System Zawiesza Się Zaraz Po Starcie
samson32
Jedyne co mogę robić po zawieszeniu to ruszać kursorem, po za tym nic nie działa. Wrzuciłbym jeszcze messages ale nie mieści się log na forum. Jest na to jakiś sposób, można umieścić go jakoś w zwijalnym oknie?
lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 006: ID 0cf3:3005 Atheros Communications, Inc.
Bus 001 Device 004: ID 13d3:5122 IMC Networks
Bus 002 Device 003: ID 2166:6649
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
dmesg
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Linux version 2.6.40.6-0.fc15.x86_64 ([email protected]) (gcc version 4.6.1 20110908 (Red Hat 4.6.1-9) (GCC) ) #1 SMP Tue Oct 4 00:39:50 UTC 2011
[    0.000000] Command line: ro root=UUID=17b553dd-f518-417c-aa7a-68f1e91a246a rd_NO_LUKS rd_NO_LVM rd_NO_MD rd_NO_DM rdblacklist=nouveau nouveau.modeset=0 LANG=en_US.UTF-8 SYSFONT=latarcyrheb-sun16 KEYTABLE=pl2 rhgb quiet 3
[    0.000000] BIOS-provided physical RAM map:
[    0.000000]  BIOS-e820: 0000000000000000 - 000000000009e800 (usable)
[    0.000000]  BIOS-e820: 000000000009e800 - 00000000000a0000 (reserved)
[    0.000000]  BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
[    0.000000]  BIOS-e820: 0000000000100000 - 0000000020000000 (usable)
[    0.000000]  BIOS-e820: 0000000020000000 - 0000000020200000 (reserved)
[    0.000000]  BIOS-e820: 0000000020200000 - 0000000040000000 (usable)
[    0.000000]  BIOS-e820: 0000000040000000 - 0000000040200000 (reserved)
[    0.000000]  BIOS-e820: 0000000040200000 - 00000000aac10000 (usable)
[    0.000000]  BIOS-e820: 00000000aac10000 - 00000000aad8e000 (reserved)
[    0.000000]  BIOS-e820: 00000000aad8e000 - 00000000aad97000 (usable)
[    0.000000]  BIOS-e820: 00000000aad97000 - 00000000aadb8000 (reserved)
[    0.000000]  BIOS-e820: 00000000aadb8000 - 00000000aadc6000 (usable)
[    0.000000]  BIOS-e820: 00000000aadc6000 - 00000000aade8000 (reserved)
[    0.000000]  BIOS-e820: 00000000aade8000 - 00000000aaf1f000 (usable)
[    0.000000]  BIOS-e820: 00000000aaf1f000 - 00000000aaf86000 (ACPI NVS)
[    0.000000]  BIOS-e820: 00000000aaf86000 - 00000000aaf8a000 (usable)
[    0.000000]  BIOS-e820: 00000000aaf8a000 - 00000000aafe8000 (ACPI NVS)
[    0.000000]  BIOS-e820: 00000000aafe8000 - 00000000aaffd000 (usable)
[    0.000000]  BIOS-e820: 00000000aaffd000 - 00000000ab000000 (ACPI data)
[    0.000000]  BIOS-e820: 00000000ab000000 - 00000000afa00000 (reserved)
[    0.000000]  BIOS-e820: 00000000e0000000 - 00000000e4000000 (reserved)
[    0.000000]  BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
[    0.000000]  BIOS-e820: 00000000fed10000 - 00000000fed14000 (reserved)
[    0.000000]  BIOS-e820: 00000000fed18000 - 00000000fed1a000 (reserved)
[    0.000000]  BIOS-e820: 00000000fed1c000 - 00000000fed20000 (reserved)
[    0.000000]  BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[    0.000000]  BIOS-e820: 00000000ff980000 - 00000000ffc00000 (reserved)
[    0.000000]  BIOS-e820: 00000000ffd80000 - 0000000100000000 (reserved)
[    0.000000]  BIOS-e820: 0000000100000000 - 000000034fe00000 (usable)
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] DMI 2.6 present.
[    0.000000] DMI: ASUSTeK Computer Inc. N53SV/N53SV, BIOS N53SV.209 02/10/2011
[    0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[    0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[    0.000000] No AGP bridge found
[    0.000000] last_pfn = 0x34fe00 max_arch_pfn = 0x400000000
[    0.000000] MTRR default type: uncachable
[    0.000000] MTRR fixed ranges enabled:
[    0.000000]   00000-9FFFF write-back
[    0.000000]   A0000-BFFFF uncachable
[    0.000000]   C0000-CFFFF write-protect
[    0.000000]   D0000-E7FFF uncachable
[    0.000000]   E8000-FFFFF write-protect
[    0.000000] MTRR variable ranges enabled:
[    0.000000]   0 base 000000000 mask C00000000 write-back
[    0.000000]   1 base 0C0000000 mask FC0000000 uncachable
[    0.000000]   2 base 0B0000000 mask FF0000000 uncachable
[    0.000000]   3 base 0AC000000 mask FFC000000 uncachable
[    0.000000]   4 base 0AB000000 mask FFF000000 uncachable
[    0.000000]   5 base 380000000 mask F80000000 uncachable
[    0.000000]   6 base 360000000 mask FE0000000 uncachable
[    0.000000]   7 base 350000000 mask FF0000000 uncachable
[    0.000000]   8 base 34FE00000 mask FFFE00000 uncachable
[    0.000000]   9 disabled
[    0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[    0.000000] original variable MTRRs
[    0.000000] reg 0, base: 0GB, range: 16GB, type WB
[    0.000000] reg 1, base: 3GB, range: 1GB, type UC
[    0.000000] reg 2, base: 2816MB, range: 256MB, type UC
[    0.000000] reg 3, base: 2752MB, range: 64MB, type UC
[    0.000000] reg 4, base: 2736MB, range: 16MB, type UC
[    0.000000] reg 5, base: 14GB, range: 2GB, type UC
[    0.000000] reg 6, base: 13824MB, range: 512MB, type UC
[    0.000000] reg 7, base: 13568MB, range: 256MB, type UC
[    0.000000] reg 8, base: 13566MB, range: 2MB, type UC
[    0.000000] total RAM covered: 12206M
[    0.000000]  gran_size: 64K 	chunk_size: 64K 	num_reg: 10  	lose cover RAM: 62M
[    0.000000]  gran_size: 64K 	chunk_size: 128K 	num_reg: 10  	lose cover RAM: 62M
[    0.000000]  gran_size: 64K 	chunk_size: 256K 	num_reg: 10  	lose cover RAM: 62M
[    0.000000]  gran_size: 64K 	chunk_size: 512K 	num_reg: 10  	lose cover RAM: 62M
[    0.000000]  gran_size: 64K 	chunk_size: 1M 	num_reg: 10  	lose cover RAM: 62M
[    0.000000]  gran_size: 64K 	chunk_size: 2M 	num_reg: 10  	lose cover RAM: 62M
[    0.000000]  gran_size: 64K 	chunk_size: 4M 	num_reg: 10  	lose cover RAM: 0G
[    0.000000]  gran_size: 64K 	chunk_size: 8M 	num_reg: 10  	lose cover RAM: 0G
[    0.000000]  gran_size: 64K 	chunk_size: 16M 	num_reg: 10  	lose cover RAM: 0G
[    0.000000]  gran_size: 64K 	chunk_size: 32M 	num_reg: 10  	lose cover RAM: 0G
[    0.000000]  gran_size: 64K 	chunk_size: 64M 	num_reg: 10  	lose cover RAM: 0G
[    0.000000]  gran_size: 64K 	chunk_size: 128M 	num_reg: 10  	lose cover RAM: 0G
[    0.000000]  gran_size: 64K 	chunk_size: 256M 	num_reg: 10  	lose cover RAM: 0G
[    0.000000] *BAD*gran_size: 64K 	chunk_size: 512M 	num_reg: 10  	lose cover RAM: -256M
[    0.000000] *BAD*gran_size: 64K 	chunk_size: 1G 	num_reg: 10  	lose cover RAM: -512M
[    0.000000] *BAD*gran_size: 64K 	chunk_size: 2G 	num_reg: 10  	lose cover RAM: -512M
[    0.000000]  gran_size: 128K 	chunk_size: 128K 	num_reg: 10  	lose cover RAM: 62M
[    0.000000]  gran_size: 128K 	chunk_size: 256K 	num_reg: 10  	lose cover RAM: 62M
[    0.000000]  gran_size: 128K 	chunk_size: 512K 	num_reg: 10  	lose cover RAM: 62M
[    0.000000]  gran_size: 128K 	chunk_size: 1M 	num_reg: 10  	lose cover RAM: 62M
[    0.000000]  gran_size: 128K 	chunk_size: 2M 	num_reg: 10  	lose cover RAM: 62M
[    0.000000]  gran_size: 128K 	chunk_size: 4M 	num_reg: 10  	lose cover RAM: 0G
[    0.000000]  gran_size: 128K 	chunk_size: 8M 	num_reg: 10  	lose cover RAM: 0G
[    0.000000]  gran_size: 128K 	chunk_size: 16M 	num_reg: 10  	lose cover RAM: 0G
[    0.000000]  gran_size: 128K 	chunk_size: 32M 	num_reg: 10  	lose cover RAM: 0G
[    0.000000]  gran_size: 128K 	chunk_size: 64M 	num_reg: 10  	lose cover RAM: 0G
[    0.000000]  gran_size: 128K 	chunk_size: 128M 	num_reg: 10  	lose cover RAM: 0G
[    0.000000]  gran_size: 128K 	chunk_size: 256M 	num_reg: 10  	lose cover RAM: 0G
[    0.000000] *BAD*gran_size: 128K 	chunk_size: 512M 	num_reg: 10  	lose cover RAM: -256M
[    0.000000] *BAD*gran_size: 128K 	chunk_size: 1G 	num_reg: 10  	lose cover RAM: -512M
[    0.000000] *BAD*gran_size: 128K 	chunk_size: 2G 	num_reg: 10  	lose cover RAM: -512M
[    0.000000]  gran_size: 256K 	chunk_size: 256K 	num_reg: 10  	lose cover RAM: 62M
[    0.000000]  gran_size: 256K 	chunk_size: 512K 	num_reg: 10  	lose cover RAM: 62M
[    0.000000]  gran_size: 256K 	chunk_size: 1M 	num_reg: 10  	lose cover RAM: 62M
[    0.000000]  gran_size: 256K 	chunk_size: 2M 	num_reg: 10  	lose cover RAM: 62M
[    0.000000]  gran_size: 256K 	chunk_size: 4M 	num_reg: 10  	lose cover RAM: 0G
[    0.000000]  gran_size: 256K 	chunk_size: 8M 	num_reg: 10  	lose cover RAM: 0G
[    0.000000]  gran_size: 256K 	chunk_size: 16M 	num_reg: 10  	lose cover RAM: 0G
[    0.000000]  gran_size: 256K 	chunk_size: 32M 	num_reg: 10  	lose cover RAM: 0G
[    0.000000]  gran_size: 256K 	chunk_size: 64M 	num_reg: 10  	lose cover RAM: 0G
[    0.000000]  gran_size: 256K 	chunk_size: 128M 	num_reg: 10  	lose cover RAM: 0G
[    0.000000]  gran_size: 256K 	chunk_size: 256M 	num_reg: 10  	lose cover RAM: 0G
[    0.000000] *BAD*gran_size: 256K 	chunk_size: 512M 	num_reg: 10  	lose cover RAM: -256M
[    0.000000] *BAD*gran_size: 256K 	chunk_size: 1G 	num_reg: 10  	lose cover RAM: -512M
[    0.000000] *BAD*gran_size: 256K 	chunk_size: 2G 	num_reg: 10  	lose cover RAM: -512M
[    0.000000]  gran_size: 512K 	chunk_size: 512K 	num_reg: 10  	lose cover RAM: 62M
[    0.000000]  gran_size: 512K 	chunk_size: 1M 	num_reg: 10  	lose cover RAM: 62M
[    0.000000]  gran_size: 512K 	chunk_size: 2M 	num_reg: 10  	lose cover RAM: 62M
[    0.000000]  gran_size: 512K 	chunk_size: 4M 	num_reg: 10  	lose cover RAM: 0G
[    0.000000]  gran_size: 512K 	chunk_size: 8M 	num_reg: 10  	lose cover RAM: 0G
[    0.000000]  gran_size: 512K 	chunk_size: 16M 	num_reg: 10  	lose cover RAM: 0G
[    0.000000]  gran_size: 512K 	chunk_size: 32M 	num_reg: 10  	lose cover RAM: 0G
[    0.000000]  gran_size: 512K 	chunk_size: 64M 	num_reg: 10  	lose cover RAM: 0G
[    0.000000]  gran_size: 512K 	chunk_size: 128M 	num_reg: 10  	lose cover RAM: 0G
[    0.000000]  gran_size: 512K 	chunk_size: 256M 	num_reg: 10  	lose cover RAM: 0G
[    0.000000] *BAD*gran_size: 512K 	chunk_size: 512M 	num_reg: 10  	lose cover RAM: -256M
[    0.000000] *BAD*gran_size: 512K 	chunk_size: 1G 	num_reg: 10  	lose cover RAM: -512M
[    0.000000] *BAD*gran_size: 512K 	chunk_size: 2G 	num_reg: 10  	lose cover RAM: -512M
[    0.000000]  gran_size: 1M 	chunk_size: 1M 	num_reg: 10  	lose cover RAM: 62M
[    0.000000]  gran_size: 1M 	chunk_size: 2M 	num_reg: 10  	lose cover RAM: 62M
[    0.000000]  gran_size: 1M 	chunk_size: 4M 	num_reg: 10  	lose cover RAM: 0G
[    0.000000]  gran_size: 1M 	chunk_size: 8M 	num_reg: 10  	lose cover RAM: 0G
[    0.000000]  gran_size: 1M 	chunk_size: 16M 	num_reg: 10  	lose cover RAM: 0G
[    0.000000]  gran_size: 1M 	chunk_size: 32M 	num_reg: 10  	lose cover RAM: 0G
[    0.000000]  gran_size: 1M 	chunk_size: 64M 	num_reg: 10  	lose cover RAM: 0G
[    0.000000]  gran_size: 1M 	chunk_size: 128M 	num_reg: 10  	lose cover RAM: 0G
[    0.000000]  gran_size: 1M 	chunk_size: 256M 	num_reg: 10  	lose cover RAM: 0G
[    0.000000] *BAD*gran_size: 1M 	chunk_size: 512M 	num_reg: 10  	lose cover RAM: -256M
[    0.000000] *BAD*gran_size: 1M 	chunk_size: 1G 	num_reg: 10  	lose cover RAM: -512M
[    0.000000] *BAD*gran_size: 1M 	chunk_size: 2G 	num_reg: 10  	lose cover RAM: -512M
