Klaster I Fencing
Sofcik
Cześć
Siedze właśnie nad tematem fencingu dla maszyn wirtualnych.
Na hoście (Centos 6.5 + update) mam zainstalowane 3 maszyny wirtualne pracujące w klastrze (także Centos 6.5+update).
Wg materiałów RH dodałem fencing z wykorzystaniem fence_xvm (w trybie Multicast) i niestety fencing nie działa.
Puszczony jest ruch igmp na wszystkich maszynach (łącznie z hypervisorem).
Poniżej configi z hosta i config klastra:
fence_virtd.conf:
cluster.conf:
<?xml version="1.0"?><cluster config_version="75" name="cluster-1">	<clusternodes>		<clusternode name="c6-node01" nodeid="1">			<fence>				<method name="kvmfence_node01">					<device domain="c6-node01" name="kvmfence"/>				</method>			</fence>		</clusternode>		<clusternode name="c6-node02" nodeid="2">			<fence>				<method name="kvmfence_node02">					<device domain="c6-node02" name="kvmfence"/>				</method>			</fence>		</clusternode>		<clusternode name="c6-node03" nodeid="3">			<fence>				<method name="kvmfence_node03">					<device domain="c6-node03" name="kvmfence"/>				</method>			</fence>		</clusternode>	</clusternodes>	<rm>		<failoverdomains>			<failoverdomain name="domain_1" ordered="1" restricted="1">				<failoverdomainnode name="c6-node01" priority="1"/>				<failoverdomainnode name="c6-node02" priority="1"/>				<failoverdomainnode name="c6-node03" priority="1"/>			</failoverdomain>		</failoverdomains>		<resources>			<ip address="192.168.0.103/24" disable_rdisc="1" sleeptime="10"/>			<lvm name="HA-LVM" self_fence="1" vg_name="havg"/>			<apache config_file="conf/httpd.conf" name="httpd" server_root="/etc/httpd" shutdown_wait="3"/>			<fs device="/dev/havg/halv" fsid="49557" fstype="ext4" mountpoint="/var/www/html" name="wwwfs" quick_status="1" self_fence="1"/>		</resources>		<service domain="domain_1" name="www_test" recovery="relocate">			<ip ref="192.168.0.103/24"/>			<lvm ref="HA-LVM"/>			<apache ref="httpd"/>			<fs ref="wwwfs"/>		</service>	</rm>	<fencedevices>		<fencedevice agent="fence_xvm" key_file="/etc/cluster/fence_xvm.key" name="kvmfence"/>	</fencedevices>	<cman>		<multicast addr="224.0.0.0"/>	</cman></cluster>
Żeby było ciekawiej to fence_xvm z poziomu hosta hypervisora działa poprawnie. Maszyny ładnie "dostają w głowę" i się składają.
Ale nie mogę wykonać "fence_node c6-node02" z poziomu innej maszyny wirtualnej.
Czy ktoś ma jakieś pomysły co robię źle i dlaczego działa to z hypervisora a nie działa z wnętrza wirtualek? A może na CentOSie jest coś nie do końca tak samo zrobione jak na RHEL?
Piotrek
Niestety fence_virt.conf się nie załączył jako kod:
backends {
        libvirt {
listeners {
        multicast {
                interface="br0";
                port = "1229";
                family = "ipv4";
                address = "225.0.0.12";
                key_file = "/etc/cluster/fence_xvm.key";
fence_virtd {
        module_path = "/usr/lib64/fence-virt";
        backend = "libvirt";
        listener = "multicast";
