Brak Połączenia Z Klienta Openvpn Na Serwer Vpn
piotrino
Po skonfigurowaniu serwera openvpn wreszcie działa i serwer vpn uruchamia się bez błedów, problem mam z klientem vpn , po uruchomieniu klienta vpn nie chce mi się połączyc z serwerem, z tego co wyczytałem jest to wina nieskonfigurowanego rouera...
Fri Nov 06 20:20:16 2009 OpenVPN 2.1_rc20 i686-pc-mingw32 [sSL] [LZO2] [PKCS11] built on Oct  1 2009
Fri Nov 06 20:20:16 2009 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Fri Nov 06 20:20:18 2009 LZO compression initialized
Fri Nov 06 20:20:18 2009 Control Channel MTU parms [ L:1542 D:138 EF:38 EB:0 ET:0 EL:0 ]
Fri Nov 06 20:20:18 2009 Data Channel MTU parms [ L:1542 D:1450 EF:42 EB:135 ET:0 EL:0 AF:3/1 ]
Fri Nov 06 20:20:18 2009 Local Options hash (VER=V4): '41690919'
Fri Nov 06 20:20:18 2009 Expected Remote Options hash (VER=V4): '530fdded'
Fri Nov 06 20:20:18 2009 Socket Buffers: R=[8192->8192] S=[8192->8192]
Fri Nov 06 20:20:18 2009 UDPv4 link local: [undef]
Fri Nov 06 20:20:18 2009 UDPv4 link remote: 10.8.0.1:1194
Fri Nov 06 20:21:18 2009 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 06 20:21:18 2009 TLS Error: TLS handshake failed
Fri Nov 06 20:21:18 2009 TCP/UDP: Closing socket
Fri Nov 06 20:21:18 2009 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 06 20:21:18 2009 Restart pause, 2 second(s)
Fri Nov 06 20:21:20 2009 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Fri Nov 06 20:21:20 2009 Re-using SSL/TLS context
Fri Nov 06 20:21:20 2009 LZO compression initialized
Fri Nov 06 20:21:20 2009 Control Channel MTU parms [ L:1542 D:138 EF:38 EB:0 ET:0 EL:0 ]
Fri Nov 06 20:21:21 2009 Data Channel MTU parms [ L:1542 D:1450 EF:42 EB:135 ET:0 EL:0 AF:3/1 ]
Fri Nov 06 20:21:21 2009 Local Options hash (VER=V4): '41690919'
Fri Nov 06 20:21:21 2009 Expected Remote Options hash (VER=V4): '530fdded'
Fri Nov 06 20:21:21 2009 Socket Buffers: R=[8192->8192] S=[8192->8192]
Fri Nov 06 20:21:21 2009 UDPv4 link local: [undef]
Fri Nov 06 20:21:21 2009 UDPv4 link remote: 10.8.0.1:1194
Fri Nov 06 20:22:24 2009 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 06 20:22:24 2009 TLS Error: TLS handshake failed
Fri Nov 06 20:22:27 2009 TCP/UDP: Closing socket
Fri Nov 06 20:22:27 2009 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 06 20:22:27 2009 Restart pause, 2 second(s)
Fri Nov 06 20:22:29 2009 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Fri Nov 06 20:22:29 2009 Re-using SSL/TLS context
Fri Nov 06 20:22:29 2009 LZO compression initialized
Fri Nov 06 20:22:29 2009 Control Channel MTU parms [ L:1542 D:138 EF:38 EB:0 ET:0 EL:0 ]
Fri Nov 06 20:22:29 2009 Data Channel MTU parms [ L:1542 D:1450 EF:42 EB:135 ET:0 EL:0 AF:3/1 ]
Fri Nov 06 20:22:29 2009 Local Options hash (VER=V4): '41690919'
Fri Nov 06 20:22:29 2009 Expected Remote Options hash (VER=V4): '530fdded'
Fri Nov 06 20:22:29 2009 Socket Buffers: R=[8192->8192] S=[8192->8192]
Fri Nov 06 20:22:29 2009 UDPv4 link local: [undef]