[    0.000000]  gran_size: 2M 	chunk_size: 2M 	num_reg: 10  	lose cover RAM: 62M
[    0.000000]  gran_size: 2M 	chunk_size: 4M 	num_reg: 10  	lose cover RAM: 0G
[    0.000000]  gran_size: 2M 	chunk_size: 8M 	num_reg: 10  	lose cover RAM: 0G
[    0.000000]  gran_size: 2M 	chunk_size: 16M 	num_reg: 10  	lose cover RAM: 0G
[    0.000000]  gran_size: 2M 	chunk_size: 32M 	num_reg: 10  	lose cover RAM: 0G
[    0.000000]  gran_size: 2M 	chunk_size: 64M 	num_reg: 10  	lose cover RAM: 0G
[    0.000000]  gran_size: 2M 	chunk_size: 128M 	num_reg: 10  	lose cover RAM: 0G
[    0.000000]  gran_size: 2M 	chunk_size: 256M 	num_reg: 10  	lose cover RAM: 0G
[    0.000000] *BAD*gran_size: 2M 	chunk_size: 512M 	num_reg: 10  	lose cover RAM: -256M
[    0.000000] *BAD*gran_size: 2M 	chunk_size: 1G 	num_reg: 10  	lose cover RAM: -512M
[    0.000000] *BAD*gran_size: 2M 	chunk_size: 2G 	num_reg: 10  	lose cover RAM: -512M
[    0.000000]  gran_size: 4M 	chunk_size: 4M 	num_reg: 10  	lose cover RAM: 62M
[    0.000000]  gran_size: 4M 	chunk_size: 8M 	num_reg: 10  	lose cover RAM: 2M
[    0.000000]  gran_size: 4M 	chunk_size: 16M 	num_reg: 10  	lose cover RAM: 2M
[    0.000000]  gran_size: 4M 	chunk_size: 32M 	num_reg: 10  	lose cover RAM: 2M
[    0.000000]  gran_size: 4M 	chunk_size: 64M 	num_reg: 10  	lose cover RAM: 2M
[    0.000000]  gran_size: 4M 	chunk_size: 128M 	num_reg: 10  	lose cover RAM: 2M
[    0.000000]  gran_size: 4M 	chunk_size: 256M 	num_reg: 10  	lose cover RAM: 2M
[    0.000000] *BAD*gran_size: 4M 	chunk_size: 512M 	num_reg: 10  	lose cover RAM: -254M
[    0.000000] *BAD*gran_size: 4M 	chunk_size: 1G 	num_reg: 10  	lose cover RAM: -510M
[    0.000000] *BAD*gran_size: 4M 	chunk_size: 2G 	num_reg: 10  	lose cover RAM: -510M
[    0.000000]  gran_size: 8M 	chunk_size: 8M 	num_reg: 10  	lose cover RAM: 62M
[    0.000000]  gran_size: 8M 	chunk_size: 16M 	num_reg: 10  	lose cover RAM: 6M
[    0.000000]  gran_size: 8M 	chunk_size: 32M 	num_reg: 10  	lose cover RAM: 6M
[    0.000000]  gran_size: 8M 	chunk_size: 64M 	num_reg: 10  	lose cover RAM: 6M
[    0.000000]  gran_size: 8M 	chunk_size: 128M 	num_reg: 10  	lose cover RAM: 6M
[    0.000000]  gran_size: 8M 	chunk_size: 256M 	num_reg: 10  	lose cover RAM: 6M
[    0.000000] *BAD*gran_size: 8M 	chunk_size: 512M 	num_reg: 10  	lose cover RAM: -250M
[    0.000000] *BAD*gran_size: 8M 	chunk_size: 1G 	num_reg: 10  	lose cover RAM: -506M
[    0.000000] *BAD*gran_size: 8M 	chunk_size: 2G 	num_reg: 10  	lose cover RAM: -506M
[    0.000000]  gran_size: 16M 	chunk_size: 16M 	num_reg: 10  	lose cover RAM: 62M
[    0.000000]  gran_size: 16M 	chunk_size: 32M 	num_reg: 10  	lose cover RAM: 14M
[    0.000000]  gran_size: 16M 	chunk_size: 64M 	num_reg: 10  	lose cover RAM: 14M
[    0.000000]  gran_size: 16M 	chunk_size: 128M 	num_reg: 10  	lose cover RAM: 14M
[    0.000000]  gran_size: 16M 	chunk_size: 256M 	num_reg: 10  	lose cover RAM: 14M
[    0.000000] *BAD*gran_size: 16M 	chunk_size: 512M 	num_reg: 10  	lose cover RAM: -242M
[    0.000000] *BAD*gran_size: 16M 	chunk_size: 1G 	num_reg: 10  	lose cover RAM: -498M
[    0.000000] *BAD*gran_size: 16M 	chunk_size: 2G 	num_reg: 10  	lose cover RAM: -498M
[    0.000000]  gran_size: 32M 	chunk_size: 32M 	num_reg: 10  	lose cover RAM: 46M
[    0.000000]  gran_size: 32M 	chunk_size: 64M 	num_reg: 10  	lose cover RAM: 46M
[    0.000000]  gran_size: 32M 	chunk_size: 128M 	num_reg: 10  	lose cover RAM: 46M
[    0.000000]  gran_size: 32M 	chunk_size: 256M 	num_reg: 10  	lose cover RAM: 46M
[    0.000000] *BAD*gran_size: 32M 	chunk_size: 512M 	num_reg: 10  	lose cover RAM: -210M
[    0.000000] *BAD*gran_size: 32M 	chunk_size: 1G 	num_reg: 10  	lose cover RAM: -466M
[    0.000000] *BAD*gran_size: 32M 	chunk_size: 2G 	num_reg: 10  	lose cover RAM: -466M
[    0.000000]  gran_size: 64M 	chunk_size: 64M 	num_reg: 8  	lose cover RAM: 110M
[    0.000000]  gran_size: 64M 	chunk_size: 128M 	num_reg: 8  	lose cover RAM: 110M
[    0.000000]  gran_size: 64M 	chunk_size: 256M 	num_reg: 9  	lose cover RAM: 110M
[    0.000000]  gran_size: 64M 	chunk_size: 512M 	num_reg: 10  	lose cover RAM: 110M
[    0.000000]  gran_size: 64M 	chunk_size: 1G 	num_reg: 10  	lose cover RAM: 110M
[    0.000000]  gran_size: 64M 	chunk_size: 2G 	num_reg: 10  	lose cover RAM: 110M
[    0.000000]  gran_size: 128M 	chunk_size: 128M 	num_reg: 7  	lose cover RAM: 174M
[    0.000000]  gran_size: 128M 	chunk_size: 256M 	num_reg: 9  	lose cover RAM: 174M
[    0.000000]  gran_size: 128M 	chunk_size: 512M 	num_reg: 10  	lose cover RAM: 174M
[    0.000000]  gran_size: 128M 	chunk_size: 1G 	num_reg: 10  	lose cover RAM: 174M
[    0.000000]  gran_size: 128M 	chunk_size: 2G 	num_reg: 10  	lose cover RAM: 174M
[    0.000000]  gran_size: 256M 	chunk_size: 256M 	num_reg: 5  	lose cover RAM: 430M
[    0.000000]  gran_size: 256M 	chunk_size: 512M 	num_reg: 5  	lose cover RAM: 430M
[    0.000000]  gran_size: 256M 	chunk_size: 1G 	num_reg: 6  	lose cover RAM: 430M
[    0.000000]  gran_size: 256M 	chunk_size: 2G 	num_reg: 7  	lose cover RAM: 430M
[    0.000000]  gran_size: 512M 	chunk_size: 512M 	num_reg: 5  	lose cover RAM: 430M
[    0.000000]  gran_size: 512M 	chunk_size: 1G 	num_reg: 6  	lose cover RAM: 430M
[    0.000000]  gran_size: 512M 	chunk_size: 2G 	num_reg: 7  	lose cover RAM: 430M
[    0.000000]  gran_size: 1G 	chunk_size: 1G 	num_reg: 4  	lose cover RAM: 942M
[    0.000000]  gran_size: 1G 	chunk_size: 2G 	num_reg: 5  	lose cover RAM: 942M
[    0.000000]  gran_size: 2G 	chunk_size: 2G 	num_reg: 3  	lose cover RAM: 1966M
[    0.000000] mtrr_cleanup: can not find optimal value
[    0.000000] please specify mtrr_gran_size/mtrr_chunk_size
[    0.000000] e820 update range: 00000000ab000000 - 0000000100000000 (usable) ==> (reserved)
[    0.000000] last_pfn = 0xaaffd max_arch_pfn = 0x400000000
[    0.000000] found SMP MP-table at [ffff8800000fcc80] fcc80
[    0.000000] initial memory mapped : 0 - 20000000
[    0.000000] Base memory trampoline at [ffff880000099000] 99000 size 20480
[    0.000000] init_memory_mapping: 0000000000000000-00000000aaffd000
[    0.000000]  0000000000 - 00aae00000 page 2M
[    0.000000]  00aae00000 - 00aaffd000 page 4k
[    0.000000] kernel direct mapping tables up to aaffd000 @ aaff8000-aaffd000
[    0.000000] init_memory_mapping: 0000000100000000-000000034fe00000
[    0.000000]  0100000000 - 034fe00000 page 2M
[    0.000000] kernel direct mapping tables up to 34fe00000 @ 34fdf1000-34fe00000
[    0.000000] RAMDISK: 1f159000 - 1fff0000
[    0.000000] ACPI: RSDP 00000000000f0430 00024 (v02 _ASUS_)
[    0.000000] ACPI: XSDT 00000000aaffee18 00074 (v01 _ASUS_ Notebook 06222004 MSFT 00010013)
[    0.000000] ACPI: FACP 00000000aaf9ad98 000F4 (v04 _ASUS_ Notebook 06222004 MSFT 00010013)
[    0.000000] ACPI Warning: 32/64 FACS address mismatch in FADT - two FACS tables! (20110413/tbfadt-369)
[    0.000000] ACPI Warning: 32/64X FACS address mismatch in FADT - 0xAAFE4E40/0x00000000AAFE4D40, using 32 (20110413/tbfadt-489)
[    0.000000] ACPI: DSDT 00000000aaf65018 13528 (v01 _ASUS_ Notebook 00000000 INTL 20091112)
[    0.000000] ACPI: FACS 00000000aafe4e40 00040
[    0.000000] ACPI: APIC 00000000aaffdf18 000CC (v02 _ASUS_ Notebook 06222004 MSFT 00010013)
[    0.000000] ACPI: DBGP 00000000aaffff18 00034 (v01 _ASUS_ Notebook 06222004 MSFT 00010013)
[    0.000000] ACPI: ECDT 00000000aafe4b18 000C1 (v01 _ASUS_ Notebook 06222004 AMI. 00000003)
[    0.000000] ACPI: SLIC 00000000aaf9be18 00176 (v01 _ASUS_ Notebook 06222004 ASUS 00000001)
[    0.000000] ACPI: HPET 00000000aafe5d18 00038 (v01 _ASUS_ Notebook 06222004 AMI. 00000003)
[    0.000000] ACPI: MCFG 00000000aafe5c98 0003C (v01 _ASUS_ Notebook 06222004 MSFT 00000097)
[    0.000000] ACPI: SSDT 00000000aaf85018 00913 (v01  PmRef  Cpu0Ist 00003000 INTL 20091112)
[    0.000000] ACPI: SSDT 00000000aaf84018 00996 (v01  PmRef    CpuPm 00003000 INTL 20091112)
[    0.000000] ACPI: ASF! 00000000aafe4a18 000A0 (v32 INTEL       HCG 00000001 TFSM 000F4240)
[    0.000000] ACPI: Local APIC address 0xfee00000
[    0.000000] No NUMA configuration found
[    0.000000] Faking a node at 0000000000000000-000000034fe00000
[    0.000000] Initmem setup node 0 0000000000000000-000000034fe00000
[    0.000000]   NODE_DATA [000000034fddd000 - 000000034fdf0fff]
[    0.000000]  [ffffea0000000000-ffffea000b9fffff] PMD -> [ffff880343400000-ffff88034ddfffff] on node 0
[    0.000000] Zone PFN ranges:
[    0.000000]   DMA      0x00000010 -> 0x00001000
[    0.000000]   DMA32    0x00001000 -> 0x00100000
[    0.000000]   Normal   0x00100000 -> 0x0034fe00
[    0.000000] Movable zone start PFN for each node
[    0.000000] early_node_map[10] active PFN ranges
[    0.000000]     0: 0x00000010 -> 0x0000009e
[    0.000000]     0: 0x00000100 -> 0x00020000
[    0.000000]     0: 0x00020200 -> 0x00040000
[    0.000000]     0: 0x00040200 -> 0x000aac10
[    0.000000]     0: 0x000aad8e -> 0x000aad97
[    0.000000]     0: 0x000aadb8 -> 0x000aadc6
[    0.000000]     0: 0x000aade8 -> 0x000aaf1f
[    0.000000]     0: 0x000aaf86 -> 0x000aaf8a
[    0.000000]     0: 0x000aafe8 -> 0x000aaffd
[    0.000000]     0: 0x00100000 -> 0x0034fe00
[    0.000000] On node 0 totalpages: 3122949
[    0.000000]   DMA zone: 56 pages used for memmap
[    0.000000]   DMA zone: 5 pages reserved
[    0.000000]   DMA zone: 3921 pages, LIFO batch:0
[    0.000000]   DMA32 zone: 14280 pages used for memmap
[    0.000000]   DMA32 zone: 680367 pages, LIFO batch:31
[    0.000000]   Normal zone: 33145 pages used for memmap
[    0.000000]   Normal zone: 2391175 pages, LIFO batch:31
[    0.000000] ACPI: PM-Timer IO Port: 0x408
[    0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] enabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x04] enabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x06] enabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x05] lapic_id[0x01] enabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x06] lapic_id[0x03] enabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x07] lapic_id[0x05] enabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x08] lapic_id[0x07] enabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x09] lapic_id[0x08] disabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x0a] lapic_id[0x09] disabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x0b] lapic_id[0x0a] disabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x0c] lapic_id[0x0b] disabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x0d] lapic_id[0x0c] disabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x0e] lapic_id[0x0d] disabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x0f] lapic_id[0x0e] disabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x10] lapic_id[0x0f] disabled)
[    0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[    0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.000000] ACPI: IRQ0 used by override.
