KhazAkar Napisano Czerwiec 1, 2015 Zgłoszenie Share Napisano Czerwiec 1, 2015 Witam!Jest problem z kompilowaniem pluginów do programu PCB ( z pakietu gEDA)System to Fedora 21 FEL po aktualizacji za pomocą FedUp do wersji 22. gEDa oraz PCB kompilowane i instalowane ręcznie(bez paczkowania) ze względu na problemy "paczkera". [khazakar@dhcppc0 pcb-plugins]$ ./configure --enable-plugins --enable-m4lib-png --enable-dbus --enable-gl --with-gui=gtk --prefix=/home/khazakar/pcb-plugins configure: WARNING: unrecognized options: --enable-plugins checking for a BSD-compatible install... /usr/bin/install -c checking whether build environment is sane... yes /home/khazakar/Pobrane/pcb-plugins/missing: Unknown `--is-lightweight' option Try `/home/khazakar/Pobrane/pcb-plugins/missing --help' for more information configure: WARNING: 'missing' script is too old or missing checking for a thread-safe mkdir -p... /usr/bin/mkdir -p checking for gawk... gawk checking whether make sets $(MAKE)... yes checking whether make supports nested variables... yes checking for style of include used by make... GNU checking for gcc... gcc checking whether the C compiler works... yes checking for C compiler default output file name... a.out checking for suffix of executables... checking whether we are cross compiling... no checking for suffix of object files... o checking whether we are using the GNU C compiler... yes checking whether gcc accepts -g... yes checking for gcc option to accept ISO C89... none needed checking whether gcc understands -c and -o together... yes checking dependency style of gcc... gcc3 checking how to run the C preprocessor... gcc -E checking for grep that handles long lines and -e... /usr/bin/grep checking for egrep... /usr/bin/grep -E checking for ANSI C header files... yes checking for sys/types.h... yes checking for sys/stat.h... yes checking for stdlib.h... yes checking for string.h... yes checking for memory.h... yes checking for strings.h... yes checking for inttypes.h... yes checking for stdint.h... yes checking for unistd.h... yes checking minix/config.h usability... no checking minix/config.h presence... no checking for minix/config.h... no checking whether it is safe to define __EXTENSIONS__... yes checking if you are building from a git checkout... yes checking if you are building from a anoncvs checkout... no checking if the documentation should be built... yes checking if maintainer mode is required... yes -- the documentation build is enabled and your sources are from git checking whether to enable maintainer-specific portions of Makefiles... yes checking build system type... x86_64-unknown-linux-gnu checking host system type... x86_64-unknown-linux-gnu checking for windows... no checking for gcc... (cached) gcc checking whether we are using the GNU C compiler... (cached) yes checking whether gcc accepts -g... (cached) yes checking for gcc option to accept ISO C89... (cached) none needed checking whether gcc understands -c and -o together... (cached) yes checking dependency style of gcc... (cached) gcc3 checking for g++... g++ checking whether we are using the GNU C++ compiler... yes checking whether g++ accepts -g... yes checking dependency style of g++... gcc3 checking whether NLS is requested... yes checking for msgfmt... /usr/bin/msgfmt checking for gmsgfmt... /usr/bin/msgfmt checking for xgettext... /usr/bin/xgettext checking for msgmerge... /usr/bin/msgmerge checking for ranlib... ranlib checking for strerror in -lcposix... no checking for an ANSI C-conforming const... yes checking for signed... yes checking for inline... inline checking for off_t... yes checking for size_t... yes checking for long long... yes checking for long double... yes checking for wchar_t... yes checking for wint_t... yes checking for inttypes.h... yes checking for stdint.h... yes checking for intmax_t... yes checking whether printf() supports POSIX/XSI format strings... yes checking for working alloca.h... yes checking for alloca... yes checking for stdlib.h... (cached) yes checking for unistd.h... (cached) yes checking for sys/param.h... yes checking for getpagesize... yes checking for working mmap... yes checking whether we are using the GNU C Library 2.1 or newer... yes checking whether integer division by zero raises SIGFPE... yes checking for unsigned long long... yes checking for inttypes.h... yes checking whether the inttypes.h PRIxNN macros are broken... no checking for stdint.h... (cached) yes checking for SIZE_MAX... yes checking for stdint.h... (cached) yes checking for ld used by GCC... /usr/bin/ld checking if the linker (/usr/bin/ld) is GNU ld... yes checking for shared library run path origin... done checking for ptrdiff_t... yes checking argz.h usability... yes checking argz.h presence... yes checking for argz.h... yes checking limits.h usability... yes checking limits.h presence... yes checking for limits.h... yes checking locale.h usability... yes checking locale.h presence... yes checking for locale.h... yes checking nl_types.h usability... yes checking nl_types.h presence... yes checking for nl_types.h... yes checking malloc.h usability... yes checking malloc.h presence... yes checking for malloc.h... yes