Gcc
PeterJack
Przy instalacji wybralem wszystko wiec nie powinno chyba niszego brakowac?? <_<
z instalacji cdemu
[root@localhost cdemu_0.5.3]# make
cc -O2 -Wall -I/lib/modules/2.6.9-1.667/build/include -D__KERNEL__ -DMODULE -c -o cdemu.o cdemu.c
In file included from /lib/modules/2.6.9-1.667/build/include/asm/processor.h:18,
from /lib/modules/2.6.9-1.667/build/include/asm/thread_info.h:16,
from /lib/modules/2.6.9-1.667/build/include/linux/thread_info.h:21,
from /lib/modules/2.6.9-1.667/build/include/linux/spinlock.h:12,
from /lib/modules/2.6.9-1.667/build/include/linux/capability.h:45,
from /lib/modules/2.6.9-1.667/build/include/linux/sched.h:7,
from /lib/modules/2.6.9-1.667/build/include/linux/module.h:10,
from cdemu.c:66:
/lib/modules/2.6.9-1.667/build/include/asm/system.h: In function `__set_64bit_var':
/lib/modules/2.6.9-1.667/build/include/asm/system.h:193: warning: dereferencing type-punned pointer will break strict-aliasing rules
In file included from cdemu.c:75:
/lib/modules/2.6.9-1.667/build/include/linux/blk.h:1:2: warning: #warning this file is obsolete, please use <linux/blkdev.h> instead
In file included from /lib/modules/2.6.9-1.667/build/include/linux/irq.h:20,
from /lib/modules/2.6.9-1.667/build/include/asm/hardirq.h:6,
from /lib/modules/2.6.9-1.667/build/include/linux/hardirq.h:6,
from /lib/modules/2.6.9-1.667/build/include/linux/interrupt.h:11,
from /lib/modules/2.6.9-1.667/build/include/asm/highmem.h:24,
from /lib/modules/2.6.9-1.667/build/include/linux/highmem.h:14,
from /lib/modules/2.6.9-1.667/build/include/linux/pagemap.h:10,
from /lib/modules/2.6.9-1.667/build/include/linux/blkdev.h:10,
from /lib/modules/2.6.9-1.667/build/include/linux/blk.h:2,
from cdemu.c:75:
/lib/modules/2.6.9-1.667/build/include/asm/irq.h:16:25: irq_vectors.h: Nie ma takiego pliku ani katalogu
In file included from /lib/modules/2.6.9-1.667/build/include/asm/hardirq.h:6,
from cdemu.c:75:
/lib/modules/2.6.9-1.667/build/include/linux/irq.h: At top level:
/lib/modules/2.6.9-1.667/build/include/linux/irq.h:70: error: `NR_IRQS' undeclared here (not in a function)
In file included from /lib/modules/2.6.9-1.667/build/include/linux/irq.h:72,
from cdemu.c:75:
/lib/modules/2.6.9-1.667/build/include/asm/hw_irq.h:28: error: `NR_IRQ_VECTORS' undeclared here (not in a function)
cdemu.c:140: error: syntax error before "kdev_t"
cdemu.c:140: warning: no semicolon at end of struct or union
cdemu.c:150: error: syntax error before '}' token
cdemu.c:171: error: syntax error before "devfs_handle"
cdemu.c:171: warning: type defaults to `int' in declaration of `devfs_handle'
cdemu.c:171: warning: data definition has no type or storage class
cdemu.c: In function `proc_read':
cdemu.c:185: error: invalid use of undefined type `struct cdemu_device'
cdemu.c:185: error: dereferencing pointer to incomplete type
cdemu.c:187: error: invalid use of undefined type `struct cdemu_device'
cdemu.c:187: error: dereferencing pointer to incomplete type
cdemu.c:190: error: invalid use of undefined type `struct cdemu_device'
cdemu.c:190: error: dereferencing pointer to incomplete type
cdemu.c: In function `ce_findtrack':
cdemu.c:240: error: dereferencing pointer to incomplete type
cdemu.c:241: error: dereferencing pointer to incomplete type
cdemu.c: In function `ce_locate_device':
cdemu.c:252: error: structure has no member named `rq_dev'
cdemu.c:259: error: invalid use of undefined type `struct cdemu_device'
