[VideoLAN] VLS
Grucha
Próbowałem zainstalwoać VNS. Przy póubie instalacji libdvb [libdvb-0.2.2.tar.gz (DVB library)] sie zatrzymałem bo jakoś nie chce mi to sie kompilowac i niebardzo rozumiem czemu :? .
[root@82 libdvb]# make
g++ -I./include -I./src -I. -I../driver -I../include -O2 -Wall -g -c devices.cc
In file included from DVB.hh:19,
                from devices.hh:15,
                from devices.cc:1:
channel.h:26:27: linux/dvb/dmx.h: No such file or directory
channel.h:27:32: linux/dvb/frontend.h: No such file or directory
channel.h:28:29: linux/dvb/video.h: No such file or directory
channel.h:29:29: linux/dvb/audio.h: No such file or directory
In file included from devices.hh:15,
                from devices.cc:1:
DVB.hh:71: error: field `dcmd' has incomplete type
DVB.hh:72: error: 'fe_sec_tone_mode_t' is used as a type, but is not defined as
  a type.
DVB.hh:73: error: 'fe_sec_voltage_t' is used as a type, but is not defined as a
  type.
DVB.hh:75: error: field `pesFilterParamsV' has incomplete type
DVB.hh:76: error: field `pesFilterParamsA' has incomplete type
DVB.hh:77: error: field `pesFilterParamsP' has incomplete type
DVB.hh:78: error: field `pesFilterParamsTT' has incomplete type
DVB.hh:79: error: field `front_param' has incomplete type
DVB.hh:84: error: 'fe_status_t' is used as a type, but is not defined as a
  type.
DVB.hh:367: error: type specifier omitted for parameter `fe_code_rate_t'
DVB.hh:367: error: syntax error before `)' token
devices.cc: In function `std::ostream& operator<<(std::ostream&, Transponder&)
devices.cc:114: error: `FE_QPSK' undeclared (first use this function)
devices.cc:114: error: (Each undeclared identifier is reported only once for
  each function it appears in.)
devices.cc:116: error: `FE_QAM' undeclared (first use this function)
devices.cc:124: error: `FE_OFDM' undeclared (first use this function)
devices.cc: In function `std::istream& operator>>(std::istream&, Transponder&)
devices.cc:264: error: `FEC_AUTO' undeclared (first use this function)
make: *** [devices.o] Error 1
[root@82 libdvb]#