[    0.000000] ACPI: IRQ2 used by override.
[    0.000000] ACPI: IRQ9 used by override.
[    0.000000] Using ACPI (MADT) for SMP configuration information
[    0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[    0.000000] SMP: Allowing 16 CPUs, 8 hotplug CPUs
[    0.000000] nr_irqs_gsi: 40
[    0.000000] PM: Registered nosave memory: 000000000009e000 - 000000000009f000
[    0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[    0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e0000
[    0.000000] PM: Registered nosave memory: 00000000000e0000 - 0000000000100000
[    0.000000] PM: Registered nosave memory: 0000000020000000 - 0000000020200000
[    0.000000] PM: Registered nosave memory: 0000000040000000 - 0000000040200000
[    0.000000] PM: Registered nosave memory: 00000000aac10000 - 00000000aad8e000
[    0.000000] PM: Registered nosave memory: 00000000aad97000 - 00000000aadb8000
[    0.000000] PM: Registered nosave memory: 00000000aadc6000 - 00000000aade8000
[    0.000000] PM: Registered nosave memory: 00000000aaf1f000 - 00000000aaf86000
[    0.000000] PM: Registered nosave memory: 00000000aaf8a000 - 00000000aafe8000
[    0.000000] PM: Registered nosave memory: 00000000aaffd000 - 00000000ab000000
[    0.000000] PM: Registered nosave memory: 00000000ab000000 - 00000000afa00000
[    0.000000] PM: Registered nosave memory: 00000000afa00000 - 00000000e0000000
[    0.000000] PM: Registered nosave memory: 00000000e0000000 - 00000000e4000000
[    0.000000] PM: Registered nosave memory: 00000000e4000000 - 00000000fec00000
[    0.000000] PM: Registered nosave memory: 00000000fec00000 - 00000000fec01000
[    0.000000] PM: Registered nosave memory: 00000000fec01000 - 00000000fed10000
[    0.000000] PM: Registered nosave memory: 00000000fed10000 - 00000000fed14000
[    0.000000] PM: Registered nosave memory: 00000000fed14000 - 00000000fed18000
[    0.000000] PM: Registered nosave memory: 00000000fed18000 - 00000000fed1a000
[    0.000000] PM: Registered nosave memory: 00000000fed1a000 - 00000000fed1c000
[    0.000000] PM: Registered nosave memory: 00000000fed1c000 - 00000000fed20000
[    0.000000] PM: Registered nosave memory: 00000000fed20000 - 00000000fee00000
[    0.000000] PM: Registered nosave memory: 00000000fee00000 - 00000000fee01000
[    0.000000] PM: Registered nosave memory: 00000000fee01000 - 00000000ff980000
[    0.000000] PM: Registered nosave memory: 00000000ff980000 - 00000000ffc00000
[    0.000000] PM: Registered nosave memory: 00000000ffc00000 - 00000000ffd80000
[    0.000000] PM: Registered nosave memory: 00000000ffd80000 - 0000000100000000
[    0.000000] Allocating PCI resources starting at afa00000 (gap: afa00000:30600000)
[    0.000000] Booting paravirtualized kernel on bare hardware
[    0.000000] setup_percpu: NR_CPUS:256 nr_cpumask_bits:256 nr_cpu_ids:16 nr_node_ids:1
[    0.000000] PERCPU: Embedded 27 pages/cpu @ffff88034fa00000 s78336 r8192 d24064 u131072
[    0.000000] pcpu-alloc: s78336 r8192 d24064 u131072 alloc=1*2097152
[    0.000000] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 08 09 10 11 12 13 14 15
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 3075463
[    0.000000] Policy zone: Normal
[    0.000000] Kernel command line: ro root=UUID=17b553dd-f518-417c-aa7a-68f1e91a246a rd_NO_LUKS rd_NO_LVM rd_NO_MD rd_NO_DM rdblacklist=nouveau nouveau.modeset=0 LANG=en_US.UTF-8 SYSFONT=latarcyrheb-sun16 KEYTABLE=pl2 rhgb quiet 3
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] xsave/xrstor: enabled xstate_bv 0x7, cntxt size 0x340
[    0.000000] Checking aperture...
[    0.000000] Calgary: detecting Calgary via BIOS EBDA area
[    0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[    0.000000] Memory: 12220636k/13891584k available (4682k kernel code, 1399788k absent, 271160k reserved, 6904k data, 936k init)
[    0.000000] SLUB: Genslabs=15, HWalign=64, Order=0-3, MinObjects=0, CPUs=16, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000] 	RCU dyntick-idle grace-period acceleration is enabled.
[    0.000000] NR_IRQS:16640 nr_irqs:808 16
[    0.000000] Extended CMOS year: 2000
[    0.000000] Console: colour VGA+ 80x25
[    0.000000] console [tty0] enabled
[    0.000000] allocated 100663296 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[    0.000000] hpet clockevent registered
[    0.000000] Fast TSC calibration using PIT
[    0.001000] Detected 1995.647 MHz processor.
[    0.000005] Calibrating delay loop (skipped), value calculated using timer frequency.. 3991.29 BogoMIPS (lpj=1995647)
[    0.000009] pid_max: default: 32768 minimum: 301
[    0.000048] Security Framework initialized
[    0.000056] SELinux:  Initializing.
[    0.000065] SELinux:  Starting in permissive mode
[    0.002198] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[    0.006732] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[    0.008405] Mount-cache hash table entries: 256
[    0.008573] Initializing cgroup subsys cpuacct
[    0.008581] Initializing cgroup subsys memory
[    0.008598] Initializing cgroup subsys devices
[    0.008600] Initializing cgroup subsys freezer
[    0.008602] Initializing cgroup subsys net_cls
[    0.008605] Initializing cgroup subsys blkio
[    0.008612] Initializing cgroup subsys perf_event
[    0.008647] CPU: Physical Processor ID: 0
[    0.008649] CPU: Processor Core ID: 0
[    0.008654] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0.008656] ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8)
[    0.008659] mce: CPU supports 9 MCE banks
[    0.008676] CPU0: Thermal monitoring enabled (TM1)
[    0.008683] using mwait in idle threads.
[    0.009284] ACPI: Core revision 20110413
[    0.181103] ftrace: allocating 24454 entries in 96 pages
[    0.191576] Not enabling x2apic, Intr-remapping init failed.
[    0.191579] Switched APIC routing to physical flat.
[    0.191935] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.201940] CPU0: Intel(R) Core(TM) i7-2630QM CPU @ 2.00GHz stepping 07
[    0.303849] Performance Events: PEBS fmt1+, SandyBridge events, Intel PMU driver.
[    0.303855] ... version:                3
[    0.303857] ... bit width:              48
[    0.303858] ... generic registers:      4
[    0.303860] ... value mask:             0000ffffffffffff
[    0.303862] ... max period:             000000007fffffff
[    0.303863] ... fixed-purpose events:   3
[    0.303865] ... event mask:             000000070000000f
[    0.304323] NMI watchdog enabled, takes one hw-pmu counter.
[    0.304417] Booting Node   0, Processors  #1
[    0.304419] smpboot cpu 1: start_ip = 99000
[    0.394906] NMI watchdog enabled, takes one hw-pmu counter.
[    0.395007]  #2
[    0.395009] smpboot cpu 2: start_ip = 99000
[    0.485891] NMI watchdog enabled, takes one hw-pmu counter.
[    0.485986]  #3
[    0.485988] smpboot cpu 3: start_ip = 99000
[    0.576869] NMI watchdog enabled, takes one hw-pmu counter.
[    0.576964]  #4
[    0.576965] smpboot cpu 4: start_ip = 99000
[    0.667858] NMI watchdog enabled, takes one hw-pmu counter.
[    0.667970]  #5
[    0.667972] smpboot cpu 5: start_ip = 99000
[    0.758758] NMI watchdog enabled, takes one hw-pmu counter.
[    0.758859]  #6
[    0.758860] smpboot cpu 6: start_ip = 99000
[    0.849746] NMI watchdog enabled, takes one hw-pmu counter.
[    0.849843]  #7
[    0.849844] smpboot cpu 7: start_ip = 99000
[    0.940731] NMI watchdog enabled, takes one hw-pmu counter.
[    0.940764] Brought up 8 CPUs
[    0.940767] Total of 8 processors activated (31924.33 BogoMIPS).
[    0.947319] devtmpfs: initialized
[    0.951292] PM: Registering ACPI NVS region at aaf1f000 (421888 bytes)
[    0.951310] PM: Registering ACPI NVS region at aaf8a000 (385024 bytes)
[    0.952084] atomic64 test passed for x86-64 platform with CX8 and with SSE
[    0.952115] Time: 15:31:49  Date: 10/28/11
[    0.952160] NET: Registered protocol family 16
[    0.952332] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.952335] ACPI: bus type pci registered
[    0.952415] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xe0000000-0xe3ffffff] (base 0xe0000000)
[    0.952419] PCI: MMCONFIG at [mem 0xe0000000-0xe3ffffff] reserved in E820
[    0.964194] PCI: Using configuration type 1 for base access
[    0.965530] bio: create slab <bio-0> at 0
[    0.968310] ACPI: EC: EC description table is found, configuring boot EC
[    0.968316] ACPI: EC: Look up EC in DSDT
[    0.971184] ACPI: Executed 1 blocks of module-level executable AML code
[    0.978621] [Firmware Bug]: ACPI: BIOS _OSI(Linux) query ignored
[    1.078694] [Firmware Bug]: ACPI: BIOS _OSI(Linux) query ignored
[    1.078772] [Firmware Bug]: ACPI: BIOS _OSI(Linux) query ignored
[    1.079369] ACPI: SSDT 00000000aadca718 00694 (v01  PmRef  Cpu0Cst 00003001 INTL 20091112)
[    1.080055] ACPI: Dynamic OEM Table Load:
[    1.080059] ACPI: SSDT           (null) 00694 (v01  PmRef  Cpu0Cst 00003001 INTL 20091112)
[    1.082890] ACPI: SSDT 00000000aadcba98 00303 (v01  PmRef    ApIst 00003000 INTL 20091112)
[    1.083618] ACPI: Dynamic OEM Table Load:
[    1.083621] ACPI: SSDT           (null) 00303 (v01  PmRef    ApIst 00003000 INTL 20091112)
[    1.087709] ACPI: SSDT 00000000aadc9d98 00119 (v01  PmRef    ApCst 00003000 INTL 20091112)
[    1.088382] ACPI: Dynamic OEM Table Load:
[    1.088385] ACPI: SSDT           (null) 00119 (v01  PmRef    ApCst 00003000 INTL 20091112)
[    1.092098] ACPI: Interpreter enabled
[    1.092102] ACPI: (supports S0 S3 S4 S5)
[    1.092129] ACPI: Using IOAPIC for interrupt routing
[    1.203963] ACPI: EC: GPE = 0x1b, I/O: command/status = 0x66, data = 0x62
[    1.204207] ACPI: No dock devices found.
