Phpunit
Plu
Witam,
nie wiem jak uruchomić PHPUnit.
Instalowałem ręcznie PHPUnit: System->Administracja->Dodaj/Usuń Oprogramowanie.
[root@localhost html]# phpunit  rpm -qa | grep PHPUnit
PHPUnit 3.3.16 by Sebastian Bergmann.
Staram się uruchomić test na podstawie tego artykułu:
http://wortal.php.pl/wortal/artykuly/proce...hpunit/tutorial
Jednak po wprowadzeniu:
 php -f stringtest.php
otrzymuje ten komunikat:
PHP Warning:  require_once(/usr/bin/PHPUnit.php): failed to open stream: No such file or directory in /var/www/html/testcase.php on line 7
PHP Stack trace:
PHP   1. {main}() /var/www/html/stringtest.php:0
PHP   2. require_once() /var/www/html/stringtest.php:3
PHP Fatal error:  require_once(): Failed opening required '/usr/bin/PHPUnit.php' (include_path='.:/usr/share/pear:/usr/share/php') in /var/www/html/testcase.php on line 7
PHP Stack trace:
Prosze o pomoc.
PHP mam zainstlowane najnowsze z repo oraz apacha.
Czy plik /usr/bin/PHPUnit.php istnieje?
Czy uruchamiasz przez suexec?
Czy jest włączony selinux?
1. Tak istnieje tylko z małych liter phpunit.php(nie wiem czy to jakaś różnica) o to jego zawartość:
#!/usr/bin/php
<?php
/* PHPUnit
* Copyright ? 2002-2009, Sebastian Bergmann <[email protected]>.
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
*   * Redistributions of source code must retain the above copyright
*     notice, this list of conditions and the following disclaimer.
*   * Redistributions in binary form must reproduce the above copyright
*     notice, this list of conditions and the following disclaimer in
*     the documentation and/or other materials provided with the
*     distribution.
*   * Neither the name of Sebastian Bergmann nor the names of his
*     contributors may be used to endorse or promote products derived
*     from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
* FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
* COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
* BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
* LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
* CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRIC
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN
* ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
* POSSIBILITY OF SUCH DAMAGE.
* $Id: phpunit.php 4572 2009-01-28 07:37:41Z sb $
if (strpos('/usr/bin/php', '@php_bin') === 0) {
   set_include_path(dirname(__FILE__) . PATH_SEPARATOR . get_include_path());
require_once 'PHPUnit/Util/Filter.php';
PHPUnit_Util_Filter::addFileToFilter(__FILE__, 'PHPUNIT');
require 'PHPUnit/TextUI/Command.php';
define('PHPUnit_MAIN_METHOD', 'PHPUnit_TextUI_Command::main');
PHPUnit_TextUI_Command::main();
2. suexec nie wiem co to :rolleyes:
3. Myśle, że mam go wyłączonego ale dala pewności:
# This file controls the state of SELinux on the system.
# SELINUX= can take one of these three values:
#	enforcing - SELinux security policy is enforced.
#	permissive - SELinux prints warnings instead of enforcing.
#	disabled - No SELinux policy is loaded.
SELINUX=disabled
# SELINUXTYPE= can take one of these two values:
#	targeted - Targeted processes are protected,
#	mls - Multi Level Security protection.
SELINUXTYPE=targeted
[Edit]
W plikach php:
require_once '/usr/bin/phpunit.php';
Paczki które instalowałem:
httpd
php
mysql
mysql-server
php-mysql
php-pear-PHPUnit
php-channel-phpunit
Kurcze nie wiem już sam! :) :) :)
Jeżeli użyję polecenia locate nie znajduje mi tego pliku.
[root@localhost ~]# locate phpunit
/usr/bin/phpunit
/usr/share/pear/.channels/pear.phpunit.de.reg
/usr/share/pear/.channels/.alias/phpunit.txt
/usr/share/pear/.pkgxml/pear.phpunit.de.xml
/usr/share/pear/.registry/.channel.pear.phpunit.de
/usr/share/pear/.registry/.channel.pear.phpunit.de/phpunit.reg
/usr/share/pear/PHPUnit/Extensions/SeleniumTestCase/phpunit_coverage.php
/usr/share/pear/test/PHPUnit/PHPUnit/Tests/phpunit.xml.dist
/var/lib/yum/yumdb/p/8bd17e5589676a6d374e9be06a9ec232ce76a56c-php-channel-phpunit-1.0-3.fc11-noarch
/var/lib/yum/yumdb/p/8bd17e5589676a6d374e9be06a9ec232ce76a56c-php-channel-phpunit-1.0-3.fc11-noarch/from_repo
/var/lib/yum/yumdb/p/8bd17e5589676a6d374e9be06a9ec232ce76a56c-php-channel-phpunit-1.0-3.fc11-noarch/reason
/var/lib/yum/yumdb/p/8bd17e5589676a6d374e9be06a9ec232ce76a56c-php-channel-phpunit-1.0-3.fc11-noarch/releasever