cdemu.c:259: error: dereferencing pointer to incomplete type
cdemu.c: In function `ce_read_actor':
cdemu.c:277: error: structure has no member named `buf'
cdemu.c:282: error: structure has no member named `buf'
cdemu.c: In function `ce_transfer':
cdemu.c:304: error: dereferencing pointer to incomplete type
cdemu.c:320: error: dereferencing pointer to incomplete type
cdemu.c:321: error: dereferencing pointer to incomplete type
cdemu.c:322: error: dereferencing pointer to incomplete type
cdemu.c:335: error: structure has no member named `buf'
cdemu.c:337: error: dereferencing pointer to incomplete type
cdemu.c:338: error: too few arguments to function `do_generic_file_read'
cdemu.c: In function `ce_request':
cdemu.c:366: error: `INIT_REQUEST' undeclared (first use in this function)
cdemu.c:366: error: (Each undeclared identifier is reported only once
cdemu.c:366: error: for each function it appears in.)
cdemu.c:376: error: `CURRENT' undeclared (first use in this function)
cdemu.c:388: error: too few arguments to function `end_request'
cdemu.c:392: error: dereferencing pointer to incomplete type
cdemu.c:394: warning: passing arg 1 of `end_request' makes pointer from integer without a cast
cdemu.c:394: error: too few arguments to function `end_request'
cdemu.c:400: warning: passing arg 1 of `end_request' makes pointer from integer without a cast
cdemu.c:400: error: too few arguments to function `end_request'
cdemu.c: In function `read_toc_header':
cdemu.c:415: error: dereferencing pointer to incomplete type
cdemu.c:419: error: dereferencing pointer to incomplete type
cdemu.c: In function `get_toc_entry':
cdemu.c:430: error: dereferencing pointer to incomplete type
cdemu.c:435: error: dereferencing pointer to incomplete type
cdemu.c:436: error: dereferencing pointer to incomplete type
cdemu.c:440: error: dereferencing pointer to incomplete type
cdemu.c: In function `unload_cd':
cdemu.c:457: error: dereferencing pointer to incomplete type
cdemu.c:461: error: dereferencing pointer to incomplete type
cdemu.c:462: error: dereferencing pointer to incomplete type
cdemu.c:464: error: `MOD_DEC_USE_COUNT' undeclared (first use in this function)
cdemu.c: In function `cdemu_audio_ioctl':
cdemu.c:487: error: structure has no member named `dev'
cdemu.c:493: error: invalid use of undefined type `struct cdemu_device'
cdemu.c:493: error: dereferencing pointer to incomplete type
cdemu.c: In function `cdemu_ioctl':
cdemu.c:534: error: structure has no member named `dev'
cdemu.c:547: error: invalid use of undefined type `struct cdemu_device'
cdemu.c:547: error: dereferencing pointer to incomplete type
cdemu.c:550: error: dereferencing pointer to incomplete type
cdemu.c:571: error: dereferencing pointer to incomplete type
cdemu.c:572: error: dereferencing pointer to incomplete type
cdemu.c:573: error: dereferencing pointer to incomplete type
cdemu.c:581: error: dereferencing pointer to incomplete type
cdemu.c:589: error: dereferencing pointer to incomplete type
cdemu.c:596: error: dereferencing pointer to incomplete type
cdemu.c:616: error: dereferencing pointer to incomplete type
cdemu.c:628: error: dereferencing pointer to incomplete type
cdemu.c:629: error: dereferencing pointer to incomplete type
cdemu.c:632: error: dereferencing pointer to incomplete type
cdemu.c:633: error: dereferencing pointer to incomplete type
cdemu.c:634: error: dereferencing pointer to incomplete type