[    1.204209] HEST: Table not found.
[    1.204212] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    1.204548] \_SB_.PCI0:_OSC invalid UUID
[    1.204549] _OSC request data:1 8 1f
[    1.204554] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
[    1.205093] pci_root PNP0A08:00: host bridge window [io  0x0000-0x0cf7]
[    1.205096] pci_root PNP0A08:00: host bridge window [io  0x0d00-0xffff]
[    1.205099] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff]
[    1.205101] pci_root PNP0A08:00: host bridge window [mem 0x000d0000-0x000d3fff]
[    1.205104] pci_root PNP0A08:00: host bridge window [mem 0x000d4000-0x000d7fff]
[    1.205106] pci_root PNP0A08:00: host bridge window [mem 0x000d8000-0x000dbfff]
[    1.205108] pci_root PNP0A08:00: host bridge window [mem 0x000dc000-0x000dffff]
[    1.205110] pci_root PNP0A08:00: host bridge window [mem 0x000e0000-0x000e3fff]
[    1.205113] pci_root PNP0A08:00: host bridge window [mem 0x000e4000-0x000e7fff]
[    1.205115] pci_root PNP0A08:00: host bridge window [mem 0xafa00000-0xfeafffff]
[    1.205117] pci_root PNP0A08:00: host bridge window [mem 0xfed40000-0xfed44fff]
[    1.205131] pci 0000:00:00.0: [8086:0104] type 0 class 0x000600
[    1.205171] pci 0000:00:01.0: [8086:0101] type 1 class 0x000604
[    1.205199] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[    1.205202] pci 0000:00:01.0: PME# disabled
[    1.205223] pci 0000:00:02.0: [8086:0116] type 0 class 0x000300
[    1.205235] pci 0000:00:02.0: reg 10: [mem 0xdc400000-0xdc7fffff 64bit]
[    1.205242] pci 0000:00:02.0: reg 18: [mem 0xb0000000-0xbfffffff 64bit pref]
[    1.205248] pci 0000:00:02.0: reg 20: [io  0xe000-0xe03f]
[    1.205303] pci 0000:00:16.0: [8086:1c3a] type 0 class 0x000780
[    1.205328] pci 0000:00:16.0: reg 10: [mem 0xdf00b000-0xdf00b00f 64bit]
[    1.205394] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[    1.205399] pci 0000:00:16.0: PME# disabled
[    1.205435] pci 0000:00:1a.0: [8086:1c2d] type 0 class 0x000c03
[    1.205464] pci 0000:00:1a.0: reg 10: [mem 0xdf008000-0xdf0083ff]
[    1.205543] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[    1.205548] pci 0000:00:1a.0: PME# disabled
[    1.205573] pci 0000:00:1b.0: [8086:1c20] type 0 class 0x000403
[    1.205591] pci 0000:00:1b.0: reg 10: [mem 0xdf000000-0xdf003fff 64bit]
[    1.205654] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[    1.205658] pci 0000:00:1b.0: PME# disabled
[    1.205682] pci 0000:00:1c.0: [8086:1c10] type 1 class 0x000604
[    1.205750] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    1.205754] pci 0000:00:1c.0: PME# disabled
[    1.205779] pci 0000:00:1c.1: [8086:1c12] type 1 class 0x000604
[    1.205847] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[    1.205852] pci 0000:00:1c.1: PME# disabled
[    1.205879] pci 0000:00:1c.3: [8086:1c16] type 1 class 0x000604
[    1.205947] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[    1.205952] pci 0000:00:1c.3: PME# disabled
[    1.205981] pci 0000:00:1c.5: [8086:1c1a] type 1 class 0x000604
[    1.206049] pci 0000:00:1c.5: PME# supported from D0 D3hot D3cold
[    1.206054] pci 0000:00:1c.5: PME# disabled
[    1.206088] pci 0000:00:1d.0: [8086:1c26] type 0 class 0x000c03
[    1.206111] pci 0000:00:1d.0: reg 10: [mem 0xdf007000-0xdf0073ff]
[    1.206189] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[    1.206194] pci 0000:00:1d.0: PME# disabled
[    1.206220] pci 0000:00:1f.0: [8086:1c49] type 0 class 0x000601
[    1.206343] pci 0000:00:1f.2: [8086:1c03] type 0 class 0x000106
[    1.206364] pci 0000:00:1f.2: reg 10: [io  0xe0b0-0xe0b7]
[    1.206373] pci 0000:00:1f.2: reg 14: [io  0xe0a0-0xe0a3]
[    1.206382] pci 0000:00:1f.2: reg 18: [io  0xe090-0xe097]
[    1.206392] pci 0000:00:1f.2: reg 1c: [io  0xe080-0xe083]
[    1.206401] pci 0000:00:1f.2: reg 20: [io  0xe060-0xe07f]
[    1.206410] pci 0000:00:1f.2: reg 24: [mem 0xdf006000-0xdf0067ff]
[    1.206451] pci 0000:00:1f.2: PME# supported from D3hot
[    1.206456] pci 0000:00:1f.2: PME# disabled
[    1.206477] pci 0000:00:1f.3: [8086:1c22] type 0 class 0x000c05
[    1.206495] pci 0000:00:1f.3: reg 10: [mem 0xdf005000-0xdf0050ff 64bit]
[    1.206518] pci 0000:00:1f.3: reg 20: [io  0xe040-0xe05f]
[    1.206585] pci 0000:01:00.0: [10de:0df4] type 0 class 0x000300
[    1.206598] pci 0000:01:00.0: reg 10: [mem 0xdb000000-0xdbffffff]
[    1.206612] pci 0000:01:00.0: reg 14: [mem 0xc0000000-0xcfffffff 64bit pref]
[    1.206627] pci 0000:01:00.0: reg 1c: [mem 0xd0000000-0xd1ffffff 64bit pref]
[    1.206636] pci 0000:01:00.0: reg 24: [io  0xd000-0xd07f]
[    1.206646] pci 0000:01:00.0: reg 30: [mem 0xdc000000-0xdc07ffff pref]
[    1.206694] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[    1.206697] pci 0000:00:01.0:   bridge window [io  0xd000-0xdfff]
[    1.206700] pci 0000:00:01.0:   bridge window [mem 0xdb000000-0xdc0fffff]
[    1.206705] pci 0000:00:01.0:   bridge window [mem 0xc0000000-0xd1ffffff 64bit pref]
[    1.206754] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[    1.206758] pci 0000:00:1c.0:   bridge window [io  0xc000-0xcfff]
[    1.206763] pci 0000:00:1c.0:   bridge window [mem 0xde600000-0xdeffffff]
[    1.206771] pci 0000:00:1c.0:   bridge window [mem 0xd4200000-0xd4bfffff 64bit pref]
[    1.206841] pci 0000:03:00.0: [168c:002b] type 0 class 0x000280
[    1.206871] pci 0000:03:00.0: reg 10: [mem 0xddc00000-0xddc0ffff 64bit]
[    1.206979] pci 0000:03:00.0: supports D1
[    1.206981] pci 0000:03:00.0: PME# supported from D0 D1 D3hot D3cold
[    1.206987] pci 0000:03:00.0: PME# disabled
[    1.207026] pci 0000:00:1c.1: PCI bridge to [bus 03-03]
[    1.207031] pci 0000:00:1c.1:   bridge window [io  0xb000-0xbfff]
[    1.207036] pci 0000:00:1c.1:   bridge window [mem 0xddc00000-0xde5fffff]
[    1.207043] pci 0000:00:1c.1:   bridge window [mem 0xd3700000-0xd40fffff 64bit pref]
[    1.207115] pci 0000:04:00.0: [1b73:1000] type 0 class 0x000c03
[    1.207137] pci 0000:04:00.0: reg 10: [mem 0xdd200000-0xdd20ffff]
[    1.207269] pci 0000:04:00.0: PME# supported from D0 D3hot
[    1.207275] pci 0000:04:00.0: PME# disabled
[    1.207306] pci 0000:00:1c.3: PCI bridge to [bus 04-04]
[    1.207311] pci 0000:00:1c.3:   bridge window [io  0xa000-0xafff]
[    1.207315] pci 0000:00:1c.3:   bridge window [mem 0xdd200000-0xddbfffff]
[    1.207322] pci 0000:00:1c.3:   bridge window [mem 0xd2c00000-0xd35fffff 64bit pref]
[    1.207452] pci 0000:05:00.0: [10ec:8168] type 0 class 0x000200
[    1.207521] pci 0000:05:00.0: reg 10: [io  0x9000-0x90ff]
[    1.207645] pci 0000:05:00.0: reg 18: [mem 0xd2104000-0xd2104fff 64bit pref]
[    1.207720] pci 0000:05:00.0: reg 20: [mem 0xd2100000-0xd2103fff 64bit pref]
[    1.207932] pci 0000:05:00.0: supports D1 D2
[    1.207934] pci 0000:05:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    1.207949] pci 0000:05:00.0: PME# disabled
[    1.208082] pci 0000:00:1c.5: PCI bridge to [bus 05-05]
[    1.208087] pci 0000:00:1c.5:   bridge window [io  0x9000-0x9fff]
[    1.208092] pci 0000:00:1c.5:   bridge window [mem 0xdc800000-0xdd1fffff]
[    1.208099] pci 0000:00:1c.5:   bridge window [mem 0xd2100000-0xd2afffff 64bit pref]
[    1.208124] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[    1.208311] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEG0._PRT]
[    1.208406] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP01._PRT]
[    1.208456] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP02._PRT]
[    1.208504] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP04._PRT]
[    1.208553] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP06._PRT]
[    1.208650] \_SB_.PCI0:_OSC invalid UUID
[    1.208652] _OSC request data:1 1f 1f
[    1.208656]  pci0000:00: Requesting ACPI _OSC control (0x1d)
[    1.208697] \_SB_.PCI0:_OSC invalid UUID
[    1.208699] _OSC request data:1 0 1d
[    1.208702]  pci0000:00: ACPI _OSC request failed (AE_ERROR), returned control mask: 0x1d
[    1.208704] ACPI _OSC control for PCIe not granted, disabling ASPM
[    1.908873] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 10 *11 12)
[    1.908928] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 *10 12)
[    1.908980] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 *5 6 7 10 12)
[    1.909032] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 *5 6 7 10 12)
[    1.909083] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 10 12) *0, disabled.
[    1.909141] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 10 12) *0, disabled.
[    1.909196] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 *5 6 7 10 12)
[    1.909247] ACPI: PCI Interrupt Link [LNKH] (IRQs *3 4 5 6 7 10 12)
[    1.909344] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[    1.909353] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=none,locks=none
[    1.909356] vgaarb: loaded
[    1.909358] vgaarb: bridge control possible 0000:01:00.0
[    1.909360] vgaarb: bridge control possible 0000:00:02.0
[    1.909434] SCSI subsystem initialized
[    1.909483] libata version 3.00 loaded.