checking stddef.h usability... yes checking stddef.h presence... yes checking for stddef.h... yes checking for stdlib.h... (cached) yes checking for string.h... (cached) yes checking for unistd.h... (cached) yes checking for sys/param.h... (cached) yes checking for asprintf... yes checking for fwprintf... yes checking for getcwd... yes checking for getegid... yes checking for geteuid... yes checking for getgid... yes checking for getuid... yes checking for mempcpy... yes checking for munmap... yes checking for putenv... yes checking for setenv... yes checking for setlocale... yes checking for snprintf... yes checking for stpcpy... yes checking for strcasecmp... yes checking for strdup... yes checking for strtoul... yes checking for tsearch... yes checking for wcslen... yes checking for __argz_count... yes checking for __argz_stringify... yes checking for __argz_next... yes checking for __fsetlocking... yes checking whether _snprintf is declared... no checking whether _snwprintf is declared... no checking whether feof_unlocked is declared... yes checking whether fgets_unlocked is declared... yes checking whether getc_unlocked is declared... yes checking for iconv... yes checking for iconv declaration... extern size_t iconv (iconv_t cd, char * *inbuf, size_t *inbytesleft, char * *outbuf, size_t *outbytesleft); checking for nl_langinfo and CODESET... yes checking for LC_MESSAGES... yes checking for bison... bison checking version of bison... 3.0.2, ok checking whether NLS is requested... yes checking whether included gettext is requested... no checking for GNU gettext in libc... yes checking whether to use NLS... yes checking where the gettext function comes from... libc checking for intltool >= 0.35.0... 0.51.0 found checking for intltool-update... /usr/bin/intltool-update checking for intltool-merge... /usr/bin/intltool-merge checking for intltool-extract... /usr/bin/intltool-extract checking for xgettext... (cached) /usr/bin/xgettext checking for msgmerge... (cached) /usr/bin/msgmerge checking for msgfmt... (cached) /usr/bin/msgfmt checking for gmsgfmt... (cached) /usr/bin/msgfmt checking for perl... /usr/bin/perl checking for perl >= 5.8.1... 5.20.2 checking for XML::Parser... ok checking for inline... (cached) inline checking for gcc option to accept ISO C99... none needed checking for gcc option to accept ISO Standard C... (cached) none needed checking how to run the C preprocessor... gcc -E checking for gawk... (cached) gawk checking for flex... flex checking lex output file root... lex.yy checking lex library... none needed checking whether yytext is a pointer... no checking for flex... /usr/bin/flex checking for bison... bison -y checking for bison... /usr/bin/bison checking for ranlib... (cached) ranlib checking for xpmtoppm... notfound checking for ppmtowinicon... notfound checking for convert... /usr/bin/convert checking for makeinfo... /usr/bin/makeinfo checking for GNU makeinfo version >= 4.6... 5.2 checking for texi2dvi... /usr/bin/texi2dvi checking for perl... /usr/bin/perl checking for kpsewhich... /usr/bin/kpsewhich checking If your TeX installation contains epsf.tex... yes (/usr/share/texlive/texmf-dist/tex/generic/epsf/epsf.tex) checking If the compiler accepts -rdynamic... yes checking ./src/hid/batch/hid.conf checking ./src/hid/bom/hid.conf checking ./src/hid/gcode/hid.conf checking ./src/hid/gerber/hid.conf checking ./src/hid/gtk/hid.conf checking ./src/hid/lesstif/hid.conf checking ./src/hid/lpr/hid.conf checking ./src/hid/nelma/hid.conf checking ./src/hid/png/hid.conf checking ./src/hid/ps/hid.conf checking for which gui to use... gtk checking whether to enable toporouter... yes checking whether to enable toporouter output... no checking for pkg-config... /usr/bin/pkg-config checking pkg-config is at least version 0.9.0... yes checking for whether to use DBUS... yes checking for DBUS... yes checking for dbus_watch_get_unix_fd... yes checking for whether to use GL drawing... yes checking for X... libraries , headers checking for a sed that does not truncate output... /usr/bin/sed checking for the pthreads library -lpthreads... no checking whether pthreads work without any flags... no checking whether pthreads work with -Kthread... no checking whether pthreads work with -kthread... no checking for the pthreads library -llthread... no checking whether pthreads work with -pthread... yes checking for joinable pthread attribute... PTHREAD_CREATE_JOINABLE checking if more special flags are required for pthreads... no checking whether we are using the Microsoft C compiler... no checking windows.h usability... no checking windows.h presence... no checking for windows.h... no checking for GL/gl.h... yes checking for OpenGL/gl.h... no checking for OpenGL library... -lGL checking for GL/glu.h... yes checking for OpenGL/glu.h... no checking for OpenGL Utility library... -lGLU checking for varargs GLU tesselator callback function type... no checking for which printer to use... lpr checking for which exporters to use... bom gcode gerber nelma png ps checking gtk dependencies checking lpr dependencies checking bom dependencies checking gcode dependencies checking gerber dependencies