cdemu.c:637: error: dereferencing pointer to incomplete type
cdemu.c:640: error: dereferencing pointer to incomplete type
cdemu.c:643: error: dereferencing pointer to incomplete type
cdemu.c:644: error: `MOD_INC_USE_COUNT' undeclared (first use in this function)
cdemu.c:646: error: dereferencing pointer to incomplete type
cdemu.c: In function `cdemu_media_changed':
cdemu.c:670: error: structure has no member named `dev'
cdemu.c:672: error: invalid use of undefined type `struct cdemu_device'
cdemu.c:672: error: dereferencing pointer to incomplete type
cdemu.c:674: error: dereferencing pointer to incomplete type
cdemu.c:675: error: dereferencing pointer to incomplete type
cdemu.c: In function `cdemu_tray_move':
cdemu.c:688: error: structure has no member named `dev'
cdemu.c:689: error: invalid use of undefined type `struct cdemu_device'
cdemu.c:689: error: dereferencing pointer to incomplete type
cdemu.c:692: error: dereferencing pointer to incomplete type
cdemu.c: In function `cdemu_drive_status':
cdemu.c:704: error: structure has no member named `dev'
cdemu.c:705: error: invalid use of undefined type `struct cdemu_device'
cdemu.c:705: error: dereferencing pointer to incomplete type
cdemu.c:707: error: dereferencing pointer to incomplete type
cdemu.c: In function `cdemu_lock_door':
cdemu.c:718: error: structure has no member named `dev'
cdemu.c:719: error: invalid use of undefined type `struct cdemu_device'
cdemu.c:719: error: dereferencing pointer to incomplete type
cdemu.c:721: error: dereferencing pointer to incomplete type
cdemu.c: In function `cdemu_reset':
cdemu.c:738: error: invalid use of undefined type `struct cdemu_device'
cdemu.c:738: error: dereferencing pointer to incomplete type
cdemu.c: In function `cdemu_open':
cdemu.c:758: error: structure has no member named `dev'
cdemu.c:768: error: invalid use of undefined type `struct cdemu_device'
cdemu.c:768: error: dereferencing pointer to incomplete type
cdemu.c:771: error: dereferencing pointer to incomplete type
cdemu.c:778: error: `MOD_INC_USE_COUNT' undeclared (first use in this function)
cdemu.c: In function `cdemu_release':
cdemu.c:793: error: structure has no member named `dev'
cdemu.c:799: error: invalid use of undefined type `struct cdemu_device'
cdemu.c:799: error: dereferencing pointer to incomplete type
cdemu.c:802: error: dereferencing pointer to incomplete type
cdemu.c:804: error: `MOD_DEC_USE_COUNT' undeclared (first use in this function)
cdemu.c: At top level:
cdemu.c:836: warning: initialization from incompatible pointer type
cdemu.c:837: warning: initialization from incompatible pointer type
cdemu.c:838: warning: initialization from incompatible pointer type
cdemu.c:839: error: unknown field `check_media_change' specified in initializer
cdemu.c:839: warning: initialization from incompatible pointer type
cdemu.c: In function `cdemu_init':
cdemu.c:868: warning: implicit declaration of function `devfs_register_blkdev'
cdemu.c:874: error: invalid application of `sizeof' to incomplete type `cdemu_device'
cdemu.c:890: error: invalid use of undefined type `struct cdemu_device'
cdemu.c:890: error: dereferencing pointer to incomplete type
cdemu.c:891: error: invalid application of `sizeof' to incomplete type `cdemu_device'
cdemu.c:892: error: dereferencing pointer to incomplete type
cdemu.c:893: error: dereferencing pointer to incomplete type