[    1.909530] usbcore: registered new interface driver usbfs
[    1.909543] usbcore: registered new interface driver hub
[    1.909573] usbcore: registered new device driver usb
[    1.909640] PCI: Using ACPI for IRQ routing
[    1.911267] PCI: pci_cache_line_size set to 64 bytes
[    1.911358] reserve RAM buffer: 000000000009e800 - 000000000009ffff
[    1.911360] reserve RAM buffer: 00000000aac10000 - 00000000abffffff
[    1.911365] reserve RAM buffer: 00000000aad97000 - 00000000abffffff
[    1.911368] reserve RAM buffer: 00000000aadc6000 - 00000000abffffff
[    1.911372] reserve RAM buffer: 00000000aaf1f000 - 00000000abffffff
[    1.911375] reserve RAM buffer: 00000000aaf8a000 - 00000000abffffff
[    1.911377] reserve RAM buffer: 00000000aaffd000 - 00000000abffffff
[    1.911380] reserve RAM buffer: 000000034fe00000 - 000000034fffffff
[    1.911477] NetLabel: Initializing
[    1.911479] NetLabel:  domain hash size = 128
[    1.911480] NetLabel:  protocols = UNLABELED CIPSOv4
[    1.911491] NetLabel:  unlabeled traffic allowed by default
[    1.911517] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[    1.911523] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[    1.913546] Switching to clocksource hpet
[    1.914130] Switched to NOHz mode on CPU #0
[    1.914221] Switched to NOHz mode on CPU #1
[    1.914236] Switched to NOHz mode on CPU #5
[    1.914247] Switched to NOHz mode on CPU #2
[    1.914265] Switched to NOHz mode on CPU #6
[    1.914268] Switched to NOHz mode on CPU #3
[    1.914289] Switched to NOHz mode on CPU #7
[    1.914299] Switched to NOHz mode on CPU #4
[    1.921049] pnp: PnP ACPI init
[    1.921064] ACPI: bus type pnp registered
[    1.921357] pnp 00:00: [bus 00-3e]
[    1.921359] pnp 00:00: [io  0x0000-0x0cf7 window]
[    1.921362] pnp 00:00: [io  0x0cf8-0x0cff]
[    1.921364] pnp 00:00: [io  0x0d00-0xffff window]
[    1.921367] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[    1.921370] pnp 00:00: [mem 0x000c0000-0x000c3fff window]
[    1.921374] pnp 00:00: [mem 0x000c4000-0x000c7fff window]
[    1.921377] pnp 00:00: [mem 0x000c8000-0x000cbfff window]
[    1.921379] pnp 00:00: [mem 0x000cc000-0x000cffff window]
[    1.921381] pnp 00:00: [mem 0x000d0000-0x000d3fff window]
[    1.921384] pnp 00:00: [mem 0x000d4000-0x000d7fff window]
[    1.921386] pnp 00:00: [mem 0x000d8000-0x000dbfff window]
[    1.921389] pnp 00:00: [mem 0x000dc000-0x000dffff window]
[    1.921391] pnp 00:00: [mem 0x000e0000-0x000e3fff window]
[    1.921394] pnp 00:00: [mem 0x000e4000-0x000e7fff window]
[    1.921396] pnp 00:00: [mem 0x000e8000-0x000ebfff window]
[    1.921399] pnp 00:00: [mem 0x000ec000-0x000effff window]
[    1.921401] pnp 00:00: [mem 0x000f0000-0x000fffff window]
[    1.921404] pnp 00:00: [mem 0xafa00000-0xfeafffff window]
[    1.921406] pnp 00:00: [mem 0xfed40000-0xfed44fff window]
[    1.921479] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[    1.970910] pnp 00:01: [io  0x0000-0x001f]
[    1.970912] pnp 00:01: [io  0x0081-0x0091]
[    1.970914] pnp 00:01: [io  0x0093-0x009f]
[    1.970917] pnp 00:01: [io  0x00c0-0x00df]
[    1.970919] pnp 00:01: [dma 4]
[    1.970947] pnp 00:01: Plug and Play ACPI device, IDs PNP0200 (active)
[    1.970957] pnp 00:02: [mem 0xff000000-0xffffffff]
[    1.970981] pnp 00:02: Plug and Play ACPI device, IDs INT0800 (active)
[    1.971077] pnp 00:03: [mem 0xfed00000-0xfed003ff]
[    1.971103] pnp 00:03: Plug and Play ACPI device, IDs PNP0103 (active)
[    1.971114] pnp 00:04: [io  0x00f0]
[    1.971124] pnp 00:04: [irq 13]
[    1.971149] pnp 00:04: Plug and Play ACPI device, IDs PNP0c04 (active)
[    1.971160] pnp 00:05: [io  0x002e-0x002f]
[    1.971162] pnp 00:05: [io  0x004e-0x004f]
[    1.971164] pnp 00:05: [io  0x0061]
[    1.971166] pnp 00:05: [io  0x0063]
[    1.971168] pnp 00:05: [io  0x0065]
[    1.971169] pnp 00:05: [io  0x0067]
[    1.971171] pnp 00:05: [io  0x0070]
[    1.971173] pnp 00:05: [io  0x0080]
[    1.971175] pnp 00:05: [io  0x0092]
[    1.971177] pnp 00:05: [io  0x00b2-0x00b3]
[    1.971179] pnp 00:05: [io  0x0680-0x069f]
[    1.971181] pnp 00:05: [io  0x1000-0x100f]
[    1.971183] pnp 00:05: [io  0xffff]
[    1.971185] pnp 00:05: [io  0xffff]
[    1.971187] pnp 00:05: [io  0x0400-0x0453]
[    1.971189] pnp 00:05: [io  0x0458-0x047f]
[    1.971191] pnp 00:05: [io  0x0500-0x057f]
[    1.971193] pnp 00:05: [io  0x164e-0x164f]
[    1.971246] system 00:05: [io  0x0680-0x069f] has been reserved
[    1.971249] system 00:05: [io  0x1000-0x100f] has been reserved
[    1.971252] system 00:05: [io  0xffff] has been reserved
[    1.971254] system 00:05: [io  0xffff] has been reserved
[    1.971256] system 00:05: [io  0x0400-0x0453] has been reserved
[    1.971259] system 00:05: [io  0x0458-0x047f] has been reserved
[    1.971261] system 00:05: [io  0x0500-0x057f] has been reserved
[    1.971263] system 00:05: [io  0x164e-0x164f] has been reserved
[    1.971267] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[    1.971276] pnp 00:06: [io  0x0070-0x0077]
[    1.971284] pnp 00:06: [irq 8]
[    1.971309] pnp 00:06: Plug and Play ACPI device, IDs PNP0b00 (active)
[    1.971331] pnp 00:07: [io  0x0454-0x0457]
[    1.971369] system 00:07: [io  0x0454-0x0457] has been reserved
[    1.971373] system 00:07: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[    1.971386] pnp 00:08: [io  0x0240-0x0259]
[    1.971426] system 00:08: [io  0x0240-0x0259] has been reserved
[    1.971429] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[    1.971471] pnp 00:09: [irq 12]
[    1.971501] pnp 00:09: Plug and Play ACPI device, IDs ETD0001 SYN0a00 SYN0002 PNP0f03 PNP0f13 PNP0f12 (active)
[    1.971522] pnp 00:0a: [io  0x0060]
[    1.971524] pnp 00:0a: [io  0x0064]
[    1.971529] pnp 00:0a: [irq 1]
[    1.971559] pnp 00:0a: Plug and Play ACPI device, IDs PNP0303 PNP030b (active)
[    1.971808] pnp 00:0b: [mem 0xfed1c000-0xfed1ffff]
[    1.971811] pnp 00:0b: [mem 0xfed10000-0xfed17fff]
[    1.971813] pnp 00:0b: [mem 0xfed18000-0xfed18fff]
[    1.971815] pnp 00:0b: [mem 0xfed19000-0xfed19fff]
[    1.971818] pnp 00:0b: [mem 0xe0000000-0xe3ffffff]
[    1.971820] pnp 00:0b: [mem 0xfed20000-0xfed3ffff]
[    1.971822] pnp 00:0b: [mem 0xfed90000-0xfed93fff]
[    1.971824] pnp 00:0b: [mem 0xfed45000-0xfed8ffff]
[    1.971826] pnp 00:0b: [mem 0xff000000-0xffffffff]
[    1.971829] pnp 00:0b: [mem 0xfee00000-0xfeefffff]
[    1.971831] pnp 00:0b: [mem 0x00000000-0xffffffffffffffff disabled]
[    1.971898] system 00:0b: [mem 0xfed1c000-0xfed1ffff] has been reserved
[    1.971901] system 00:0b: [mem 0xfed10000-0xfed17fff] could not be reserved
[    1.971903] system 00:0b: [mem 0xfed18000-0xfed18fff] has been reserved
[    1.971906] system 00:0b: [mem 0xfed19000-0xfed19fff] has been reserved
[    1.971909] system 00:0b: [mem 0xe0000000-0xe3ffffff] has been reserved
[    1.971912] system 00:0b: [mem 0xfed20000-0xfed3ffff] has been reserved
[    1.971914] system 00:0b: [mem 0xfed90000-0xfed93fff] has been reserved
[    1.971917] system 00:0b: [mem 0xfed45000-0xfed8ffff] has been reserved
[    1.971920] system 00:0b: [mem 0xff000000-0xffffffff] could not be reserved
[    1.971922] system 00:0b: [mem 0xfee00000-0xfeefffff] could not be reserved
[    1.971925] system 00:0b: Plug and Play ACPI device, IDs PNP0c02 (active)
[    1.971981] pnp 00:0c: [mem 0xafa00000-0xafa00fff]
[    1.972039] system 00:0c: [mem 0xafa00000-0xafa00fff] has been reserved
[    1.972042] system 00:0c: Plug and Play ACPI device, IDs PNP0c02 (active)
[    1.972172] pnp 00:0d: [mem 0x20000000-0x201fffff]
[    1.972174] pnp 00:0d: [mem 0x40000000-0x401fffff]
[    1.972238] system 00:0d: [mem 0x20000000-0x201fffff] has been reserved
[    1.972240] system 00:0d: [mem 0x40000000-0x401fffff] has been reserved
[    1.972243] system 00:0d: Plug and Play ACPI device, IDs PNP0c01 (active)
[    1.972268] pnp: PnP ACPI: found 14 devices
[    1.972269] ACPI: ACPI bus type pnp unregistered
[    1.978438] PCI: max bus depth: 1 pci_try_num: 2
[    1.978478] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[    1.978481] pci 0000:00:01.0:   bridge window [io  0xd000-0xdfff]
[    1.978484] pci 0000:00:01.0:   bridge window [mem 0xdb000000-0xdc0fffff]
[    1.978488] pci 0000:00:01.0:   bridge window [mem 0xc0000000-0xd1ffffff 64bit pref]
[    1.978492] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[    1.978496] pci 0000:00:1c.0:   bridge window [io  0xc000-0xcfff]
[    1.978502] pci 0000:00:1c.0:   bridge window [mem 0xde600000-0xdeffffff]
[    1.978507] pci 0000:00:1c.0:   bridge window [mem 0xd4200000-0xd4bfffff 64bit pref]
[    1.978514] pci 0000:00:1c.1: PCI bridge to [bus 03-03]
[    1.978518] pci 0000:00:1c.1:   bridge window [io  0xb000-0xbfff]
[    1.978524] pci 0000:00:1c.1:   bridge window [mem 0xddc00000-0xde5fffff]
[    1.978529] pci 0000:00:1c.1:   bridge window [mem 0xd3700000-0xd40fffff 64bit pref]
[    1.978536] pci 0000:00:1c.3: PCI bridge to [bus 04-04]
[    1.978540] pci 0000:00:1c.3:   bridge window [io  0xa000-0xafff]
[    1.978546] pci 0000:00:1c.3:   bridge window [mem 0xdd200000-0xddbfffff]
[    1.978551] pci 0000:00:1c.3:   bridge window [mem 0xd2c00000-0xd35fffff 64bit pref]
[    1.978558] pci 0000:00:1c.5: PCI bridge to [bus 05-05]
[    1.978562] pci 0000:00:1c.5:   bridge window [io  0x9000-0x9fff]
[    1.978568] pci 0000:00:1c.5:   bridge window [mem 0xdc800000-0xdd1fffff]
[    1.978573] pci 0000:00:1c.5:   bridge window [mem 0xd2100000-0xd2afffff 64bit pref]
[    1.978591] pci 0000:00:01.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[    1.978595] pci 0000:00:01.0: setting latency timer to 64
[    1.978603] pci 0000:00:1c.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[    1.978608] pci 0000:00:1c.0: setting latency timer to 64
[    1.978619] pci 0000:00:1c.1: PCI INT B -> GSI 17 (level, low) -> IRQ 17
[    1.978624] pci 0000:00:1c.1: setting latency timer to 64
[    1.978635] pci 0000:00:1c.3: PCI INT D -> GSI 19 (level, low) -> IRQ 19
[    1.978640] pci 0000:00:1c.3: setting latency timer to 64
[    1.978648] pci 0000:00:1c.5: PCI INT B -> GSI 17 (level, low) -> IRQ 17
[    1.978652] pci 0000:00:1c.5: setting latency timer to 64
[    1.978657] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7]
[    1.978659] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff]
[    1.978661] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[    1.978664] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000d3fff]
[    1.978666] pci_bus 0000:00: resource 8 [mem 0x000d4000-0x000d7fff]
[    1.978668] pci_bus 0000:00: resource 9 [mem 0x000d8000-0x000dbfff]
[    1.978670] pci_bus 0000:00: resource 10 [mem 0x000dc000-0x000dffff]
[    1.978672] pci_bus 0000:00: resource 11 [mem 0x000e0000-0x000e3fff]
[    1.978674] pci_bus 0000:00: resource 12 [mem 0x000e4000-0x000e7fff]
[    1.978677] pci_bus 0000:00: resource 13 [mem 0xafa00000-0xfeafffff]
[    1.978679] pci_bus 0000:00: resource 14 [mem 0xfed40000-0xfed44fff]
[    1.978682] pci_bus 0000:01: resource 0 [io  0xd000-0xdfff]
[    1.978684] pci_bus 0000:01: resource 1 [mem 0xdb000000-0xdc0fffff]
[    1.978686] pci_bus 0000:01: resource 2 [mem 0xc0000000-0xd1ffffff 64bit pref]
[    1.978688] pci_bus 0000:02: resource 0 [io  0xc000-0xcfff]
[    1.978691] pci_bus 0000:02: resource 1 [mem 0xde600000-0xdeffffff]
[    1.978693] pci_bus 0000:02: resource 2 [mem 0xd4200000-0xd4bfffff 64bit pref]
[    1.978695] pci_bus 0000:03: resource 0 [io  0xb000-0xbfff]
[    1.978697] pci_bus 0000:03: resource 1 [mem 0xddc00000-0xde5fffff]
[    1.978699] pci_bus 0000:03: resource 2 [mem 0xd3700000-0xd40fffff 64bit pref]
[    1.978702] pci_bus 0000:04: resource 0 [io  0xa000-0xafff]
[    1.978704] pci_bus 0000:04: resource 1 [mem 0xdd200000-0xddbfffff]
[    1.978706] pci_bus 0000:04: resource 2 [mem 0xd2c00000-0xd35fffff 64bit pref]
[    1.978708] pci_bus 0000:05: resource 0 [io  0x9000-0x9fff]
[    1.978710] pci_bus 0000:05: resource 1 [mem 0xdc800000-0xdd1fffff]
[    1.978712] pci_bus 0000:05: resource 2 [mem 0xd2100000-0xd2afffff 64bit pref]
[    1.978740] NET: Registered protocol family 2
[    1.979272] IP route cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    1.980631] TCP established hash table entries: 524288 (order: 11, 8388608 bytes)
[    1.982165] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[    1.982313] TCP: Hash tables configured (established 524288 bind 65536)
[    1.982315] TCP reno registered
[    1.982349] UDP hash table entries: 8192 (order: 6, 262144 bytes)
[    1.982434] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes)
[    1.982615] NET: Registered protocol family 1
[    1.982630] pci 0000:00:02.0: Boot video device
[    2.228873] PCI: CLS 64 bytes, default 64
[    2.228921] Trying to unpack rootfs image as initramfs...