checking nelma dependencies checking png dependencies checking ps dependencies checking for env... /usr/bin/env checking for gtk-update-icon-path... true checking for update-desktop-database... /usr/bin/update-desktop-database checking for update-mime-database... /usr/bin/update-mime-database checking for gm4... no checking for m4... /usr/bin/m4 checking if /usr/bin/m4 has the division involving negative numbers bug... no checking for wish... /usr/bin/wish checking for pdflatex... /usr/bin/pdflatex checking for texi2dvi... (cached) /usr/bin/texi2dvi checking for ps2pdf... /usr/bin/ps2pdf checking for gschem... /usr/local/bin/gschem checking for animate... /usr/bin/animate checking for compare... /usr/bin/compare checking for composite... /usr/bin/composite checking for convert... /usr/bin/convert checking for display... /usr/bin/display checking for montage... /usr/bin/montage checking if all ImageMagick tools needed for the testsuite were found... yes checking for gerbv... /usr/bin/gerbv checking if all the requried testsuite tools were found... yes checking for sqrt in -lm... yes checking for dlopen in -ldl... yes checking for gethostbyname in -lxnet... no checking for yywrap in -lfl... no checking for strerror... yes checking for regcomp... yes checking for re_comp... yes checking for logf... yes checking for expf... yes checking for rint... yes checking for vsnprintf... yes checking for getpwuid... yes checking for getcwd... (cached) yes checking for rand... yes checking for random... yes checking for stat... yes checking for mkdtemp... yes checking for popen... yes checking for realpath... yes checking for canonicalize_file_name... yes checking whether canonicalize_file_name must be declared... no checking for _spawnvp... no checking for ANSI C header files... (cached) yes checking for limits.h... (cached) yes checking for locale.h... (cached) yes checking for string.h... (cached) yes checking for sys/types.h... (cached) yes checking regex.h usability... yes checking regex.h presence... yes checking for regex.h... yes checking pwd.h usability... yes checking pwd.h presence... yes checking for pwd.h... yes checking sys/socket.h usability... yes checking sys/socket.h presence... yes checking for sys/socket.h... yes checking netinet/in.h usability... yes checking netinet/in.h presence... yes checking for netinet/in.h... yes checking netdb.h usability... yes checking netdb.h presence... yes checking for netdb.h... yes checking for sys/param.h... (cached) yes checking sys/times.h usability... yes checking sys/times.h presence... yes checking for sys/times.h... yes checking sys/wait.h usability... yes checking sys/wait.h presence... yes checking for sys/wait.h... yes checking dlfcn.h usability... yes checking dlfcn.h presence... yes checking for dlfcn.h... yes checking for GLIB... yes checking for pkg-config... /usr/bin/pkg-config checking for GTK... yes checking for GTKGLEXT... yes checking if GIF output from the png HID is desired... yes checking if JPEG output from the png HID is desired... yes checking if PNG output from the png HID is desired... yes checking for gdlib-config... /usr/bin/gdlib-config checking for libgd cflags... -I/usr/include checking for libgd libs... -lgd -ljpeg -lz -lm -lpng16 -lfreetype -lfontconfig -lfreetype -lfontconfig -lXpm -lX11 -L/usr/lib -lvpx -L/usr/lib -ltiff -lgd checking gd.h usability... yes checking gd.h presence... yes checking for gd.h... yes checking for gdImageGif... yes checking for gdImageJpeg... yes checking for gdImagePng... yes checking if the m4lib to newlib export should create png previews... yes checking If pcblib-newlib needs to be rebuilt... yes checking for XRenderQueryExtension in -lXrender... yes checking for XineramaQueryExtension in -lXinerama... yes checking if dmalloc debugging should be enabled... no checking if ElectricFence debugging should be enabled... no checking for whether to enable debugging code... no checking for mkdir... yes checking for _mkdir... no checking whether mkdir takes one argument... no checking for stdint.h... (cached) yes no:no:yes checking if the compiler accepts -Wall... yes checking if the compiler accepts -Wdeclaration-after-statement... yes checking for the bindir to pcblibdir relative path... ../share/pcb checking for the bindir to pcbtreedir relative path... ../share/pcb/newlib checking for the bindir to exec_prefix relative path... .. checking that generated files are newer than configure... done configure: creating ./config.status config.status: creating Makefile config.status: creating data/Makefile config.status: creating intl/Makefile config.status: WARNING: 'intl/Makefile.in' seems to ignore the --datarootdir setting config.status: creating po/Makefile.in config.status: creating README_FILES/Makefile config.status: creating doc/Makefile config.status: creating doc/gs/Makefile config.status: creating doc/gs/gafrc config.status: creating doc/gs/gschemrc config.status: creating example/Makefile config.status: creating example/libraries/Makefile config.status: creating lib/CreateLibraryContents.sh config.status: creating lib/CreateLibrary.sh config.status: creating lib/ListLibraryContents.sh config.status: creating lib/Makefile config.status: creating lib/QueryLibrary.sh config.status: creating lib/qfp-ui config.status: creating newlib/2_pin_thru-hole_packages/Makefile config.status: creating newlib/Makefile config.status: creating newlib/connectors/Makefile config.status: creating newlib/crystal/Makefile config.status: creating newlib/electro-optics/Makefile config.status: creating newlib/headers/Makefile config.status: creating newlib/keystone/Makefile config.status: creating newlib/msp430/Makefile config.status: creating newlib/not_vetted_ingo/Makefile config.status: creating newlib/sockets/Makefile config.status: creating newlib/tests/Makefile config.status: creating src/Makefile config.status: creating src/icons/Makefile config.status: creating tools/Makefile config.status: creating tutorial/Makefile config.status: creating tests/inputs/Makefile config.status: creating tests/golden/Makefile config.status: creating tests/golden/hid_bom1/Makefile config.status: creating tests/golden/hid_bom2/Makefile config.status: creating tests/golden/hid_bom3/Makefile config.status: creating tests/golden/hid_bom4/Makefile config.status: creating tests/golden/hid_gcode1/Makefile config.status: creating tests/golden/hid_gcode2/Makefile config.status: creating tests/golden/hid_gcode3/Makefile config.status: creating tests/golden/hid_gcode4/Makefile config.status: creating tests/golden/hid_gcode5/Makefile config.status: creating tests/golden/hid_gcode6/Makefile config.status: creating tests/golden/hid_gcode7/Makefile config.status: creating tests/golden/hid_gcode8/Makefile config.status: creating tests/golden/hid_gcode9/Makefile config.status: creating tests/golden/hid_gcode10/Makefile config.status: creating tests/golden/hid_gcode11/Makefile config.status: creating tests/golden/hid_gerber1/Makefile config.status: creating tests/golden/hid_gerber2/Makefile config.status: creating tests/golden/hid_gerber3/Makefile config.status: creating tests/golden/hid_png1/Makefile config.status: creating tests/golden/hid_png2/Makefile config.status: creating tests/golden/hid_png3/Makefile config.status: creating tests/Makefile config.status: creating gts/Makefile config.status: creating w32/Makefile config.status: creating config.h config.status: executing depfiles commands config.status: executing default-1 commands config.status: creating po/POTFILES config.status: creating po/Makefile config.status: executing po/stamp-it commands configure: WARNING: unrecognized options: --enable-plugins ** Configuration summary for pcb 1.99z: GUI: gtk Printer: lpr Exporters: bom gcode gerber nelma png ps Coordinate type: long Source tree distribution: GIT Build documentation: yes Build toporouter: yes Enable toporouter output: no xdg data directory: ${datarootdir} KDE data directory: ${datarootdir} dmalloc debugging: no ElectricFence debugging: no Cross Compiling: no CC: gcc CXX: g++ CPPFLAGS: -I/usr/include -I/usr/include/dbus-1.0 -I/usr/lib64/dbus-1.0/include -I/usr/include/glib-2.0 -I/usr/lib64/glib-2.0/include -pthread -I/usr/include/gtk-2.0 -I/usr/lib64/gtk-2.0/include -I/usr/include/pango-1.0 -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/pixman-1 -I/usr/include/libdrm -I/usr/include/gdk-pixbuf-2.0 -I/usr/include/libpng16 -I/usr/include/pango-1.0 -I/usr/include/harfbuzz -I/usr/include/pango-1.0 -I/usr/include/glib-2.0 -I/usr/lib64/glib-2.0/include -I/usr/include/freetype2 -I/usr/include/libpng16 -I/usr/include/freetype2 -I/usr/include/libpng16 -I/usr/include -pthread -I/usr/include/gtkglext-1.0 -I/usr/lib64/gtkglext-1.0/include -I/usr/include/gtk-2.0 -I/usr/lib64/gtk-2.0/include -I/usr/include/pango-1.0 -I/usr/include/gtk-2.0 -I/usr/lib64/gtk-2.0/include -I/usr/include/pango-1.0 -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/pixman-1 -I/usr/include/libdrm -I/usr/include/gdk-pixbuf-2.0 -I/usr/include/libpng16 -I/usr/include/pango-1.0 -I/usr/include/harfbuzz -I/usr/include/pango-1.0 -I/usr/include/glib-2.0 -I/usr/lib64/glib-2.0/include -I/usr/include/freetype2 -I/usr/include/libpng16 -I/usr/include/freetype2 -I/usr/include/libpng16 -pthread -pthread -DPREFIXDIR=\"${prefix}\" -DBINDIR=\"${bindir}\" -DHOST=\"${host}\" -DPCBLIBDIR=\"${datarootdir}/pcb\" -DPCBTREEDIR=\"${datarootdir}/pcb/newlib\" -DPCBTREEPATH=\"${datarootdir}/pcb/newlib:${datarootdir}/pcb/pcblib-newlib\" CFLAGS: -g -O2 -Wall -Wdeclaration-after-statement CXXFLAGS: -g -O2 -Wall LIBS: -ldl -lm -ldbus-1 -lXinerama -lXrender -lglib-2.0 -lgtk-x11-2.0 -lgdk-x11-2.0 -lpangocairo-1.0 -latk-1.0 -lcairo -lgdk_pixbuf-2.0 -lgio-2.0 -lpangoft2-1.0 -lpango-1.0 -lgobject-2.0 -lglib-2.0 -lfontconfig -lfreetype -lgd -ljpeg -lz -lm -lpng16 -lfreetype -lfontconfig -lfreetype -lfontconfig -lXpm -lX11 -L/usr/lib -lvpx -L/usr/lib -ltiff -lgd -lgtkglext-x11-1.0 -lgdkglext-x11-1.0 -lGLU -lGL -lXmu -lXt -lSM -lICE -lgdk-x11-2.0 -lpangox-1.0 -lX11 -Wl,--export-dynamic -lgmodule-2.0 -pthread -lgtk-x11-2.0 -lgdk-x11-2.0 -lpangocairo-1.0 -latk-1.0 -lcairo -lgdk_pixbuf-2.0 -lgio-2.0 -lpangoft2-1.0 -lpango-1.0 -lgobject-2.0 -lglib-2.0 -lfontconfig -lfreetype -lGLU -lGL PCB: ${top_builddir}/src/pcb [khazakar@dhcppc0 pcb-plugins]$ make make all-recursive make[1]: Wejście do katalogu '/home/khazakar/Pobrane/pcb-plugins' Making all in w32 make[2]: Wejście do katalogu '/home/khazakar/Pobrane/pcb-plugins/w32' make[2]: Nie ma nic do zrobienia w 'all'. make[2]: Opuszczenie katalogu '/home/khazakar/Pobrane/pcb-plugins/w32' Making all in intl make[2]: Wejście do katalogu '/home/khazakar/Pobrane/pcb-plugins/intl' make[2]: Nie ma nic do zrobienia w 'all'. make[2]: Opuszczenie katalogu '/home/khazakar/Pobrane/pcb-plugins/intl' Making all in gts make[2]: Wejście do katalogu '/home/khazakar/Pobrane/pcb-plugins/gts' gcc -DHAVE_CONFIG_H -I. -I.. -I. -DG_LOG_DOMAIN=\"Gts\" -I/usr/include -I/usr/include/dbus-1.0 -I/usr/lib64/dbus-1.0/include -I/usr/include/glib-2.0 -I/usr/lib64/glib-2.0/include -pthread -I/usr/include/gtk-2.0 -I/usr/lib64/gtk-2.0/include -I/usr/include/pango-1.0 -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/pixman-1 -I/usr/include/libdrm -I/usr/include/gdk-pixbuf-2.0 -I/usr/include/libpng16 -I/usr/include/pango-1.0 -I/usr/include/harfbuzz -I/usr/include/pango-1.0 -I/usr/include/glib-2.0 -I/usr/lib64/glib-2.0/include -I/usr/include/freetype2 -I/usr/include/libpng16 -I/usr/include/freetype2 -I/usr/include/libpng16 -I/usr/include -pthread -I/usr/include/gtkglext-1.0 -I/usr/lib64/gtkglext-1.0/include -I/usr/include/gtk-2.0 -I/usr/lib64/gtk-2.0/include -I/usr/include/pango-1.0 -I/usr/include/gtk-2.0 -I/usr/lib64/gtk-2.0/include -I/usr/include/pango-1.0 -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/pixman-1 -I/usr/include/libdrm -I/usr/include/gdk-pixbuf-2.0 -I/usr/include/libpng16 -I/usr/include/pango-1.0 -I/usr/include/harfbuzz -I/usr/include/pango-1.0 -I/usr/include/glib-2.0 -I/usr/lib64/glib-2.0/include -I/usr/include/freetype2 -I/usr/include/libpng16 -I/usr/include/freetype2 -I/usr/include/libpng16 -pthread -pthread -DPREFIXDIR=\"/home/khazakar/pcb-plugins\" -DBINDIR=\"/home/khazakar/pcb-plugins/bin\" -DHOST=\"x86_64-unknown-linux-gnu\" -DPCBLIBDIR=\"/home/khazakar/pcb-plugins/share/pcb\" -DPCBTREEDIR=\"/home/khazakar/pcb-plugins/share/pcb/newlib\" -DPCBTREEPATH=\"/home/khazakar/pcb-plugins/share/pcb/newlib:/home/khazakar/pcb-plugins/share/pcb/pcblib-newlib\" -g -O2 -Wall -Wdeclaration-after-statement -MT misc.o -MD -MP -MF .deps/misc.Tpo -c -o misc.o misc.c mv -f .deps/misc.Tpo .deps/misc.Po gcc -DHAVE_CONFIG_H -I. -I.. -I. -DG_LOG_DOMAIN=\"Gts\" -I/usr/include -I/usr/include/dbus-1.0 -I/usr/lib64/dbus-1.0/include -I/usr/include/glib-2.0 -I/usr/lib64/glib-2.0/include -pthread -I/usr/include/gtk-2.0 -I/usr/lib64/gtk-2.0/include -I/usr/include/pango-1.0 -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/pixman-1 -I/usr/include/libdrm -I/usr/include/gdk-pixbuf-2.0 -I/usr/include/libpng16 -I/usr/include/pango-1.0 -I/usr/include/harfbuzz -I/usr/include/pango-1.0 -I/usr/include/glib-2.0 -I/usr/lib64/glib-2.0/include -I/usr/include/freetype2 -I/usr/include/libpng16 -I/usr/include/freetype2 -I/usr/include/libpng16 -I/usr/include -pthread -I/usr/include/gtkglext-1.0 -I/usr/lib64/gtkglext-1.0/include -I/usr/include/gtk-2.0 -I/usr/lib64/gtk-2.0/include -I/usr/include/pango-1.0 -I/usr/include/gtk-2.0 -I/usr/lib64/gtk-2.0/include -I/usr/include/pango-1.0 -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/pixman-1 -I/usr/include/libdrm -I/usr/include/gdk-pixbuf-2.0 -I/usr/include/libpng16 -I/usr/include/pango-1.0 -I/usr/include/harfbuzz -I/usr/include/pango-1.0 -I/usr/include/glib-2.0 -I/usr/lib64/glib-2.0/include -I/usr/include/freetype2 -I/usr/include/libpng16 -I/usr/include/freetype2 -I/usr/include/libpng16 -pthread -pthread -DPREFIXDIR=\"/home/khazakar/pcb-plugins\" -DBINDIR=\"/home/khazakar/pcb-plugins/bin\" -DHOST=\"x86_64-unknown-linux-gnu\" -DPCBLIBDIR=\"/home/khazakar/pcb-plugins/share/pcb\" -DPCBTREEDIR=\"/home/khazakar/pcb-plugins/share/pcb/newlib\" -DPCBTREEPATH=\"/home/khazakar/pcb-plugins/share/pcb/newlib:/home/khazakar/pcb-plugins/share/pcb/pcblib-newlib\" -g -O2 -Wall -Wdeclaration-after-statement -MT predicates.o -MD -MP -MF .deps/predicates.Tpo -c -o predicates.o predicates.c mv -f .deps/predicates.Tpo .deps/predicates.Po gcc -DHAVE_CONFIG_H -I. -I.. -I. -DG_LOG_DOMAIN=\"Gts\" -I/usr/include -I/usr/include/dbus-1.0 -I/usr/lib64/dbus-1.0/include -I/usr/include/glib-2.0 -I/usr/lib64/glib-2.0/include -pthread -I/usr/include/gtk-2.0 -I/usr/lib64/gtk-2.0/include -I/usr/include/pango-1.0 -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/pixman-1 -I/usr/include/libdrm -I/usr/include/gdk-pixbuf-2.0 -I/usr/include/libpng16 -I/usr/include/pango-1.0 -I/usr/include/harfbuzz -I/usr/include/pango-1.0 -I/usr/include/glib-2.0 -I/usr/lib64/glib-2.0/include -I/usr/include/freetype2 -I/usr/include/libpng16 -I/usr/include/freetype2 -I/usr/include/libpng16 -I/usr/include -pthread -I/usr/include/gtkglext-1.0 -I/usr/lib64/gtkglext-1.0/include -I/usr/include/gtk-2.0 -I/usr/lib64/gtk-2.0/include -I/usr/include/pango-1.0 -I/usr/include/gtk-2.0 -I/usr/lib64/gtk-2.0/include -I/usr/include/pango-1.0 -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/pixman-1 -I/usr/include/libdrm -I/usr/include/gdk-pixbuf-2.0 -I/usr/include/libpng16 -I/usr/include/pango-1.0 -I/usr/include/harfbuzz -I/usr/include/pango-1.0 -I/usr/include/glib-2.0 -I/usr/lib64/glib-2.0/include -I/usr/include/freetype2 -I/usr/include/libpng16 -I/usr/include/freetype2 -I/usr/include/libpng16 -pthread -pthread -DPREFIXDIR=\"/home/khazakar/pcb-plugins\" -DBINDIR=\"/home/khazakar/pcb-plugins/bin\" -DHOST=\"x86_64-unknown-linux-gnu\" -DPCBLIBDIR=\"/home/khazakar/pcb-plugins/share/pcb\" -DPCBTREEDIR=\"/home/khazakar/pcb-plugins/share/pcb/newlib\" -DPCBTREEPATH=\"/home/khazakar/pcb-plugins/share/pcb/newlib:/home/khazakar/pcb-plugins/share/pcb/pcblib-newlib\" -g -O2 -Wall -Wdeclaration-after-statement -MT cdt.o -MD -MP -MF .deps/cdt.Tpo -c -o cdt.o cdt.c mv -f .deps/cdt.Tpo .deps/cdt.Po rm -f libgts.a ar cru libgts.a object.o point.o vertex.o segment.o edge.o triangle.o face.o kdtree.o bbtree.o misc.o predicates.o heap.o eheap.o fifo.o matrix.o surface.o stripe.o vopt.o refine.o iso.o isotetra.o split.o psurface.o hsurface.o cdt.o boolean.o named.o oocs.o container.o graph.o pgraph.o partition.o curvature.o tribox3.o ar: `u' modifier ignored since `D' is the default (see `U') ranlib libgts.a make[2]: Opuszczenie katalogu '/home/khazakar/Pobrane/pcb-plugins/gts' Making all in src make[2]: Wejście do katalogu '/home/khazakar/Pobrane/pcb-plugins/src' true > core_lists.h (for f in action.c action.h autoplace.c autoplace.h autoroute.c autoroute.h box.h buffer.c buffer.h change.c change.h clip.c clip.h command.c command.h compat.c compat.h const.h copy.c copy.h create.c create.h crosshair.c crosshair.h data.c data.h djopt.c djopt.h dolists.h draw.c draw.h drill.c drill.h edif.y edif_parse.h error.c error.h file.c file.h find.c find.h flags.c fontmode.c free_atexit.c free_atexit.h gettext.h global.h heap.c heap.h hid.h hid_draw.h insert.c insert.h intersect.c intersect.h line.c line.h lrealpath.c lrealpath.h macro.h main.c mirror.c mirror.h misc.c misc.h move.c move.h mtspace.c mtspace.h mymem.c mymem.h netlist.c parse_l.h parse_l.l parse_y.h parse_y.y pcb-printf.c pcb-printf.h polygon.c polygon.h polygon1.c polyarea.h puller.c print.c print.h rats.c rats.h remove.c remove.h report.c report.h res_parse.y res_lex.l resource.h rotate.c rotate.h rtree.c rtree.h rubberband.c rubberband.h search.c search.h select.c select.h set.c set.h strflags.c strflags.h thermal.c thermal.h undo.c undo.h vector.c vector.h vendor.c vendor.h hid/common/actions.c hid/common/actions.h hid/common/flags.c hid/common/hidinit.c hid/common/hidinit.h hid/common/hidnogui.c hid/common/hidnogui.h hid/common/extents.c hid/common/draw_helpers.c hid/common/draw_helpers.h hid/common/hid_resource.c hid/common/hid_resource.h hid/hidint.h toporouter.c toporouter.h dbus-pcbmain.c dbus-pcbmain.h dbus.h dbus.c hid/common/hidgl.c hid/common/hidgl.h hid/common/trackball.c hid/common/trackball.h ; do cat ./$f ; done) | grep "^REGISTER" > core_lists.h.tmp mv core_lists.h.tmp core_lists.h /usr/bin/mkdir -p hid/gtk true > hid/gtk/gtk_lists.h (for f in dolists.h hid/hidint.h hid/gtk/ghid-cell-renderer-visibility.c hid/gtk/ghid-cell-renderer-visibility.h hid/gtk/ghid-coord-entry.c hid/gtk/ghid-coord-entry.h hid/gtk/ghid-layer-selector.c hid/gtk/ghid-layer-selector.h hid/gtk/ghid-main-menu.c hid/gtk/ghid-main-menu.h hid/gtk/ghid-route-style-selector.c hid/gtk/ghid-route-style-selector.h hid/gtk/gtkhid-main.c hid/gtk/gtkhid.h hid/gtk/gui.h hid/gtk/gui-command-window.c hid/gtk/gui-config.c hid/gtk/gui-dialog-print.c hid/gtk/gui-dialog.c hid/gtk/gui-drc-window.c hid/gtk/gui-drc-window.h hid/gtk/gui-keyref-window.c hid/gtk/gui-library-window.c hid/gtk/gui-library-window.h hid/gtk/gui-log-window.c hid/gtk/gui-misc.c hid/gtk/gui-netlist-window.c hid/gtk/gui-output-events.c hid/gtk/gui-pinout-preview.c hid/gtk/gui-pinout-preview.h hid/gtk/gui-pinout-window.c hid/gtk/gui-top-window.c hid/gtk/gui-utils.c hid/gtk/gtkhid-gl.c hid/gtk/gui-trackball.c hid/gtk/gui-trackball.h ; do cat ./$f ; done) | grep "^REGISTER" > hid/gtk/gtk_lists.h.tmp mv hid/gtk/gtk_lists.h.tmp hid/gtk/gtk_lists.h /usr/bin/mkdir -p hid/lesstif true > hid/lesstif/lesstif_lists.h (for f in dolists.h hid/hidint.h hid/lesstif/dialogs.c hid/lesstif/lesstif.h hid/lesstif/library.c hid/lesstif/main.c hid/lesstif/menu.c hid/lesstif/netlist.c hid/lesstif/styles.c hid/lesstif/xincludes.h ; do cat ./$f ; done) | grep "^REGISTER" > hid/lesstif/lesstif_lists.h.tmp mv hid/lesstif/lesstif_lists.h.tmp hid/lesstif/lesstif_lists.h /usr/bin/mkdir -p hid/batch true > hid/batch/batch_lists.h (for f in hid/hidint.h hid/batch/batch.c ; do cat ./$f ; done) | grep "^REGISTER" > hid/batch/batch_lists.h.tmp mv hid/batch/batch_lists.h.tmp hid/batch/batch_lists.h /usr/bin/mkdir -p hid/png true > hid/png/png_lists.h (for f in dolists.h hid/hidint.h hid/png/png.c hid/png/png.h ; do cat ./$f ; done) | grep "^REGISTER" > hid/png/png_lists.h.tmp mv hid/png/png_lists.h.tmp hid/png/png_lists.h /usr/bin/mkdir -p hid/gcode true > hid/gcode/gcode_lists.h (for f in dolists.h hid/hidint.h hid/gcode/gcode.c hid/gcode/decompose.c hid/gcode/decompose.h hid/gcode/trace.c hid/gcode/trace.h hid/gcode/curve.c hid/gcode/curve.h hid/gcode/auxiliary.h hid/gcode/bitmap.h hid/gcode/lists.h hid/gcode/potracelib.h ; do cat ./$f ; done) | grep "^REGISTER" > hid/gcode/gcode_lists.h.tmp mv hid/gcode/gcode_lists.h.tmp hid/gcode/gcode_lists.h /usr/bin/mkdir -p hid/nelma