Fri Nov 06 20:22:29 2009 UDPv4 link remote: 10.8.0.1:1194
Fri Nov 06 20:23:29 2009 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 06 20:23:29 2009 TLS Error: TLS handshake failed
Fri Nov 06 20:23:29 2009 TCP/UDP: Closing socket
Fri Nov 06 20:23:29 2009 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 06 20:23:29 2009 Restart pause, 2 second(s)
Fri Nov 06 20:23:31 2009 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Fri Nov 06 20:23:31 2009 Re-using SSL/TLS context
Fri Nov 06 20:23:31 2009 LZO compression initialized
Fri Nov 06 20:23:31 2009 Control Channel MTU parms [ L:1542 D:138 EF:38 EB:0 ET:0 EL:0 ]
Fri Nov 06 20:23:31 2009 Data Channel MTU parms [ L:1542 D:1450 EF:42 EB:135 ET:0 EL:0 AF:3/1 ]
Fri Nov 06 20:23:31 2009 Local Options hash (VER=V4): '41690919'
Fri Nov 06 20:23:31 2009 Expected Remote Options hash (VER=V4): '530fdded'
Fri Nov 06 20:23:31 2009 Socket Buffers: R=[8192->8192] S=[8192->8192]
Fri Nov 06 20:23:31 2009 UDPv4 link local: [undef]
Fri Nov 06 20:23:31 2009 UDPv4 link remote: 10.8.0.1:1194
Fri Nov 06 20:24:31 2009 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 06 20:24:31 2009 TLS Error: TLS handshake failed
Fri Nov 06 20:24:31 2009 TCP/UDP: Closing socket
Fri Nov 06 20:24:31 2009 SIGUSR1[soft,tls-error] received, process restarting
Fri Nov 06 20:24:31 2009 Restart pause, 2 second(s)
Fri Nov 06 20:24:33 2009 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Fri Nov 06 20:24:33 2009 Re-using SSL/TLS context
Fri Nov 06 20:24:33 2009 LZO compression initialized
Fri Nov 06 20:24:33 2009 Control Channel MTU parms [ L:1542 D:138 EF:38 EB:0 ET:0 EL:0 ]
Fri Nov 06 20:24:33 2009 Data Channel MTU parms [ L:1542 D:1450 EF:42 EB:135 ET:0 EL:0 AF:3/1 ]
Fri Nov 06 20:24:33 2009 Local Options hash (VER=V4): '41690919'
Fri Nov 06 20:24:33 2009 Expected Remote Options hash (VER=V4): '530fdded'
Fri Nov 06 20:24:33 2009 Socket Buffers: R=[8192->8192] S=[8192->8192]
Fri Nov 06 20:24:33 2009 UDPv4 link local: [undef]
Fri Nov 06 20:24:33 2009 UDPv4 link remote: 10.8.0.1:1194
Fri Nov 06 20:25:33 2009 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Nov 06 20:25:33 2009 TLS Error: TLS handshake failed
Fri Nov 06 20:25:33 2009 TCP/UDP: Closing socket
Szczególnie chodzi mi o te wpisy:
Z tego co wyczytałm bład w połączeniu ponosi zle skonfigurowany firewall, lub wyłączenie go....Wyłączyłem go na kliencie i serwerze ale nadal mam to samo....Rozwiazaniem może być co przyszło mi do głowy wyłączenie firewalla lub skonfigurowanie go na routerze u dostawcy internetowego od którego mam internet(radiówka), dzwoniłem do niego, i powiedział że być moze u niego firewall blokuje mi dostep do seerwera....Czy jest jakaś możliwość żebym połączył się z serwerem, bo raczej dostawca int. nie wyłaczy mi routera, co najwyżej mógłby go skonifgurować , ustawiająć zeby interfejs TAP był interfejsem lokalnym przepuszczający wszystkie pakiety....Chętnie posłucham waszych opini na ten temat....