[    2.569834] Freeing initrd memory: 14940k freed
[    2.571951] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    2.571956] Placing 64MB software IO TLB between ffff8800a6c10000 - ffff8800aac10000
[    2.571958] software IO TLB at phys 0xa6c10000 - 0xaac10000
[    2.573148] Intel AES-NI instructions are not detected.
[    2.573276] audit: initializing netlink socket (disabled)
[    2.573289] type=2000 audit(1319815910.164:1): initialized
[    2.610842] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    2.640598] VFS: Disk quotas dquot_6.5.2
[    2.640663] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    2.641203] msgmni has been set to 23897
[    2.641269] SELinux:  Registering netfilter hooks
[    2.641682] alg: No test for stdrng (krng)
[    2.641691] NET: Registered protocol family 38
[    2.641744] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[    2.641782] io scheduler noop registered
[    2.641784] io scheduler deadline registered
[    2.641824] io scheduler cfq registered (default)
[    2.641923] pcieport 0000:00:01.0: setting latency timer to 64
[    2.641954] pcieport 0000:00:01.0: irq 40 for MSI/MSI-X
[    2.642194] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[    2.642222] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[    2.642224] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    2.642730] intel_idle: MWAIT substates: 0x21120
[    2.642732] intel_idle: v0.4 model 0x2A
[    2.642733] intel_idle: lapic_timer_reliable_states 0xffffffff
[    2.664629] ACPI: Deprecated procfs I/F for AC is loaded, please retry with CONFIG_ACPI_PROCFS_POWER cleared
[    2.664710] ACPI: AC Adapter [AC0] (on-line)
[    2.664826] input: Lid Switch as /devices/LNXSYSTM:00/device:00/PNP0C0D:00/input/input0
[    2.675347] ACPI: Lid Switch [LID]
[    2.675392] input: Sleep Button as /devices/LNXSYSTM:00/device:00/PNP0C0E:00/input/input1
[    2.675397] ACPI: Sleep Button [sLPB]
[    2.675442] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[    2.675446] ACPI: Power Button [PWRF]
[    2.675671] ACPI: acpi_idle yielding to intel_idle
[    2.727689] thermal LNXTHERM:00: registered as thermal_zone0
[    2.727693] ACPI: Thermal Zone [THRM] (57 C)
[    2.727705] ERST: Table is not found!
[    2.727781] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    2.731134] Non-volatile memory driver v1.3
[    2.731136] Linux agpgart interface v0.103
[    2.731221] agpgart-intel 0000:00:00.0: Intel Sandybridge Chipset
[    2.731348] agpgart-intel 0000:00:00.0: detected gtt size: 2097152K total, 262144K mappable
[    2.732861] agpgart-intel 0000:00:00.0: detected 65536K stolen memory
[    2.732993] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xb0000000
[    2.734272] brd: module loaded
[    2.734848] loop: module loaded
[    2.734935] ahci 0000:00:1f.2: version 3.0
[    2.734948] ahci 0000:00:1f.2: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[    2.735004] ahci 0000:00:1f.2: irq 41 for MSI/MSI-X
[    2.745571] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x5 impl SATA mode
[    2.745581] ahci 0000:00:1f.2: flags: 64bit ncq sntf pm led clo pio slum part ems apst
[    2.745591] ahci 0000:00:1f.2: setting latency timer to 64
[    2.748096] scsi0 : ahci
[    2.748181] scsi1 : ahci
[    2.748245] scsi2 : ahci
[    2.748310] scsi3 : ahci
[    2.748373] scsi4 : ahci
[    2.748442] scsi5 : ahci
[    2.748792] ata1: SATA max UDMA/133 abar m2048@0xdf006000 port 0xdf006100 irq 41
[    2.748794] ata2: DUMMY
[    2.748797] ata3: SATA max UDMA/133 abar m2048@0xdf006000 port 0xdf006200 irq 41
[    2.748799] ata4: DUMMY
[    2.748800] ata5: DUMMY
[    2.748801] ata6: DUMMY
[    2.748874] Fixed MDIO Bus: probed
[    2.748925] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.748943] ehci_hcd 0000:00:1a.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[    2.748960] ehci_hcd 0000:00:1a.0: setting latency timer to 64
[    2.748964] ehci_hcd 0000:00:1a.0: EHCI Host Controller
[    2.749022] ehci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 1
[    2.749054] ehci_hcd 0000:00:1a.0: debug port 2
[    2.752926] ehci_hcd 0000:00:1a.0: cache line size of 64 is not supported
[    2.752942] ehci_hcd 0000:00:1a.0: irq 16, io mem 0xdf008000
[    2.762540] ehci_hcd 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[    2.762583] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    2.762591] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.762598] usb usb1: Product: EHCI Host Controller
[    2.762604] usb usb1: Manufacturer: Linux 2.6.40.6-0.fc15.x86_64 ehci_hcd
[    2.762610] usb usb1: SerialNumber: 0000:00:1a.0
[    2.762738] hub 1-0:1.0: USB hub found
[    2.762743] hub 1-0:1.0: 2 ports detected
[    2.762812] ehci_hcd 0000:00:1d.0: PCI INT A -> GSI 23 (level, low) -> IRQ 23
[    2.762827] ehci_hcd 0000:00:1d.0: setting latency timer to 64
[    2.762830] ehci_hcd 0000:00:1d.0: EHCI Host Controller
[    2.762869] ehci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[    2.762893] ehci_hcd 0000:00:1d.0: debug port 2
[    2.766775] ehci_hcd 0000:00:1d.0: cache line size of 64 is not supported
[    2.766790] ehci_hcd 0000:00:1d.0: irq 23, io mem 0xdf007000
[    2.776534] ehci_hcd 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[    2.776569] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    2.776577] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.776584] usb usb2: Product: EHCI Host Controller
[    2.776589] usb usb2: Manufacturer: Linux 2.6.40.6-0.fc15.x86_64 ehci_hcd
[    2.776595] usb usb2: SerialNumber: 0000:00:1d.0
[    2.776729] hub 2-0:1.0: USB hub found
[    2.776733] hub 2-0:1.0: 2 ports detected
[    2.776789] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.776802] uhci_hcd: USB Universal Host Controller Interface driver
[    2.776846] usbcore: registered new interface driver usbserial
[    2.776854] USB Serial support registered for generic
[    2.776865] usbcore: registered new interface driver usbserial_generic
[    2.776867] usbserial: USB Serial Driver core
[    2.776917] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f03:PS2M] at 0x60,0x64 irq 1,12
[    2.778547] i8042: Detected active multiplexing controller, rev 1.1
[    2.779390] serio: i8042 KBD port at 0x60,0x64 irq 1
[    2.779396] serio: i8042 AUX0 port at 0x60,0x64 irq 12
[    2.779405] serio: i8042 AUX1 port at 0x60,0x64 irq 12
[    2.779408] serio: i8042 AUX2 port at 0x60,0x64 irq 12
[    2.779410] serio: i8042 AUX3 port at 0x60,0x64 irq 12
[    2.779568] mousedev: PS/2 mouse device common for all mice
[    2.779733] rtc_cmos 00:06: RTC can wake from S4
[    2.779836] rtc_cmos 00:06: rtc core: registered rtc_cmos as rtc0
[    2.779864] rtc0: alarms up to one year, y3k, 242 bytes nvram, hpet irqs
[    2.779965] device-mapper: uevent: version 1.0.3
[    2.780042] device-mapper: ioctl: 4.20.0-ioctl (2011-02-02) initialised: [email protected]
[    2.780358] cpuidle: using governor ladder
[    2.780808] cpuidle: using governor menu
[    2.781159] EFI Variables Facility v0.08 2004-May-17
[    2.781290] usbcore: registered new interface driver usbhid
[    2.781291] usbhid: USB HID core driver
[    2.781359] ip_tables: (C) 2000-2006 Netfilter Core Team
[    2.781376] TCP cubic registered
[    2.781377] Initializing XFRM netlink socket
[    2.781395] NET: Registered protocol family 17
[    2.781409] Registering the dns_resolver key type
[    2.781498] PM: Hibernation image not present or could not be loaded.
[    2.781520] registered taskstats version 1
[    2.795447] IMA: No TPM chip found, activating TPM-bypass!
[    2.796041]   Magic number: 15:198:539
[    2.796167] rtc_cmos 00:06: setting system clock to 2011-10-28 15:31:51 UTC (1319815911)
[    2.796254] Initializing network drop monitor service
[    2.815750] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
[    3.053512] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    3.053558] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[    3.054941] ata1.00: ACPI cmd f5/00:00:00:00:00:a0 (SECURITY FREEZE LOCK) filtered out
[    3.056154] ata3.00: ACPI cmd ef/10:06:00:00:00:a0 (SET FEATURES) succeeded
[    3.056165] ata3.00: ACPI cmd ef/10:03:00:00:00:a0 (SET FEATURES) filtered out
[    3.057814] ata3.00: ATAPI: MATSHITADVD-RAM UJ8A0ASW, 1.01, max UDMA/100
[    3.060987] ACPI: Deprecated procfs I/F for battery is loaded, please retry with CONFIG_ACPI_PROCFS_POWER cleared
[    3.061000] ACPI: Battery Slot [bAT0] (battery present)
[    3.061420] ata3.00: ACPI cmd ef/10:06:00:00:00:a0 (SET FEATURES) succeeded
[    3.061457] ata3.00: ACPI cmd ef/10:03:00:00:00:a0 (SET FEATURES) filtered out
[    3.063213] ata3.00: configured for UDMA/100
[    3.064139] ata1.00: ACPI cmd ef/10:06:00:00:00:a0 (SET FEATURES) succeeded
[    3.064150] ata1.00: ACPI cmd ef/10:03:00:00:00:a0 (SET FEATURES) filtered out
[    3.064497] usb 1-1: new high speed USB device number 2 using ehci_hcd
[    3.128843] ata1.00: ATA-8: ST9640320AS, 0002SDM1, max UDMA/133
[    3.128853] ata1.00: 1250263728 sectors, multi 16: LBA48 NCQ (depth 31/32)
[    3.145034] ata1.00: ACPI cmd f5/00:00:00:00:00:a0 (SECURITY FREEZE LOCK) filtered out
[    3.154818] ata1.00: ACPI cmd ef/10:06:00:00:00:a0 (SET FEATURES) succeeded
[    3.154830] ata1.00: ACPI cmd ef/10:03:00:00:00:a0 (SET FEATURES) filtered out
[    3.176606] elantech: assuming hardware version 2, firmware version 4.2.1
[    3.178873] usb 1-1: New USB device found, idVendor=8087, idProduct=0024
[    3.178877] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.179144] hub 1-1:1.0: USB hub found
[    3.179235] hub 1-1:1.0: 6 ports detected
[    3.185037] ata1.00: configured for UDMA/133
[    3.185324] scsi 0:0:0:0: Direct-Access     ATA      ST9640320AS      0002 PQ: 0 ANSI: 5
[    3.185494] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    3.185548] sd 0:0:0:0: [sda] 1250263728 512-byte logical blocks: (640 GB/596 GiB)
[    3.185594] sd 0:0:0:0: [sda] Write Protect is off
[    3.185597] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    3.185617] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    3.188791] scsi 2:0:0:0: CD-ROM            MATSHITA DVD-RAM UJ8A0ASW 1.01 PQ: 0 ANSI: 5
[    3.192047] sr0: scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[    3.192058] cdrom: Uniform CD-ROM driver Revision: 3.20
[    3.192221] sr 2:0:0:0: Attached scsi CD-ROM sr0
[    3.192309] sr 2:0:0:0: Attached scsi generic sg1 type 5
[    3.204596] elantech: Synaptics capabilities query result 0x78, 0x14, 0x0b.