true > hid/nelma/nelma_lists.h (for f in dolists.h hid/hidint.h hid/nelma/nelma.c ; do cat ./$f ; done) | grep "^REGISTER" > hid/nelma/nelma_lists.h.tmp mv hid/nelma/nelma_lists.h.tmp hid/nelma/nelma_lists.h /usr/bin/mkdir -p hid/ps true > hid/ps/ps_lists.h (for f in dolists.h hid/hidint.h hid/ps/ps.c hid/ps/ps.h hid/ps/eps.c ; do cat ./$f ; done) | grep "^REGISTER" > hid/ps/ps_lists.h.tmp mv hid/ps/ps_lists.h.tmp hid/ps/ps_lists.h /usr/bin/mkdir -p hid/common true > hid/common/hidlist.h for e in gtk lpr bom gcode gerber nelma png ps; do \ echo "HID_DEF(${e})" >> hid/common/hidlist.h; \ done echo '/* AUTOMATICALLY GENERATED FROM dbus.xml DO NOT EDIT */' > dbus-introspect.h.tmp echo "static char *pcb_dbus_introspect_xml =" > dbus-introspect.h.tmp sed 's/\\/\\\\/g; s/"/\\"/g; s/^/"/; s/$/"/' < ./dbus.xml >> dbus-introspect.h.tmp echo ";" >> dbus-introspect.h.tmp mv dbus-introspect.h.tmp dbus-introspect.h make all-recursive make[3]: Wejście do katalogu '/home/khazakar/Pobrane/pcb-plugins/src' Making all in icons make[4]: Wejście do katalogu '/home/khazakar/Pobrane/pcb-plugins/src/icons' make[4]: Nie ma nic do zrobienia w 'all'. make[4]: Opuszczenie katalogu '/home/khazakar/Pobrane/pcb-plugins/src/icons' Making all in plugins make[4]: Wejście do katalogu '/home/khazakar/Pobrane/pcb-plugins/src/plugins' make[4]: *** Brak reguł do wykonania obiektu 'all'. Stop. make[4]: Opuszczenie katalogu '/home/khazakar/Pobrane/pcb-plugins/src/plugins' Makefile:1928: polecenia dla obiektu 'all-recursive' nie powiodły się make[3]: *** [all-recursive] Błąd 1 make[3]: Opuszczenie katalogu '/home/khazakar/Pobrane/pcb-plugins/src' Makefile:889: polecenia dla obiektu 'all' nie powiodły się make[2]: *** [all] Błąd 2 make[2]: Opuszczenie katalogu '/home/khazakar/Pobrane/pcb-plugins/src' Makefile:511: polecenia dla obiektu 'all-recursive' nie powiodły się make[1]: *** [all-recursive] Błąd 1 make[1]: Opuszczenie katalogu '/home/khazakar/Pobrane/pcb-plugins' Makefile:450: polecenia dla obiektu 'all' nie powiodły się make: *** [all] Błąd 2 [khazakar@dhcppc0 pcb-plugins]$ make install Making install in w32 make[1]: Wejście do katalogu '/home/khazakar/Pobrane/pcb-plugins/w32' make[2]: Wejście do katalogu '/home/khazakar/Pobrane/pcb-plugins/w32' make[2]: Nie ma nic do zrobienia w 'install-exec-am'. make[2]: Nie ma nic do zrobienia w 'install-data-am'. make[2]: Opuszczenie katalogu '/home/khazakar/Pobrane/pcb-plugins/w32' make[1]: Opuszczenie katalogu '/home/khazakar/Pobrane/pcb-plugins/w32' Making install in intl make[1]: Wejście do katalogu '/home/khazakar/Pobrane/pcb-plugins/intl' if { test "pcb" = "gettext-runtime" || test "pcb" = "gettext-tools"; } \ && test 'no' = yes; then \ /bin/sh .././mkinstalldirs /home/khazakar/pcb-plugins/lib /home/khazakar/pcb-plugins/include; \ /usr/bin/install -c -m 644 libintl.h /home/khazakar/pcb-plugins/include/libintl.h; \ @LIBTOOL@ --mode=install \ /usr/bin/install -c -m 644 libintl.a /home/khazakar/pcb-plugins/lib/libintl.a; \ if test "@RELOCATABLE@" = yes; then \ dependencies=`sed -n -e 's,^dependency_libs=\(.*\),\1,p' < /home/khazakar/pcb-plugins/lib/libintl.la | sed -e "s,^',," -e "s,'\$,,"`; \ if test -n "$dependencies"; then \ rm -f /home/khazakar/pcb-plugins/lib/libintl.la; \ fi; \ fi; \ else \ : ; \ fi if test "pcb" = "gettext-tools" \ && test 'no' = no; then \ /bin/sh .././mkinstalldirs /home/khazakar/pcb-plugins/lib; \ @LIBTOOL@ --mode=install \ /usr/bin/install -c -m 644 libgnuintl.a /home/khazakar/pcb-plugins/lib/libgnuintl.a; \ rm -f /home/khazakar/pcb-plugins/lib/preloadable_libintl.so; \ /usr/bin/install -c -m 644 /home/khazakar/pcb-plugins/lib/libgnuintl.so /home/khazakar/pcb-plugins/lib/preloadable_libintl.so; \ @LIBTOOL@ --mode=uninstall \ rm -f /home/khazakar/pcb-plugins/lib/libgnuintl.a; \ else \ : ; \ fi if test 'no' = yes; then \ test yes != no || /bin/sh .././mkinstalldirs /home/khazakar/pcb-plugins/lib; \ temp=/home/khazakar/pcb-plugins/lib/t-charset.alias; \ dest=/home/khazakar/pcb-plugins/lib/charset.alias; \ if test -f /home/khazakar/pcb-plugins/lib/charset.alias; then \ orig=/home/khazakar/pcb-plugins/lib/charset.alias; \ sed -f ref-add.sed $orig > $temp; \ /usr/bin/install -c -m 644 $temp $dest; \ rm -f $temp; \ else \ if test yes = no; then \ orig=charset.alias; \ sed -f ref-add.sed $orig > $temp; \ /usr/bin/install -c -m 644 $temp $dest; \ rm -f $temp; \ fi; \ fi; \ /bin/sh .././mkinstalldirs /home/khazakar/pcb-plugins/share/locale; \ test -f /home/khazakar/pcb-plugins/share/locale/locale.alias \ && orig=/home/khazakar/pcb-plugins/share/locale/locale.alias \ || orig=./locale.alias; \ temp=/home/khazakar/pcb-plugins/share/locale/t-locale.alias; \ dest=/home/khazakar/pcb-plugins/share/locale/locale.alias; \ sed -f ref-add.sed $orig > $temp; \ /usr/bin/install -c -m 644 $temp $dest; \ rm -f $temp; \ else \ : ; \ fi if test "pcb" = "gettext-tools"; then \ /bin/sh .././mkinstalldirs /home/khazakar/pcb-plugins/share/gettext/intl; \ /usr/bin/install -c -m 644 VERSION /home/khazakar/pcb-plugins/share/gettext/intl/VERSION; \ /usr/bin/install -c -m 644 ChangeLog.inst /home/khazakar/pcb-plugins/share/gettext/intl/ChangeLog; \ dists="COPYING.LIB-2.0 COPYING.LIB-2.1 Makefile.in