cdemu.c:894: error: dereferencing pointer to incomplete type
cdemu.c:895: error: dereferencing pointer to incomplete type
cdemu.c:896: error: dereferencing pointer to incomplete type
cdemu.c:897: error: dereferencing pointer to incomplete type
cdemu.c:898: error: dereferencing pointer to incomplete type
cdemu.c:899: error: dereferencing pointer to incomplete type
cdemu.c:902: error: dereferencing pointer to incomplete type
cdemu.c:903: error: dereferencing pointer to incomplete type
cdemu.c:904: warning: implicit declaration of function `devfs_plain_cdrom'
cdemu.c:904: error: dereferencing pointer to incomplete type
cdemu.c:910: warning: implicit declaration of function `devfs_register_series'
cdemu.c:910: error: `DEVFS_FL_DEFAULT' undeclared (first use in this function)
cdemu.c:916: warning: implicit declaration of function `BLK_DEFAULT_QUEUE'
cdemu.c:916: warning: passing arg 1 of `blk_init_queue' makes pointer from integer without a cast
cdemu.c:916: warning: passing arg 2 of `blk_init_queue' from incompatible pointer type
cdemu.c:919: error: `blk_size' undeclared (first use in this function)
cdemu.c:920: error: `blksize_size' undeclared (first use in this function)
cdemu.c: In function `cdemu_exit':
cdemu.c:962: warning: implicit declaration of function `fsync_dev'
cdemu.c:965: warning: passing arg 1 of `blk_cleanup_queue' makes pointer from integer without a cast
cdemu.c:968: error: invalid use of undefined type `struct cdemu_device'
cdemu.c:968: error: dereferencing pointer to incomplete type
cdemu.c:969: error: dereferencing pointer to incomplete type
cdemu.c:974: warning: implicit declaration of function `devfs_unregister_blkdev'
cdemu.c:978: warning: implicit declaration of function `devfs_unregister'
make: *** [cdemu.o] Błąd 1
koncuwka z instalacji nowej wersji gcc
make[4]: Leaving directory `/mnt/win_c/fedora/gcc-3.4.2/i686-pc-linux-gnu/libstdc++-v3'
make[3]: Nie nic do roboty w `install-data-am'.
make[3]: Leaving directory `/mnt/win_c/fedora/gcc-3.4.2/i686-pc-linux-gnu/libstdc++-v3'
make[2]: Leaving directory `/mnt/win_c/fedora/gcc-3.4.2/i686-pc-linux-gnu/libstdc++-v3'
make[1]: Leaving directory `/mnt/win_c/fedora/gcc-3.4.2/i686-pc-linux-gnu/libstdc++-v3'
/bin/sh: line 0: cd: i686-pc-linux-gnu/libf2c: Nie ma takiego pliku ani katalogu
make: *** [install-target-libf2c] Błąd 1
Sprawdz, czy masz gdzieś w folderze /mnt/win_c/fedora/gcc-3.4.2 ten plik libf2c, a jeżeli tak, to skopiuj go do tego katalogu co wyżej i wtedy sprawdz.
..ja tez mam problem z gcc... tzn. jakos mi sie udalo nie zainstalowac przy instalacji fc3 ;-)
doinstlowalem rpm z plyty ...ale teraz tak.. po pierwsze:
przy uruchomieniu ./configure pojawialo mi sie:
¨checking for gcc... gcc
checking for C compiler default output... configure: error: C compiler cannot create executables ¨
po drugie... przy kompilacji przykladowego programu
typu printf(¨\n hello world \n¨); wywala mi bledy...
dokladnie..cos takiego
$ gcc test.c -otest
/usr/bin/ld: crt1.o: No such file: No such file or directory
collect2: ld returned 1 exit status
co to moze znaczyc?
Matko... Po kiego grzyba instalujesz jakieś antyki? Ta wersja działa tylko z jądrem 2.4 - jest to wyrażnie napisane na stronie projektu. cdemu-0.7 powinno rozwiązać Twój problem.
Aha, nie ma potrzeby kompilować program z konta roota.
Jeszcze powiedz, że /mnt/win_c to partycja FAT32 <_< To se ne da. Nie prościej zainstalować odpowiednie paczki yumem?
