lszk Napisano Styczeń 20, 2005 Zgłoszenie Share Napisano Styczeń 20, 2005 Chcąc sobie przebudować ten pakiet, dostaje: Configuration: release Host system type: i686-redhat-linux-gnu Install path: /usr C++ compiler: g++ (g++ (GCC) 3.4.2 20041017 (Red Hat 3.4.2-6.fc3)) ESD output: enabled OSS output: enabled libao output: disabled ------------------------------------------------------------------------------ + make make all-recursive make[1]: Entering directory `/usr/src/redhat/BUILD/d4x-2.5.0rc1' Making all in DOC make[2]: Entering directory `/usr/src/redhat/BUILD/d4x-2.5.0rc1/DOC' make[2]: Nie nic do roboty w `all'. make[2]: Leaving directory `/usr/src/redhat/BUILD/d4x-2.5.0rc1/DOC' Making all in intl make[2]: Entering directory `/usr/src/redhat/BUILD/d4x-2.5.0rc1/intl' make[2]: Nie nic do roboty w `all'. make[2]: Leaving directory `/usr/src/redhat/BUILD/d4x-2.5.0rc1/intl' Making all in main make[2]: Entering directory `/usr/src/redhat/BUILD/d4x-2.5.0rc1/main' Making all in face make[3]: Entering directory `/usr/src/redhat/BUILD/d4x-2.5.0rc1/main/face' if g++ -DHAVE_CONFIG_H -I. -I. -I../.. -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -DXTHREADS -D_REENTRANT -DXUSE_MTSAFE_API -I/usr/include/gtk-2.0 -I/usr/lib/gtk-2.0/include -I/usr/X11R6/include -I/usr/include/atk-1.0 -I/usr/include/pango-1.0 -I/usr/include/freetype2 -I/usr/include/freetype2/config -include ../../config.h -O2 -MT about.o -MD -MP -MF ".deps/about.Tpo" \ -c -o about.o `test -f 'about.cc' || echo './'`about.cc; \ then mv -f ".deps/about.Tpo" ".deps/about.Po"; \ else rm -f ".deps/about.Tpo"; exit 1; \ fi In file included from <command line>:6: ./../../config.h:410:1: warning: "_REENTRANT" redefined <command line>:4:1: warning: this is the location of the previous definition about.cc: In function `void init_about_window(...)': about.cc:220: error: `gtk_timeout_add' undeclared (first use this function) about.cc:220: error: (Each undeclared identifier is reported only once for each function it appears in.) make[3]: *** [about.o] Błąd 1 make[3]: Leaving directory `/usr/src/redhat/BUILD/d4x-2.5.0rc1/main/face' make[2]: *** [all-recursive] Błąd 1 make[2]: Leaving directory `/usr/src/redhat/BUILD/d4x-2.5.0rc1/main' make[1]: *** [all-recursive] Błąd 1 make[1]: Leaving directory `/usr/src/redhat/BUILD/d4x-2.5.0rc1' make: *** [all] Błąd 2 błąd: Błędny status wyjścia z /var/tmp/rpm-tmp.63663 (%build) Błędy budowania RPM-a: użytkownik max nie istnieje - użyto konta root grupa max nie istnieje - użyto grupy root Błędny status wyjścia z /var/tmp/rpm-tmp.63663 (%build) :shock: Niech no ktoś wypatrzy o co się pluje, bo mnie juz oczy dzisiaj bolą Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