[    3.259245]  sda: sda1 sda2 sda3 < sda5 sda6 sda7 sda8 sda9 sda10 >
[    3.259834] sd 0:0:0:0: [sda] Attached SCSI disk
[    3.262044] Freeing unused kernel memory: 936k freed
[    3.262160] Write protecting the kernel read-only data: 10240k
[    3.268833] Freeing unused kernel memory: 1444k freed
[    3.276545] Freeing unused kernel memory: 1684k freed
[    3.281379] usb 2-1: new high speed USB device number 2 using ehci_hcd
[    3.282818] input: ETPS/2 Elantech Touchpad as /devices/platform/i8042/serio4/input/input4
[    3.309134] dracut: dracut-009-12.fc15
[    3.317147] dracut: rd.luks=0: removing cryptoluks activation
[    3.319586] dracut: rd.lvm=0: removing LVM activation
[    3.324891] udev[135]: starting version 167
[    3.340264] wmi: Mapper loaded
[    3.344189] [drm] Initialized drm 1.1.0 20060810
[    3.355873] i915 0000:00:02.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[    3.355879] i915 0000:00:02.0: setting latency timer to 64
[    3.396692] usb 2-1: New USB device found, idVendor=8087, idProduct=0024
[    3.396695] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.396961] hub 2-1:1.0: USB hub found
[    3.397031] hub 2-1:1.0: 6 ports detected
[    3.414279] mtrr: type mismatch for b0000000,10000000 old: write-back new: write-combining
[    3.414282] [drm] MTRR allocation failed.  Graphics performance may suffer.
[    3.414589] i915 0000:00:02.0: irq 42 for MSI/MSI-X
[    3.414595] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[    3.414596] [drm] Driver supports precise vblank timestamp query.
[    3.414868] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=none:owns=io+mem
[    3.414871] vgaarb: transferring owner from PCI:0000:00:02.0 to PCI:0000:01:00.0
[    3.470420] usb 1-1.1: new full speed USB device number 3 using ehci_hcd
[    3.556401] usb 1-1.1: New USB device found, idVendor=13d3, idProduct=3304
[    3.556405] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.573302] Refined TSC clocksource calibration: 1995.468 MHz.
[    3.573308] Switching to clocksource tsc
[    3.576346] fbcon: inteldrmfb (fb0) is primary device
[    3.629496] usb 1-1.2: new high speed USB device number 4 using ehci_hcd
[    3.739958] Console: switching to colour frame buffer device 170x48
[    3.743949] fb0: inteldrmfb frame buffer device
[    3.743950] drm: registered panic notifier
[    3.745247] ACPI Warning: _BQC returned an invalid level (20110413/video-473)
[    3.745577] acpi device:04: registered as cooling_device8
[    3.745690] input: Video Bus as /devices/LNXSYSTM:00/device:00/PNP0A08:00/device:01/LNXVIDEO:00/input/input5
[    3.745736] ACPI: Video Device [GFX0] (multi-head: yes  rom: yes  post: no)
[    3.753950] usb 1-1.2: New USB device found, idVendor=13d3, idProduct=5122
[    3.753960] usb 1-1.2: New USB device strings: Mfr=2, Product=1, SerialNumber=3
[    3.753967] usb 1-1.2: Product: USB2.0 UVC 2M WebCam
[    3.753972] usb 1-1.2: Manufacturer: USB2.0 UVC 2M WebCam
[    3.753976] usb 1-1.2: SerialNumber: USB2.0 UVC 2M WebCam
[    3.759768] ACPI Warning: _BQC returned an invalid level (20110413/video-473)
[    3.760112] acpi device:48: registered as cooling_device9
[    3.760547] input: Video Bus as /devices/LNXSYSTM:00/device:00/PNP0A08:00/LNXVIDEO:01/input/input6
[    3.760589] ACPI: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
[    3.760613] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[    3.797706] dracut: Starting plymouth daemon
[    3.832469] usb 2-1.2: new low speed USB device number 3 using ehci_hcd
[    3.921292] usb 2-1.2: New USB device found, idVendor=2166, idProduct=6649
[    3.921302] usb 2-1.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    3.921309] usb 2-1.2: Product:  USB OPTICAL MOUSE
[    3.923880] input:  USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.0/input/input7
[    3.924032] generic-usb 0003:2166:6649.0001: input,hidraw0: USB HID v1.11 Mouse [ USB OPTICAL MOUSE] on usb-0000:00:1d.0-1.2/input0
[    3.944602] dracut: rd.dm=0: removing DM RAID activation
[    3.947458] dracut: rd.md=0: removing MD RAID activation
[    5.730534] EXT4-fs (sda8): INFO: recovery required on readonly filesystem
[    5.730538] EXT4-fs (sda8): write access will be enabled during recovery
[    6.099305] EXT4-fs (sda8): orphan cleanup on readonly fs
[    6.099314] EXT4-fs (sda8): ext4_orphan_cleanup: deleting unreferenced inode 47751
[    6.099339] EXT4-fs (sda8): ext4_orphan_cleanup: deleting unreferenced inode 47157
[    6.099348] EXT4-fs (sda8): ext4_orphan_cleanup: deleting unreferenced inode 47155
[    6.099356] EXT4-fs (sda8): ext4_orphan_cleanup: deleting unreferenced inode 47149
[    6.099364] EXT4-fs (sda8): ext4_orphan_cleanup: deleting unreferenced inode 47148
[    6.099371] EXT4-fs (sda8): ext4_orphan_cleanup: deleting unreferenced inode 47145
[    6.099379] EXT4-fs (sda8): ext4_orphan_cleanup: deleting unreferenced inode 278116
[    6.099387] EXT4-fs (sda8): ext4_orphan_cleanup: deleting unreferenced inode 47143
[    6.099395] EXT4-fs (sda8): ext4_orphan_cleanup: deleting unreferenced inode 47134
[    6.099403] EXT4-fs (sda8): ext4_orphan_cleanup: deleting unreferenced inode 278115
[    6.099410] EXT4-fs (sda8): ext4_orphan_cleanup: deleting unreferenced inode 47028
[    6.099418] EXT4-fs (sda8): ext4_orphan_cleanup: deleting unreferenced inode 47021
[    6.099428] EXT4-fs (sda8): ext4_orphan_cleanup: deleting unreferenced inode 6272
[    6.099436] EXT4-fs (sda8): ext4_orphan_cleanup: deleting unreferenced inode 278114
[    6.099444] EXT4-fs (sda8): ext4_orphan_cleanup: deleting unreferenced inode 278113
[    6.099456] EXT4-fs (sda8): 15 orphan inodes deleted
[    6.099458] EXT4-fs (sda8): recovery complete
[    6.389323] EXT4-fs (sda8): mounted filesystem with ordered data mode. Opts: (null)
[    6.484263] dracut: Checking filesystems
[    6.484287] dracut: fsck -T -t noopts=_netdev -A -a
[    6.604317] dracut: _Fedora-15-x86_6: clean, 139095/966656 files, 1106015/3840000 blocks
[    6.604504] dracut: Remounting /dev/disk/by-uuid/17b553dd-f518-417c-aa7a-68f1e91a246a with -o ro,
[    6.719844] EXT4-fs (sda8): mounted filesystem with ordered data mode. Opts: (null)
[    6.733912] dracut: Mounted root filesystem /dev/sda8
[    6.934042] dracut: Switching root
[    7.851802] type=1404 audit(1319815916.556:2): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
[    8.095771] SELinux: 2048 avtab hash slots, 226256 rules.
[    8.178814] SELinux: 2048 avtab hash slots, 226256 rules.
[    8.488357] SELinux:  9 users, 13 roles, 3644 types, 192 bools, 1 sens, 1024 cats
[    8.488362] SELinux:  81 classes, 226256 rules
[    8.496127] SELinux:  Completing initialization.
[    8.496129] SELinux:  Setting up existing superblocks.
[    8.496137] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
[    8.496143] SELinux: initialized (dev rootfs, type rootfs), uses genfs_contexts
[    8.496155] SELinux: initialized (dev bdev, type bdev), uses genfs_contexts
[    8.496161] SELinux: initialized (dev proc, type proc), uses genfs_contexts
[    8.496169] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[    8.496194] SELinux: initialized (dev devtmpfs, type devtmpfs), uses transition SIDs
[    8.496961] SELinux: initialized (dev sockfs, type sockfs), uses task SIDs
[    8.496965] SELinux: initialized (dev debugfs, type debugfs), uses genfs_contexts
[    8.497638] SELinux: initialized (dev pipefs, type pipefs), uses task SIDs
[    8.497643] SELinux: initialized (dev anon_inodefs, type anon_inodefs), uses genfs_contexts
[    8.497647] SELinux: initialized (dev devpts, type devpts), uses transition SIDs
[    8.497666] SELinux: initialized (dev hugetlbfs, type hugetlbfs), uses transition SIDs
[    8.497682] SELinux: initialized (dev mqueue, type mqueue), uses transition SIDs
[    8.497695] SELinux: initialized (dev selinuxfs, type selinuxfs), uses genfs_contexts
[    8.497709] SELinux: initialized (dev usbfs, type usbfs), uses genfs_contexts
[    8.497714] SELinux: initialized (dev securityfs, type securityfs), uses genfs_contexts
[    8.497719] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
[    8.498135] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[    8.498142] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[    8.498655] SELinux: initialized (dev sda8, type ext4), uses xattr
[    8.501662] type=1403 audit(1319815917.205:3): policy loaded auid=4294967295 ses=4294967295
[    8.790741] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[    8.791780] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[    8.921711] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[    8.937660] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[    8.938045] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[    8.953692] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[    8.962691] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[    8.975659] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[    8.984687] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[    8.996685] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[    9.006674] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
[    9.059034] systemd[1]: systemd 26 running in system mode. (+PAM +LIBWRAP +AUDIT +SELINUX +SYSVINIT +LIBCRYPTSETUP; fedora)
[    9.473677] NET: Registered protocol family 10
[    9.535993] systemd[1]: Set hostname to <samson32>.
