koval_ski Napisano Listopad 26, 2004 Zgłoszenie Share Napisano Listopad 26, 2004 Mam taki problem z dns'em: 1. zarejestrowałem domenę kom.pl, w polu serwer nazw: ns.koval.kom.pl nr.IP podałem mój IP (stały) 2. zrobiłem u siebie dns'a, to są pliki: named.conf // // named.conf for Red Hat caching-nameserver // options { directory "/var/named"; dump-file "/var/named/data/cache_dump.db"; statistics-file "/var/named/data/named_stats.txt"; /* * If there is a firewall between you and nameservers you want * to talk to, you might need to uncomment the query-source * directive below. Previous versions of BIND always asked * questions using port 53, but BIND 8.1 uses an unprivileged * port by default. */ query-source address * port 53; }; // // a caching only nameserver config // controls { inet 127.0.0.1 allow { localhost; } keys { rndckey; }; }; zone "." IN { type hint; file "named.ca"; }; zone "localdomain" IN { type master; file "localdomain.zone"; allow-update { none; }; }; zone "localhost" IN { type master; file "localhost.zone"; allow-update { none; }; }; zone "0.0.127.in-addr.arpa" IN { type master; file "named.local"; allow-update { none; }; }; zone "0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.ip6.arpa" IN { type master; file "named.ip6.local"; allow-update { none; }; }; zone "255.in-addr.arpa" IN { type master; file "named.broadcast"; allow-update { none; }; }; zone "0.in-addr.arpa" IN { type master; file "named.zero"; allow-update { none; }; }; zone "koval.kom.pl" { type master; file "/var/named/koval.kom.pl"; allow-update { none; }; }; zone "253.168.81.in-addr.arpa" { notify yes; type master; file "253.168.81.in-addr.arpa"; }; include "/etc/rndc.key"; to jest koval.kom.pl : $ttl 86400 $ORIGIN koval.kom.pl. @ IN SOA ns.koval.kom.pl. root.koval.kom.pl. ( 2004112501; Serial ( yyyy/mm/dd/nn/) 3600; Refresh (1 hour) 1800; Retry (30 minutes) 604800; Expire (1 week) 7200 ); Minimum TTL (2 hours) ; IN A 81.168.253.133 IN NS ns.koval.kom.pl.; adres naszego nameservera IN MX 5 mail.koval.kom.pl.; podstawowy serwer poczty www IN A 81.168.253.133 ftp IN A 81.168.253.133 mail IN A 81.168.253.133 pop IN A 81.168.253.133 smtp IN A 81.168.253.133 to jest 253.168.81.in-addr.arpa @ IN SOA ns.koval.kom.pl. ns.koval.kom.pl ( 2004112501; Serial ( yyyy/mm/dd/nn/) 3600; Refresh (1 hour) 1800; Retry (30 minutes) 604800; Expire (1 week) 7200 ); Minimum TTL (2 hours) ; NS ns.koval.kom.pl. 21 PTR koval.kom.pl. dodatkowo jak testuję to w ten sposób: # dig @ns.koval.kom.pl koval.kom.pl dig: Couldn't find server 'ns.koval.kom.pl': Temporary failure in name resolution nie wiem do czego jest ta małpa (@) ale bez małpy jest tak: # dig ns.koval.kom.pl koval.kom.pl ; <<>> DiG 9.2.4 <<>> ns.koval.kom.pl koval.kom.pl ;; global options: printcmd ;; Got answer: ;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 16252 ;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 0, ADDITIONAL: 0 ;; QUESTION SECTION: ;ns.koval.kom.pl. IN A ;; Query time: 115 msec ;; SERVER: 217.30.137.200#53(217.30.137.200) ;; WHEN: Thu Nov 25 23:21:11 2004 ;; MSG SIZE rcvd: 33 ;; Got answer: ;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 20243 ;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 0, ADDITIONAL: 0 ;; QUESTION SECTION: ;koval.kom.pl. IN A ;; Query time: 64 msec ;; SERVER: 217.30.137.200#53(217.30.137.200) ;; WHEN: Thu Nov 25 23:21:12 2004 ;; MSG SIZE rcvd: 30 Liczę na pomoc, z góry dzięki, pozdrawiam! Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