config.charset locale.alias ref-add.sin ref-del.sin gmo.h gettextP.h hash-string.h loadinfo.h plural-exp.h eval-plural.h localcharset.h relocatable.h xsize.h printf-args.h printf-args.c printf-parse.h wprintf-parse.h printf-parse.c vasnprintf.h vasnwprintf.h vasnprintf.c os2compat.h libgnuintl.h.in bindtextdom.c dcgettext.c dgettext.c gettext.c finddomain.c loadmsgcat.c localealias.c textdomain.c l10nflist.c explodename.c dcigettext.c dcngettext.c dngettext.c ngettext.c plural.y plural-exp.c localcharset.c relocatable.c localename.c log.c printf.c osdep.c os2compat.c intl-compat.c"; \ for file in $dists; do \ /usr/bin/install -c -m 644 ./$file \ /home/khazakar/pcb-plugins/share/gettext/intl/$file; \ done; \ chmod a+x /home/khazakar/pcb-plugins/share/gettext/intl/config.charset; \ dists="plural.c"; \ for file in $dists; do \ if test -f $file; then dir=.; else dir=.; fi; \ /usr/bin/install -c -m 644 $dir/$file \ /home/khazakar/pcb-plugins/share/gettext/intl/$file; \ done; \ dists="xopen-msg.sed linux-msg.sed po2tbl.sed.in cat-compat.c COPYING.LIB-2 gettext.h libgettext.h plural-eval.c libgnuintl.h"; \ for file in $dists; do \ rm -f /home/khazakar/pcb-plugins/share/gettext/intl/$file; \ done; \ else \ : ; \ fi make[1]: Opuszczenie katalogu '/home/khazakar/Pobrane/pcb-plugins/intl' Making install in gts make[1]: Wejście do katalogu '/home/khazakar/Pobrane/pcb-plugins/gts' make[2]: Wejście do katalogu '/home/khazakar/Pobrane/pcb-plugins/gts' make[2]: Nie ma nic do zrobienia w 'install-exec-am'. make[2]: Nie ma nic do zrobienia w 'install-data-am'. make[2]: Opuszczenie katalogu '/home/khazakar/Pobrane/pcb-plugins/gts' make[1]: Opuszczenie katalogu '/home/khazakar/Pobrane/pcb-plugins/gts' Making install in src make[1]: Wejście do katalogu '/home/khazakar/Pobrane/pcb-plugins/src' make install-recursive make[2]: Wejście do katalogu '/home/khazakar/Pobrane/pcb-plugins/src' Making install in icons make[3]: Wejście do katalogu '/home/khazakar/Pobrane/pcb-plugins/src/icons' make[4]: Wejście do katalogu '/home/khazakar/Pobrane/pcb-plugins/src/icons' make[4]: Nie ma nic do zrobienia w 'install-exec-am'. make[4]: Nie ma nic do zrobienia w 'install-data-am'. make[4]: Opuszczenie katalogu '/home/khazakar/Pobrane/pcb-plugins/src/icons' make[3]: Opuszczenie katalogu '/home/khazakar/Pobrane/pcb-plugins/src/icons' Making install in plugins make[3]: Wejście do katalogu '/home/khazakar/Pobrane/pcb-plugins/src/plugins' make[3]: *** Brak reguł do wykonania obiektu 'install'. Stop. make[3]: Opuszczenie katalogu '/home/khazakar/Pobrane/pcb-plugins/src/plugins' Makefile:1928: polecenia dla obiektu 'install-recursive' nie powiodły się make[2]: *** [install-recursive] Błąd 1 make[2]: Opuszczenie katalogu '/home/khazakar/Pobrane/pcb-plugins/src' Makefile:2085: polecenia dla obiektu 'install' nie powiodły się make[1]: *** [install] Błąd 2 make[1]: Opuszczenie katalogu '/home/khazakar/Pobrane/pcb-plugins/src' Makefile:511: polecenia dla obiektu 'install-recursive' nie powiodły się make: *** [install-recursive] Błąd 1 [khazakar@dhcppc0 pcb-plugins]$ I nie wiem co z tym robić :/ Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
tele Napisano Czerwiec 1, 2015 Zgłoszenie Share Napisano Czerwiec 1, 2015 Ja jak mam problem z kompilacja programow z sieci, piszę do developerów ktorzy je zrobili, zazwyczaj pomagają. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
KhazAkar Napisano Czerwiec 2, 2015 Autor Zgłoszenie Share Napisano Czerwiec 2, 2015 Ta,tyle tylko że u niego nie ma aż takiego problemu,u niego jakoś się kompiluje tylko u niego jest problem z ratsel.c,wykazuje coś takiego jak "bitrot". Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
tele Napisano Czerwiec 2, 2015 Zgłoszenie Share Napisano Czerwiec 2, 2015 Skad wzieles opcje "enable-plugins" ? ./configure --enable-plugins Moze ktoras z tych opcji juz nie dziala, zazwyczaj tak bywa. Ja testowalem tylko ./configure make i nie ma błędów, moze tez być różnica w wersji kompilatora, ale moze wtedy mialbys konkretniejszy bląd. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
KhazAkar Napisano Czerwiec 3, 2015 Autor Zgłoszenie Share Napisano Czerwiec 3, 2015 Strzelałem z enable-plugins przy ./configure. Zależy mi tylko na pluginach tak szczerze,dlatego też ogarniam teraz samo pcb-plugins z githuba tego samego człowiekatu link -> https://github.com/bert/pcb-pluginsWersja "master" działa mi idealnie,ale chciałem wersję z pluginami aby je mieć. Teraz kompiluję same pluginy,a mój błąd jest w Issues "Missing config.h"Zresztą widać że to właśnie pcb-plugins które podlinkowałem,Fedora Rawhide,ale ten sam problem miałen na Fedorze 22,więc to nie wina wersji systemu Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
tele Napisano Czerwiec 3, 2015 Zgłoszenie Share Napisano Czerwiec 3, 2015 Spytaj się developera jak powinno się kompilować. Domyślnie bywa to tak: konfiguracja ./configure kompilacja make I to wszystko, jeśli wyjątkowo czegoś potrzebujesz - wlaczyc , wylaczyc , etc. możesz skorzystać z opcji przy konfiguracji aby je poznac wpisujesz w terminalu ./configure --help Ale jak wspomnialem, spytaj developera, zamiast strzelać. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
