11.i586 conflicts with file from package compiz-fusion-0.7.8-8.fc11.i586
 file /usr/lib/compiz/libvpswitch.so from install of compiz-plugins-main-0.8.3-2.fc11.i586 conflicts with file from package compiz-fusion-0.7.8-8.fc11.i586
 file /usr/lib/compiz/libwall.so from install of compiz-plugins-main-0.8.3-2.fc11.i586 conflicts with file from package compiz-fusion-0.7.8-8.fc11.i586
 file /usr/lib/compiz/libwinrules.so from install of compiz-plugins-main-0.8.3-2.fc11.i586 conflicts with file from package compiz-fusion-0.7.8-8.fc11.i586
 file /usr/lib/compiz/libworkarounds.so from install of compiz-plugins-main-0.8.3-2.fc11.i586 conflicts with file from package compiz-fusion-0.7.8-8.fc11.i586
 file /usr/share/compiz/animation.xml from install of compiz-plugins-main-0.8.3-2.fc11.i586 conflicts with file from package compiz-fusion-0.7.8-8.fc11.i586
 file /usr/share/compiz/colorfilter.xml from install of compiz-plugins-main-0.8.3-2.fc11.i586 conflicts with file from package compiz-fusion-0.7.8-8.fc11.i586
 file /usr/share/compiz/expo.xml from install of compiz-plugins-main-0.8.3-2.fc11.i586 conflicts with file from package compiz-fusion-0.7.8-8.fc11.i586
 file /usr/share/compiz/ezoom.xml from install of compiz-plugins-main-0.8.3-2.fc11.i586 conflicts with file from package compiz-fusion-0.7.8-8.fc11.i586
 file /usr/share/compiz/imgjpeg.xml from install of compiz-plugins-main-0.8.3-2.fc11.i586 conflicts with file from package compiz-fusion-0.7.8-8.fc11.i586
 file /usr/share/compiz/mag.xml from install of compiz-plugins-main-0.8.3-2.fc11.i586 conflicts with file from package compiz-fusion-0.7.8-8.fc11.i586
 file /usr/share/compiz/mousepoll.xml from install of compiz-plugins-main-0.8.3-2.fc11.i586 conflicts with file from package compiz-fusion-0.7.8-8.fc11.i586
 file /usr/share/compiz/neg.xml from install of compiz-plugins-main-0.8.3-2.fc11.i586 conflicts with file from package compiz-fusion-0.7.8-8.fc11.i586
 file /usr/share/compiz/opacify.xml from install of compiz-plugins-main-0.8.3-2.fc11.i586 conflicts with file from package compiz-fusion-0.7.8-8.fc11.i586
 file /usr/share/compiz/put.xml from install of compiz-plugins-main-0.8.3-2.fc11.i586 conflicts with file from package compiz-fusion-0.7.8-8.fc11.i586
 file /usr/share/compiz/resizeinfo.xml from install of compiz-plugins-main-0.8.3-2.fc11.i586 conflicts with file from package compiz-fusion-0.7.8-8.fc11.i586
 file /usr/share/compiz/ring.xml from install of compiz-plugins-main-0.8.3-2.fc11.i586 conflicts with file from package compiz-fusion-0.7.8-8.fc11.i586
 file /usr/share/compiz/scaleaddon.xml from install of compiz-plugins-main-0.8.3-2.fc11.i586 conflicts with file from package compiz-fusion-0.7.8-8.fc11.i586
 file /usr/share/compiz/session.xml from install of compiz-plugins-main-0.8.3-2.fc11.i586 conflicts with file from package compiz-fusion-0.7.8-8.fc11.i586
 file /usr/share/compiz/shift.xml from install of compiz-plugins-main-0.8.3-2.fc11.i586 conflicts with file from package compiz-fusion-0.7.8-8.fc11.i586
 file /usr/share/compiz/snap.xml from install of compiz-plugins-main-0.8.3-2.fc11.i586 conflicts with file from package compiz-fusion-0.7.8-8.fc11.i586
 file /usr/share/compiz/staticswitcher.xml from install of compiz-plugins-main-0.8.3-2.fc11.i586 conflicts with file from package compiz-fusion-0.7.8-8.fc11.i586
 file /usr/share/compiz/text.xml from install of compiz-plugins-main-0.8.3-2.fc11.i586 conflicts with file from package compiz-fusion-0.7.8-8.fc11.i586
 file /usr/share/compiz/thumbnail.xml from install of compiz-plugins-main-0.8.3-2.fc11.i586 conflicts with file from package compiz-fusion-0.7.8-8.fc11.i586
 file /usr/share/compiz/vpswitch.xml from install of compiz-plugins-main-0.8.3-2.fc11.i586 conflicts with file from package compiz-fusion-0.7.8-8.fc11.i586
 file /usr/share/compiz/wall.xml from install of compiz-plugins-main-0.8.3-2.fc11.i586 conflicts with file from package compiz-fusion-0.7.8-8.fc11.i586
 file /usr/share/compiz/winrules.xml from install of compiz-plugins-main-0.8.3-2.fc11.i586 conflicts with file from package compiz-fusion-0.7.8-8.fc11.i586
 file /usr/share/compiz/workarounds.xml from install of compiz-plugins-main-0.8.3-2.fc11.i586 conflicts with file from package compiz-fusion-0.7.8-8.fc11.i586
Podsumowanie błędów
Nie wiem co jest nie tak, próbowałem graficznej aktualizacji i przez terminal. Skutek jest ten sam.
Dzięki z góry za pomoc.
Pozdr.
1. Dlugie listingi umieszczaj w znacznikach [ codebox ] & [ / codebox ]
2. Zanim przejdziemy do dochodzenia jakich repo uzywasz i skad instalowales stara wersje... wyczysc cache yuma (terminal)
yum clean all
3. Jesli
yum update
nadal nie zadziala, to
4.
yum update exclude=*compiz*
... poszlo bez compiza albo po czyszczeniu?