[   11.542067] SELinux: initialized (dev autofs, type autofs), uses genfs_contexts
[   11.545821] SELinux: initialized (dev autofs, type autofs), uses genfs_contexts
[   11.546531] SELinux: initialized (dev autofs, type autofs), uses genfs_contexts
[   11.599636] SELinux: initialized (dev autofs, type autofs), uses genfs_contexts
[   11.708791] SELinux: initialized (dev autofs, type autofs), uses genfs_contexts
[   12.111153] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[   12.142639] EXT4-fs (sda8): re-mounted. Opts: (null)
[   13.215539] udev[465]: starting version 167
[   13.453484] microcode: CPU0 sig=0x206a7, pf=0x10, revision=0x12
[   13.550144] Bluetooth: Core ver 2.16
[   13.550537] NET: Registered protocol family 31
[   13.550539] Bluetooth: HCI device and connection manager initialized
[   13.550541] Bluetooth: HCI socket layer initialized
[   13.550543] Bluetooth: L2CAP socket layer initialized
[   13.552247] Bluetooth: SCO socket layer initialized
[   13.661282] mtp-probe[588]: checking bus 2, device 3: "/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2"
[   13.662490] mtp-probe[588]: bus: 2, device: 3 was not an MTP device
[   13.712266] iTCO_vendor_support: vendor-support=0
[   13.819782] microcode: CPU0 updated to revision 0x17, date = 2011-04-07
[   13.819793] microcode: CPU1 sig=0x206a7, pf=0x10, revision=0x12
[   13.821691] microcode: CPU1 updated to revision 0x17, date = 2011-04-07
[   13.821701] microcode: CPU2 sig=0x206a7, pf=0x10, revision=0x12
[   13.823445] microcode: CPU2 updated to revision 0x17, date = 2011-04-07
[   13.823470] microcode: CPU3 sig=0x206a7, pf=0x10, revision=0x12
[   13.825279] microcode: CPU3 updated to revision 0x17, date = 2011-04-07
[   13.825289] microcode: CPU4 sig=0x206a7, pf=0x10, revision=0x17
[   13.826668] microcode: CPU5 sig=0x206a7, pf=0x10, revision=0x17
[   13.828191] microcode: CPU6 sig=0x206a7, pf=0x10, revision=0x17
[   13.829608] microcode: CPU7 sig=0x206a7, pf=0x10, revision=0x17
[   13.831072] microcode: Microcode Update Driver: v2.00 <[email protected]>, Peter Oruba
[   13.833481] cfg80211: Calling CRDA to update world regulatory domain
[   13.857386] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.06
[   13.857496] iTCO_wdt: Found a Cougar Point TCO device (Version=2, TCOBASE=0x0460)
[   13.857574] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[   14.038605] i801_smbus 0000:00:1f.3: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[   14.084987] xhci_hcd 0000:04:00.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[   14.085083] xhci_hcd 0000:04:00.0: setting latency timer to 64
[   14.085089] xhci_hcd 0000:04:00.0: xHCI Host Controller
[   14.085684] xhci_hcd 0000:04:00.0: new USB bus registered, assigned bus number 3
[   14.094678] asus_wmi: ASUS WMI generic driver loaded
[   14.099545] asus_wmi: Initialization: 0x1
[   14.099612] asus_wmi: BIOS WMI version: 1792.6
[   14.099697] asus_wmi: SFUN value: 0x1a0877
[   14.100810] input: Asus WMI hotkeys as /devices/platform/asus-nb-wmi/input/input8
[   14.129564] asus_wmi: Backlight controlled by ACPI video driver
[   14.201794] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[   14.201825] r8169 0000:05:00.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[   14.201911] r8169 0000:05:00.0: setting latency timer to 64
[   14.202033] r8169 0000:05:00.0: irq 43 for MSI/MSI-X
[   14.202255] r8169 0000:05:00.0: eth0: RTL8168e/8111e at 0xffffc90006646000, bc:ae:c5:69:f5:a0, XID 0c200000 IRQ 43
[   14.226901] xhci_hcd 0000:04:00.0: irq 19, io mem 0xdd200000
[   14.226967] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[   14.226970] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.226973] usb usb3: Product: xHCI Host Controller
[   14.226975] usb usb3: Manufacturer: Linux 2.6.40.6-0.fc15.x86_64 xhci_hcd
[   14.226977] usb usb3: SerialNumber: 0000:04:00.0
[   14.227105] xHCI xhci_add_endpoint called for root hub
[   14.227107] xHCI xhci_check_bandwidth called for root hub
[   14.227137] hub 3-0:1.0: USB hub found
[   14.227144] hub 3-0:1.0: 1 port detected
[   14.227203] xhci_hcd 0000:04:00.0: xHCI Host Controller
[   14.227248] xhci_hcd 0000:04:00.0: new USB bus registered, assigned bus number 4
[   14.227270] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[   14.227273] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.227275] usb usb4: Product: xHCI Host Controller
[   14.227277] usb usb4: Manufacturer: Linux 2.6.40.6-0.fc15.x86_64 xhci_hcd
[   14.227279] usb usb4: SerialNumber: 0000:04:00.0
[   14.227358] xHCI xhci_add_endpoint called for root hub
[   14.227361] xHCI xhci_check_bandwidth called for root hub
[   14.227388] hub 4-0:1.0: USB hub found
[   14.227394] hub 4-0:1.0: 1 port detected
[   14.228197] Bluetooth: Generic Bluetooth USB driver ver 0.6
[   14.228254] usbcore: registered new interface driver btusb
[   14.235722] Bluetooth: Atheros AR30xx firmware driver ver 1.0
[   14.425447] Linux media interface: v0.10
[   14.432693] Linux video capture interface: v2.00
[   14.671171] ath9k 0000:03:00.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[   14.671185] ath9k 0000:03:00.0: setting latency timer to 64
[   14.676542] uvcvideo: Found UVC 1.00 device USB2.0 UVC 2M WebCam (13d3:5122)
[   14.686983] input: USB2.0 UVC 2M WebCam as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.2/1-1.2:1.0/input/input9
[   14.687073] usbcore: registered new interface driver uvcvideo
[   14.687076] USB Video Class driver (v1.1.0)
[   14.720563] ath: EEPROM regdomain: 0x60
[   14.720566] ath: EEPROM indicates we should expect a direct regpair map
[   14.720569] ath: Country alpha2 being used: 00
[   14.720570] ath: Regpair used: 0x60
[   14.754884] udev[484]: renamed network interface eth0 to p5p1
[   14.779612] ieee80211 phy0: Selected rate control algorithm 'ath9k_rate_control'
[   14.779897] Registered led device: ath9k-phy0
[   14.779906] ieee80211 phy0: Atheros AR9285 Rev:2 mem=0xffffc90006f20000, irq=17
[   14.939556] cfg80211: World regulatory domain updated:
[   14.939560] cfg80211:     (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[   14.939563] cfg80211:     (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[   14.939566] cfg80211:     (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[   14.939568] cfg80211:     (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[   14.939571] cfg80211:     (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[   14.939573] cfg80211:     (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[   14.983397] HDA Intel 0000:00:1b.0: PCI INT A -> GSI 22 (level, low) -> IRQ 22
[   14.983465] HDA Intel 0000:00:1b.0: irq 44 for MSI/MSI-X
[   14.983491] HDA Intel 0000:00:1b.0: setting latency timer to 64
[   15.854431] Adding 524284k swap on /dev/sda9.  Priority:0 extents:1 across:524284k
[   15.946488] ALSA sound/pci/hda/patch_realtek.c:1752 SKU: Nid=0x1d sku_cfg=0x40079a2d
[   15.946494] ALSA sound/pci/hda/patch_realtek.c:1754 SKU: port_connectivity=0x1
[   15.946498] ALSA sound/pci/hda/patch_realtek.c:1755 SKU: enable_pcbeep=0x0
[   15.946501] ALSA sound/pci/hda/patch_realtek.c:1756 SKU: check_sum=0x00000007
[   15.946504] ALSA sound/pci/hda/patch_realtek.c:1757 SKU: customization=0x0000009a
[   15.946506] ALSA sound/pci/hda/patch_realtek.c:1758 SKU: external_amp=0x5
[   15.946508] ALSA sound/pci/hda/patch_realtek.c:1759 SKU: platform_type=0x1
[   15.946510] ALSA sound/pci/hda/patch_realtek.c:1760 SKU: swap=0x0
[   15.946513] ALSA sound/pci/hda/patch_realtek.c:1761 SKU: override=0x1
[   15.947073] hda_codec: ALC269VB: BIOS auto-probing.
[   15.947079] ALSA sound/pci/hda/hda_codec.c:4707 autoconfig: line_outs=1 (0x1b/0x0/0x0/0x0/0x0) type:speaker
[   15.947082] ALSA sound/pci/hda/hda_codec.c:4711    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[   15.947085] ALSA sound/pci/hda/hda_codec.c:4715    hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[   15.947087] ALSA sound/pci/hda/hda_codec.c:4716    mono: mono_out=0x0
[   15.947089] ALSA sound/pci/hda/hda_codec.c:4719    dig-out=0x1e/0x0
[   15.947091] ALSA sound/pci/hda/hda_codec.c:4720    inputs:
[   15.947094] ALSA sound/pci/hda/hda_codec.c:4724  Mic=0x18
[   15.947096] ALSA sound/pci/hda/hda_codec.c:4724  Internal Mic=0x19
[   15.947098] ALSA sound/pci/hda/hda_codec.c:4726
[   15.947406] ALSA sound/pci/hda/patch_realtek.c:1809 realtek: No valid SSID, checking pincfg 0x40079a2d for NID 0x1d
[   15.947410] ALSA sound/pci/hda/patch_realtek.c:1825 realtek: Enabling init ASM_ID=0x9a2d CODEC_ID=10ec0269
[   16.148843] HDMI status: Pin=6 Presence_Detect=0 ELD_Valid=0
[   16.153502] input: HDA Intel PCH HDMI/DP as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[   16.153604] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[   16.153702] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
[   16.335196] cfg80211: Calling CRDA for country: PL
[   16.338109] cfg80211: Regulatory domain changed to country: PL
[   16.338112] cfg80211:     (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[   16.338115] cfg80211:     (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[   16.338118] cfg80211:     (5170000 KHz - 5250000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[   16.338120] cfg80211:     (5250000 KHz - 5330000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[   16.338123] cfg80211:     (5490000 KHz - 5710000 KHz @ 40000 KHz), (N/A, 2700 mBm)
[   16.677762] systemd-fsck[746]: /dev/sda10: recovering journal
[   17.181661] systemd-fsck[746]: /dev/sda10: Clearing orphaned inode 791060 (uid=500, gid=500, mode=0100600, size=1)
[   17.187049] systemd-fsck[746]: /dev/sda10: Clearing orphaned inode 786823 (uid=500, gid=500, mode=0100644, size=2734)
[   17.199533] systemd-fsck[746]: /dev/sda10: clean, 5609/1548288 files, 250116/6190848 blocks
[   17.420124] systemd-fsck[734]: /dev/sda7: recovering journal
[   17.505124] systemd-fsck[734]: /dev/sda7: clean, 43/76912 files, 62562/307200 blocks
[   17.624985] EXT4-fs (sda10): mounted filesystem with ordered data mode. Opts: user_xattr
[   17.624996] SELinux: initialized (dev sda10, type ext4), uses xattr
[   17.749282] EXT4-fs (sda7): mounted filesystem with ordered data mode. Opts: (null)
[   17.756017] SELinux: initialized (dev sda7, type ext4), uses xattr
[   19.698866] ath3k_load_firmware: Can't change to loading configuration err
[   19.698900] ath3k: probe of 1-1.1:1.0 failed with error -110
[   19.698935] usbcore: registered new interface driver ath3k
[   21.790171] ntpd[837]: ntpd [email protected] Fri May  6 16:26:49 UTC 2011 (1)
[   21.791130] ntpd[837]: proto: precision = 0.060 usec
[   21.791193] ntpd[837]: 0.0.0.0 c01d 0d kern kernel time sync enabled
[   21.824336] ntpd[837]: ntp_io: estimated max descriptors: 1024, initial socket boundary: 16
[   21.824350] ntpd[837]: Listen and drop on 0 v4wildcard 0.0.0.0 UDP 123
[   21.838388] ntpd[837]: Listen and drop on 1 v6wildcard :: UDP 123
[   21.838794] ntpd[837]: Listen normally on 2 lo 127.0.0.1 UDP 123
[   21.838856] ntpd[837]: Listen normally on 3 lo ::1 UDP 123
[   21.838899] ntpd[837]: peers refreshed
[   21.839045] ntpd[837]: Listening on routing socket on fd #20 for interface updates
[   22.255238] ntpd[837]: Deferring DNS for 0.fedora.pool.ntp.org 1
[   22.256059] ntpd[837]: Deferring DNS for 1.fedora.pool.ntp.org 1
[   22.256294] ntpd[837]: Deferring DNS for 2.fedora.pool.ntp.org 1
[   22.256540] ntpd[837]: Deferring DNS for 3.fedora.pool.ntp.org 1
[   22.256780] ntpd[837]: 0.0.0.0 c016 06 restart
[   22.256813] ntpd[837]: 0.0.0.0 c012 02 freq_set kernel 20.297 PPM
[   22.257132] ntpd[859]: signal_no_reset: signal 17 had flags 4000000
[   22.279153] avahi-daemon[840]: Found user 'avahi' (UID 70) and group 'avahi' (GID 70).
[   22.279492] avahi-daemon[840]: Successfully dropped root privileges.
[   22.279905] avahi-daemon[840]: avahi-daemon 0.6.30 starting up.
[   22.730467] ip6_tables: (C) 2000-2006 Netfilter Core Team
[   23.261732] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[   24.629933] systemd[1]: akmods.service: control process exited, code=exited status=128
[   24.660749] systemd[1]: Unit akmods.service entered failed state.
[   25.307121] r8169 0000:05:00.0: p5p1: link down
[   25.307129] r8169 0000:05:00.0: p5p1: link down
[   25.308497] ADDRCONF(NETDEV_UP): p5p1: link is not ready
[   25.690695] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   25.690699] Bluetooth: BNEP filters: protocol multicast
[   26.110595] RPC: Registered named UNIX socket transport module.
[   26.110602] RPC: Registered udp transport module.
[   26.110605] RPC: Registered tcp transport module.
[   26.110609] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   26.114980] SELinux: initialized (dev rpc_pipefs, type rpc_pipefs), uses genfs_contexts
[   26.349185] 802.1Q VLAN Support v1.8
[   26.926736] r8169 0000:05:00.0: p5p1: link up
[   26.927682] ADDRCONF(NETDEV_CHANGE): p5p1: link becomes ready
[   27.070353] usb 1-1.1: USB disconnect, device number 3
[   27.325786] usb 1-1.1: new full speed USB device number 5 using ehci_hcd
[   27.411505] usb 1-1.1: New USB device found, idVendor=13d3, idProduct=3304
[   27.411516] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[   27.837989] usb 1-1.1: USB disconnect, device number 5
[   28.270473] usb 1-1.1: new full speed USB device number 6 using ehci_hcd
[   28.356512] usb 1-1.1: New USB device found, idVendor=0cf3, idProduct=3005
[   28.356522] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[   37.470236] p5p1: no IPv6 routers present