Pokaż więc zawartość
testcase.php
<?php
testcase.php
require_once 'string.php';
class StringTest extends PHPUnit_TestCase
// zawiera obiekt obsługujący klasę
var $abc;
// konstruktor ciągu testów
function StringTest($name) {
$this->PHPUnit_TestCase($name);
// wywołanie zanim funkcje testujące zostaną wykonane
// ta funkcja zdefiniowana jest w PHPUnit_TestCase i nadpisana
// tutaj
function setUp() {
// stwórz nowa instancję String z
// ciągiem znaków 'abc'
$this->abc = new String("abc");
// wywołane po wykonaniu funkcji testujących
// tutaj
function tearDown() {
// usuń swoją instancję
unset($this->abc);
// przetestuj funkcję toString
function testToString() {
$result = $this->abc->toString('contains %s');
$expected = 'contains abc';
$this->assertTrue($result == $expected);
// przetestuj funkcję copy
function testCopy() {
$abc2 = $this->abc->copy();
$this->assertEquals($abc2, $this->abc);
// przetestuj funkcję add
function testAdd() {
$abc2 = new String('123');
$this->abc->add($abc2);
$result = $this->abc->toString("%s");
$expected = "abc123";
stringtest.php
<?php
require_once 'testcase.php';
$suite = new PHPUnit_TestSuite("StringTest");
$result = PHPUnit::run($suite);
echo $result -> toString();
W php.ini włączyłem safe_mode = On
Po wprowadzeniu polecenia "phpunit stringtest.php ":
[root@localhost html]# phpunit stringtest.php
PHP Warning:  shell_exec(): Cannot execute using backquotes in Safe Mode in /usr/share/pear/PHPUnit/Util/Fileloader.php on line 190
PHP Stack trace:
PHP   1. {main}() /usr/bin/phpunit:0
PHP   2. PHPUnit_TextUI_Command::main() /usr/bin/phpunit:52
PHP   3. PHPUnit_Runner_BaseTestRunner->getTest() /usr/share/pear/PHPUnit/TextUI/Command.php:84
PHP   4. PHPUnit_Runner_BaseTestRunner->loadSuiteClass() /usr/share/pear/PHPUnit/Runner/BaseTestRunner.php:201
PHP   5. PHPUnit_Runner_StandardTestSuiteLoader->load() /usr/share/pear/PHPUnit/Runner/BaseTestRunner.php:267
PHP   6. PHPUnit_Util_Fileloader::checkAndLoad() /usr/share/pear/PHPUnit/Runner/StandardTestSuiteLoader.php:98
PHP   7. PHPUnit_Util_Fileloader::syntaxCheck() /usr/share/pear/PHPUnit/Util/Fileloader.php:99
PHP   8. shell_exec() /usr/share/pear/PHPUnit/Util/Fileloader.php:190
Call Stack:
   0.0004      48596   1. {main}() /usr/bin/phpunit:0
   0.3049    3566160   2. PHPUnit_TextUI_Command::main() /usr/bin/phpunit:52
   0.3055    3573376   3. PHPUnit_Runner_BaseTestRunner->getTest() /usr/share/pear/PHPUnit/TextUI/Command.php:84
   0.3055    3573436   4. PHPUnit_Runner_BaseTestRunner->loadSuiteClass() /usr/share/pear/PHPUnit/Runner/BaseTestRunner.php:201
   0.3056    3573612   5. PHPUnit_Runner_StandardTestSuiteLoader->load() /usr/share/pear/PHPUnit/Runner/BaseTestRunner.php:267
   0.3058    3588260   6. PHPUnit_Util_Fileloader::checkAndLoad() /usr/share/pear/PHPUnit/Runner/StandardTestSuiteLoader.php:98
   0.3059    3588368   7. PHPUnit_Util_Fileloader::syntaxCheck() /usr/share/pear/PHPUnit/Util/Fileloader.php:99
   0.3061    3588668   8. shell_exec() /usr/share/pear/PHPUnit/Util/Fileloader.php:190
PHP Warning:  require_once(): Unable to access /usr/bin/phpunit.php in /var/www/html/testcase.php on line 7
PHP Stack trace:
PHP   7. PHPUnit_Util_Fileloader::load() /usr/share/pear/PHPUnit/Util/Fileloader.php:102
PHP   8. include_once() /usr/share/pear/PHPUnit/Util/Fileloader.php:119
PHP   9. require_once() /var/www/html/stringtest.php:3
Call Stack:
   0.3158    3588984   7. PHPUnit_Util_Fileloader::load() /usr/share/pear/PHPUnit/Util/Fileloader.php:102
   0.3263    3592576   8. include_once('/var/www/html/stringtest.php') /usr/share/pear/PHPUnit/Util/Fileloader.php:119
   0.3271    3605320   9. require_once('/var/www/html/testcase.php') /var/www/html/stringtest.php:3
PHP Warning:  require_once(/usr/bin/phpunit.php): failed to open stream: No such file or directory in /var/www/html/testcase.php on line 7
PHP Stack trace:
Call Stack:
PHP Fatal error:  require_once(): Failed opening required '/usr/bin/phpunit.php' (include_path='.:/usr/share/pear:/usr/share/php') in /var/www/html/testcase.php on line 7
PHP Stack trace:
Call Stack:
[Edit]
Może to dlatego, że nie mam biblioteki Pear nie instalowałem.
Możesz podać mi krok po kroku jak ty instalowałeś php.... phpunit?
